深圳市德威达科技有限公司
  • BDPA系列压差开关报警器
  • 发布时间:2012/9/7 10:11:35   修改时间:2012/9/7 13:58:22 浏览次数:3799
  • 产品名称:  BDPA系列压差开关报警器
    产品型号:  BDPA
    介质: 空气或非可燃的兼容气体.
    材质: Diaphragm: Silicone; Housing: Switch Body: PA 6.6 and POM; Cover: Polystyrene.
    温度限制: 32 to 122°F (0 to 50°C).
    压力限制: 40" w.c. (10 kPa).
    开关额定: 1.0 A @ 30 VDC/VAC.
    开关类型: SPDT.
    报警指示: Red LED and audible alarm.
    报警级别: Approximately 90 db at 4" (10 cm).
    报经确认: Button press.
    电源: 16 to 30 VDC, 18 to 30 VAC or battery. If line power supplied battery acts as back-up if power loss.
    电池: 1/2 AA LS14250.
    电池寿命: Approximately 1.5 years with 3.6 V/1.2 Ah.
    重复性: ±15% FS.
    电气连接: Screw terminals. M20x1.5 with cable strain relief or optional 1/2" NPT connection.
    过程连接: 5/16" (7.94 mm) outside diameter tubing, 1/4" (6.0 mm) inside diameter tubing.
    安装方向: Vertically, with pressure connections pointing downwards.
    重量: 6.1 oz (173 g).
    封装: IP21.
    认证: CE, RoHS.
    选型表:
    型号 特性
    BDPA-08-1-N Adjustable differential pressure alarm, range .08-1.20" w.c., 1/2" NPT connection.
    BDPA-04-1-N Adjustable differential pressure alarm, range .12-1.60" w.c., 1/2" NPT connection.
    BDPA-03-1-N Adjustable differential pressure alarm, range .20-2.00" w.c., 1/2" NPT connection.
    BDPA-05-1-N Adjustable differential pressure alarm, range .80-4.00" w.c., 1/2" NPT connection.
    BDPA-06-1-N Adjustable differential pressure alarm, range 2.00-10.00" w.c., 1/2" NPT connection.
    BDPA-07-1-N Adjustable differential pressure alarm, range 4.00-20.00" w.c., 1/2" NPT connection.
    BDPA-08-1-N-C Adjustable differential pressure alarm, range .08-1.20" w.c., 1/2" NPT connection, with installer kit.
    BDPA-04-1-N-C Adjustable differential pressure alarm, range .12-1.60" w.c., 1/2" NPT connection, with installer kit.
    BDPA-03-1-N-C Adjustable differential pressure alarm, range .20-2.00" w.c., 1/2" NPT connection, with installer kit.
    BDPA-05-1-N-C Adjustable differential pressure alarm, range .80-4.00" w.c., 1/2" NPT connection, with installer kit.
    BDPA-06-1-N-C Adjustable differential pressure alarm, range 2.00-10.00" w.c., 1/2" NPT connection, with installer kit.
    BDPA-07-1-N-C Adjustable differential pressure alarm, range 4.00-20.00" w.c., 1/2" NPT connection, with installer kit.
    BDPA-08-2-N Adjustable differential pressure alarm, range .08-1.20" w.c., M20 connection.
    BDPA-04-2-N Adjustable differential pressure alarm, range .12-1.60" w.c., M20 connection.
    BDPA-03-2-N Adjustable differential pressure alarm, range .20-2.00" w.c., M20 connection.
    BDPA-05-2-N Adjustable differential pressure alarm, range .80-4.00" w.c., M20 connection.
    BDPA-06-2-N Adjustable differential pressure alarm, range 2.00-10.00" w.c., M20 connection.
    BDPA-07-2-N Adjustable differential pressure alarm, range 4.00-20.00" w.c., M20 connection.
    BDPA-08-2-N-C Adjustable differential pressure alarm, range .08-1.20" w.c., M20 connection, with installer kit.
    BDPA-04-2-N-C Adjustable differential pressure alarm, range .12-1.60" w.c., M20 connection, with installer kit.
    BDPA-03-2-N-C Adjustable differential pressure alarm, range .20-2.00" w.c., M20 connection, with installer kit.
    BDPA-05-2-N-C Adjustable differential pressure alarm, range .80-4.00" w.c., M20 connection, with installer kit.
    BDPA-06-2-N-C Adjustable differential pressure alarm, range 2.00-10.00" w.c., M20 connection, with installer kit.
    BDPA-07-2-N-C Adjustable differential pressure alarm, range 4.00-20.00" w.c., M20 connection, with installer kit.
美国德威尔(Dwyer)仪器仪表授权中国代理——深圳市德威达科技有限公司深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动…  更多>>
深圳市德威达科技有限公司
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
  • 韩先生 在2013/5/22 14:48:00留言
  • 详细留言:GFC-1144 供货及附件清单 价格
  • 韩先生 在2013/5/22 14:46:00留言
  • 详细留言:GFC-1144
