![](http://www.szdwd.com/UploadPhotos/201131415205335.jpg)
产品名称: EDPS系列压差开关
产品型号: EDPS
符合UL508,材质符合UL94VO
介质: Air and noncombustible, compatible gases.
材质: Diaphragm Material: Silicone. Housing Material: Switch Body: PA 6.6, Cover: Polystyrene. Materials UL94 V0 Rated.
温度限制: Process and ambient temperature from -4 to 140°F (-20 to 60°C).
压力限制: Max. Operating Pressure: 40" w.c. (10 kPa) for all pressure ranges.
开关: Single-pole double-throw (SPDT).
开关额定: Max.1.0 A/250 VAC, 50-60 Hz, max switching rate: 6 cycles/min.
电气连接: Push-on screw terminals. 1/2" NPT connection. M20x1.5 with cable strain relief optional.
过程连接: 5/16" (7.94 mm) outside diameter tubing, 1/4" (6.0 mm) inside diameter tubing.
安装方向: Vertically, with pressure connections pointing downwards.
开关寿命: Over 106 switching operations.
重量: 5.6 oz (160 g).
封装: NEMA 13 (IP54).
认证: CE, RoHS, ETL approved to UL508 and CSA C22.2#14
选型表:
型号 |
特性 |
EDPS-08-1-N |
Adjustable differential pressure switch, range .08-1.20" w.c., with 1/2" NPT connection. |
EDPS-04-1-N |
Adjustable differential pressure switch, range .12-1.60" w.c., with 1/2" NPT connection. |
EDPS-03-1-N |
Adjustable differential pressure switch, range .20-2.00" w.c., with 1/2" NPT connection. |
EDPS-05-1-N |
Adjustable differential pressure switch, range .80-4.00" w.c., with 1/2" NPT connection. |
EDPS-06-1-N |
Adjustable differential pressure switch, range 2.00-10.00" w.c., with 1/2" NPT connection. |
EDPS-07-1-N |
Adjustable differential pressure switch, range 4.00-16.00" w.c., with 1/2" NPT connection. |
EDPS-08-1-N-C |
Adjustable differential pressure switch, range .08-1.20" w.c., with 1/2" NPT connection and installer kit. |
EDPS-04-1-N-C |
Adjustable differential pressure switch, range .12-1.60" w.c., with 1/2" NPT connection and installer kit. |
EDPS-03-1-N-C |
Adjustable differential pressure switch, range .20-2.00" w.c., with 1/2" NPT connection and installer kit. |
EDPS-05-1-N-C |
Adjustable differential pressure switch, range .80-4.00" w.c., with 1/2" NPT connection and installer kit. |
EDPS-06-1-N-C |
Adjustable differential pressure switch, range 2.00-10.00" w.c., with 1/2" NPT connection and installer kit. |
EDPS-07-1-N-C |
Adjustable differential pressure switch, range 4.00-16.00" w.c., with 1/2" NPT connection and installer kit. |
EDPS-08-2-N |
Adjustable differential pressure switch, range .08-1.20" w.c., with M20 connection. |
EDPS-04-2-N |
Adjustable differential pressure switch, range .12-1.60" w.c., with M20 connection. |
EDPS-03-2-N |
Adjustable differential pressure switch, range .20-2.00" w.c., with M20 connection. |
EDPS-05-2-N |
Adjustable differential pressure switch, range .80-4.00" w.c., with M20 connection. |
EDPS-06-2-N |
Adjustable differential pressure switch, range 2.00-10.00" w.c., with M20 connection. |
EDPS-07-2-N |
Adjustable differential pressure switch, range 4.00-16.00" w.c., with M20 connection. |
EDPS-08-2-N-C |
Adjustable differential pressure switch, range .08-1.20" w.c., with M20 connection and installer kit. |
EDPS-04-2-N-C |
Adjustable differential pressure switch, range .12-1.60" w.c., with M20 connection and installer kit. |
EDPS-03-2-N-C |
Adjustable differential pressure switch, range .20-2.00" w.c., with M20 connection and installer kit. |
EDPS-05-2-N-C |
Adjustable differential pressure switch, range .80-4.00" w.c., with M20 connection and installer kit. |
EDPS-06-2-N-C |
Adjustable differential pressure switch, range 2.00-10.00" w.c., with M20 connection and installer kit. |
EDPS-07-2-N-C |
Adjustable differential pressure switch, range 4.00-16.00" w.c., with M20 connection and installer kit. |
