深圳市德威达科技有限公司
  • 16A系列温度/过程控制仪
  • 发布时间:2012/9/7 11:00:46   修改时间:2012/9/7 11:00:46 浏览次数:1258
  • 产品名称:  16A系列温度/过程控制仪
    产品型号:  16A
    1/16DIN,通用输入,模糊逻辑,自适应PID
    可选输入: Thermocouple, RTD, DC Voltage, or DC Current.
    显示: Two four-digit LED displays, 0.3 in (7.62 mm) high.
    显示分辨率: 1 degree or 0.1 degree (sensor dependent), or 1 count.
    精度: ±0.25% of span ±1 least significant digit.
    电源: 100 to 240 VAC nominal, +10% -15%, 50 to 400 Hz single phase; 132 to 240 VDC +10% 20%.
    操作温度: 14 to 131°F (-10 to 55°C).
    功耗: 5 VA maximum.
    输出参数: SSR: 2.0 A at 240 VAC resistive at 77°F (25°C). De-rates to 1.0 A at 130°F (55°C). Minimum load of 100 mA. DC SSR: 1.75 A at 32 VDC maximum. Relay: SPST, 3A at 240 VAC resistive, 1.5 A @ 240 VAC inductive. Pilot Duty rating: 250 VA, 2 A @ 120 VAC, 1 A @ 240 VAC. Alarm Relay: SPST, 3 A @ 240 VAC resistive; 1.5 A @ 240 VAC inductive. Pilot Duty Rating: 240 VA, 2 A @ 120 VAC or 1 A @ 240 VAC. Switched Voltage: 15 VDC at 20 mA. 比例电流: 0 to 20 mADC, scalable, into 600 ohms maximum.
    重量: 8 oz (227g).
    认证: UL E83725, CE.
    前面板封装: NEMA 4X (IP66).
    通讯(Optional): RS-232 or RS-485 with either LoveLink? or Modbus? RTU protocol.
    型号 特性
    16A2111 Temperature controller/process, Two SSR outputs, with alarm.
    16A2030 Temperature controller/process, Relay output, no alarm.
    16A2133 Temperature controller/process, Two relay outputs, with alarm.
    16A2130 Temperature controller/process, Relay output, with alarm.
    16A2110 Temperature controller/process, One SSR output, with alarm.
    16A2020 Temperature controller/process, 15 VDC output, no alarm.
    16A2150 Temperature controller/process, One current output, with alarm.
    16A2050 Temperature controller/process, current output, no alarm.
    EXAMPLE 16A 2 0 1 1 934 Series 16A2011-934 Temperature Controller/Process, no alarm, SSR output A and B, with set point/process signal output 0-20 mA.
    SERIES 16A           Temperature Controller//Process
    TYPE   2
    3
    Standard
    Enhanced
    ALARM     0
    1
    No Alarm
    With Alarm
    OUTPUT A       1
    2
    3
    4
    5
    8
    SSR
    15 VDC
    Relay N.O.
    Relay N.C.
    Current
    DC-SSR
    OUTPUT B         0
    1
    2
    3
    4
    5
    None
    SSR
    15 VDC
    Relay N.O.
    Relay N.C.
    Current
    OPTIONS           934
    936
    948
    992
    993
    995
    996
    9152
    9502
    Set Point/Process Signal Output 0-20 mA
    Set Point/Process Signal Output 0-10 VDC
    4-Stage Set Point
    RS-485 Lovelink?
    RS-232 Lovelink?
    RS-232 Modbus?
    RS-485 Modbus?
    16A3 Program R/H Key Reset
    12/24 VDC Power Supply
美国德威尔(Dwyer)仪器仪表授权中国代理——深圳市德威达科技有限公司深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动…  更多>>
深圳市德威达科技有限公司
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
  • 韩先生 在2013/5/22 14:48:00留言
  • 详细留言:GFC-1144 供货及附件清单 价格
  • 韩先生 在2013/5/22 14:46:00留言
  • 详细留言:GFC-1144
