产品名称: 2600系列温度/过程控制仪产品型号: 2600
1/4DIN,自适应PID,模糊逻辑软件
可选输入: Thermocouple, RTD, DC voltage or DC current.
输入阻抗: Thermocouple: 3 Megohms minimum; Voltage: 5000 ohms; Current: 10 ohms; RTD Current: 200 μA maximum.
显示: Two 4-digit, 7 segment, 0.56" (14.2 mm) high LED.
精度: ±0.25% of span, ±1 least significant digit.
电源: 100 to 240 VAC nominal, +10%-15%, 50 to 400 Hz, single phase; 132 to 240 VDC +10% -20%.
操作温度: 14 to 131°F (-10 to 55°C).
输出参数: Relay: SPDT, 10 A @ 240 VAC resistive, 1/2 hp @ 120 VAC, 1/3 hp @ 240 VAC; Alarm Relay: SPST, 3 A @ 240 VAC resistive; Proportional Current: 0-20 mA DC, scalable into 600 ohms maximum.
重量: 13 oz (369 g).
前面板封装: NEMA 4X (IP66).
Series 26010-924 Temperature/Process Controller, no alarm, SSR output A and B, with remote set point (0-10 VDC).
No AlarmWith Alarm
SSRRelayCurrent
NoneSSRRelayCurrent
Remote Set Point (0-10 VDC)Remote Set Point (0-20 mA)Remote Set Point (0-10 kohms)Process Signal Output, Non-isolated, 0-20 mAProcess Signal Output, Non-isolated, 0-10 VDC4-Stage Set PointType J Portable HousingType K Portable HousingType T Portable HousingType E Portable HousingRTD Portable HousingType J Portable Housing NO/NCType K Portable Housing NO/NCType T Portable Housing NO/NCType E Portable Housing NO/NCRTD Portable Housing NO/NCRS-485 Serial CommunicationsRS-232 Serial CommunicationsRS-485 SPI Computer Compatible ControlRS-232 Modbus? CommunicationsRS-485 Modbus? Communications
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
