深圳市德威达科技有限公司
  • Dwyer 4B系列温度/过程控制仪
  • 发布时间:2012/9/7 11:05:56   修改时间:2012/9/7 11:05:56 浏览次数:1546
  • 产品名称:  4B系列温度/过程控制仪
    产品型号:  4B
    1/4DIN,双路控制输出,RS485通讯,自适应
    输入: Thermocouple, RTD, DC voltages or DC current.
    显示: Two 4-digit, 7 segment. PV: 3/4" H (19 mm) red; SV: 1/2" H (12.7 mm) green.
    精度: ±0.25% span, ±1 least significant digit.
    电源: 100 to 240 VAC, 50/60 Hz.
    功耗: 5 VA max.
    操作温度: 32 to 122°F (0 to 50°C).
    记忆:永久记忆.
    输出参数: Relay: SPDT, 5 A @ 250 VAC resistive; Voltage Pulse: 14 V, 10% to -20% (max 40 mA); Current: 4 to 20 mA; Linear Voltage: 0-10 V.
    Communication: RS-485 Modbus? A-5-11/RTU communication protocol.
    重量: 15 oz (425 g).
    认证: CE, UL, cUL, RoHS.
    前面封装: NEMA 4X (IP66).
    型号 特性
    4B-23 1/4 DIN temperature/process controller, (1) voltage pulse output and (1) relay output.
    4B-231 1/4 DIN temperature/process controller, (1) voltage pulse output and (1) relay output, with event input.
    4B-232 1/4 DIN temperature/process controller, (1) voltage pulse output and (1) relay output, with current transformer.
    4B-33 1/4 DIN temperature/process controller, (2) relay outputs.
    4B-331 1/4 DIN temperature/process controller, (2) relay outputs, with event input.
    4B-332 1/4 DIN temperature/process controller, (2) relay outputs, with current transformer.
    4B-53 1/4 DIN temperature/process controller, (1) current output and (1) relay output.
    4B-531 1/4 DIN temperature/process controller, (1) current output and (1) relay output, with event input.
    4B-532 1/4 DIN temperature/process controller, (1) current output and (1) relay output, with current transformer.
    4B-63 1/4 DIN temperature/process controller, (1) linear voltage output and (1) relay output.
    4B-631 1/4 DIN temperature/process controller, (1) linear voltage output and (1) relay output, with event input.
    4B-632 1/4 DIN temperature/process controller, (1) linear voltage output and (1) relay output, with current transformer.
美国德威尔(Dwyer)仪器仪表授权中国代理——深圳市德威达科技有限公司深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动…  更多>>
深圳市德威达科技有限公司
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
  • 韩先生 在2013/5/22 14:48:00留言
  • 详细留言:GFC-1144 供货及附件清单 价格
  • 韩先生 在2013/5/22 14:46:00留言
  • 详细留言:GFC-1144
