深圳市德威达科技有限公司
  • SCZ10系列 DIN导轨安装温度/过程控制器
  • 发布时间:2012/9/7 11:10:39   修改时间:2012/9/7 11:10:39 浏览次数:1557
  • 产品名称:  SCZ10系列 DIN导轨安装温度/过程控制器
    产品型号:  SCZ10
    通用输入,双色显示
    输入: Thermocouple: K, J, R, S, E, T, N, PL-II, C (W/Re5-26) External resistance: 100Ω or less. B Thermocouple: External resistance: 40Ω or less. RTD: Pt100, JPt100 3-wire system, allowable input wire resistance (10Ω or less per wire). DC Current: 0 to 20 mA DC, 4 to 20 mA input impedance 50Ω (50Ω shunt resistor sold separately). DC Voltage: 0 to 1 VDC. Input Impedance: 1MΩ or greater.
    输出额定: Relay Contact: 3A @ 250 VAC, Resistive: 1A @ 250 VAC inductive (C?S=0.4), Electric life 100,000 cycles. Switched Voltage (for SSR drive): 12 VDC @ 40 mA max. (short-circuit protected). DC Current: 4 to 20 mA DC, load resistance: max. 550Ω output accuracy: ±0.3% of output span. Resolution: 12,000 counts.
    控制类型: P, PI, PD, PID, Self Tune, On-Off, Process Retransmission.
    比例带: 0.0 to 110.0% (ON/OFF when set to 0.0).
    积分常数: 0 to 1000 seconds (off when set to 0).
    微分常熟: 0 to 300 seconds (off when set to 0).
    比例循环: 1 to 120 seconds.
    手动复位: Proportional band converted value.
    输出限制: 0 to 100% (DC current output type: -5 to 105%).
    滞后: Thermocouple and RTD Input: 0.1 to 100.0 degrees; DC Voltage and Current Input: 1 to 1000 (decimal point place follows the selection).
    电源: 120-240 VAC, 50-60 Hz, 24 VAC 50-60 Hz optional.
    功耗: Approximately 6VA.
    精度: Thermocouple Input: ±0.2% of input span, ±1 digit or 4°F (2°C), whichever is greater. R, S Input: 0 to 400°F (0 to 200°C): ±6°C (12°F). B Input: 0 to 600°F (0 to 300°C): Accuracy is not guaranteed. K, J, E, N Input less than 32°F (0°C): ±4% of input span ±1 digit. RTD Input: ±0.1% of input span ±1 digit or ±2°F (1°C), whichever is greater. DC Voltage Input: ±0.2% of input span ±1 digit. DC Current Input: ±0.2% of input span ±1 digit.
    输入采样间隔: 0.25 seconds, 4 Hz.
    PV 显示: Red LED 4-digit character size: 7.5 x 4.1 mm (H x W).
    SV 显示: Green LED 4-digit character size: 7.5 x 4.1 mm (H x W).
    显示分辨率: 1 count, 1 degree, or 0.1 degree, depending on selected range.
    记忆: Nonvolatile memory, no battery used.
    环境温度: 32 to 131°F (0 to 50°C).
    环境湿度: 35 to 85% RH (non-condensing).
    重量: Approx. 5.3 oz (150 g).
    认证: CE, UL, cUL.
    型号 描述
    SCZ10-1000-00 DIN rail mount temperature/process control, 120 to 240 VAC supply voltage, relay output.
    SCZ10-2000-00 DIN rail mount temperature/process control, 120 to 240 VAC supply voltage, switched voltage output.
    SCZ10-3000-00 DIN rail mount temperature/process control, 120 to 240 VAC supply voltage, current output.
    SCZ10-3100-00 DIN rail mount temperature/process control, 24 VAC/DC supply voltage, current output.
美国德威尔(Dwyer)仪器仪表授权中国代理——深圳市德威达科技有限公司深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动…  更多>>
深圳市德威达科技有限公司
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
  • 韩先生 在2013/5/22 14:48:00留言
  • 详细留言:GFC-1144 供货及附件清单 价格
  • 韩先生 在2013/5/22 14:46:00留言
  • 详细留言:GFC-1144
