![](http://www.szdwd.com/UploadPhotos/201111817253984.jpg)
产品名称: 16L 系列1/16 限制控制器
产品型号: 16L
FM 认证, 双路大显示, 通用输入
输入: 10 Thermocouple, 4 RTD, DC Voltage, or DC Current selectable.
显示: Two 4-digit, 7 segment 0.3" (7.62 mm) high LEDs.
精度: ±0.25% of span, ±1 least significant digit.
电源: 100 to 240 VAC, nominal, +10 - 15%, 50 to 400 Hz. single phase; 132 to 240 VDC, nominal, +10 - 20%.
功耗: 5 VA maximum.
操作温度: 14 to 131°F (-10 to 55°C).
记忆: Nonvolatile memory. No batteries required.
输出额定: Relay: SPST, 3 A @ 240 VAC resistive; 1.5 A @ 240 VAC inductive.
重量: 8 oz (227 g).
认证: UL, FM.
前面板额定: NEMA 4X (IP66).
EXAMPLE |
16L |
201 |
0 |
934 |
Series 16L2010-934 Limit Control, SSR output A, with set point/process signal output 0-20 mA. |
SERIES |
16L |
Limit Control |
OUTPUT A |
201 202 203 204 208 |
SSR 15 VDC N.O. Relay N.C. Relay DC-SSR |
OUTPUT B |
0 1 2 3 4 |
None SSR 15 VDC N.O. Relay N.C. Relay |
OPTIONS |
934 936 948 992 993 |
Set Point/Process Signal Output 0-20 mA Set Point/Process Signal Output 0-10 VDC 4-Stage Set Point RS-485 Computer Compatible Control RS-232 Computer Compatible Control |
