南京崇基机电工程有限公司
  • 现货供应:Honeywell TDC3000/PKS系统卡件备件
  • 发布时间:2009/7/21 10:07:27   修改时间:2009/7/21 10:07:27 浏览次数:2206
    南京崇基机电工程有限公司,专业提供Honeywell DCS系统软、硬件支持与技术服务。公司主要从事DCS系统软、硬件的技术支持与研发,具体业务包括: 1Honeywell DCS系统工程组态,安装,调试,开车; 2Honeywell DCS系统升级; 3Honeywell DCS系统检修;  4. Honeywell DCS系统板卡、键盘、CRT、电源等维修; 5.   Honeywell/横河/ABB/罗斯蒙特/西门子S5等新老系统的备件等  公司拥有Honeywell TDC3000TPSPKSS9000PlantScape等多类系统不同年代的备品备件产品库存。我们的客户遍及中石油、中石化及冶金、造纸、水泥、电力等行业。 我公司长年销售Honeywell DCS TDC-3000TPSS9000PlantScape等系统)各类卡件、电源及专门配套Honeywell DCS操作站USGUS国产化的液晶显示器(带触摸屏、鼠标)等。
     欢迎DCS新老用户来电来邮不吝垂询:025-845844738458447684584479E-mail:  NJ1368@163.com . 欢迎登录:www.conkey.cn .
    下面是部分库存DCS备件清单,以资参考:
    51196653-100 Pwr Supply, 5 Slot File, EC
    51196654-100 Pwr Supply, 10 Slot File, EC
    51196655-100 P/S DUAL NODE EC
    51196690-401 Ptr Ribbon, Black
    51201420-015 Cable, FTA I/O Phone/Phone, 15M, non-CE
    51201420-020 Cable, FTA I/O Phone/Phone, 20M, non-CE
    51201557-150 I/O Link Module, Single, CC
    51201667-100 Cable, HPM Redundancy
    51202306-915 Cable, I/O LIM Protection, 1.5M
    51190523-125 Relay, Dual Input, EC
    51195153-010 Drop Cable Set, 10M RG6
    51195178-100 SCSI Bus Term
    51195199-005 Cable Set, UCN Trunk RG-11, 5M
    51195199-010 Cable Set, UCN Trunk RG-11, 10M
    51195479-200 Cable Set, I/O Link, 3 Drop
    51195479-300 Cable Set, I/O Link, 4 Drop
    30754661-022 Fuse, 3 Amp
    51196742-100 Cable, Video, 10ft, HD15 Male to DB9 Female
    51196929-135 Drive, 3.5in Zip
    51197593-100 Lithium Battery (TC-BATT01)
    51198947-100 Pwr Supply, PM
    51198947-100F Pwr Supply, PM
    51199188-100 Cable, PS2 To Summ. Mouse Conv.
    51199194-100 LCD Flat Panel Display, 20.1in
    51201394-100 Tap Assy, 2-Drop
    51201395-100 Tap Assy, 4-Drop (Qty 2 in Set)
    51201420-003 Cable, FTA I/O Phone/Phone, 3M, non-CE
    51201557-350 I/O Link Module, Triple, CC
    51204172-175 HD FTA, A/O w/Standby, Comp Term, CC, CE
    51303928-150 FTA, D/I 24VDC, Screw Term, CC
    51303932-476 FTA, Serial I/F, Modbus RS-232, CC
    51201420-005 Cable, FTA I/O Phone/Phone, 5M, non-CE
    51196094-200 FTA Mtg Channel, Wide Rittal w/Sh Grnd Bar
    51190523-325 Relay, Dual Input, EC
    51190582-125 Fuse, .25 Amp
    51190582-210 Fuse, 1 Amp
    51190584-150 Fuse, .5 Amp Slo-Blow
    51190728-105 Tee Connector, LCN Coax
    51190782-200 Terminator, UCN Carrier Band wo/chain
    51191561-100 SPC Firmware Upgrade Kit
    51192060-100 Battery, Ni Cad
    51192337-101 Battery Pack NI-CAD
    51192417-100 CONN CABLE QTY 2 REPLACES TC-MC1BNC
    51192418-100 Connector, 75 Ohm
    51192887-100 Adapter, ST-SMA
    51195153-001 Drop Cable Set, 1M RG6
    51303940-150 Fan Assy w/Alarm, 115V, CC
    51303940-250 Fan Assy w/Alarm, 230V, CC
    51196694-200 Kybd, IKB w/Trackball, Desktop
    51196694-300 Kybd, IKB w/Trackball, PS/2, Desktop
    51196694-350 Kybd, IKB w/Trackball, Z Console, GUS
    TC-PRR021
    TK-PRS021
    30754661-011 Fuse, Subminiature, .25 Amp
    30754661-021 Fuse, 2 Amp10100/2/1 Horizontal Bus Driver
    10101/2/1 DI Module
    10302/2/1 Watchdog Repeater
    10303/1/1 Power supply distribution module (PSD)
    10313/1/1 5 Vdc + Watchdog distribution module
    10105/2/1 AI Module
    10005/1/1 Watchdog Module
    10006/2/1 3400310 Diagnostic and battery module (DBM)
    10018/E/1 3400282 FSC PlantScape connection Module
    10024/H/F Enhanced COM Module,Central Part/RS232
    10201/2/1 DO Module
    10205/2/1 Fail-safe analog output module
    10208/2/1 3400118 Relay output module
    10020/1/2 CPU Module
    10024/I/F Enhanced COM Module,RS485/RS232
    10024/I/I 3400307Enhanced communication module (ECM)
    10018/E/E FSC PlantScape connection Module
    10300/1/1 Converter 24V to 5V
    10001/R/1 Vertical Bus Driver
    51204126-002 Cable Set, PM Power w/Link Protect, 2M
    51204146-010 ControlNet Trunk Cable (10M)
    51204147-001 Redundancy Cable 1 Meter
    51204160-125 FTA, D/I 24VDC, Comp Term, CE
    51204160-175 FTA, D/I 24VDC, Comp Term, CC, CE
    51204162-175 FTA, D/O 24VDC, Comp Term, CC, CE
    51204166-175 HD FTA, D/O Relay, Comp Term, CC, CE
    51204170-250 HD FTA, HLAI/STI, Comp Term, CC
    51107595-100 Pwr Supply, WDC
    51109612-100 Torque Wrench for Tap
    51201420-010 Cabl1e, FTA I/O Phone/Phone, 10M, non-EC
    51303948-100 Battery Assy, 48V
    51303979-550 APM I/O LINK DRIVER CC
    51303979-550-RP PWA, APM I/O LINK DRIVER CC
    51304084-175 FTA, Pulse input, Comp Term, CC
    51304335-175 FTA, Redundant A/O, Comp Term, CC
    51304337-150 FTA, Redundant HLAI, Comp Term, CC
    51304337-250 FTA, Redundant HLAI/STI, Screw Term, CC
    51304362-150 IOP, LLAI Mux, CC
    51304362-350 IOP, Serial I/F, CC
    51304386-150 IOP, Pulse Input, CC
    51304419-150 IOP, Fiber Optic, CC
    51304431-175 FTA, 240VAC D/I, Comp Term, CC
    51304437-100 FTA, LLAI, Comp Term
    51304437-150 FTA, LLAI, Comp Term, CC
    51304441-175 FTA, 24VDC D/I, Comp Term, CC
    51304453-150 FTA, HLAI/STI, Comp Term, CC
    51304465-100 Cable, Twisted Pair w/Shield, 30cm
    51304685-150 APM ADV COMM CC (SEE NOTES)
    51304754-150 IOP, HLAI, CC
    51304903-200 I/O Card, WDI, EC
    51304907-100 I/O Card, SPC II, non-EC
    51304907-200 I/O Card, SPC II, EC
    51305072-100 I/O Card, CLCN A/B, EC
    51304584-100 I/O Card, EPDGP
    51304648-175 FTA, 120/240VAC SS D/O, Comp Term, CC, CE
    51304650-150 FTA, 3/30VDC D/O, Comp Term, CC
    51305380-100 Cable, MAU, EC
    51305557-100 Power Cord, 220VAC
    51305776-100 OEP/IKB Module Assy
    51305890-175 FTA, LLMUX TC, Solid State, CC, CE
    51305896-200 PWA, NIM Modem EC
    51304485-150 IOP, DI, CC
    51304487-150 IOP, D/O, CC
    51304493-250 APM MODEM CC, R400
    51304516-250 IOP, STI/MV, CC
    51304518-150 APM ADV CONTROLLER CC
    51308058-200 KYBD I/F CBL
    51308111-002 Cable Set, LCN Coax, 2M
    51308112-003 Cable Set, LCN Coax, 3M
    51309241-125 Battery Extension Module
    51305907-175 Top Assembly LLMUX2, RTD, CE, CC
    51308047-100 CABLE, TOUCH SCR
    51308058-100 able, Keyboard I/F, 16in
    51305072-200 I/O Card, CLCNA, EC
    51305334-100 COVER, MAU
    51305348-100 MAU Assy
    51305378-100 IKBI2 PWA
    51304465-500 Cable, Twisted Pair w/Shield, 300cm
    51304476-175 FTA, A/O, Comp Term, CC
    51304481-150 IOP, LLAI, CC
    51308112-008 Cable Set, LCN Coax, 8M
    5308112-015 Cable Set, LCN Coax, 15M
    51309148-125 FTA, 120V D/O Relay, Comp Term, CE
    51309150-175 FTA, 240V D/O Relay, Comp Term, CC, CE
    51309152-175 IOP, A/O, CC
    51309204-175 FTA, LLAI Mux/SDI/SI Pwr Adapter, CC
    51309218-175 FTA, LLMux RTD, Comp Term, CC, CE
    51309241-175 Battery Extension Module (conformal coated)
    51309276-150 PWA, HPM I/O Link, CC
    51309288-275 PLANTSCAPE RM MODULE (CC)
    51402184-200 Pwr Supply Replacement Kit, 5 Slot File
    51402447-200 I/O Card, EPDGC, Z-Console
    51402497-200 QWY KYBD W/BEEPER EC
    51309288-375 PWA, RED MODULE CC
    51309512-175 FTE Bridge Module, CC
    51309516-175 SI Pwr Adapter, AC
    51402573-250 UCNIF Module Assembly CC
    51402625-175 IOP, Redundant DISOE2, CC
    51403165-400 OEP Assy, EC
    51403645-400 SBHM Single Drive Assy
    51403698-100 SBHM Motherboard Assy
    51403988-150 PWA, HPM COMM CONTROL CC
    51404127-250 HPM File, 15 Slot, CC
    51404172-175 Baclpanel, PM Pwr System
    51404174-275 PM Pwr System Assy, 20Amp Redundant, CC,
    51404305-325 C200 Control Processor(51404305-225)
    51403299-200 LCNP4 GPS Assy w/Card Guide
    51403422-150 PWA, HPM Comm/Controller, CC
    51403427-175 LIM Module CC
    51403427-275 LIM Module CC
    51403519-160 K4SDR 16 MW
    51309540-175 AO GI/IS FTA (16), HART CC
    51401052-100 PWA, SPCI
    51401135-350 PWA, Redundant Pwr Sply, 230VAC, CC
    51401140-450 Pwr System, AC Only,240VAC,16A, Redundant, CC
    51401496-100 FAN ASSM, 2 NODE
    51401560-100 Kybd, QWERTY Membrane
    51401577-100 QWERTY KYBD KIT
    51401583-100
    51401594-200 PWB, KJUMP
    51402089-100 PWA, EPDG2
    51404391-125 P/S SER INT ASSY EC
    620-0024    24K Memory Module
    620-0036 Processor Power Supply
    620-0054 620-35 System Control Module
    620-0056 Register Module -- 4K x 4K
    620-0080 620-35 Processor Module
    620-0085 2048 I/O Control Module
    621-0021RC Enhanced Diagnostics Module
    621-1250RC 240Vac Input, 16 point
    621-2201RC 230Vac Isolated Output, 6 point
    621-3560RC 24Vdc Input, 16 point
    621-3580RC 24Vdc Input, 32 point
    621-6550RC 24Vdc Source Output, 16 point
    621-9934C I/O Rack Power Supply - 115/230Vac, 8amp
    621-9938RC Redundant Serial I/O Module
    621-9939C Serial Link Module
    621-9940C Serial I/O Module
    80363969-150 HD IOP, HPM A/O, CC
    80363972-150 HD IOP, HPM D/I, CC
    80363975-100 HD IOP, HPM D/O
    80363975-150 HD IOP, HPM D/O, CC
    80366177-250 HD FTA, A/O Redn, Comp Term, CC
    MC-HPMR01 HPMM BOARD SET - REDUNDANT
    MC-HPMS01 HPMM BOARD SET - SINGLE
    TC-CCN013 CNI Module, Single Media
    TC-CCR013 CNI Module, Redundant Media
    TC-CCR014 CNI Module, Redundant Media (TC-CCR013)
    TP-LCNECM-100 XLCN EXTENDER SET CE MULTIMODE
    TP-LCNP02-100 LCNP4M Interface Card, Mid-siz
    TP-OPADP1-100 OEP Adapter, 120V, Deskside IKB
    TP-OPADP1-200 OEP Adapter, 240V, Deskside IKB
    MP-ZHMU18-100 HM Upgrade Kit,Dual 1.8GB Drives w/o Tray
    MP-ZHMU19-100 HM Upgrade Kit, Dual 1.8GB Drives w/Tray
    MP-ZIP100-100 Upgrade Kit, Single Bernoulli to Single Zip Dr
    MP-ZPSC16-100 Upgrade Kit, K4SDR-16MW
    TC-ODA161 AC Output Module 120/220vac 16pt, CIOM-A
    TC-ODD321  DC Output Module 24vdc 32 pt, CIOM-A
    TC-ODJ161 DC Output Module 24vdc 16pt, CIOM-A
    TC-ODK161 AC Output Module 120/220vac 16pt, CIOM-A
    TC-PCIC01 ControlNet Interface Card (PCI Bus)
    TC-PCIC02 ControlNet Interface Module, PCI bus
    TC-RPCXX1 120/240 VAC Redundant Power Supply
    TC-TBCH Fild Wiring Connector 36 pos
    TC-CEN021 Ethernet Interface Module, 10/100 MB
    TC-FPCXX2 120/240vac Pwr Supply
    TC-FPDXX2 24Vvdc Pwr Supply
    TC-FXX102 10 Slot Chassis, 13 Amp
    TC-FXX132 13 Slot Chassis, 13 Amp
    TC-FXX172 17 slot chassis, 13 amp
    TC-IAH061 Analog Input 6pt Module, CIOM-A
    TC-IAH161 AI 16 Module (single or 8 diff.), CIOM-A
    TC-IDD321 DC Input Module 24vdc 32pt, CIOM-A
    TC-IDJ161 DC Input Module 24vdc 16pt (isoltd.), CIOM-A
    TC-IDW161 AC Input Module 220vac 16pt, CIOM-A
    TC-IXL061 Thermocouple Input Module 6pt, CIOM-A
    TC-IXL062 Thermocouple Input Module 6pt, CIOM-A
    TC-IXR061 RTD Input Module 6pt, CIOM-A
    TC-OAH061 Analog Ouput 6pt Mod (4-20MA) CIOM-A
    TC-OAV061 Analog Output Module 6 pt (10V), CIOM-A
    TC-OAV081 AO Module 8pt (4-20ma & 10V), CIOM-A
    TK-FXX132 13 slot chassis, coated, 13 amp
    TK-IAH161 AI 16 Module, CIOM-A, Coated
    TP-ZFPDZT-100 MONITOR
    TK-IDD321 DC Input 24vdc 32pt, CIOM-A, Coated
    TK-IXL061 Thermocouple Input 6pt, CIOM-A, Coated
    TK-IXR061 RTD Input 6pt, Coated
    TK-OAV081 Analog Output 8pt, CIOM-A, Coated
    TK-ODD321 DC Output 24vdc 32 pt, Coated
    TP-DIKBTA-100 IKB Keyboard w/Trackball, Desktop
    TP-DOKBNA-100 OEP KYBD DESKSIDE GUS
    TC-TBNH Field Wiring Connector 20 pos
    TK-CCR014 CNI, Redundant Media, Coated (TK-CCR013)
    TK-FPDXX2 Conformal coated 24VDC Pwr Supply
    南京崇基机电工程有限公司 025-845844738458447684584479
南京崇基机电工程有限公司:是集科、工、贸于一体的多元化技术型企业。公司下设三个事业部:工控仪表部、液压气动部及机电工程部。其中,工控仪表部主要从事HONEYWELL(霍尼韦尔)、YOKOGAWA(横河)等DCS系统的备件供应、点检维护与卡件…  更多>>
南京崇基机电工程有限公司
联系人:李近锋
地址:南京市江宁区胜太东路36号
邮编:211100
电话:025-84584473
传真:025-84584479
公司网址:http://www.conkey.cn
  • 在2024/1/2 12:09:00留言
  • 详细留言:SPC-945--LAS,是不是新品,价格,交期
  • 王力 在2015/3/17 13:40:00留言
  • 张亚峰 在2013/11/11 18:39:00留言
  • 详细留言:PPC-COT-01
  • 熊R 在2012/7/21 20:45:00留言
  • 详细留言:本人需求PC-ESD500的硬盘,麻烦报价。
  • Geetam 在2012/6/6 15:31:00留言
  • 详细留言:please sne d prices for MU-TAMT03 LLMUC FTA TC
