EDC(Embedded Disk Card) 一般参数 容量: 32MB~4GB 接口: 40Pin 44Pin IDE传输模式: PIO Mode 0~4 MwDMA Mode 0~2 UDMA Mode 0~2 尖峰速率: 33.3Mbtes/sec 数据传输率: 13Mbtes/sec~17Mbtes/sec 操作温度: -10℃~70℃ -40℃~85℃ 存储温度: -55℃~125℃ 湿度: 10%~95% 振动: 30G 冲击: 1500G 电源要求 DC输入电压: +3.3v/+5v 单向电源 电源模式: 自动休息和睡眠模式 功耗: 15mA 系统可靠性 ECC技术: 内建高可靠性的纠错功能 不正常掉电次数: 3000次 平均无故障时间: >3000000小时 最小插拔次数: 最小10000次 平均写入技术: 支援 证书: CE、FCC、RoHS EDC EDC2001 General Specification Capacities 32MB - 1GB 32MB - 4GB Interface 40pin or 44 pin IDE/ATA 40-pin or 44-pin IDE/ATA IDE Transfer Mode PIO Mode 0-4 PIO Mode 0-4, MwDMA Mode 0-2, UltraDMA Mode 0-2 Drive Config. Switch Master / Slave Master / Slave Burst Speed Rate 16.6Mbyte/sec 33.3Mbyte/sec Data Transfer Rate Read: 10.0Mbytes/sec (max.) Write: 9.0Mbytes/sec (max.) Read: 17.0Mbytes/sec (max.) Write: 13.0Mbytes/sec (max.) System Reliability ECC technology High reliability based on the internal ECC function High reliability based on the internal ECC function Power-cycling 3,000 times 3,000 times MTBF > 3,000,000 hours > 3,000,000 hours Wear-leveling Support Support Environmental Specification Operating Temp. -10° C ~ +70° C (Commercial) -10° C ~ +70° C (Commercial) -40° C ~ +85° C (Industrial) -40° C ~ +85° C (Industrial) Storage Temp. -55° C ~ +125° C -55° C ~ +125° C Humidity 10% ~ 95% non-condensing 10% ~ 95% non-condensing Vibration 30G maximum 30G maximum Shock 1,500G maximum 1,500G maximum Power Requirment DC Input Voltage +3.3V/+5V single power supply operation +3.3V/+5V single power supply operation Power Mode Auto Stand-by and Sleep Mode Auto Stand-by and Sleep Mode Power Consumption 15mA 15mA Physical Specifications Enclosure Material PC Mechanical Cover PC Mechanical Cover Dimension 40-pin: 58x6.6x23.5mm(WxLxH) 40-pin: 58x6.6x23.5mm(WxLxH) 44-pin: 50.4x6.6x23.5mm(WxLxH) 44-pin: 50.4x5.92x21.1mm(WxLxH) Certification CE, FCC, RoHS CE, FCC, RoHS
联系人:姜小忠
地址:莲花南路1388弄8号
邮编:200237
电话:021-61274015 61274016 61274017
传真:021-61274019
公司网址:http://www.controleasy.net
