FiD(Flash in Disk) 一般参数 容量: 128MB~32GB接口: 44Pin (2.0mm)IDE/ATA IDE传输模式: PIO Mode 0~4 MwDMA Mode 0~2 UDMA Mode 0~2尖峰速率: 66.6Mbtes/sec数据传输率: 30Mbtes/sec~33Mbtes/sec 环境参数 操作温度: -10℃~70℃ -40℃~85℃存储温度: -55℃~125℃湿度: 10%~95%振动: 30G冲击: 1000G 电源要求 DC输入电压: +5v 单向电源电源模式: 自动休息和睡眠模式功耗: 15mA 系统可靠性 ECC技术: 内建高可靠性的纠错功能不正常掉电次数: 3000次平均无故障时间: >3000000小时最小插拔次数: 最小10000次平均写入技术: 支援 证书: CE、FCC、RoHS FID 2.6" ATA+ FID 2.5" ATA4001 General Specification Capacities 128MB - 4GB 2GB - 32GB Interface 44 pin(2.0mm) IDE/ATA 44pin(2.0mm) IDE/ATA IDE Transfer Mode PIO Mode 0-4 PIO Mode 0-4,MuDMA Mode 0-2 UltraDMA mode 0-2 Burst Speed Rate 16.6Mbyte/sec 66.6Mbyte/sec Sustained Speed Rate 8.0Mbyte/sec 28.0Mbyte/sec Data Transfer Rate Read: 8.0Mbytes/sec (max.) Write: 6.3Mbytes/sec (max.) Read: 33.0Mbytes/sec (max.) Write: 30.0Mbytes/sec (max.) System Reliability ECC technology High reliability based on the internal ECC function High reliability based on the internal ECC function Power-cycling 3,000 times 3,000 times MTBF ?> 3,000,000 hours > 3,000,000 hours Wear-leveling Support Support Environmental Specification Operating Temp. -10° C ~ +70° C (Commercial) -10° C ~ +70° C (Commercial) -40° C ~ +85° C (Industrial) -40° C ~ +85° C (Industrial) Storage Temp. -55° C ~ +125° C -55 C ~ +125 C Humidity 10% ~ 95% non-condensing 10% ~ 95% non-condensing Vibration 30G maximum 30G maximum Shock 1,500G maximum 1,500G maximum Power Requirment DC Input Voltage +5V single power supply operation +5V single power supply operation Auto Stand-by Mode 0.18mA 0.18mA Sleep mode 55mA 55mA Physical Specifications Enclosure Material Aluminum Mechanical Cover Aluminum Mechanical Cover Dimension 69.8x100.1x9.5mm(WxLxH) 69.8x100.1x9.5mm(WxLxH) Certification CE, FCC, RoHS CE, FCC, RoHS
联系人:姜小忠
地址:莲花南路1388弄8号
邮编:200237
电话:021-61274015 61274016 61274017
传真:021-61274019
公司网址:http://www.controleasy.net
