Rugged Removable Data Storage
The rugged TranzPak 7 removable storage module offers the most advanced level of flexibility, transportability, and robust storage modularity in the FIELD-READY arena.
The groundbreaking rugged TranzPak 7 hot-pluggable hard drive with up to 250 GB of storage capacity is the cornerstone of this rugged storage system. Featuring an extruded aluminum body and die cast cam locking front panel, the TranzPak 7 provides solid protection for your deployed media investment.
The TranzPak 7 works in concert with an array of TranzStor docking stations that range from a single docking space that allows the TranzPak 7 to plug into any computer through RAID and 12X mass storage subsystems.
With the single docking station, the TranzPak 7 works like any removable drive but it's storage capacity allows more flexibility and efficiency in reproducing fielded settings in lab situation and visa versa. You can actually plug-in or remove an entire operating system including programs and projects in any computer or storage system in any location.
The TranzPak 7 module is interchangeable among the complete family of Z Microsystems' low profile TranzStor storage systems and Z ATX, Z MPU, ZXt and ZXi workstations and servers.
Highlights:
- Houses any low profile hard drives
- "Hot-swap" disk modules
- Shock mounted disk drive substructure
- EMI/RFI protection
- Light weight, rugged construction
- SCSI or IDE option
- Future devices as they become available
![Ultra rugged TranzPak 7](http://www.zmicro.com/rugged-mass-storage/images/tp7-view-3.jpg)
Ultra rugged TranzPak 7 removable storage modules house any 3.5" hard drive.
![High life-cycle connectors](http://www.zmicro.com/rugged-mass-storage/images/tp7-view-1.jpg)
![rugged high-performance modules](http://www.zmicro.com/rugged-mass-storage/images/tp7-view-2.jpg)
These rugged high-performance
modules withstand daily
insertion/removal cycles.
![Aluminum housing](http://www.zmicro.com/rugged-mass-storage/images/tp7-view-4.jpg)
Aluminum housing holds 3.5" drives that float in a precision engineered, heat conductive and vibration dampening elastomer.
TranzPak 7 Specifications |
SCSI Capacity (Formatted) |
73 GB |
146 GB |
IDE Capacity (Formatted) |
80 GB |
120 GB |
160 GB |
250 GB |
Options |
Ultra SCSI, Ultra SCSI 2, Ultra160 SCSI, Ultra ATA/100 |
Dimensions |
1.34"H x 4.45"W x 7.76"D |
Net Weight |
2.5 lbs. (IDE) / 2.75 lbs. (SCSI) |
Environmental |
Operating Temp. |
+5º to + 50º Celsius |
Non Operating Temp. |
-40º to +70º Celsius |
Operating Humidity |
5% to 95% Non condensing |
Non Op. Humidity |
Non Op. Altitude |
-1,300 to 40,000 ft. |
Operating Altitude |
-1,300 to 10,000 ft. |
Vibration |
Mil-Std-167 |
Shock |
MIL-STD-810E, Method 516, 30g's |
Sand & Dust |
5.5 M.P.H. for 25 min. |
Rain |
Per Mil-Std-810E (Method 506, Proc. II) |
Fungus |
Non Nutrients / contaminants |
Reliability |
Operating Life |
10 years |
MTTR |
<20 minutes |
MTBF |
600,000 Hrs. (per MIL-HDBK-217F) |
Regulatory |
Safety |
UL 1950 |
EMC |
FCC Class A |
Quality/Workmanship |
IPC / ISO 9002 and applicable section of MIL-HDBK-454 |
