EK-C6652 EK-C6682
- 发布时间:2012/8/14 14:37:26
修改时间:2012/8/14 14:37:26 浏览次数:1871
EK-C6652 EK-C6682
http://www.81817979.cn
北 京 祥 顺 达 恒 有 限 公 司
电 话:010- 6338 8986
传 真:010- 5141 7964
薛 晨:13801020197
EK-C6652: Dual Channel Relative
Vibration (V2)
The 6652 Dual Channel Relative VibrationMonitor is used to monitor shaft vibrationand shaft radial position (using X-Y
probeconfiguration) in rotating machinery. Theamplitude and frequency content of thevibration signal, as well as the shaft
radialposition (DC Gap) are good indicators ofmachine condition, and can help detect a host of machinery problems including:unbalance,
wear, pre-load conditions/misalignment, rotor cracks, and rubsbetween rotating and stationary parts. In addition, all of the 6600
vibrationmonitors accept a tachometer input toprovide order analysis capabilities.
EK-C6652 DSP: Dual Channel
Relative Vibration (DSP)
The 6652 DSP Dual Channel AbsoluteVibration Monitor is primarily utilizedwhere advanced analysis may be required.The 6652 DSP can
process and store upto 800 line spectra, up to 1800 trend and trip trend data points, 300 sets ofstartup/coastdown vectors, and
shaftorbits. In addition, the 6652 DSP canperform vector monitoring by comparingthe current 1x vibration vector to an alarm region set
around the endpoint of areference vector; furthermore, the monitorcan be configured such that the secondDanger alarm relay is used for
vectoralarming (tachometer input required).
EK-C6682 : Dual Channel Position
The 6682 Dual Channel PositionMonitor provides continuous monitoringof shaft axial position on rotatingmachinery. The primary
application ofthe 6682 is to monitor the axial positionof a thrust bearing at the end of a shaft;however, the 6682 can also be used
forother applications including guide vaneposition monitoring and axial vibrationmonitoring. High axial vibration can bean indicator of
misalignment andcompressor surge. Other machineryfault modes that can be detected withthe 6682 monitor include: thrust bearingwear,
balance piston wear, and a loosethrust bearing.
EK-05474 RELAY 650 OHM COIL 24VDC 4PDT
EK-07868 RES/ 100K 1/8W MF 1
EK-22954 ASM,PANEL FRONT 5802
EK-23063 PICKUP VEL 544MSP WITH RIGHT A
EK-23085 TRANSF PWR 5802 POWER SUPPLY 9
EK-23094 FILTER 5802 SCREENED 0-10
EK-23364 TRANSF PWR 5806 POWER SUPPLY
EK-23385 ASM,PCB 5800 SIG COND 403 THRU
EK-23396 ASM,PROGRAMMER 5806
EK-23540 ASM,PCB 5800 SIG COND 544 0.5
EK-23542 ASM,PANEL FRONT 5806
EK-23550 ASM,FINAL 5806 MONITOR 6 CHANN
EK-23980 TRANSF PWR 5806 POWER SUPPLY
EK-24331 ASM,FINAL NEMA 4 ENCLOSURE NO-
EK-24919 ASM,PCB 5802 DISPLAY
EK-25246 ASM,PCB 5800 SIG COND 403 SPEE
EK-25320 RETAINER 5802 SIGNAL CARD
EK-25521 TRANSF PWR 5802 POWER SUPPLY 1
EK-25886 ASM,PCB 5800 SIG COND TYPE K T
EK-25888 ASM,PCB 5800 SIG COND K T/C 30
EK-25889 ASM,PCB 5800 SIG COND K T/C 15
EK-25891 ASM,PCB 5800 SIG COND RTD 150-
EK-25892 ASM,PCB 5800 SIG COND K T/C 30
EK-25894 ASM,PCB 5800 SIG COND K T/C 30
EK-25895 ASM,PCB 5800 SIG COND K T/C 15
EK-25896 ASM,PCB 5800 SIG COND RTD 150-
EK-25897 ASM,PCB 5800 SIG COND RTD 150-
EK-25955 PCB 5800 SIG COND RTD TEMP
EK-26184 ASM,PCB 5800 SIG COND TYPE J T
EK-26185 ASM,PCB 5800 SIG COND J T/C 30
EK-26186 ASM,PCB 5800 SIG COND J T/C 15
EK-26193 ASM,PCB 5800 SIG COND T T/C 30
EK-26195 ASM,PCB 5800 SIG COND T T/C 15
EK-28825 ASM,PCB 5800 SIG COND TSI/ROTO
EK-28827 ASM,PCB 5800 SIG COND TSI/SHEL
EK-28829 ASM,PCB 5800 SIG COND TSI/DIFF
EK-28841 MANUAL SERVICE 5800 VEL PU SIG
EK-28940 BATTERY 3.5V 750MAH LITHIUM
EK-29127 PCB 5806 POWER SUPPLY
EK-29128 ASM,PCB 5806 POWER SUPPLY WITH
EK-29129 ASM,PCB 5806 POWER SUPPLY WITH
EK-29577 PCB 5815 DISPLAY
EK-29579 ASM,PCB 5815 DISPLAY
EK-29659 BATTERY 3.9V 1.0AH LITHIUM
EK-29661 KEYBOARD QWERTY ASCII PARALLEL
EK-29668 SUPPLY POWER +5V @ 9A
EK-29670 SUPPLY POWER 15VDC +/- @1.5A
EK-29671 SUPPLY POWER 24VDC @ 2.4A
EK-29672 SUPPLY POWER 24VDC @ 1.2A
EK-29784 CABLE ASM RIBBON 26GA W/2 16-P
EK-29785 CABLE ASM RIBBON 26GA W/2 20-P
EK-30007 PANEL 5915 FRONT SCREENED
EK-3001-SS-1-1-2-2 SENTINEL 24VDC STD VEL10MM/SEC
EK-30259 HINGE 5915 FRONT PANEL
EK-30530 EXPANDER 5815/5915 ALARM RELAY
EK-30621 EXPANDER 5815/5915 ALARM RELAY
EK-30685 ASM,KEYPAD 5915
EK-31696 ASM,PCB 5800 SIG COND 0-5GSE
EK-32114 ASM,PCB 5800 SIG COND DUAL CHA
EK-32620 ASM JUNCTION BOX NEMA 4 NON I
EK-32706 ASM PCB 5800 SIG CON ABSOLUTE SHAFT 940P/U W/IXTR
EK-33894 SC/IC/DIG SN65176BP RS422 USED ON C6666 PCB
EK-34177 ASM,PCB 5800 SIG COND FOR 941/
EK-34177-30 5800 SIG COND DUAL CHAN 544
EK-34294 ASM,PCB 5800 SIG COND FOR 941/
EK-34305 INTFC DCE FEM DRIVER 4PRSRS422
EK-35076 ASM.FINAL 5806 CSA APPROVED MO
EK-35293 ASM,PCB 5800 SIG COND FOR942/9
EK-35838 KIT CONV 5915 V1.XX TO V2.00
EK-35840 KIT CONV 5915 V1.40/.5X TO 2.0
EK-36003 SWITCH TOUCH 1 POLE PCB MTG
EK-36092 OVERLAY SWITCH RED POLY ADHV
EK-36226 ASM,PCB 5915 MAIN CPU V2.00
EK-36542 INDEX TABS #1 - 8 FOR MANUALS
EK-39854 ASM,PCB 5806 PROM
EK-40322 ASM,PCB 6622HS
EK-40323 ASM,PCB 66 DSP
EK-40325 ASM,PCB 6652
EK-40500 ASM,PCB 6600 BACKPLANE
EK-40504 ASM,BRACKT SUPPRT PNL MNT 6600
EK-40536 OVERLAY 6623 F/FRONT PANEL
EK-40537 OVERLAY 6652DSP F/FRONT PANEL
EK-40538 OVERLAY 6622DSP F/FRONT PANEL
EK-40542 OVERLAY 6652 F/FRONT PANEL
EK-40543 OVERLAY 6667 F/FRONT PANEL
EK-40545 OVERLAY 6666 F/FRONT PANEL
EK-40603 EAR MOUNTING 6624 4U PAINTED
EK-40621 PANEL SIDE NS3 420X177.8X3 FRA
EK-40623 EAR MOUNTING 6625 4U PAINTED
EK-40624 FRONT GUIDE RAIL
EK-40630 RAIL GUIDE 220MM #60817-098
EK-40632 END PIECE FRONT RAIL
EK-40635 SCREW M5 X 12 C/SK SFHM
EK-40654 OVERLAY 6622 F/FRONT PANEL
EK-40655 OVERLAY 6682DSP F/FRONT PANEL
EK-40665 ASM,PCB 6666 BASE BUILD
EK-40666 ASM,PCB 6667 MAIN BOARD
EK-40687 TRIM COSMETIC 6625HIS/7
EK-40691 TRIM COSMETIC 6625HIS/8
EK-40707 TRIM COSMETIC 6625HIS/12
EK-40736 PANEL FRONT 6600
EK-40738 PIN MOUNTING SSTL FOR 6600
EK-40743 FUSE 1A 250V SEMI-DELAY 5X20MM
EK-40744 FUSE SA 250V SEMI-DELAY 5X20MM
EK-40802 ASM,CABLE 6600 COM,2 CONNECT
EK-40803 ASM,CABLE 6600 COMM 3 CONNECT
EK-40804 ASM,CABLE 6600 COMM,4 CONNECT
EK-40805 ASM,CABLE 6600 COMM,5 CONNECT
EK-40806 ASM,CABLE 6600 COMM,6 CONNECT
EK-40807 ASM,CABLE 6600 COMM,7 CONNECT
EK-40808 ASM,CABLE 6600 COMM,8 CONNECT
EK-40809 ASM,CABLE 6600 COMM,09 CONNECT
EK-40810 ASM,CABLE 6600 COMM,10 CONNECT
EK-40811 ASM,CABLE 6600 COMM,11 CONNECT
EK-40812 ASM,CABLE 6600 COMM,12 CONNECT
EK-40835 HANDLE AL FOR 6600 FRONT PANEL
EK-40836 KEYPAD 6600 8KEYS BLK SIL RUB
EK-40840 BACKLIGHT 6600 YEL-ORG 115V
EK-40867 INVERTER BACKLIGHT LAH 1540
EK-40868 SC/IC/DIG MAX875BCPA
EK-40872 SC/IC/DIG EEPROM 4K USED IN C6666 PCB
EK-40897 INTERFACE UNIT TYPE 34 R/MOUNT
EK-40933 RES/ 250, 0.1 , 1W, WW
EK-41001 6600 COOLING FAN TRAY 6 FANS
EK-41002 COOLING FAN TRAY 3 FANS
EK-43416 ASM,CABLE 6600 RIBBON 34 CONDU
EK-43973 NAMEPLATE BLANK 6600 1 X 2-3/8
EK-43999 INSERT MNL 6600 CVR/BACK/SPINE
EK-44054 MANUAL 6687 MONITOR
EK-44609 SC/SM/DIG C167 MICROCONTROLLER
EK-44901 MANUAL 6600 CE UPGRADE INSTRUC
EK-45033 SIDE PANEL ADAPTER FOR 6625HIS
EK-45171 MANUAL 6687 PROTECTION MONITOR
EK-45172 MANUAL 6689 PROTECTION MONITOR
EK-45334 INSERT ENLINE 66 MANUAL FRONT/
EK-46018 SENTINEL, MANUAL
EK-46638 SENTINEL,24 VDC, INT ACCEL PARALLEL TO FACE
EK-46639 SENTINEL,24 VDC, INT ACCEL PERP TO FACE
EK-46640 SENTINEL,120/240 VAC, INT ACCEL PARALLEL TO FACE
EK-46641 SENTINEL,120/240 VAC, INT ACCEL PERP TO FACE
EK-46642 SENTINEL,120/240 VAC, EXT ACCEL ONLY
EK-47035 ASM, DISPLAY, 6600 TM1755
EK-47351 USER GUIDE 6652 V5 MONITOR
EK-47354 USER GUIDE FOR 6682 V5
EK-C6622HS 6622HS 2CH VIB MON HIGH SENSITIVITY TRANSDUCER
EK-C6622LS ASM, 6622LS DUAL CH LO
EK-C6622NB ASM,6622NB TWO CH VIB MON
EK-C6624HIS FRAME 19 RACK MOUNTING
EK-C6625HIS-1 FRAME PANEL MOUNT, 1 MODULE
EK-C6625HIS-10 FRAME PANEL MOUNT, 10 MODULE
EK-C6625HIS-11 FRAME PANEL MOUNT, 11 MODULE
EK-C6625HIS-12 FRAME PANEL MOUNT, 12 MODULE
EK-C6625HIS-2 FRAME PANEL MOUNT, 2 MODULE
EK-C6625HIS-3 FRAME PANEL MOUNT, 3 MODULE
EK-C6625HIS-4 FRAME PANEL MOUNT, 4 MODULE
EK-C6625HIS-5 FRAME PANEL MOUNT, 5 MODULE
EK-C6625HIS-6 FRAME PANEL MOUNT, 6 MODULE
EK-C6625HIS-7 FRAME PANEL MOUNT, 7 MODULE
EK-C6625HIS-8 FRAME PANEL MOUNT, 8 MODULE
EK-C6625HIS-9 FRAME PANEL MOUNT, 9 MODULE
EK-C6628 ASM BLANK PANEL
EK-C6652 MODEL 6652 DUAL CHANNEL VIB MON (NCPU INPUT)
EK-C6660 ASM,6660 6CHAN PROCESS TEMP/F
EK-C6666-BBBBBB MODEL 6666 6CH. TEMP MONITOR
EK-C6666-CCCCCC MONITOR RTD 0/250C 100PT
EK-C6666-DDDDDD MONITOR RTD 0/200C 100PT
EK-C6666-EEEEEE ASM,PCB MON RTD 0/150C 100PT
EK-C6666-FFFFFF ASM,PCB MON RTD 0/100C 100PT
EK-C6666-KKKKKK ASM,PCB MON RTD -20/200C 10COP
EK-C6666-LLLLLL MODEL 6666 6 CH TEMP MONITOR 100 OHM PTRTD 0/+300C
EK-C6666-MMMMMM ASM,PCB MON RTD -40/100C 120NK
EK-C6666-NNNNNN ASM,PCB MON RTD 3/300F 120NK
EK-C6666-PPPPPP ASM,PCB MON RTD 0/300F 100PT
EK-C6666-RRRRRR MODEL 6666-6CH TEMP MONITOR(100OHM PT RTD 0/+400F)
EK-C6666-SSSSSS MODEL 6666 6 CH TEMP MON 10 OHM CU RTD -40/+250DEG
EK-C6666-TTTTTT MODEL 6666 6 CH TEMP MON 100 OHM RTD 0/+600 DEG F
EK-C6667-BBBBBB MODEL 6667-6 CH TEMP MONITOR (TYPE K T/C 0/+200 C)
EK-C6667-CCCCCC MODEL 6667-6 CH TEMP MONITOR (TYPE K T/C 0/+150 C)
EK-C6667-DDDDDD MODEL 6667-6 CH TEMP MONITOR (TYPE K T/C 0/+100 C)
EK-C6667-EEEEEE ASM,PCB MON T/C 0/350C TYPE K
EK-C6667-FFFFFF ASM,PCB MON T/C 0/999C TYPE K
EK-C6667-HHHHHH ASM,PCB MON T/C 0/100C TYPE T
EK-C6667-JJJJJJ ASM,PCB MON T/C 0/300F TYPE T
EK-C6667-PPPPPP ASM,PCB MON T/C 0/300F TYPE J
EK-C6667-SSSSSS MODEL 6667 6 CH TEMP MON TYPE J T/C -40/+250 F
EK-C6675 ASM,6675 ROTATION MONITOR
EK-C6675M MONITOR SPEED (MAGNETIC INTERR
EK-C6676 ASM,6676 REVERSE ROTATION MON.
EK-C6682 MODEL 6682 DUAL CHANNEL THRUST MONITOR
EK-C6686 ASM,6686 ECCENTRICITY MONITOR
EK-C6687 ASM,6687 CASE EXPANSION MON.
EK-C6688 ASM,6688 DIFFERENTIAL EXP MON
EK-C6689 ASM,6689 DUAL VALVE POS MON.
EK-C6691 ASM,6691 POWER SUPPLY/RELAY V2
EK-C6691--12 POWER SUPPLY/RELAY -12VDC
EK-C6691-18 POWER SUPPLY/RELAY (18VDC)
EK-C6691--18 POWER SUPPLY/RELAY -18VDC
EK-C6691-24 POWER SUPPLY/RELAY (24VDC)
EK-C6691-ICP POWER SUPPLY/RELAY (ICP)
EK-C6692 MODEL 6692 PWR SUPPLY & RELAY UNIT FOR DSP MONITOR
EK-M34177 ASM,5800 SIGNAL COND 2-CH
EK-M34294 ASM,5800 SIGNAL COND 1-CH
EK-M34294-43 5800 SIGNAL CONDITIONER/MODEL 580/0-1 IN/SEC
EK-RP23095 MODEL 5802 MONITOR 0-SIG CONDS
EK-RP25365-01 ASM 5800 SIG COND 2-CH HI-2 580
EK-RP25890 MODEL 5800 SIG COND CARD,100 OHM RTD 0-300 DEG F
EK-RP25891 MODEL 5800 SIG COND RTD TEMP
EK-RP25896 MODEL 5800 SIG COND RTD TEMP
EK-RP25897 MODEL 5800 S/C RTD 1-CH
EK-RP26185 MODEL 5800 SIG COND J-T/C TEMP
EK-RP28825 ASM,PCB 5800 SIG COND TSI/ROTO
EK-RP35293 ASM 5800 SIG COND 2-CH ALLCARD
EK-RP35293-33 ASM, 5800 ALL CARD RP35293-33
EK-RP40304 ASM PANEL FRONT 6652
EK-RP47383 IC, PROM, 6622FW U30, V5.02
EK-RP47384 IC, PROM, 6622FW U31, V5.02
EK-SP01333 MODEL 5800 SP01333 SPEED/ACCEL
EK-SP01638 MODEL 5806 BLIND MONITOR RACK
EK-SP01726 MODEL 5800 SIG COND SP01726
EK-SP01727 ASM,PCB 5800 SIG COND RTD 600F
EK-SP10157 MODEL 5800 S/C GSE 2-CH 942
EK-SP10169 MODEL 5800 SIG COND SINGLE CH.
EK-SP10172 MODEL 544 CABLE 50' SPD LGS 1-
EK-SP10274 MODEL 544 PU CABLE ASM 125 FT
EK-SP1515 ASM,5800 SIG COND 2-CH
EK-SP1616 MODEL 5800 SIG COND DIFF EXP
EK-SP99600 SYSTEM MONITOR MODEL 6600
