韩国“AUTONICS(奥托尼克斯)”全系列工控产品:
LCD计数器
LA7N-1,LA7N-2,LA7N-3,LA7N-4,LA7N-1R,LA7N-2R,LA7N-3R,LA7N-4R,LA7N-F,LA7N-FR:W48*H24MM
数显计数器
FS5B W48*H24MM
FS4A W48*H24MM 100-240VAC,12-24VDC INPUT NPN
数显计时计数器
单预设FX4S,FX4,FX6,FX4H
双预设FX4-2P*,FX6-2P*,FX4H-2P,FX4L-2P,FX6L-2P
显示专用FX4Y-I,FX6Y-I,FX5S-I,FX4-I,FX6-I,FX4H-I,FX4L-I,FX6L-I
FX4Y-1 W72*H36MM INPUT NPN
FX6Y-1
FX5S-1 W48*H48MM 100-240VAC,12-24VDC INPUT NPN
FX4S W48*H48MM INPUT NPN
FX4-1 W72*H72MM 100-240VAC,12-24VDC INPUT PNP
FX6-1 W72*H72MM INPUT PNP
FX4 W72*H72MM INPUT PNP
FX6 W72*H72MM INPUT PNP
FX4-2P W72*H72MM INPUT PNP
FX6-2P W72*H72MM INPUT PNP
FX4H-1 W48*H96MM 100-240VAC,12-24VDC INPUT PNP
FX4L-1 W48*H96MM INPUT PNP
FX4H-2P W48*H96MM INPUT PNP
FX4H W144*H72MM INPUT PNP
FX6L-1 W144*H72MM INPUT PNP
FX4L-2P W144*H72MM 100-240VAC,12-24VDC INPUT PNP
FX6L-2P W144*H72MM INPUT PNP
数显计时计数器
CT4S W48*H48MM INPUT NPN/PNP
CT4S-2P W48*H48MM INPUT NPN/PNP
CT6S-1 W48*H48MM INPUT NPN/PNP
CT6S W48*H48MM INPUT NPN/PNP
CT6S-2P W48*H48MM INPUT NPN/PNP
CT6-1 W72*h72MM 100-240VAC,24-60VDC INPUT NPN/PNP
CT6 W72*h72MM INPUT NPN/PNP
CT6-2P W72*h72MM INPUT NPN/PNP
模拟计时器
AT8AN 100-240VAC/24-240VDC(12DCV)24,48VAC,110.220VAC,12,24,48,100VDC 8PIN SOCKET
AT11DN 11PIN SOCKET
AT11EN 8PIN SOCKET
AT8SDN W48*H48mm 110,220VAC,24,48,100/110VDC 0.5SEC-100SEC
AT8PSN W48*H48mm 110,220VAC24,48,100/110VDC 0.5,1.5,10SEC
AT8PMN W48*H48mm 0.5,1.5,10 Min
ATE W48*H48mm 110/220VAC12,24VDC100, 220VAC12.24VDC 1s,3s,6s,10s,30s,60s,
3m,6m,10m,30m,60m,3h,6h,12h,24h
ATE-1,2 W48*H48mm
数显计时器
FS4E W48*H48mm 100-240VAC,12-24VDC
FS5E1 W48*H48mm
LCD计时器
LE3S W48*H48mm 100-240VAC,24-240VDC
LE3SA W48*H48mm 110,220VAC
LE3SB W48*H48mm
LE4S W48*H48mm 24-240VAC,24-240VDC
LE4SA W48*H48mm
LE7N-S,M,H,HR w48*H24mm
LE7N-SF,MF,HF,HFR w48*H24mm / input24-240VAC,6-240VDC
LE7D-2 W72*h72mm 100-240VDC MULTITYPE
安装套
FGB48-BL,GR / / BRACKET
FGB48-W / / 8PIN SOCKET
插座 PG-D8 / / 11PIN SOCKET
PG-11 / / 8PIN SOCKET
PS-08 / / 11PIN SOCKET
PS-11 / /
LCD转速表
LR7N-S1,S10 w48*H24mm
LR7N-M60,M600 w48*H24mm
脉冲(转/线速度表)
MP5W-4N W96*H48mm AC100-240V 50/60HZ INDICATOR
MP5W-41 W96*H48mm RELAY(H.GO.L)
MP5W-42 W96*H48mm NPN+BCD
MP5W-43 W96*H48mm PNP+BCD
MP5W-44 W96*H48mm NPN+4-20mA
MP5W-45 W96*H48mm PNP+4-20mA
MP5W-46 W96*H48mm AC100-240V 50/60HZ NPN+serial
MP5W-47 W96*H48mm PNP+serial
MP5W-48 W96*H48mm NPN+RS485
MP5W-49 W96*H48mm PNP+RS485
MP5W-4A W96*H48mm RELAY(HH,H,GO.L.LL)
D5Y-M w72*H36mm 12-24VDC MULT1 INPUT
显示单元
D5W-M w96*H48mm MULT1 INPUT
D5W-MX 110/220VAC50/60HZ
D1SA-RN,GN w11*H20mm 12-24VDC 7SEGMENT
M4N-DV,DA 16 SEGMENT
D1SC-N w31.9*H56.9mm 7 SEGMENT
显示单元外罩/档板
DAR(L)-R,BL
面板表(指示型) D1AA-RN,GN W48*H24mm 12-24VDC 5VDC
M4N-D1-XX INPUT 4-20mADC
M4Y-DV,DA w72*H36mm 110-240VAC 5VDC
M4Y-AV,AA,AVR,AAR w72*H36mm 110-240VAC 6VDC
M4Y-W-XX w72*H36mm 110-240VAC 7VDC
M4Y-T-DX w72*H36mm 110-240VAC 8VDC
M4Y-T-AX w72*H36mm 110-240VAC 9VDC
M4Y-TR-AX w72*H36mm 110-240VAC 10VDC 110-240VAC 11VDC
M4Y-S-DX w72*H36mm
面板表(指示型)
M4Y-S-AX w72*H36mm 110-240VAC 12VDC
M4Y-SR-AX w72*H36mm 110-240VAC 13VDC
M4Y-XX-XX w72*H36mm 110-240VAC 14VDC INPUT 4-20mADC
M4Y-XX-SMPS W72*H36mm 110/220VAC INPUT1-5VDC,4-20mADC
M4W-DV,DA W96*H48mm 110/220VAC
M4W-AV,AA,AVR,AAR
M4W-W-XX
M4W-T-DX
M4W-T-AX
M4W-TR-AX
M4W-S-DX
M4W-S-AX
M4W-SR-AX
M4W-XX-XX
M4W-XX-SMPS W96*H48mm 24-70VDC,90-264VAC
M4W-P W96*H48mm 110/220VAC 4-20mADC,1-5VDC,DISPLAY,0.50~1.00-+0.5
面板表(设定型)
M4W1P-DV,DA
M4W1P-AV,AA,AVR,AAR
M4W1P-W-XX
M4W1P-S,T,SR,TR
M4W1P-XX-SMPS W96*H48mm 24-70VDC,90-264VAC
面板表(双设定型)
M4W2P-DV,DA W96*H48mm 110/220VAC
M4W2P-AV,AA,AVR,AAR W96*H48mm 110/220VAC
M4W2P-W-XX W96*H48mm 110/220VAC
M4W2P-S,T,SR,TR W96*H48mm 110/220VAC
M4W2P-XX-SMPS W96*H48mm 24-70VDC,90-264VAC
面板表(指示型)
M4M-DV,DA W72*H72mm 110/220VAC
M4M-AV,AA,AVR,AAR W72*H72mm 110/220VAC
M4M-W-XX W72*H72mm 110/220VAC
M4M-S,T,SR,TR W72*H72mm 110/220VAC
M4M-XX-5MPS W72*H72mm 24-70VDC,90-264VAC
M4M-XX-XX W72*H72mm 110/220VAC INPUT 4-20mADC
面板表(设定型)
M4M1P-DV,DA W72*H72mm 110/220VAC
M4M1P-AV,AA,AVR,AAR W72*H72mm 110/220VAC
M4M1P-W-XX W72*H72mm 110/220VAC
M4M1P-S,TM,SR,TR W72*H72mm 110/220VAC
M4M1P-XX-SMPS W72*H72mm 24-70VAC,90-264VAC
面板表(双设定型)
M4M2P-DV,DA W72*H72mm 110/220VAC
M4M2P-AV,AA,AVR,AAR W72*H72mm 110/220VAC
M4M2P-W-XX W72*H72mm 110/220VAC
M4M2P-S,T,SR,TR W72*H72mm 110/220VAC
M4M2P-XX-SMPS W72*H72mm 24-70VADC,90-264VAC
面板表(指示型)
M5W-DV,DA W96*H48mm 110/220VAC
M5W-AV,AA,AVR,AAR W96*H48mm 110/220VAC
M5W-W-XX W96*H48mm 110/220VAC
M5W-T-DX W96*H48mm 110/220VAC
M5W-T-AX W96*H48mm 110/220VAC
M5W-TR-AX W96*H48mm 110/220VAC
M5W-S-DX W96*H48mm 110/220VAC
M5W-S-AX W96*H48mm 110/220VAC
M5W-XX-XX W96*H48mm 110/220VAC INPUT-5VDC,4-20mADC
M5W-XX-SMPS W96*H48mm 24-70VDC, 90-264VAC
面板表(比例型) M4V W75*H25mm 12-24VDC INPUT-5VDC,4-20mADC
多用面板表
MT4W-DV(A)-4N W96*H48mm 100-240VAC RELAY/NPN/PNP/BCD/4-20mA
DC,RS485/SERIAI OUTPUT
MT4W-DV(A)-41 W96*H48mm 100-240VAC
多用面板表
MT4W-DV(A)-42-49 W96*H48mm 100-240VAC RELAY/NPN/PNP/BCD/4-20mADC/SERIAI OUTPUT
MT4W-AV(A)-4N W96*H48mm 100-240VAC RELAY/NPN/PNP/BCD/4-20mADC,
/SERIAI OUTPUT
MT4W-AV(A)-41 W96*H48mm 100-240VAC
MT4W-AV(A)-42-49 W96*H48mm 100-240VAC
温度控制仪(模拟型)
TOS W48*H48mm 110,220VAC
TOM w72*H72mm 110/220VAC
温度控制仪(偏差型) TDM w72*H72mm 110/220VAC
温度控制仪(模拟型) TOL W96*H96MM 110/220VAC
温度控制仪(偏差型) TDL W96*H96MM 110/220VAC
温度控制仪(指示型)
T3N1 W48*H24MM 12-24VDC
T3S1 W48*H48MM 100-240VAC
T4Y1 W72*36MM 100-240VAC
T4W1 W96*H48MM 100/220VAC
T4M1 W72*H72MM 100/220VAC
T3HI W48*H96MM 100/220VAC
T4L1 W96*H96MM 100/220VAC
温度控制仪
T3S W48*H48MM 100-240VAC
T3H W48*H96MM 110/220VAC
T4M W72*H72MM 110/220VAC
T4L W96*H96MM 110/220VAC
温度控制仪(报警输出型) T3HA W48*H96MM 110/220VAC
温度控制仪(辅助输出型) T3HS W48*H96MM 110/220VAC
温度控制仪(报警输出) T4MA W72*H72MM 110/220VAC
温度控制仪(报警输出型) T4LA W96*H96MM 110/220VAC
温度控制仪(双设定输出) T4LP W96*H96MM 110/220VAC
温度控制仪(5输入型) T4WM W96*H48MM 110/220VAC indicator
PID温度控制仪
TZ4SP-14R,14C,14S W48*H48MM AC100-240V
TX4ST-14R,14C,14S W48*H48MM AC100-240V
TX4ST-24R,24C,24S W48*H48MM AC100-240V
TZ4M-14R,14C,14S W72*H72MM AC100-240V
PID温度控制仪
TZ4M-24R,24C,24S W72*H72MM AC100-240V
TZ4M-R4R,R4C,R4S AC100-240V
TZ4M-A4R,A4C,A4S AC100-240V
TZ4H-14R,14C,14S W48*H96MM AC100-240V
TZ4H-24R,24C,24S AC100-240V
TZ4H-R4R,R4C,R4S AC100-240V
TZ4H-A4R,A4C,A4S AC100-240V
TZ4L-14R,14C,14S W96*H96MM AC100-240V
TZ4L-24R,24C,24S AC100-240V
TZ4L-R4R,R4C,R4S AC100-240V
TZ4L-A4R,A4C,A4S W96*H96MM AC100-240V
TZ4W-14R,14C,14S W96*H48MM AC100-240V
TZ4W-24R,24C,24S AC100-240V
TZ4W-R4R,R4C,R4S AC100-240V
TZ4W-A4R,A4C,A4S AC100-240V
TZN4S-14R,14C,14S W48*H48MM AC100-240V
TZN4M-14R,14C,14S W72*H72MM AC100-240V
TZN4M-24R,24C,24S AC100-240V
TZN4M-R4R,R4C,R4S AC100-240V
TZN4M-R4R,R4C,A4S AC100-240V
SPC1-35 AC100-240V 35A
SPC1-50 AC100-240V 50A
PID面板式温度控制仪 TB42-14R,14C,14S 100-240VAC 100MM,300MM
光电传感器
BY500-TDT1,2
BYS500-TDT1,2
BYD3M-TDT
BYD3M-TDT-P
BYD30-DDT,DDT-T
光电传感器
BYD50-DDT,DDT-T 10-50MM 12-24VDC NPN OPEN COLLECTOR OUTPUT
BYD100-DDT 10-100MM 12-24VDC
BA2M-DDT 2M 12-24VDC
BPS3M-TDT 3M 12-24VDC
BPS3M-TDT-P 3M 12-24VDC
光电传感器 BM3M-TDT1,2 3M 12-24VDC
BM1M-MDT 1M 12-24VDC
BM200-DDT 200MM 12-24VDC
BMS5M-TDT1,2 5M 12-24VDC
BMS2M-MDT 2M 12-24VDC
BMS300-DDT 300MM 12-24VDC
BMS2M-MDT-P 2M 12-24VDC
BMS300-DDT-P 300MM 12-24VDC
BEN10M-TDT1,2 10M 12-24VDC NPN/PNP OUTPUT
BEN5M-MDT 5M 12-24VDC
BEN3M-PDT 3M 12-24VDC
BEN300-DDT 300MM 12-24VDC
光电传感器
BEN10M-TFR1,2 10M 24-240VAC(24-240VDC) NPN OPEN COLLECTOR OUTPUT
BEN5M-MFR 5M 24-240VAC(24-240VDC)
BEN3M-PFR 3M 24-240VAC(24-240VDC)
BEN300-DFR 300MM 24-240VAC(24-240VDC)
BX1SM-TDT 15M 12-24VDC
BX15M-TDT-T 15M 12-24VDC
BX15M-TDT-P 15M 12-24VDC
BX15M-TDT-TP 15M 12-24VDC
BX15M-TFR 15M 24-240VAC(24-240VDC)
BX15M-TFR-T 15M 24-240VAC(24-240VDC) RELAY OUTPUT(TIM ER)
BX5M-MDT 5M 12-24VDC NPN OPEN COLLECTOR OUTPUT
BX5M-MDT-T 5M 12-24VDC NPN OPEN COLLECTOR OUTPUT(TIMEER)
BX5M-MDT-P 5M 12-24VDC PNP OPEN COLLECTOR OUTPUT
BX5M-MDT-TP 12-24VDC PNP OPEN COLLECTOR OUTPUT(TIMER)
BX5M-MFR 24-240VAC(24-240VDC) RELAY OUTPUT
BX5M-MFR-T 24-240VAC(24-240VDC) RELAY OUTPUT(TIMER)
BX3M-PDT 3M 12-24VDC NPN OPEN COLLECTOR OUTPUT
BX3M-PDT-T 12-24VDC NPN OPEN COLLECTOR OUTPUT(TIMER)
BX3M-PDT-P 12-24VDC PNP OPEN COLLECTOR OUTPUT
BX3M-PDT-TP 12-24VDC PNP OPEN COLLECTOR OUTPUT(TIMER)
BX3M-PFR 24-240VAC(24-240VDC) RELAY OUTPUT
BX3M-PFR-T 24-240VAC(24-240VDC) RELAY OUTPUT(TIMER)
BX700-DDT 700MM 12-24VDC NPN OPEN COLLECTOR OUTPUT
BX700-DDT-T 12-24VDC NPN OPEN COLLECTOR OUTPUT(TIMER)
BX700-DDT-P 12-24VDC PNP OPEN COLLECTOR OUTPUT
BX700-DDT-TP 12-24VDC PNP OPEN COLLECTOR OUTPUT(TIMER)
BX700-DFR 24-240VAC(12-240VDC) RELAY OUTPUT
BX700-DFR-T 24-240VAC(12-240VDC) RELAY OUTPUT(TIMER)
BR4M-TDTD 4M 12-24VDC DARK ON,NPN OC.
BR4M-TDTL 12-24VDC LIGHT ON,NPN OC.
BR4M-TDTD-P 12-24VDC DARK ON,NPN OC.
BR4M-TDTL-P 12-24VDC LIGHT ON,NPN OC.
BR100-DDT 100MM 12-24VDC NPNOPEN COLLECTOR
BR100-DDT-P 12-24VDC PNP OPEN COLLECTOR
BRP100-DDT 12-24VDC NPN OPEN COLLECTOR
BRP100-DDT-P 12-24VDC PNP OPEN COLLECTOR
BUD-30 30MM 12-24VDC NPN OPEN COLLECTOR OUTPUT
BUD-50 50MM 12-24VDC NPN OPEN COLLECTOR OUTPUT
BUD-30S 30MM 12-24VDC
BUD-50S 50MM 12-24VDC NPN OPEN COLLECTOR OUTPUT
BUD-50-H 50MM 18-35VDC
微型光电传感器
BS5-K2M / 5-24VDC
BS5-T2M / 5-24VDC
BS5-L2M / 5-24VDC
连接器 CT-01 / 5-24VDC CONNCTOR
光电传感器的反射镜 MS-2,MS-3 MIRROR
光纤传感器
BF3RX / 12-24VDC NPN OPEN COLLECTOR OUTPUT
BF4R,BF4R-E,BF4R-R / 12-24VDC
BF3RX-P / 12-24VDC PNP OPEN COLLECTOR OUTPUT
BF4RP / 12-24VDC
光纤
FD-320-05 40MM 10R (-40℃ TO 70℃)(-40℃ - 70 ℃)
FD-420-05 40MM 15R
FD-620-10 120MM 30R
FDC-320-05 40MM 15R
FDCS-320-05 40MM 15R
FDP-320-10 120MM 30R
FDS-320-05 40MM 15R(SUS 10R)
FDS2-320-05 40MM 15R(SUS 10R)
FDS-420-05 40MM 15R(SUS 10R)
FDS2-420-05 40MM 15R(SUS 10R)
FDS-620-10 120MM 30R(SUS 10R)
FDS2-620-10 120MM 30R(SUS 10R)
FD-320-F 60MM 15R (-40 TO 70℃)(-40℃- 70℃)
FD-320-F1 40MM 15R
FD-620-F2 120MM 30R
FD-620-10H 120MM 30R (-40℃TO125℃)(-40℃ - 125 ℃)
FD-620-15H1 160MM 50R (-40℃TO150℃)(-40℃ - 150℃)
FT-320-05 150MM 15R (-40℃TO 70℃)(-40℃-70℃)
FT-420-10 500mm 30R (-40℃TO70℃)(-40℃-70 ℃)
FTC-220-05 150mm 15R
FTC-320-10 500mm 30R
FTCS-220-05 150mm 30R
FTP-320-10 500mm 30R
FTR-420-10 500mm 15R
FTS-320-05 150mm 30R(SUS10)
光纤 FTS2-320-05 150mm
FTS-420-10 500mm
FTS2-420-10 500mm
FTS1-320-05 150mm 15R
FT-420-10H 300mm 30R (-40℃ TO 125℃)(-40℃ - 125 ℃)
FT-420-10H1 500mm 30R (-40℃ TO 150℃)(-40℃ - 150℃)
GT-420-14H2 500mm 50R (-40℃ TO 250℃)(-40℃ - 250℃)
光纤护套
FTH-310 / /
FTH-410 / /
FTH-610 / /
ADS-A max 3m 24-240VAC,24-240VDC 2.0-2.7M
旋转编码器(增量型)
ENA 1P/R-600P/R 5-24VDC(但电压输出5V,12v,24v)
800P/R-3600P/R
ENB (1P/R-600P/R) 5-24VDC(但电压输出5V,12v,24v)
800P/R-3600P/R
(1P/R-600P/R-6-L) 5VDC
800P/R-3600P/R-E-L
ENC / 5-24VDC(但电压输出5V,12v,24v)
E30S-XXX-X-2,X-3 100P/R,200P/R,360P/R,500P/R
1000P/R,1024P/R
旋转编码器(增量型)
E30S-XXX-X-L 100P/R,200P/R, 360P/R,500P/R 5VDC 1000P/R,1024P/R
E40S-XXX-3-1,3-2,3-3(shaft:6mm) 1P/R-300P/R 5-24VDC(但电压输出5V,12V,24V)
360P/R-1800P/R
2000P/R-3600P/R
E40S8-XXX-3-1,3-2,3-3(shaft:6mm) 1P/R-300P/R 5-24VDC(但电压输出5V,12V,24V)
360P/R-1800P/R
2000P/R-3600P/R
旋转编码器(增量型))
E40S-XXX-6-L(shaft:6mm) 1P/R-300P/R 5VDC 360P/R-1800P/R 2000P/R-3600P/R 5VDC
360P/R-1800P/R
2000P/R-3600P/R
E40H8-XXX-3-2,3-3(hall:8mm) 1P/R-300P/R 5-24VDC 360P/R-1800P/R 2000P/R-3600P/R
E40HXX-XXX-3-2,3-3(hall:6,10,12mm) 1P/R-300P/R 5-24VDC(但电压输出5V,12V,24V)
360P/R-1800P/R2000P/R-3600P/R
E40H8-XXX-6-L(hall:8mm) 1P/R-300P/R 5VDC
360P/R-1800P/R
2000P/R-3600P/R
旋转编码器(增量型)
E40HXX,XXX-6-L(hall:6,10,12mm) 1P/R-300P/R
360P/R-1800P/R
2000P/R-3600P/R
E80H30,32-XXX3-1,3-2,6-6.3-4,6-L (60P/R-512P/R) 1,2,4,5-24VDC,3;5VDC
,12VDC,24VDC L:5VDC
(1024P/R)
E68S15-1024-6-L (1024P/R) 5VDC
ENH-100-X-1,3,L / 1;5VDC 7;7-24VDC 3;5VDC 12VDC 24VDC L;5VDC
旋转编码器(绝对值型)
ENP-50 6,8,12,16,24,32,40,45,60,64,90,128,180,256,360,512,720,1024 5-24VDC BCD code; binarg code; grag code
ENP-XXXX-006,008,012,016,024,360 / 5-12VDC,12-24VDC
旋转编码器(连接型) COUPLING / 6 mm;8mm;10mm
接近开关(直流2线)
PRT08-1.5DO,1.5DC 1.5mm 24VDC(15-30VDC)
PRT08-2DO.2DC 2mm 24VDC(15-30VDC)
PRT12-2DO,2DC 2mm 24VDC(15-30VDC)
PRT12-4DO,4DC 4mm 24VDC(15-30VDC)
PRT18-5DO,5DC 5mm 24VDC(15-30VDC)
接近开关(直流2线)
PRT18-8DO,5DC 8mm 24VDC(15-30VDC)
PRT10-10O,10G 10mm 24VDC(15-30VDC)
PRT30-15DO.15DC 15mm 24VDC(15-30VDC)
接近开关(直流指示型)
PR08-1.5DN,1,5DP 1.5mm 12-24VDC(10-30VDC)
PR08-1.5DN2,1.5DP2 1.5mm
PR08-2DN,2DP 2mm
PR08-2DN2,2DP2 2mm
接近开关(直流短型)
PRS12-2DN,2DP 2mm 12-24VDC(10-30VDC)
PRS12-2DN2 2mm
PRS12-4DN,4DP 4mm
PRS12-4DN2 4mm
接近开关(直流指示型)
PR12-2DN,2DP 2mm 12-24VDC(10-30VDC)
PR12-2DN2,2DP2 2mm
PR12-4DN,4DP 4mm
PR12-4DN2,4DP2 4mm
接近开关(直流指示型)
PR18-5DN,5DP 5mm 12-24VDC(10-30VDC)
PR18-SDN2,SDP2
PR18-8DN,8DP 8mm
PR18-8DN2,8DP2
接近开关(直流指示型)
PR30-10DN,10DP 10mm 12-24VDC(10-30VDC)
PR30-10DN2,10DP2
PR30-15DN,15DP 15mm
PR30-15DN2,15DP2
接近开关(交流型)
PR12-2AO,2AC 2mm 100-220VAC(85-264VAC)
PR12-4AP,4AC 4mm
PR18-5AO,5AC 5mm
PR18-8AO,8AC 8mm
PR30-10AO,10AC 10mm
PR30-15AO,15AC 15mm
接近开关(直流长型)
PRL12-2DN,2DP 2mm 12-24VDC(10-30VDC)
PRL12-4DN,4DP 4mm
PRL18-5DN,SDP 5mm
PRL18-5DN2,5DP2 5mm
PRL18-8DN,8DP 8mm
接近开关(直流长型)
PRL16-8DN2,8DP2 8mm
PRL30-10DN,10DP 10mm
PRL30-10DN2,10DP2 10mm
PRL30-15DN,15DP 15mm
PRL30-15DN2,15DP2 15mm
接近开关(交流长型)
PRL18-5AO,5AC 5mm 100-240VAC(85-264VAC)
PRL18-8AO,8AC 6mm
PRL30-10AO,10AC 10mm
RPL30-15AO,15AC 15mm
接近开关(直流2线带连接头型)
PRCMT12-2DO,2DC 2mm 24VDC(15-30VDC)
PRCMT12-4DO,4DC 4mm
PRCMT18-5DO,5DC 5mm
PRCMT18-8DO,8DC 8mm
PRCMT30-10DO,10DC 10mm
PRCMT30-15DO,15DC 15mm
接近开关(直流带连接头型)
PRCM12-2DN,2DP 2mm 12-24VDC(10-30VDC)
PRCM12-2DN2,2DP2 2mm
PRCM12-4DN,4DP 4mm
PRCM12-4DN2,4DP2 4mm
PRCM18-5DN,5DP 5mm
PRCM18-5DN2,5DP2 5mm
PRCM18-8DN,8DP 8mm
PRCM18-8DN,8DP2 8mm
PRCM30-10DN,10DP 10mm
PRCM30-10DN2,10DP2 10mm
LRCM30-15DN,15DP 15mm
PRCM30-15DN2,15DP2 15mm
接近开关(带连接头型)
PRCM12-2AO,2AC 2mm 100-240VDC(85-264VAC)
PRCM12-4AO,4AC 4mm
PRCM18-5AO,5AC 5mm
PRCM18-8AO,8AC 8mm
PRCM30-10AO,10AC 10mm
PRCM30-15AO,15AC 15mm
接近开关(直流带连接头长型)
PRCML18-5DN,5DP 5mm 12-24VDC(10-30VDC)
PRCML18-5DN2,5DP2 5mm
PRCML18-8DN,8DP 8mm
PRCML18-8DN2,8DP2 8mm
接近开关(直流带连接头) PRCML30-10DN,10DP 10mm 12-24VDC(10-30VDC)
PRCML30-10DN2,10DP2 10mm
PRCML30-15DN,15DP 15mm
PRCML30-15DN2,15DP2 15mm
接近开关(交流带连接头长型)
PRCML18-5AO,5AC 5mm 100-240VAC(85-264VAC)
PRCML18-8AO,8AC 8mm
PRCML30-10AO,10AC 10mm
PRCML30-15AO,15AC 15mm
接近开关(直流2线带连接头型)
PRWT12-2DO,2DC 2mm 24VDC(15-30VDC)
PRWT12-4DO,4DC 4mm
PRWT18-5DO,5DC 5mm
PRWT18-8DO,8DC 8mm
PRWT30-10DO,10DC 10mm
PRWT30-15DO,15DC 15mm
PRW12-2DN,2DP 2mm 12-24VDC(10-30VDC)
PRW12-2DN2,2DP2 2mm
PRW12-4DN,4DP 4mm
PRW12-4DN,4DP2 4mm
PRW18-5DN,5DP 5mm 12-24VDC(10-30VDC)
PRW18-5DN2,5DP2 5mm
PRW18-8DN,8DP 8mm
PRW18-8DN2,8DP2 8mm
PRW30-10DN,10DP 10mm 12-24VDC(10-30VDC)
PRW30-10DN2,10DP2 10mm
PRW30-15DN,15DP 15mm
PRW30-15DN2,15DP2 15mm
接近开关(交流带连接头型)
PRW12-2AO,2AC 2mm 100-240VDC(85-264VAC)
PRW12-4AO,4AC 4mm
接近开关(交流带连接头)
PRW18-5AO,5AC 5mm 100-240VDC(85-264VAC)
PRW18-8AO,8AC 8mm
PRW30-10AO,10AC 10mm
PRW30-15AD,15AC 15mm
接近开关(直流带连接头长型)
PRWL18-5DN,5DP 5mm 12-24VDC(10-30VDC)
PRWL18-5DN2,5DP2 5mm
PRWL18-8DN,8DP 8mm
PRWL18-8DN2,8DP2 8mm
PRWL30-10DN,10DP 10mm
接近开关(直流带连接头长型)
PRWL30-10DN2,10DP2 10mm 12-24VDC(10-30VDC)
PRWL30-15DN,15DP 15mm
PRWL30-15DN2,15DP2 15mm
PRWL18-5AO,5AC 5mm 100-240VAC(85-264VAC)
PRWL18-8AO,8AC 8mm
PRWL30-10AO,10AC 10mm
PRWL30-15AO,15AC 15mm
接近开关(直流2线防火花型)
PRAT18-5DO,5DC 5mm
PRAT30-10DO,10DC 10mm
接近开关(直流防火花型)
PRA12-2DN,2DP 2mm 12-24VDC(10-30VDC)
PRA12-2DN2,2DP2 2mm
PRA18-5DN,5DP 5mm
PRA18-5DN2,5DP2 5mm
PRA30-10DN,10DP 10mm
PRA30-10DN2,10DP2 2mm
接近开关(交流防火花型)
PRA12-2AO,2AC 2mm 100-240VDC(85-264VAC)
PRA18-5AO,5AC 5mm
PRA30-10AO,10AC 10mm
电容式接近开关(直流型)
CR18-8DN,8DP 8mm 12-24VDC(10-30VDC)
CR18-8DN2 8mm
CR30-15DN,15DP 15mm
CR30-15DN2 15mm
电容式接近开关(交流型)
CR18-8AO,8AC 8mm 100-240VAC(18-264VAC)
CR30-15AO,15AC 15mm
接近开关(直流2线)
PST17-5DO,5DC 5mm 24VDC(15-30VDC)
PST17-5DO,5DC 5mm
接近开关(直流型)
PS12-4DN,4DP,4DN2 4mm 12-24VDC(10-30VDC)
PS12-4DNU,4DPU,4DN2U 4mm
PS17-3DN,3DP,3DN2 3mm 12-24VDC(10-30VDC)
PS17-3DNU,3DPU,3DN2U 3mm
PS17-5DN,5DP,5DN2 5mm
PS17-5DNU,5DPU,5DN2U 5mm
PS17-5DN-F 5mm
PS17-8DN,8DP,8DN2 8mm
接近开关(直流型)
PS17-8DNU,8DPU,8DN2U 8mm 12-24VDC(10-30VDC)
PS17-8XXX-F 8mm
接近开关(长距离型)
PS50-30DN,30DP 30mm 12-24VDC(10-30VDC)
PS50-30DN2,30DP2 30mm
AS80-50DN3,50DP3 50mm 12-40VDC
接近开关(直流扁平型)
PV125-8DN,8DF 8mm 12-24VDC(10-30VDC)
PF125-8DN2,8DF2 8mm
接近开关(直流型)
PSN25-5DN,5DP 5mm
PSN25-5DN2,5DP2 5mm
PSN30-10DN,10DP 10mm
接近开关(直流型)
PSN30-10DN2,10DP2 10mm 12-24VDC(10-30VDC)
PSN30-15DN,15DP 15mm
接近开关(直流型)
PSN30-15DN2,15DP2 15mm
PSN40-20DN,20DP 20mm
PSN40-20DN2,20DP2 20mm
接近开关(交流型)
PSN25-5AO,5AC 5mm 100-240VAC(85-264VAC)
PSN30-10AO,10AC 10mm
PSN30-15AO,15AC 15mm
PSN40-20AO,20AC 20mm
传输耦合器 PET18-5 5mm
连接盒
PT4-2D,3DN,3DP / / input4
PT6-2D,3DN,3DP / / input6
PT8-2D,3DN,3DP / / input8
圆型用支架 P90-R12,R18,3R30 /
连接器
PT1-D,A /
PT2-D,A /
连接电缆
CID2-2,3-2 / / DC 2M
CLD2-2,3-2 / /
CIA2-2,CLA2-2 / / AC 2M
CID2-5,3-5 / / DC 5M
CLD2-5,3-5 / /
CIA2-5,CLA2-5 / / AC 5M
C1D4-2,C2D4-2 / / DC 2M
C3D4-2,C4D4-2 / /
C1A4-2,C2A4-2 / / AC 2M
C3A4-2,C3A4-2 / / AC 2M
C1D4-5,C2D4-5 / / DC 5M
C3D4-5,C4D4-5 / / DC 5M
C1A4-5,C2A4-5 AC 5M
C3A4-5,C4A4-5 AC 5M
传感器控制器
PA-12 110/220VAC
PA10-U 100-240VAC NPN INPOT
PA10-V-W NPN INPOT
PA10-VP,WP PNP INPOT
传感器开关电源
SP-0305 100-240VAC DC 5V,3W
SP-0312 DC 12V,3W
SP-0324 DC 24,3W
压力传感器
PAS-V01-R1/8 0.0-101.3kpa 12-24vdc NPN OPEN COLLECTOR OUTPUT
PAS-V01P-R1/8 12-24vdc PNP OPEN COLLECTOR OUTPUT
PAS-01-R1/8 0.0-100.0kpa 12-24vdc NPN OPEN COLLECTOR OUTPUT
PAS-01-R1/8 12-24vdc PNP OPEN COLLECTOR OUTPUT
PAS-1-R1/8 0-1000kpa 12-24vdc NPN OPEN COLLECTOR OUTPUT
PAS-1P-R1/8 12-24vdc PNP OPEN COLLECTOR OUTPUT
BW型(AREA SENSOR)
BW20-08(P) 0,1~7M 140mm DC12-24V PNP集电极开路输出PNP集电极开路输出 亮光动作
BW20-12(P) 220mm
BW20-16(P) 300mm
BW20-20(P) 280mm
BW20-24(P) 460mm
BW20-28(P) 540mm
BW20-32(P) 620mm
BW20-36(P) 700mm
BW20-40(P) 780mm
BW20-44(P) 860mm
BW20-48(P) 940mm
BW40-04(P)0,1~7M 120mm DC12-24V NPN集电极开路输出,PNP集电极开路输出 亮光动作
BW40-06(P)200mm
BW40-08(P) 280mm
BW40-10(P) 360mm
BW40-12(P) 440mm
BW40-14(P) 520mm
BW40-16(P) 600mm
BW40-18(P) 680mm
BW40-20(P) 760mm
BW40-22(p) 840mm
BW40-24(P) 920mm
区域传感器连接电缆
CID4-3(黑色) 3M
CID4-3(灰色) 3M
CID4-5(黑色) 5M
CID4-5(灰色) 5M
CID4-7(黑色) 7M
CID4-7(灰色) 7M
CID4-10(黑色) 10M
CID4-10(灰色) 10m
注: 有多款型号尚未一一列出
