北京华嘉信达机电设备有限公司
  • 6分量传感器
  • 发布时间:2007/10/24 17:24:19   修改时间:2007/10/24 17:24:19 浏览次数:1957
  • 6分量传感器
  • 品牌 GTM
    型号 RLS
    精度要求 综合精度
    发货期限 60天内发货
    产品说明 Technical Data
    Unit RLS 25 RLS 50 RLS 120/200
    max. loads
    (vehicle coordinate system)
    Fx (driving direction) kN ± 25 ± 120
    Fy (lateral) kN ± 25 ± 30 ± 100
    Fz (vertical) kN 25 50 ± 120 + 80 static
    Mx (around longitudinal axis) N·m ± 7,000 ± 14,000 ± 30,000
    My (around lateral axis) N·m ± 7,000 ± 10,000 ± 50,000
    Mz (around vertical axis) N·m ± 7,000 ± 30,000
    Life expectancy, 10,000,000 km
    load with Standard CARLOS vertical kN 25 50 120
    Weight
    Wheel fixed parts ca. kg 3.5 5 7
    Test rig fixed parts ca. kg 7.5 11 15
    Metrology data (with amplifier MCM, f.s.)
    Total error ± % 0.7
    Linearity error ± % 0.5 0.7
    Hysteresis ± % 0.5 0.7
    Cross talk with correction matrix (MCM) ± % 2 (0.5)
    Dimensions
    Overall diameter ca. mm 350 400 650
    Overall width ca. mm 90 95 110
    Fixing customer adaptable
    Centring diameter customer adaptable
    Environmental conditions
    Operational temperature range ° C +10 to +70
    Temperature influence on zero (f.s.) ± % 0.0025
    Temperature influence on span (a.v.) ± % 0.005
    Protection rating (EN60529) IP64
    Material Aluminium / Steel
?? 北京华嘉信达机电设备有限公司位于中华人民共和国的首都----北京;是专业从事力学、扭矩、压力等传感器和非标传感器、仪表的生产、研发、销售的公司;是专业从事欧美先进的自控产品在中国市场的推广;进口自动化设备、进口测控设备、测力传感…  更多>>
北京华嘉信达机电设备有限公司
联系人:赵洋权
地址:北京市房山区良乡长虹西路翠柳东街1-491号
邮编:102488
电话:010-83392343
传真:010-83392342
公司网址:http://www.sensorhj.com
