北京华嘉信达机电设备有限公司
  • 6分量传感器
  • 发布时间:2007/10/24 17:25:47   修改时间:2007/10/24 17:25:47 浏览次数:1932
  • 6分量传感器
  • 品牌 GTM
    型号 MKA
    测量范围 400KN-1MN
    精度要求 精度等级0.05
    发货期限 60天内发货
    产品说明 Multi-Component Transducer MKA
    General Data (realtive to full scale output)
    Accuracy class 0.2
    Reproducibility error frep ± % 0.01
    Linearity error dlin ± % 0.2
    Hysteresis u ± % 0.05
    Temperature influence on zero TK0 ± %/K 0.0025
    Temperature influence on span TKC ± %/K 0.004
    rel. crosstalk (typical)
    rel. to FSO of the disturbed component at full load of
    the disturbing component
    fü ± % 1.5
    Permissible dynamic load range 1.6 · Fnom or 1.6 · Mnom respectively
    all components simultaneously
    Electrical Data
    Additional Data (relative to actual value)
    Technical Data
    MKA Size ± Fnom / ± Mnom
    Fx, Fy, Fz / Mx, My, Mz
    Sensitivity
    CFx, CFy
    Sensitivity
    CFz
    Sensitivity
    CMx, CMy
    Sensitivity
    CMz
    kN/N·m mV/V
    I 2.5/120 1.7 0.3 1.6 1.6
    5/250 2.0 0.4 2.0 2.0
    10/500
    20/1,000
    II 50/2,500 2.5 0.5 1.3
    III 100/5,000 2.9 0.6 1.6 1.0
    Configuration of measuring ranges (examples for optimum measuring range combinations)
    Due to the multitude of possible combinations of forces and moments, only the optimum combination at the maximum loads is given here. Other combinations are available on
    request. These load to different sensitivities, which are also available on request
    Total error (incl. hysteresis, linearity
    and temperature error)
    in the range 10% - 100% Fnom or Mnom
    ?F/F
    or
    ?M/M
    ± % 0.5
    Rel. creep (tB = 30 min) dcr, F, E ± % 0.05
    Nominal temperature range Bt, nom °C +10 to +60
    Component Fx Fy Fz Mx My Mz
    Bridge impedance nominal Re Ω ca. 400 ca. 800 ca. 400
    Output impedance Ra Ω ca. 350 ca. 700 ca. 350
    Maximum excitation Ue, max V 12
?? 北京华嘉信达机电设备有限公司位于中华人民共和国的首都----北京;是专业从事力学、扭矩、压力等传感器和非标传感器、仪表的生产、研发、销售的公司;是专业从事欧美先进的自控产品在中国市场的推广;进口自动化设备、进口测控设备、测力传感…  更多>>
北京华嘉信达机电设备有限公司
联系人:赵洋权
地址:北京市房山区良乡长虹西路翠柳东街1-491号
邮编:102488
电话:010-83392343
传真:010-83392342
公司网址:http://www.sensorhj.com
