北京市北方思源电子技术中心
  • MPA7300 多路协议分析仪
  • 发布时间:2007/11/4 16:34:51   修改时间:2009/3/26 14:54:18 浏览次数:3085
  • MPA7300 多路协议分析仪
  • 场信令仪(多路协议分析仪)
    MPA7300 MPA7200 MPA7100
    厂家 GN Nettest
    包含所有主要的电信协议:SS7, DASS2, DPNSS, BTNR167, GSM, ETSI Q931, INAP 等等.
    所 配 模 块
    MPA7300 Multi Processor *2 2 Mbit/s Unbalanced Quad Link *1 -
    MPA7300 Multi Processor *3
    MPA7300 Multi Processor *1 2 Mbit/s Unbalanced Quad Link *1 2 Mbit/s Balanced Quad Link *1
    MPA7200 Multi Processor *2 2 Mbit/s Unbalanced Quad Link *5 PCI Link Interface *1
    MPA7200 PCI Controller *2 2 Mbit/s Unbalanced Quad Link *6 -
    MPA7100 Multi Processor *1 2 Mbit/s Unbalanced Quad Link *1
    MPA7100 Multi Processor *1 2 Mbit/s Unbalanced Quad Link *1 -
    ◆系统软、硬件性能非常稳定,应用极其广泛,技术服务全面专业
    ◆先进的硬件结构(前后台处理分开),超大容量处理能力(上百小时不间断记录)保证数据处理快速可靠,昼夜不间断
    ◆所有规程同时解码,跨链路实时跟踪呼叫,保证快速故障定位
    ◆自动识别信令及消息序列错误,给出告警
    ◆智能化自动搜索信令时隙
    ◆多种应用:信令配合、呼叫追踪、接通率分析、呼损分析、网络规划、GSM网络优化,MAP层增值业务开发、网关计费验证,欺诈检测、网络告警监测等
    ◆ODBC开放数据库格式及中文界面
    ◆中文操作界面仿真设计 提供友好的人机交互界面,系统操作简单易学。
    系统标准配置
    操作系统 Microsoft Windows2000
    CPU Pentium 400MHz
    RAM 128MB
    显示模式 SVGA,TFT真彩色
    缓存 1Gbyte disk on the MPU
    硬盘 12GB
    Used for acceptance testing, detailed trouble shooting, daily maintenance and performance analysis of telecoms networks and switches.
    多达10种协议同时分析。Easy to use multi-link instrument with true multi-protocol analysis capability for up to ten protocols simultaneously.
    Ability to store 1GB of data with 1ms resolution, filter trigger and perform sequence recording for easy analysis.
    协议分析
    协议分析功能捕获发出的信号单元并以解码的形式显示。The protocol-analysis function captures signaling units and displays them in decoded form. The captured signaling units in the log are time-stamped with a resolution of 1 millisecond. The MPA 7300provides full correlation of signaling information recorded from all connected signaling links. Different protocol descriptions may be associated with the various signaling-link interfaces. National protocol descriptions can easily be customized. Automatic error recognition The unique MPA 7300 expert system automatically recognizes all invalid signaling messages and sequences (all valid messages and sequences are contained in the protocol description). In case of a signaling error (syntax error, messages out of sequence or timeout between two messages), the collected events will be stored with an error message in the log.
    滤波器
    In this context, filtering means controlling which signaling messages/sequences and alarms are stored in the event log. An event recognizer in the MPA 7300 is a mechanism that allows the user to look for individual signaling messages and alarms with a specific content – e.g. ISUP RELease messages with cause 17 “user busy”. Sequence recognizers are used to capture a complete sequence of events forming a meaningful transaction – e.g. a telephone call or a Service 800 IN transaction. Both event recognizers and sequence recognizers can be used as filter conditions. The user can select from a wide range of predefined “click-and-go” events and sequence recognizers. Up to 500 concurrent calls/transactions can be followed by a sequence recognizer.
    触发类型
    The MPA contains two trigger types: One start trigger for enabling (open) storage of events and one stop trigger for disabling (close). An event recognizer can be selected as start trigger. A timing offset or event-number offset can also be specified before the event recognizer.
    • Replacement for the successful ETP-71 protocol analyser
    • Used for acceptance testing, detailed trouble shooting, daily maintenance and performance analysis of telecoms networks and switches
    • Easy to use multi-link instrument with true multi-protocol analysis capability for up to ten protocols simultaneously
    • Incorporates a Windows? GUI with pentium processor, 10.4" screen and remote control capability
    • Includes all major telecoms protocols such as SS7, DASS2, DPNSS, BTNR167, GSM, ETSI Q931, INAP etc
    • Ability to store 1GB of data with 1ms resolution, filter trigger and perform sequence recording for easy analysis
我公司专营全新及二手通用电子仪器仪表设备、测试电缆、测试附件等等。为全国厂商企业、科研单位、各类院校及部队提供质优价廉的仪器仪表。十余年来,以专业细致的技术支持和周到的售后服务,赢得了广大用户的青睐。所售仪器,经专业技术人员逐…  更多>>
北京市北方思源电子技术中心
联系人:小孙
地址:北京海淀区大柳树路富海中心4号楼105室
邮编:100081
电话:010-62123259
传真:-
公司网址:http://www.buy17.com
  • Simon Yeung 在2021/8/11 23:03:00留言
  • 详细留言:小孫,你好,有沒有二手 Tektronix A6302 ? 加我微信回覆我什麼價錢 ?
  • Simon 在2020/10/5 8:41:00留言
  • 详细留言:報價 : 二手功能完全正常 Tektronix A6302 current probe
  • Shaukat 在2018/9/24 23:20:00留言
  • 详细留言:Hi i need r&s URE3 voltmeter.
  • 王力 在2015/3/17 14:02:00留言
  • 赵先生 在2012/2/24 16:59:00留言
  • 详细留言:台湾铨华9032C五合一安规综合测试仪报价和周期
