COM-E-02-01日本RKC通信协议变换器
- 发布时间:2015/2/3 8:54:31
修改时间:2015/2/3 8:54:31 浏览次数:4222
COM-E-02-01
日本RKC通信协议变换器COM-E是将选配了通信功能的数字温度控制器(CB100, CB400, CB500, CB700, CB900, SA200, REX-F400, REX-F700, REX-F900)、背压式液位计(LE100)连接到可编程控制器(以下简称PLC)的信号变换器。把温度控制器的数据存储到相应的寄存器中。
REX-F900 AD04-M*EF-838-NN/CE
REX-F900 WD04-M*EF-838-NN/CE
DP-350C
H-PCP-J-241-D*AB-05E
H-TIO-C-WJ09-VM*NN
H-CT-A-S
CZ-100P-HLZ-SN 0-200 L=300MM Y1CZ100P2-139 (01K16006)
PG500B3*N-8-NN
HA900DD-VV-4*NN-NNIN-N/A/Y ZK-1155
F400WJA5-MM-AB-NNN-NN
F400FD12-8XGJ-NNN-4N
F400WD12-8MXGN-NNN-4N/CE
CB900FK07-VXAF-NN/A/X
RD900FD05-8N-4*1N-NN/AN
PCT-300-4N
CZ-100P-HLZ-SN NO;10E27009
CZ-100P-HB-SN 0-350KG 06F27005
SA200FK01MN3*NN-DN/N
H-PCP-B-14N-D*CT
F400F301-V*CC-NNN-1N/CE
F400FD04-V*CC-NNN-1N/CE
PF900-MMN4*CND2-W401/Y(0-ABD9-NN)=2
CZ-200P-HB-SNN-050P*NNN-N
PG500A4*1-N-N N-HNNN
CZ-100P-HB-SN 0-50MPA NO 93E31005A
CZ-100P-LLA-SN, 0-10kgf/cm2
H-TIO-B-CK09-T*NN
Z-TIO-AC-8888/N2-FD35 AT6N-N2
CB400FK01-M AN-NN/N
ST-23-K-1000-3C/A
FB400-8N-4*4TND/N2-FK09
RD900FD05-8N-4*NN-NN/A/N
CZ-200P-HB-SNN-050P*NCN-K0100
PG500A4*25-N1-HGNN/Y
AG500 4*N-N-N-N-N1-501
REX-P48FK16-V*AB-Y2-N
F900FK11-8*AF-83N-NN
CB900FK01-8*NP-NN/A/Y
Z-TIO-AC-8888/NN/Y
H-HIO-B-FJ09-V*NN
FB-400-8N-4*4NN5/AN-F801
FK38-MM-4*NN-51/ /Y+ATC180041
CZ-100P-HZ-SN 10G23002
Z-T10-AT-VVVV/N1-FK02/Y
CH402FD10-V×AN-NN
CZ-100P-HLZ-SN, 0-200 L="300MM"、 YICZ100P2-139 with CU gasket T="2mm"*2pcs, S/No. 01K16006
Z-TIO-AC-VVVV/NN
CD901-FK01-8*AN-NN
FB400-8N-4*4NN5/A1-F201/Y
H-PCP-A-34N-M*GA/00E Z-1021
h-pcp-a-34n-m*ga/cez-1021
Z-TIO-AT-VVVV/A1-FK01
W-AB-NG-PA-5000
FB400-8V-4*4NNN/A1-WK02
COM-JC*01
FB400-MM-4*2NNN/A1-WJA5
JB-15-3C
ST-30L-3C
REX-D900F-N*DN-N-5
ST-50-500
W-ST50A-1000-Y3
ST-29H-3C
CZ-100P-HC-HK
CB100WJ01-MM*NN-NN/A
W-AB-YS-PB-20000
