REX-F900WD04-VM*AB-535-NN/CECB100 FK02-M*HJ-NN/A/Y AC100-240 用ch102代替CD401 FK02-M*GN-5NCD401 FK02-M*GN-NN 用CH402代替
CD901FK04M GMCH102 FK02-M*GN-NNCD901FK02-M-ANOPL-ANMT18-B-FK04-DNNM-PCP-A-2-24N-MABREXF900CH402FK02-M*ABCH402FK02-M*NNCD701FK02-M*GNCH402FD10-V*NNCB100FK02-VXAP-NN1A1TREX-PG410A4HJ-5N? AC220VCZ-100P-HB-HSN? 0-50MPAFK02-V*AP-NN/A/Y,0-400度CH102 CH402 PT100 400度的 ch102fk02-v*ap-nnCD901VD12-88*AN-NNN-NA CD901VD12-8M*AN-NNN-NA REC-D900ST-41ch102fk02-m8gnST-50不是表 是整包起买的一包5根CZ-100P-LLA-SNG RKC CD901FD10-8*AB-NN-/Y CH402WK02-VM CH402WE01-VM CH402WK02-VM*an-5n 带通讯fb400-6-4*4nnn-n CD901F-801-8*ANCH102-FD10-M*GN-NN CZ-100P-HLZ-SN CT-300-4 CH402FD08-8GA-AACH102FJ01-V*AB-N-N? CD401AK0688NP51CH402FS02-MM*AN-NN CH402FK10-8*GNREXC900FT-MM*A-NRKC85-50M/DC24cd901fk02-v*gn-nnCH402FK02-M*GN-NN CD901FK06-8*AB-5Nfb400-8-4*4nnn/f801CD901 FK02-M*AN-NNCD901FK06-8*AA-NNFB400-8N-4*1NNN/A1-FS01 FB400-8N-4*1NN5/A1-FS01cd701C-700FK06-MM*N CH402-8450V 0-400度,K型 RELAY 继电器输出/ ALM1,ALM2ST-30F400FK10-V*NP-NNN-NN 用fb400替代CD401VM 带通信 继电器输出CH402VM 不带通信,带报警 ,继电器输出fb900-8-4*4nn5/f801REX-CD901-FK07-8*ANCD901FK02-M*AN*NN 是K型CD901Fd08-M*AN*NN PT100CH901FK02-M*GN-NN CD901Fd10-M*AN*NN CD901Fd10-V*AN*NN cd901fd08-vm*gn-nnREX-P96P96FK-8*AB-Y1-N REX-C100 C100FK07-8*AN用ch102替代CD901FD01-M*M*AN-200C-649C PT100ch102FK05-V*CN-NN/A REX-P96FK16-VCD501FK07-M*NND900W-8-DN-N-5901温控仪,0-800度,K型,控制可控硅CD901CODEFK02-M*GN-NNCD901WD05-8M*AB-NN/NYCD901FD01-V*ABCD901-FK02-MM*AA-NNCD901WD05-8M*AB-NN/NYCH902/901-V*AB-NNCH402FK01-VAVREX-D900-8-DN-N-5REX-F400 F400FD04-V*CC-NNN-1NREX-C400FK02-R*KNCH102FK02-V*NNCH102FK04-V*AP*5NCH402FK01-V*ANCH102A801-MMST-23LFB400COBE-8N-4*4N-8N-AN-Y AC240CH102FD07-M*ANCD901FK02-M*Gn-nnCD901FR01-8M*GN-NNCD901FR01-M*GN-NNCD701FK02-V*ENCB100FK07-8V*APREX-P96FK16-Vcd701f801-8*an-nnCH402 CODE FK02-M*GN-NN 0-400 输入:K,输出RELAYHA900-DD-VV-4*NN-NN1-N/A/YFB400 8N-4*4NNN/A1-FD35/Y 4HA901 80-B6-4-M2-NNNN-A-Y?cd401fk02-vm*an-5n (带通信)F900FD12-8*AF-NNN-NN AC110V TO 240VCH402FK10-8*GN CH402FS02-MM*AN-NNF900FD12-8*AF-NNN-NN AC110V TO 240VCT-300 PCT-300N-4NM-PCP-A-24N-M*AB Z-190 INPUT:200-240VACM-TIO-B-FD16-V*NN OUTPUT:0-12VDCM-DO-A-M OUTPUT:RELAY(250VAC 1A)D400F-N*DN-8-ND400W-V*NN CD901FK02-M*GH-NNCD901FK020MMAP-NNCH102 FK07-V*AP-NNREX-P200 FDC-F*B-NN-NCH102-DT03-8*NNREX-C400FK02-V*NN 用ch402替代REX-C900FK02-V*NN 用cd901替代c900fd10-m*an 用cd901替代ST-32CH102-DT03-8*NNch102fk07-m*nn-nn/a/ycB500fk07-m*nn-nn/a/y CD901FK02-8*ANCH402FD05-M*GN-2NCH402FD05-M*GN-2NCH402FK03-MM*GN-NNMA9004FD10-8N*ABF-D6/N/Y PT100 0-500 四通道CB900FD10-88AF-5N/A/Y PT100 0-500 二通道CH102FK06-M*KNP96 LK22-V*GD-Y1-NCB900FD10-V*AF-NN/A/YCD901F801-8*HJ-NNdp350cCH402FK02-M*GN-NN 里面带ZK-1033 0-400度CD401FK02-MNNCB900FK07-V*AF 用cd901替代CH402FD05-M*GN-5Nrex700fk02-m*gn 用CD701FK02-M*GN替代cd701fk01-8gnCH402WK02-VM*AN 0-400ch402fk02-v*avREX-P96FK-16-8*NN-NN-Nch402wk02-vm*gnCH402 WK01-MV HB ch102fj03-8*nn-n1/a/y REX-F900WD04-VM*AB-535-NN/CECD701 PT100 电流输出CD701 PT100 继电器和电压输出CH402FK02-M*KN-NNCD701FK02-M*GN-NNCH402FD10-V*GN-NNREX-D100F-8N*DN-NN-NN AC100-240V 50/60HZ 4-20MAREX-D100F-5N*DN-NN-NN AC100-240V 50/60HZ 0-10Vch402fe02-m*gn-nnCD701FK02-M*KN-5N 带通信ad401a-4nnnnRH100FK02-V*GN/ACH402WD01-MM*ANCH402WD02-MM*NNCD901FD01-V*AA-NNCD901FK07-V*AFFB400-8N-4*4NN5/A1-FS06-YCH402FK02-M*ANCD901FK02-M*AN-NNCD901FD01-M*GN-5NCH402FD10-V*AN-NN用CD901FD10-8*GN-NN 替代REX-900 C900FD 10-8CH402FK-M 替代400FK02-M*AND400F-N*DN-N-Ncd901fk07-man-nnREX-400 F400WD12-MM-AB-NNN-NN 94L15038Z-156ACB100-FK02-M*GN-NN-A/YREX-P96FK-VAB-YE-NH402FD05-M-GN-5NREX-F900WD04-VM*AB-535-NN/CEREX-F900WD04-VM*AB-838-NN/CEcd701fd10-m*an-nnCH402FK02-M*GNCD901F801-8*AN-NNDP-350ch402fk02-m*gn/aCH102FD08-M*NN-NNCH902FK02-VMAP-NN 用CD901WK02-VM*AP替代CB100FK07-M*AP-NN/A/Y 用CH102替代CZ-100P-HLZ-SN 0-35MPA CZ-100P-[LL]-SN 0-5MPA Loose nut type L="6mm"CZ-100P-[LL]-SN 0-5MPA Loose nut type L="55mm" CZ-100P-[LL]-SN 0-5MPA Loose nut type L="110mm" CZ-100P-HLZ-SN 0-35MPA NO.02B18003fb400 8n-4*4n8n/an/yREX-P96FK16-V*AB-Y1-NC400WJ02-8M*AF 这个已经停产用CH402WJ02-8M*AFCB900FD10-M*AF-NN-A-Y 用CD901FD10-M*AF-NN替代D900F-8*DN-N-5REX-P96FK16-V*AB-Y1-NF400F301-V*CC-NNN-1N
联系人:陈一非
地址:上海市延长西路25号
邮编:200072
电话:021-66100983
传真:021-66100983
公司网址:http://boyi1010.net114.com/
