上海博谊自控电气设备有限公司
  • 施耐德140CPS12420大量库存低价
  • 发布时间:2012/1/16 10:37:25   修改时间:2012/1/16 10:37:25 浏览次数:2738
  • 140CPS12420
    Schneider施耐德 Quantum Processor 处理器
    140CPU11302 Quantum CPU256K,8K用户逻辑,10K寄存器,1MB和1MB+
    140CPU11302C Quantum CPU256K,8K用户逻辑,10K寄存器,1MB和1MB+,C
    140CPU11303 Quantum CPU512K,16K用户逻辑,10K寄存器,1MB和1MB+
    140CPU11303C Quantum CPU512K,16K用户逻辑,10K寄存器,1MB和1MB+,
    140CPU31110 Quantum Unity Quantum 31110 CPU
    140CPU31110C Quantum Unity Quantum 31110 CPU,带涂敷涂层
    140CPU43412A Quantum CPU 486,2M用户逻辑,2MB,1MB+
    140CPU43412AC Quantum CPU 486,2M用户逻辑,2MB,1MB+,CC
    140CPU43412U Quantum Unity Quantum 43412 CPU
    140CPU43412UC Quantum Unity Quantum 43412 CPU,带涂敷涂层
    140CPU53414B Quantum Quantum 534 PLC CONTROLLER
    140CPU53414BC Quantum Quantum 534 PLC CONTROLLER CC
    140CPU65150 Quantum Unity Quantum CPU with Ethernet,w 512/71
    140CPU65160 Quantum Unity CPU 266MHz, 2M, 2048/7168K
    140CPU67160 Quantum Unity Quantum 67160 CPU
    140CPU65260 Quantum Unity CPU 266MHz, 4M, 4096/7168K
    140CPU65260C Quantum Unity Quantum 65260 CPU,带涂敷涂层
    140CPU65150C Quantum CC QUANTUM PROCESS- UNITY W/ 1024/7
    140CPU65160C Quantum CC QUANTUM PROCESS- UNITY W/ 2048/7
    140CPU67160C Quantum CC QUANTUM HSBY PROCESS UNITY 2048/
    Quantum Hot Standby  双机热备
    140CHS11000 Quantum QUANTUM 热备模块
    140CHS11000C Quantum QUANTUM 热备模块, CC
    140CHS21000 Quantum QUANTUM 热备套件
    140CHS21000C Quantum QUANTUM 热备套件, CC
    140CHS32000 Quantum QUANTUM 热备远程I/O同轴电缆终结套件
    140CHS41010 Quantum Quantum经济性热备包,140CPU11302
    140CHS41020 Quantum Quantum经济性热备包,140CPU11303
    140SHS94500 Quantum 热备功能可装载软件
    990XCA65609 Quantum 热备模块光纤电缆
    490NOR00003 Networks Ethernet MTRJ- MTRJ 光纤电缆,3m
    490NOR00005 Networks Ethernet MTRJ/MTRJ 5M Opt
    Quantum Memory  内存卡
    TSXMCPC002M Quantum Unity V2 PCMCIA存储扩展卡,程序存储 2x1024K(Flash),数据存储1024K(RAM)
    TSXMCPC512K Quantum Unity V2 PCMCIA存储扩展卡,程序存储512K(Flash),数据存储512K(RAM)
    TSXMFPP001M Quantum Unity V2 PCMCIA存储扩展卡,程序存储1x1024K(Flash)
    TSXMFPP002M Quantum Unity V2 PCMCIA存储扩展卡,程序存储2x1024K(Flash)
    TSXMFPP004M Quantum Unity V2 PCMCIA存储扩展卡,程序存储4x1024K(Flash)
    TSXMRPC001MC Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-1024K,数据存储832-0K,带涂敷涂层
    TSXMRPC003MC Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-3072K,数据存储2880-0K,带涂敷涂层
    TSXMRPC007MC Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-7168K,数据存储6976-0K,带涂敷涂层
    TSXMRPF004M Quantum Unity V2 PCMCIA存储扩展卡(SRAM),文件存储4096K
    Quantum Power Supply  电源模板
    140CPS11100 Quantum 电源, 115/230 VAC, 独立, 3A
    140CPS11100C Quantum 电源, 115/230 VAC, 独立, 3A, CC
    140CPS11420 Quantum 电源, 115/230 VAC, 可累加, 8A
    140CPS11420C Quantum 电源, 115/230 VAC, 可累加, 8A, CC
    140CPS12420 Quantum 电源, 115/230 VAC, 冗余, 8A
    140CPS12420C Quantum LMS AC PS 115/230V RED CC
    140CPS21100 Quantum 电源, 24 VDC, 独立, 3A
    140CPS21100C Quantum 电源, 24 VDC, 独立, 3A, CC
    140CPS21400 Quantum 电源, 24 VDC, 可累加, 8A
    140CPS21400C Quantum 电源, 24 VDC, 可累加, 8A, CC
    140CPS22400 Quantum 电源, 24 VDC, 冗余, 8A
    140CPS22400C Quantum 电源, 24 VDC, 冗余, 8A, CC
    140CPS41400 Quantum 电源, 48/60 VDC, 可累加, 8A
    140CPS41400C Quantum 电源, 48/60 VDC, 可累加, 8A, CC
    140CPS42400 Quantum 电源, 48/60 VDC, 冗余, 8A
    140CPS42400C Quantum 电源, 48/60 VDC, 冗余, 8A, CC
    140CPS51100 Quantum 电源, 125 VDC, 独立, 3A
    140CPS51100C Quantum 电源, 125 VDC, 独立, 3A, CC
    140CPS52400 Quantum 电源, 125 VDC, 冗余, 8A
    140CPS52400C Quantum 电源, 125 VDC, 冗余, 8A, CC
    Quantum Digital Input Module 开关量输入模板
    140DAI34000 Quantum 开关量 AC 输入, 16点, 24 VAC, 隔离
    140DAI34000C Quantum 开关量 AC 输入, 16点, 24 VAC, 隔离, CC
    140DAI35300 Quantum 开关量AC输入,32点,24VAC,8点成组隔离
    140DAI35300C Quantum 开关量AC输入,32点,24VAC,8点成组隔离,CC
    140DAI44000 Quantum 开关量 AC 输入, 16点, 48 VAC, 隔离
    140DAI44000C Quantum 开关量 AC 输入, 16点, 48 VAC, 隔离, CC
    140DAI45300 Quantum 开关量AC输入,32点,48VAC,8点成组隔离
    140DAI45300C Quantum 开关量AC输入,32点,48VAC,8点成组隔离,CC
    140DAI54000 Quantum 开关量 AC 输入, 16点, 115 VAC, 隔离
    140DAI54000C Quantum 开关量 AC 输入, 16点, 115 VAC, 隔离, CC
    140DAI54300 Quantum 开关量AC输入,16点,115VAC,8点成组隔离
    140DAI54300C Quantum 开关量AC输入,16点,115VAC,8点成组隔离,CC
    140DAI55300 Quantum 开关量AC输入,32点,115VAC,8点成组隔离
    140DAI55300C Quantum 开关量AC输入,32点,115VAC,8点成组隔离,CC
    140DAI74000 Quantum 开关量 AC 输入, 16点, 48 VAC, 隔离
    140DAI74000C Quantum 开关量 AC 输入, 16点, 48 VAC, 隔离, CC
    140DAI75300 Quantum 开关量AC输入,32点,230VAC,8点成组隔离
    140DAI75300C Quantum 开关量AC输入,32点,230VAC,8点成组隔离,CC
    140DDI15310 Quantum 开关量DC输入,32点,5VDC,4组隔离,负逻辑
    140DDI15310C Quantum DC IN 5V TTL 4X8 CC
    140DDI35300 Quantum 开关量 DC 输入, 32点, 24 VDC, 4组隔离
    140DDI35300C Quantum 开关量DC输入,32点,24VDC,4组隔离,CC
    140DDI35310 Quantum 开关量DC输入,32点,24VDC,4组隔离,负逻辑
    140DDI35310C Quantum 开关量DC输入32点24V,4组隔离,负逻辑,CC
    140DDI36400 Quantum 开关量 DC 输入, 64点, 24 VDC, 6组隔离
    140DDI36400C Quantum DC IN 24VDC 6X16 SINK, CONFORMAL COAT
    140DDI67300 Quantum 开关量 DC 输入, 24点, 125 VDC, 3组隔离
    140DDI67300C Quantum 开关量DC输入,24点,125VDC,3组隔离,CC
    140DDI84100 Quantum 开关量 DC 输入, 16点, 10-60 VDC, 8组隔离
    140DDI84100C Quantum 开关量DC输入,16点,10-60VDC,8组隔离,CC
    140DDI85300 Quantum 开关量 DC 输入, 32点, 10-60 VDC, 4组隔离
    140DDI85300C Quantum 开关量DC输入,32点,10-60VDC,4组隔离,CC
    140DII33000 Quantum 开关量输入, 8点, 本安型
    140DII33000C Quantum 开关量输入, 8点, 本安型,CC
    140DSI35300 Quantum 开关量输出, 32点,4组
    140DSI35300C Quantum 开关量输出, 32点,4组,CC
    Quantum Digital Output Module 开关量输出模板
    140DAO84000 Quantum 开关量AC输出,16点,24-230VAC,隔离,4A/点
    140DAO84000C Quantum 开关量AC输出,16点,24-230VAC,隔离,4A/点,C
    140DAO84010 Quantum 开关量AC输出,16点,24-115VAC,隔离,4A/点
    140DAO84010C Quantum 开关量AC输出,16点,24-230VAC,隔离,4A/点,C
    140DAO84210 Quantum 开关量AC输出,16点,110-230VAC,隔离,4组
    140DAO84210C Quantum 开关量AC输出,16点,110-230VAC,隔离,4组
    140DAO84220 Quantum 开关量 AC 输出, 16点, 24-48 VAC, 4组隔离
    140DAO84220C Quantum 开关量AC输出,16点,24-48VAC,4组隔离,CC
    140DAO85300 Quantum 开关量AC输出,32点,24-240VAC,4组隔离
    140DAO85300C Quantum 开关量AC输出,32点,24-240VAC,4组隔离,CC
    140DDO15310 Quantum 开关量DC输出,32点,5VDC,4组隔离,0.5A/点
    140DDO15310C Quantum 开关量DC输出,32点,5VDC,4组隔离,0.5A/点,C
    140DDO35300 Quantum 开关量DC输出,32点,24VDC,4组隔离,0.5A/点
    140DDO35300C Quantum 开关量DC输出,32点,24VDC,4组隔离,0.5A/点,
    140DDO35301 Quantum 开关量 DC 输出,32点,24VDC, 4组隔离
    140DDO35301C Quantum DC OUT 24 VDC 4X8 SOURCE CONFORMAL COAT
    140DDO35310 Quantum 开关量DC输出,32点,24VDC,4组隔离,0.5A/点,
    140DDO35310C Quantum 开关量DC输出,32点,24VDC,4组隔离,0.5A/点,
    140DDO36400 Quantum 开关量 DC 输出,64点,24VDC, 6组隔离
    140DDO84300 Quantum 开关量DC输出,16点,10-60VDC,2组隔离,2A/组
    140DDO84300C Quantum 开关量DC输出,16点,10-60VDC,2组隔离,2A/组
    140DDO88500 Quantum 开关量DC输出,12点,24-125VDC,2组6点成组隔
    140DDO88500C Quantum 开关量DC输出,12点,24-125VDC,2组6点成组隔
    140DIO33000 Quantum 开关量输出, 8点, 本安型
    140DIO33000C Quantum 开关量输出, 8点, 本安型,CC
    140DRA84000 Quantum 继电器输出, 16点, NO, 2A/点
    140DRA84000C Quantum 继电器输出, 16点, NO, 2A/点, CC
    140DRC83000 Quantum 继电器输出, 8点, NO/NC, 2A/点
    140DRC83000C Quantum 继电器输出, 8点, NO/NC, 2A/点, CC
    140DVO85300 Quantum 开关量输出, 32点,10-30VDC, 校验 0.5A/点
    140DVO85300C Quantum 开关量输出,32点,10-30VDC,校验0.5A/点,CC
    Quantum Digital Mixed Module 开关量混合模板
    140DAM59000 Quantum 开关量AC混合模块,16点输入,115VAC;8点输出
    140DAM59000C Quantum 开关量AC混合模块,16点输入,115VAC;8点输出
    140DDM39000 Quantum 开关量DC混合模块,16点输入,24VDC;8点输出
    140DDM39000C Quantum 开关量DC混合模块,16点输入,24VDC;8点输出
    140DDM69000 Quantum 开关量DC混合模块,4点输入,125VDC;4点输出
    140DDM69000C Quantum 开关量DC混合模块,4点输入,125VDC;4点输出
    Quantum Analog Input Module  模拟量输入模板
    140ACI03000 Quantum 模拟量输入,单极性高速,8通道,4-20mA或1-5V
    140ACI03000C Quantum 模拟量输入,单极性高速,8通道,4-20mA或1-5V
    140ACI04000 Quantum 模拟量输入, 16通道, 高密度
    140ACI04000C Quantum 模拟量输入, 16通道, 高密度,CC
    140AII33000 Quantum RTD/TC 输入, 8通道, 本安型
    140AII33000C Quantum RTD/TC 输入, 8通道, 本安型, CC
    140AII33010 Quantum 模拟量输入, 8通道, 电流, 本安型
    140AII33010C Quantum 模拟量输入, 8通道, 电流, 本安型,CC
    140ARI03010 Quantum RTD输入,8通道,类型NI或PT,100,200,500,100
    140ARI03010C Quantum RTD输入,8通道,类型NI或PT,100,200,500,100
    140ATI03000 Quantum TC 输入, 8通道, 类型 J,K,E,T,S,R,B
    140ATI03000C Quantum TC 输入, 8通道, 类型 J,K,E,T,S,R,B, CC
    140AVI03000 Quantum 模拟量输入, 8通道, 双极性, 多量程
    140AVI03000C Quantum 模拟量输入, 8通道, 双极性, 多量程, CC
    Quantum Analog Output Module  模拟量输出模板
    140ACO02000 Quantum 模拟量输出, 4通道, 4-20mA, 通道隔离
    140ACO02000C Quantum 模拟量输出, 4通道, 4-20mA, 通道隔离, CC
    140ACO13000 Quantum 模拟量输出, 8通道, 高密度
    140ACO13000C Quantum 模拟量输出, 8通道, 高密度, CC
    140AIO33000 Quantum 模拟量输出, 8通道, 电流, 本安型
    140AIO33000C Quantum 模拟量输出, 8通道, 电流, 本安型, CC
    140AVO02000 Quantum 模拟量输出, 4通道, 电压
    140AVO02000C Quantum 模拟量输出, 4通道, 电压, CC
    Quantum Analog Mixed Module  模拟量混合模板
    140AMM09000 Quantum 模拟量混合模块, 4通道输入, 2通道输出
    140AMM09000C Quantum 模拟量混合模块, 4通道输入, 2通道输出,CC
    Quantum Intelligent Module  智能模板
    140EHC20200 Quantum 高速计数模块, 24 VDC, 500Hz, 2通道
    140EHC10500 Quantum 高速计数模块, 35kHz@5 VDC, 5通道
    140EHC10500C Quantum 高速计数模块, 35kHz@5 VDC, 5通道,CC
    140EHC20200C Quantum 高速计数模块, 24 VDC, 500Hz, 2通道, CC
    140HLI34000 Quantum 高速锁存/计数模块,24 VDC
    140HLI34000C Quantum 高速锁存/计数模块,24 VDC, CC
    140ERT85410 Quantum 事件纪录模块, SER
    416NHM21234 Quantum MB+ PCMCIA TYPE3 PNP,32威网络适配器
    416NHM30030A Quantum Modbus Plus PCIadapter for PCs,with Plug
    416NHM30032A Quantum Modbus Plus PCIadapter for PCs,with Plug
    Quantum Backplane  背板
    140XBP00200 Quantum 背板, 2槽
    140XBP00200C Quantum 背板, 2槽,CC
    140XBP00300 Quantum 背板, 3槽
    140XBP00300C Quantum 背板, 3槽, CC
    140XBP00400 Quantum 背板, 4槽
    140XBP00400C Quantum 背板, 4槽, CC
    140XBP00600 Quantum 背板, 6槽
    140XBP00600C Quantum 背板, 6槽, CC
    140XBP01000 Quantum 背板, 10槽
    140XBP01000C Quantum 背板, 10槽, CC
    140XBP01600 Quantum 背板, 16槽
    140XBP01600C Quantum 背板, 16槽, CC
    140XBE10000 Quantum 背板扩展模块
    140XBE10000C Quantum 背板扩展模块, CC
    140XCA71703 Quantum 背板扩展电缆, 1M
    140XCA71706 Quantum 背板扩展电缆, 2M
    140XCA71709 Quantum 背板扩展电缆, 3M
    Quantum Remote I/O (S908-Coax.)   远程I/O系统
    140CRP93100 Quantum RIO 处理器接口, S908 Head, 单电缆,本地(总站)
    140CRP93200 Quantum RIO 处理器接口, S908 Head, 双电缆,本地(总站)
    140CRA93100 Quantum RIO 站适配器, S908 RIO, 单电缆,远程(分站)
    140CRA93200 Quantum RIO 站适配器, S908 RIO, 单电缆,远程(分站)
    140CRA93100C Quantum RIO 站适配器, S908 RIO, 单电缆, CC
    140CRA93101 Quantum LMS RIO 站适配器, S908 RIO, 单电缆
    140CRA93101C Quantum LMS RIO 站适配器, S908 RIO, 单电缆, CC
    140CRA93200C Quantum RIO 站适配器, S908 RIO, 单电缆, CC
    140CRP93100C Quantum RIO 处理器接口, S908 Head, 单电缆, CC
    140CRP93200C Quantum RIO 处理器接口, S908 Head, 双电缆, CC
    490NRP95400 Quantum 光纤中极器,RMI/
    975750000 Quantum RIO同轴电缆,RG-6
    975951000 Quantum CABLE MAP/TOP QUAD RG-11
    ASMBII003 Quantum DROP CBL 50FT
    ASMBII004 Quantum DROP CBL 140FT
    MA0185100 Quantum LINE TAP/COAX CBL SYS
    MA0186100 Quantum 远程电缆分离器
    MA0331000 Quantum REMOTE I/O TRUNK SPLITTER
    520402000 Quantum 远程I/O分支器终端电阻
    520422000 Quantum 远程I/O干电缆终结电阻,75 欧
    MA0329001 Quantum CONNECTOR SET,CASSETTE,W/BOOTS
    490RIO00211 Quantum RG11 COAXIAL CONNECTOR
    520480000 Quantum CONN COAX M/F R/A F-STYLE
    520614000 Quantum F TO BNC ADAPTER
    600513000 Quantum BNC 终结电阻
    490RIO00400 Quantum MP COAXIAL CABLE STRIPPING TOOL
    490RIO0S411 Quantum CABLE INSTALLATION TOOL
    490RIO00406 Quantum MP RG6 CABLE BLADE PACK(FOR 490RIO00400)
    490RIO00411 Quantum MP RG11 CABLE BLADE PACK/FOR 490RIO00400
    490RIO0C411 Quantum CONNECTOR INSTALLATION TOOL
    600544000 Quantum 用于 RG-6 F 连接器压接工具
    600558000 Quantum 电缆切割钳
    Quantum Distributed I/O (Modbus Plus) 分布式I/O
    140CRA21110 Quantum DIO站适配器和电源,115/230VAC,独立,3A
    140CRA21110C Quantum DIO站适配器和电源,115/230VAC,独立,3A
    140CRA21120 Quantum DIO站适配器和电源,24VDC,独立,3A,单电缆
    140CRA21120C Quantum DIO站适配器和电源,24VDC,独立,3A,单电缆,C
    140CRA21210 Quantum DIO站适配器和电源,115/230VAC,独立,3A
    140CRA21210C Quantum DIO站适配器和电源,115/230VAC,独立,3A
    140CRA21220 Quantum DIO站适配器和电源,24VDC,独立,3A,双电缆
    140CRA21220C Quantum DIO站适配器和电源,24VDC,独立,3A,双电缆,C
    Quantum Communication Module 网络通讯模板
    140NOE77101 Quantum TSX QUANTUM ETHERNET 10/100 BASE T100FX
    140NOE77101C Quantum TSX Quantum Ethernet 10/100 Option Modul
    140NOE77111 Quantum TSX Quantum FactoryCast Web Server Modul
    140NOE77111C Quantum TSX Quantum FactoryCast Web Server Modul
    140NOM21100 Quantum MB+ 网络适配器, 1MB, 1MB+, 单电缆
    140NOM21100C Quantum MB+ 网络适配器, 1MB, 1MB+, 单电缆, CC
    140NOM21200 Quantum MB+ 网络适配器, 1MB, 1MB+, 双电缆
    140NOM21200C Quantum MB+ 网络适配器, 1MB, 1MB+, 双电缆, CC
    140NOM25200 Quantum MB+ 网络适配器, 光纤头/中继器, 1通道
    140NOM25200C Quantum MB+ 网络适配器, 光纤头/中继器, 1通道, CC
    140NWM10000 Quantum TSX QUANTUM FCHMI MODULE
    140EIA92100 Quantum AS-I MASTER模块, 1通道
    140EIA92100C Quantum AS-I MASTER模块, 1通道,CC
    140NOA62200 Quantum Interbus-S Master网络适配器, 4G
    140ESI06210 Quantum ASCII 接口模块, RS232, 2通道
    140ESI06210C Quantum ASCII 接口模块, RS232, 2通道, CC
    140NOC77100 Quantum Quantum Ethernet/IP通讯模板
    Quantum Communication Accessories  网络通讯及附件
    490NAE91100 Quantum Profibus DP Tap 备用
    467NHP81100 Quantum 467 NHP 811 00-PC/DP包
    490NAD91103 Quantum Profibus Line 终结器接头
    490NAD91104 Quantum Profibus 单接头
    490NAD91105 Quantum Profibus 双接头
    490NAC72100 Quantum MODBUS+避雷装置
    490NRP25300 Quantum 光纤中极器,MBPL
    490NRP25400 Quantum 光纤中极器,MBPL
    490NAA21302 Quantum MODBUS PLUS SUPPER 网络电缆,500FT
    490NAA27101 Quantum MODBUS PLUS电缆,100
    490NAA27102 Quantum MODBUS PLUS电缆,500
    490NAA27103 Quantum MODBUS PLUS电缆,1000
    490NAA27104 Quantum MODBUS PLUS电缆,1500
    490NAA27106 Quantum MODBUS PLUS电缆,5000
    990NAD21110 Quantum MB+ 站电缆,2.4M
    990NAD21130 Quantum MB+ 站电缆,6M
    990NAD23000 Quantum MB+ TAP接头
    990NAD23010 Quantum MB+ TAP接头,RUGGEDIZED
    990NAD23011 Quantum RUGGEDIZED MBUS+ TAP TERM
    990NAD23020 Quantum Modbus Plus Super Tap
    990NAD23021 Quantum Modbus Plus Super Tap
    990NAD23022 Quantum Modbus Plus Super Tap
    990NAA21510 Quantum RUGGEDIZED MBUS+ TAP PROG
    990NAD21810 Quantum MBUS+ DROP CABLE 8 LFT-HD DEC
    990NAD21830 Quantum MBUS+ DROP CABLE 20 LFT-HD DE
    990NAD21910 Quantum MBUS+ DROP CABLE 8 RT-HD DEC
    990NAD21930 Quantum MBUS+ DROP CABLE 20 RT-HD DEC
    990NAD23012 Quantum RUGGEDIZED MBUS+ TAP DIN
    ASMBKT085 Quantum MB+ LINE CONNECTOR KIT
    ASMBKT185 Quantum MB+ TERMINATOR CONNECTOR KIT
    ASMBPL001 Quantum MODBUS+ CONNECTOR TOOL
    NWBM85C002 Quantum ASSY BRIDGE/MUX
    NWBM85D008 Quantum BRIDGE MUX
    NWBM85S232 Quantum multibridge, MB+/4 RS232, user programma
    NWBM85S485 Quantum MBUS+ PROG BRIDGE/MUX SUPRS485
    NWBP85002 Quantum ASSY BRIDGE PLUS
    NWRR85001 Quantum REPEATER ASSY
    TSXCUSB485 Twido USB - RS485 CONVERTER
    TSXCUSB232 Twido USB - RS232 CONVERTER
    TSXCUSBMBP Quantum USB - Modbus Plus converter
    Quantum Cablefast Connection  Cablefast 预接线系统
    140CFA04000 Quantum CABLEFAST, 通用连接块, 直头连接
    140CFB03200 Quantum CABLEFAST, 数字输入块, 单独保险
    140CFC03200 Quantum CABLEFAST, 数字输出块, 成组保险
    140CFD03200 Quantum CABLEFAST,数字输入块,2线或3线,单独保险
    140CFE03200 Quantum CABLEFAST, 数字输出块, 单独保险
    140CFG01600 Quantum CABLEFAST, 大功率数字 I/O 块, 单独保险
    140CFH00800 Quantum CABLEFAST, 模拟量输入块, 带保险
    140CFI00800 Quantum CABLEFAST, 模拟量输入块, 无保险
    140CFJ00400 Quantum CABLEFAST, 模拟量输出块, 带保险
    140CFK00400 Quantum CABLEFAST, 模拟量输出块, 无保险
    140CFU00600 Quantum CABLEFAST 保险, 1/16 AMP
    140CFU08000 Quantum CABLEFAST 保险, 0.8 AMP
    140CFU40000 Quantum CABLEFAST 保险, 4 AMP
    140CFX00110 Quantum CABLEFAST 端子块接地条, 10位置
    140CFX00210 Quantum CABLEFAST 保险备用跨接器
    140XCA10206 Quantum CABLEFAST电缆, 大电流, 50针D型,2M
    140XCA10215 Quantum CABLEFAST电缆, 大电流, 50针D型,5M
    140XTS00203 Quantum CABLEFAST电缆, 带 QUANTUM I/O 端子, 0.9M
    140XTS00206 Quantum CABLEFAST电缆, 带 QUANTUM I/O 端子, 1.8M
    140XTS00209 Quantum CABLEFAST电缆, 带 QUANTUM I/O 端子, 2.7M
    140XTS00212 Quantum CABLEFAST电缆, 带 QUANTUM I/O 端子, 3.7M
    140XTS01203 Quantum CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端
    140XTS01206 Quantum CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端
    140XTS01209 Quantum CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端
    140XTS01212 Quantum CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端
    140XTS10206 Quantum CABLEFAST电缆, 大电流, 带 I/O 端子, 1.8M
    140XTS10215 Quantum CABLEFAST电缆, 大电流, 带 I/O 端子, 4.6M
    Quantum Terminal Block and Accecories  端子连接器及附件
    140XCP20000 Quantum I/O 模块标签
    140XCP40100 Quantum 10槽本版安装架, 125MM
    140XCP40200 Quantum 10槽本版安装架, 20MM
    140XCP50000 Quantum 空槽模块, 无端字条
    140XCP51000 Quantum 空槽模块, 带悬挂门
    140XCP60000 Quantum 端子条跨接器
    140XCP90000 Quantum RAM电池备用模块, 用于ESI061和EHC105
    140XCP90000C Quantum RAM电池备用模块, 用于ESI061和EHC105, CC
    140XSM00200 Quantum 开关量输入模拟器, 用于DAI540或DAI740
    140XSM01000 Quantum 模拟量模拟器, 2个电位器,用于AMM090
    140XTS00100 Quantum 40点模块端子条, IP20
    140XTS00200 Quantum 40点模块端子条
    140XTS00500 Quantum 7点端字条, IP20
    140XTS33200 Quantum IP20 本安型蓝色线端子, 40点
    990XCP98000 Quantum Quantum CPU 电池
    990XTS00300 Quantum B200 转换接头
    Safety Quantum系统
    140CPU65160S Quantum 安全型CPU
    140CPU67160S Quantum 安全型热备CPU
    140SAI94000S Quantum 安全型模拟量输入模板
    140SDI95300S Quantum 安全型开关量输入模板
    140SDO95300S Quantum 安全型开关量输出模板
    该产品种类齐全,品质优良,如您有意购买,欢迎来电咨询!
上海博谊自控电气设备有限公司是专门从事工业自动化产品的销售、服务和系统集成的高科技公司。经销全系列罗克韦尔PLC,伺服系统,低压电器,开关,传感器,变频器,电源,气动元件,工业以太网,编码器,仪器仪表,工具,人机界面自动化产品。公…  更多>>
上海博谊自控电气设备有限公司
联系人:陈一非
地址:上海市延长西路25号
邮编:200072
电话:021-66100983
传真:021-66100983
公司网址:http://boyi1010.net114.com/
  • 林海 在2025/2/24 16:35:00留言
  • 详细留言:你好!我询价洛克韦尔的产品,请帮我联系销售人员或者技术人员
  • 李娜 在2025/2/12 17:33:00留言
  • 陈女士 在2024/9/26 19:58:00留言
  • 详细留言:AB 700-KL22Z-KQ,询价
  • 谢小月 在2024/8/1 14:37:00留言
  • 详细留言:断路器;COM-E-02-01/CE
  • 李志凡 在2024/7/19 10:35:00留言
  • 详细留言:1485G-P5R5-C 20 1485G-P2R5-C 10
