上海博谊自控电气设备有限公司
  • FBC PA M12 FMA 10M魏德米勒联接器
  • 发布时间:2013/5/13 10:56:08   修改时间:2013/5/13 10:56:08 浏览次数:2439
    总线线路, 一端不带联接器, M12, 回路数: 2, 10 m, 孔式 弯, 已屏蔽的: 是, LED: 不, 护套材料: PVC, 卤素: 是
    FBC PA M12 MA 10M
    FBCEX PA M12 FMA 10M
    FBCEX PA M12 MA 10M
    IE-C5DB4RE0100MCAXXX-X
    IE-C5DB4RE0100MCSXXX-X
    SAIL-M8GM8SG-4S20UIE
    PZ 6 ROTO
    IE-FM6D2UE0005MLD4LD4X
    IE-C5ES8UG0100A45A45-X
    TBY-C3-AI16-KS AAI 143
    TRAGEKASTEN MTR 300
    IE-C5ES8UG0200A46XXX-X
    MP TB916120 MS
    TBF 30/30/18 7036
    Insta-Set D + SD
    Insta-Set D + VDE SDI
    THM WRITE ON 49,5/57 WS
    IE-C6ES8VG0250A40A40-E
    SAIL-M12GM12G-CD-15A
    FBCon PA CG 2way OVP
    AIE multi-stripax ASI
    AIE multi-stripax AWG
    SAI-4-F 5P CNOMO 5M
    VPU II 1+1 R 280V/40KA
    SAI-6-MHD-5P M12
    IE-C5ES8UG0150A46A46-X
    SCS 24VDC P1SIL3 DS
    IE-C6FP8LD0800A40A40-D
    WTS4 PT100/2 V 0-10V 0...100C
    WTS4 PT100/3 V 0-10V
    WTZ4 PT100/3 V 0-10V
    WTZ4 PT100/3 C 0/4-20mA
    WTS4 PT100/2 C 4-20mA  0...100C
    SAI-4-MM 5P M12
    POK 10 black
    GP, CB636020, 316L
    FBC PA M12 M 15M
    KTB GP 453820 AB S4 6MM
    IE-C5ES8UG0200A40A40-E
    KTB GP 553515 CD S4 6MM
    SAI-4-F 4P M12 L 5M
    B8E/40T  STI.0,8X2,4 A1
    IE-C6FP8LD0800M40M40-D
    FBCon DP M12 Term 5V
    KTB GP 765015 AB S4 6MM
    SAI-8-F 5P PUR 3M
    IE-C5DD4UG0100A2EA2E-X
    ARB/NP/150NPT(M) /M20(F)
    ARB/NP/150NPT(M) /M25(F)
    ARB/NP/150NPT(M) /M32(F)
    ARB/NP/150NPT(M) /M40(F)
    VSSC4 CL FG 12VDC 0.5A
    VSSC4 CL FG 24VAC/DC 0.5A
    VSSC4 CL FG 48VAC/DC 0.5A
    VSSC4 CL FG 60VAC/DC 0.5A
    VSSC4 SL FG 12VDC 0.5A
    VSSC4 SL FG 24VAC/DC 0.5A
    VSSC4 SL FG 48VAC/DC 0.5A
    VSSC4 SL FG 60VAC/DC 0.5A
    VPU I 1 400V/12,5KA
    Ribbon HSS R 83/300
    IE-C5DS4VG0250MCAA20-E
    IE-C5DS4VG0250MCSA20-E
    EGWD 24VCC 0,1S...1S
    IE-C5DD4UG0150A20A20-E
    IE-C5ES8VG0450A40A40-E
    PowerBox Fuse
    ARB/NP/M50(M) /M32(F)
    KES CF 8/9
    EINSATZP.WM 120QMM
    EINSATZP.WM 50QMM
    EINSATZP.WM 70QMM
    EINSATZP.WM 95QMM
    SAIL-M12G-CD-21A
    HTN 21
    RS F10 8R OUT 24VDC
    IE-FM6D2UE0018MSD0SJ0X
    KLIPPON STB 6 MS HT
    VG M40-1/Exe/d A MS 33-40,6
    IES10-SW8
    EINSATZ MTR 160 10HEX
    EINSATZ MTR 160 120HEX
    EINSATZ MTR 160 150HEX
    EINSATZ MTR 160 16HEX
    EINSATZ MTR 160 25HEX
    EINSATZ MTR 160 35HEX
    EINSATZ MTR 160 50HEX
    EINSATZ MTR 160 70HEX
    EINSATZ MTR 160 95HEX
    DMS manuell 2,0-8,0
    IE-FM6Z2VO0050MST0ST0X
    WSM TOOL AUTOMATIK
    FBC PA M12 M-FM 7M
    SAIL-M12GM12W-CD-10A
    SAIL-M12GM12W-PB-10D
    SAIL-M12WM12G-CD-10A
    SAIL-M12WM12G-PB-10D
    SAIL-M12WM12W-CD-10A
    SAIL-M12WM12W-PB-10D
    SAI-6-F 4P M12 L 10M
    IE-C5ES8VG0160A46A41-X
    KLIPPON STB 1 SS
    FBCon SS PCG 1way
    IE-FM5D2UE0008MST0SD1X
    EINSATZ MTR 160 120WM
    EINSATZ MTR 160 150WM
    EINSATZ MTR 160 50WM
    EINSATZ MTR 160 70WM
    EINSATZ MTR 160 95WM
    ADAP EX 1 1/2NPT-2NPT
    VPU I 1 LCF 280V/12,5KA
    WZTE 21 RED-L
    IE-C5DD4UG0200A2EXXX-X
    CENTRONICS-USB2.0 ADAPT
    IE-CD-V14MRJ/VAPM24V-C-MA
    IE-C5DB4RE0130MCSXXX-E
    KLIPPON K81
    SAI-8-MH-5P M12
    IE-FM5B2VE0002MSD0SD1X
    SAI-6-M 4P M12 Ex ia
    40 E1FW / NP M40 &washer+locknut
    SAI-6-F 5P PUR 10M
    GP 48 N EX
    GP 48 I EX
    KES CF 8 Ex
    SAI-4-MF 5P PUR 5M
    SAI-8-F 5P 2M 0.5/1.0U
    A2L/63S/NPT2-1/2-WM
    RS32ES-T-L H/V
    EINSATZP.HEX10QMM
    EINSATZP.HEX120QMM
    EINSATZP.HEX16QMM
    EINSATZP.HEX25QMM
    EINSATZP.HEX35QMM
    EINSATZP.HEX50QMM
    EINSATZP.HEX70QMM
    EINSATZP.HEX95QMM
    FBC PA M12 FM 25M
    FBCEX PA M12 FM 25M
    CP M SNT3 120W 24V 5A       Plastic foot
    VSSC6 SL LD 12VDC 0.5A
    VSSC6 SL LD 24VAC/DC 0.5A
    VSSC6 SL LD 48VAC/DC 0.5A
    VSSC6 SL LD 60VAC/DC 0.5A
    VSSC6 TR CL 12VDC 0.5A
    VSSC6 TR CL 24VAC/DC 0.5A
    VSSC6 TR CL 48VAC/DC 0.5A
    VSSC6 TR CL 60VAC/DC 0.5A
    VPU I 0  400V/25KA
    IE-C5DD4UG0200MCSA20-E
    THM ET S7 50/12,5 GE
    THM ET S7 50/12,5 TU
    THM ET S7 50/12,5 WS
    THM ET S7 50/25 GE
    THM ET S7 50/25 TU
    SAI-8-F 5P FC 10M GR
    SAI-8-S 5P M12
    IE-FM6D2UE0020MST0ST0X
    MCP PHU
    SAI-8-MHD-4P M12
    SAIS-M23-19P-ST-15M
    RSU 24VAC/DC 6A LP
    SAI-4-F 3P IDC PUR 10M
    SAI-8-F 3P IDC PUR 5M
    KLIPPON K7 VMQ RAL7001
    IE-C6ES8UG0150A46A46-X
    PZ 16 NE
    PZ 16 S
    AIE M-SPX 0.25-1.5 S
    AIE M-SPX 1.5-6.0 S
    AIE multi-spx 0.75-42SL
    SAI-8-F 3P M8 L 10M
    SAI-8-F 4P FC 10M
    SAI-8-F 4P M8 L 5M
    SAI-8-MM 5P M12 UT
    ADAP EX 2NPT-2NPT
    PZ 16 55714
    EF TBF 60/60
    E1XZ/50S/M50-WM
    FBC PA M12 M 25M
    IE-C5ES8UG0190A46A40-X
    SAI-4-F 4P M12 L 10M
    CP M SNT3 120W 24V 5A       Metal foot
    SAI-6-F 4P PUR 15M
    SAIL-M12G-USB-1.5U
    IE-FM6D2UE0016MLD0LD0X
    SAIB-M23-19P-ST-15,0M
    A2L/63/M63-WM
    E1W/50S/NPT1-1/2-WM
    POWERBOX STARTER SET
    SAIB-M23-12P-ST-15M GR
    IE-C6FP8LD0850M40M40-D
    E1W/50S/M50-WM
    IE-FM6D2UE0010MSD0SD0X
    EINSATZP.WM 150QMM
    EINSATZP.WM 185QMM
    EINSATZP.WM 240QMM
    MP NexT 74/55 ss
    MP NexT 76/50 ss
    SAI-4-MMS 4P M12
    E1XZ/50S/NPT1-1/2-WM
    IE-C6FP8LD0850A40A40-D
    ABISOMESSERSATZ/CA100
    CP SNT 55W 24-28V 2.3A
    IE-C5ED8UG0200A40A40-E
    A2LC/63S/M63-NPT2-1/2F-WM
    SAIB-M23-12P-AN-15M
    FBCon SS PCG 1way Limiter
    IE-C6ES8UG0200A40A40-E
    HTX 138
    ACT20P-AI-AO-S
    ACT20P-PVI3-VO3-S
    ADAP EX 2NPT-M63
    GP KLIPPON JB636025SSBU
    IE-FM6D2UE0018MSD0LD0X
    PZ 16
    ABISOLIERMESSERSATZ
    KLIPPON STB 1.1 SS
    RS32ES-D-L H/V
    EINSATZP.WM 10+25QMM
    EINSATZP.WM 16+35QMM
    FBCon PA CG/M12 2way Ex
    IEM-SC
    GP, CB636025, 316L
    GP, CB767630, 304L
    VPU II 2 750V/25KA
    SAI-4-M 4P Exi Z1 OL
    SAIL-M12BG-5-85U
    PROFI SET WERKZEUGE
    EINSATZ MTR 160 185HEX
    EINSATZ MTR 160 185WM
    EINSATZ MTR 160 240HEX
    EINSATZ MTR 160 240WM
    ANDR-EH FIX-STR PJ
    IE-C5ED8UG0100A41A40-X
    SAIB-M23-19P-ST-20M
    TBY-RS-D08-AKB SDV 531
    MP TB484815 SS
    SAI-8-B 5P M12 SL
    SAIL-M12BG-8-50U
    A2LF/NP/40/150NPT + ACNSW
    A2LF/NP/40/150NPT + Washer
    EINSATZ MTR 160 10+25WM
    EINSATZ MTR 160 16+35WM
    RSU 230VAC/DC 6A LP
    A2L/63/NPT2-1/2-WM
    QM642-FULL DEPTH GP PT
    MARKING TAG KIT
    SAI-8-F 4P M8 PUR 5M
    TBF 37/30/18 trsp
    SCHWENKJOCH      MTR 35
    KTB GP 916120 CD S4 6MM
    VPU I 1 R 280V/12,5KA
    SAI-4/6/8-MHF 5P PUR 9M
    SAI-6-M 5P Ex Z22
    SAI-6-F 3P IDC PUR 10M
    KES CF 16/4 MS Ex
    SAI-6-M 5P M12 Ex ia
    STRIPAX 16 ZERT
    A2LC/63S/NPT2-NPT2-1/2F-WM
    THM MT30x 30/52 SI
    THM MT30x 89/60 SI
    FBCon SS DP PCG 1way
    40 E1FW NP 1 1/2"NPT &washer
    SAI-6-MH-5P M12
    MAS RPS
    SAI-8-F 5P PUR 5M SAB
    SAI-4-MMS 5P M12
    A2LC/63S/NPT2-1/2-NPT2F-WM
    FPL 4G2.5/2x3.0/PD/F
    VPU II 3 150V/40KA
    VPU II 2 PV 1000VDC
    GP 48 N EX 3
    GP 48 I EX 3
    WTS4 PT100/3 V 0-10V 0...100C
    WTS4 PT100/3 V 0-10V  variabel
    WTZ4 PT100/2 C 0/4-20mA variabel
    PowerBox SET D11
    40 A2FRC M40(M)/ 1 1/2"NPT(F) &washer+locknut
    40 A2FRC M40(M)/ M40(F) &washer+locknut
    RS D8-I 0...20MA
    SAI-6-F 4P IDC PUR 10M
    KTB GP 484820 CD S4 6MM
    D1.5/2.5-8 BP
    EINSATZP.HEX150QMM
    EINSATZP.HEX185QMM
    EINSATZP.HEX240QMM
    KTB GP 624515 CD S4 6MM
    SAIB-M23-12P-AN-20M
    SAIL-M12BG-4S35Q
    SAIL-M12GM12G-PB-12D
    VSSC6 TR SL LD12VDC0.5A
    VSSC6 TR SL LD24VAC/DC0.5A
    VSSC6 TR SL LD48VAC/DC0.5A
    VSSC6 TR SL LD60VAC/DC0.5A
    SAI-4-M 4P Exi Z1 IL
    FPC 40/60/13 7035
    FPC 40/60/13 trsp
    IE-FM6D2UE0019MSD0LD0X
    A2LC/63S/NPT2-1/2-M63F-WM
    IE-C6FS8UG0300A40A40-G
    KES CF 16/10 MS Ex
    SCHNEIDPLATTE KT45
    RS32ES-T-L H/Z
    RS U-D8 +-10V
    RS U-D8 0...10V
    RS I-D8 0...20MA
    VG M40-EXE MS
    FBCon PA CG 4way Ex
    SAI-4/6/8-MHF 4P PUR 9M
    SAI-6-S 5P M12
    SAIL-M12BG-PB-25D
    VPU II 3 280V/40KA
    VPU II 3 400V/40KA
    SAI-4-FMM-4P M12 10M
    SAI-8-F 3P M5 L10M
    SAI-8-F 4P M5 L5M
    SAI-8-F 5P FC 10M
    SAI-8-MF 4P PUR 10M M12
    PowerBox XL leer Standard
    STB 2 PAINTED
    KLIPPON STB 2 SS
    FBC PA M12 MA-FM 5M
    FBC PA M12 MA-FMA 5M
    FBC PA M12 M-FMA 5M
    FBCEX PA M12 MA-FM 5M
    FBCEX PA M12 MA-FMA 5M
    FBCEX PA M12 M-FMA 5M
    FBC-PA M12 M-M 5M
    ACT20P-AI-AO VC-C
    ACT20P-TI-AO TC-V
    ACT20P-TI-AO TC-C
    ACT20P-TI-AO RTD-V
    ACT20P-TI-AO RTD-C
    ACT20P-AI-AO VC-V
    ACT20P-2CI-2CO-12
    IE-OC-V05M-K21-2RL
    CP NT 192W 24V 8A
    EINSATZ MTR35 10 ISOL.
    EINSATZ MTR35 16 ISOL.
    EINSATZ MTR35 25 ISOL.
    VPU I 1 R 400V/12,5KA
    IE-C5DD4UG0180A20A20-E
    KTB GP 624520 AB S4 6MM
    KES CF 16/16 MS Ex
    Klippon POK 10 Ex
    SAIL-M12GM8SG-4S25UIE
    PZ 1.5 ZERT
    MASTER CHECK 3.2 SET
    IEM-ST
    IE-C5DB4RE0100MCAMCA-E
    IE-C5DB4RE0100MCSMCA-E
    IE-C5DB4RE0100MCSMCS-E
    IE-C5DB4RE0100MCSMSS-E
    IE-FM6D2UE0010MSJ0LD0X
    POK 91 black
    IE-C5DS4VG0300A20A20-E
    QM 30/20/12 7032
    PowerBox XL
    SAI-4-F 5P PUR 15M
    SAIL-M12GM12G-PB-15E
    THERMOMETER 610 LC
    IE-C5DS4VG0300MCSMCS-E
    FüHRUNGSSTüCK    MTR 35
    IE-C5DB4WE0100MCSXXX-E
    WAS5 VMR 1ph
    ACT20P-RTI-AO-S -50-100
    ACT20P-RTI-AO-S -50-150
    ACT20P-RTI-AO-S 0-100
    ACT20P-RTI-AO-S 0-200
    ACT20P-RTI-AO-S 0-250
    ACT20P-RTI-AO-S 0-300
    ACT20P-RI-AO-S 0-5K
    ACT20P-RI-AO-S 0-10K
    ACT20P-TCI-AO-S K 0-250
    ACT20P-TCI-AO-S K 0-500
    ACT20P-TCI-AO-S K 0-1000
    ACT20P-TCI-AO-S K 0-1200
    ACT20P-TCI-AO-S J 0-250
    ACT20P-TCI-AO-S J 0-500
    ACT20P-TCI-AO-S J 0-1000
    ACT20P-TCI-AO-S J 0-1200
    IE-FM6D2UE0020MSD0LD0X
    FBCon DP CG Term 24V
    THM MT30x 101/74 GE
    D4.0-3 BP
    ADAP EX M32-M40
    SAI-8-F 4P PUR 15M
    IE-C5DD4UG0150MCSMCS-E
    FPL 4G6/CUT/HQ4-2/5
    FPL 4G6/CUT/HQ4-2L/5
    VPU I 1RLCF 280V/12,5KA
    GESENK MTR110 10-35DIN
    GESENK MTR110 16-50DIN
    SAI-4-F 4P PUR 20M
    E1W/50/M50-WM
    SAI-8-M 4P M12 Ex ia
    IE-C5DB4RE0150MCSXXX-E
    KTB GP 484820 AB S4 6MM
    KTB GP 987420 CD S4 6MM
    IE-CTI-SC-POF
    KTB GP 916115 AB S4 6MM
    CP SNT 12W 24V 0.5A
    FBCon DP M12 Term 24V
    E1XZ/50/M50-WM
    RS I-D8 4...20MA
    FBCon PA CG 4way
    NexT 50/35 LID KIT
    SAI-8-M 5P Ex Z22
    GP 48 N EX 4
    GP 48 I EX 4
    SAI-8-M16 3P M8
    63S A2F/NP/M63 & washer + locknut
    A2LC/63/M63-M63F-WM
    EINSATZP.HEX300QMM
    A2LCS/32/M32-NPT1F-WM
    IE-C5ES8UG0150A45A45-X
    VPU I 1  400V/25KA
    SAIL-7/8"BG-5-10U
    SAIL-7/8"BW-5-10U
    SAIL-7/8"G-5-10U
    SAIL-7/8"W-5-10U
    IE-C5ES8UG0250A46XXX-X
    SAI-8-F 5P 5M 0.5/1.0U
    SAI-8-MHD-5P M12
    FBCon SS PCG 1way OVP
    CTI 6
    SAI-4-MF 5P PUR 10M
    SAI-8-MF 5P PUR 5M
    ADAP EX M32-1 1/4NPT
    CP T SNT 90W 24V 3,8A
    IE-C5ED8UG0150A46A46-X
    WTZ4 PT100/4 C 0/4-20mA
    WTS4 PT100/4 V 0-10V
    WTS4 PT100/4 C 0/4-20mA
    DK6/ISO/I-V/4..20/0..10
    DK6/ISO/V-V/0..10/0..10
    WavePak DC/DC
    PRINT KIT
    IE-C5DD4UG0150MCSA20-E
    CP SNT 250W 24V 10A
    IE-C5ES8UG0250A40A40-E
    WAZ5 CCC 0-20/0-20mA
    WAZ5 VCC 0-10V/4-20MA
    WAS5 VCC 0-10V/0-20MA
    WAZ5 VVC 0-10V/0-10V
    WAS5 CCC 4-20/0-20MA
    WAS5 CVC 4-20mA/0-10V
    WAS5 CVC 0-20mA/0-10V
    WAS5 VCC 0-10V/4-20MA
    WAZ5 VCC 0-10V/0-20MA
    WAS5 VVC 0-10V/0-10V
    RS D8-I 4...20MA
    SAIL-M12GM12G-PB-14D
    SAI-8-MH-4P M12
    RV 16/9
    IE-OM-V01M-K21-2L
    IE-OM-V01M-K21-2R
    IE-OM-V01M-K21-2S
    FBCon PA CG 4way Limiter
    SIM S7/300 FB4*10 2.0M
    KLIPPON K71 VMQ RAL7001
    TBF 37/30/18 7036
    DK F-U DK5 0-16KHZ 24V
    HDC-KIT-HE 48.150
    SAI-8-MF-5P M12 15V ECO
    SAIL-M23GM23G-19-3.5U
    IE-C5DD4UG0160MCSMCS-E
    A2LC/63/NPT2-1/2-M63F-WM
    CP SNT 250W 24V 10A         Metal foot
    KTB MOPL 6245 S2N
    WTZ4 PT100/3 C 0/4-20mA variabel
    VG NPT1/2"ADE4F 12-21SS
    IE-FM6D2UE0025MST0ST0X
    GP, CB767630, 304L
    MOPL KLIPPON CB 7676  (zinc)
    VSPC 1CL 12VDC R
    VSPC 1CL 24VAC R
    VSPC 1CL 24VDC R
    VSPC 1CL 5VDC R
    VSSC6  CL FG 12VDC 0.5A
    VSSC6  CL FG 24VAC/DC 0.5A
    VSSC6  CL FG 48VAC/DC 0.5A
    VSSC6  CL FG 60VAC/DC 0.5A
    IE-FM6B2VE0020MSD0LD0X
    WAZ5 OLP
    VPU II 2 R 750V/25KA
    RS32ES-S-I-L H/V
    IE-C5DD4UG0150A2EA2E-X
    IE-FM6D2UE0020MLD0LD0X
    SAI-8-F 4P IDC PUR 10M
    E1W/50/NPT2-WM
    CBX 100-USB
    KTB GP 484815 AB S4 6MM
    SAIB-M23-19P-AN-15M
    E1ZF NP/40/M40 &locknut&washer
    IE-C5DD4UG0200A20A20-E
    MP TB765015 SS
    20 TE1FU M20 ss &locknut&washer
    SAI-8-MM 5P M12
    SAI-8-M 5P M12 Ex ia
    E1XZ/50/NPT2-WM
    PZ 6/5
    VERSCHLUSSBOLZEN SET MTR 160
    SAIB-M23-19P-ST-25M
    POK2/KL/VG13.5
    E1W/50S/NPT2-WM
    HDC-KIT-HE 32.140 M
    THM VIN 18/10 WS
    E1XZ/50S/NPT2-WM
    Multimeter 1037
    SAI-8-M 4P IDC Ex ia
    IE-FM6B2VE0001MLDSLD1X
    FPL 4G2.5/CUT/HQ4-2/10
    FPL4G2.5/CUT/HQ4-2L/10
    E1XZ/50S/M50-WM/KIT
    IE-C5DB4RE0120MCSMCS-E
    SAIL-M12WM12W-PB-15D
    FBCon PA CG 4way OVP
    KTB GP 553520 CD S4 6MM
    VG M32-Exe/d A MSN
    VSSC6 TR CLFG 12VDC0.5A
    VSSC6 TR CLFG 24VAC/DC0.5A
    VSSC6 TR CLFG 48VAC/DC0.5A
    VSSC6 TR CLFG 60VAC/DC0.5A
    VSSC6 TR SL FG LD 12VDC
    VSSC6 TR SL FG LD 24VAC/DC
    VSSC6 TR SL FG LD 48VAC/DC
    VSSC6 TR SL FG LD 60VAC/DC
    VPU I 0 N-PE 260V/50KA
    VPU II 3 R 150V/40KA
    VPU II 2 R PV 1000V DC
    AEH-ZANGE
    WTS4 PT100/3 C 0/4-20mA variabel
    CP E SNT 500W 27V 18A U
    Klippon POK 91 Ex
    STRIPAX PLUS 2.5
    SAI-8-F 3P M8 PUR 10M
    CP SNT3 250W 24V 10A
    E1W/50S/M50-WM/KIT
    IE-FM6D2UE0026MST0ST0X
    SAI-8-F 5P PUR 10M
    VSPC 2SL 12VDC R
    VSPC 2SL 24VAC R
    VSPC 2SL 24VDC R
    VSPC 2SL 5VDC R
    THM MT30x 57/27 SI
    QM 20/20/12 7032
    KLIPPON K81 RAL7001
    SAI-8-MH-5P M12 ZF III
    DMSI manuell 0,5-1,7
    KES CF 32
    SAI-8-M 4P Exi Z1 IL
    SAI-8-M 4P Exi Z1 OL
    EMA EG3 SW24 -10...+10V
    SIM S7/300 FB4*10 2.5M
    CP SNT3 250W 24V 10A        Metal foot
    KES CF 8/5 Ex
    K 81 (KEMA)
    A2LC/63/M63-NPT2-1/2F-WM
    SAI-8-F 3P IDC PUR 10M
    HDC IP68 HP 24B ASL
    TRAGETASCHE MTR 160
    SAI-4/6/8-MHF 5P PUR14M
    SAI-8-F 4P M5 L10M
    SAI-8-FMM-4P M12 5M
    SAI-8-MF 5P PUR 10m
    QM662-FULL DEPTH GP P+
    KES CF 8/8 Ex
    THM MT30X 8/8 GE
    VG M50-1/Exe/d A MSN 39,4-46,7
    VG M50-1/Exe/d A MSN 45,7-53,2
    ANTRIEBSREP. SET MTR 35
    IE-C6ES8UG0250A40A40-E
    IE-FM6D2UE0015MSD4SD4X
    THM WRITEON 25/140 BL
    THM WRITEON 25/140 VAR.
    SAI-8-MMS 4P M12
    HTX ST 214  ITALIEN
    A2LC/63S/NPT2-1/2-NPT2-1/2F-WM
    DKPL 35 24VDC SW-0002
    DKPL 35 24VDC SW-0003
    DKPL 35 24VDC SW-0502
    IE-5CC4x2xAWG26/7-PVC
    IE-5IC4x2xAWG24/1-PVC
    FBCon PA CG/M12 2way OVP
    SAI-8-F 3P M8 L 15M
    QM 30/30/12 7032
    THM MT30X 15/4 GE/M
    SIM S7/300 FB40 10.0M
    HTI 15 ZERT
    IE-FM6D2UE0027MST0ST0X
    A2LCFF 100NPT/NP/32/M32 + LOCKNUT & IP W
    A2LCFF M32/NP/32/M32
    ADAP EX 1 1/2NPT-M40
    COPL POK 10
    DK U-F DK5 0-10V
    WTS4 PT100/4 V 0-10V 0...100C
    WTS4 THERMO
    WTZ4 THERMO
    SAIL-M8GM8SG-4S30UIE
    SAIS-M23-19P-ST-25M
    IE-FM6B2VE0010MSD4SD4X
    SAI-6-F 5P PUR 15M
    TT 1064RS
    IE-FM5D2UE0030MST0ST0X
    HTX LWL
    RS32ES-D-I-L H/V
    A2LC/63/NPT2-1/2-NPT2-1/2F-WM
    E1WSF/20S/M20+LOCKNUT&WASHER
    SS316 E1XSF/20s/M20 Locknut+washer
    FBCon SS PCG 4way
    THM WRITEON 25,4/62 WS
    VPU II 3 600V/25KA
    VPU II 3 PV 1000VDC
    STB2 PHT M1DES NO LUGS
    ABISOMESSSATZ CFX 2.5M
    THM WH 15/6 WS
    CP SNT 250W 48V 5A
    RSM 8R 24VDC LP GEM.-
    RSM 8RS 24VDC LP GEM.-
    IE-FM6D2UE0024MSD0LD0X
    VPU I 1 R  400V/25KA
    SMPHS M40c/w Nut & TP Washer
    THM GEW FLAG 54/8 WS
    RSM 8RS 24VDC GEM.+
    RSM 8RS 24VUC LP
    HTN 21 M. AN
    KES CF 16/19 MS Ex
    SAI-8-F 4P M8 L 10M
    E1XF/40/M40+locknut &IP washer
    ELEKTRONIK ZANGEN SET
    E1WXZF/NP/40/M40 + Locknut & IP Wash
    CP SNT 300W 24V 12.5A       Plastic foot
    VSPC 3/4WIRE 24VDC
    VSPC 3/4WIRE 5VDC
    SIM S7/300 FB4*10 3.0M
    CP A Battery 24V DC 7.2Ah
    SAI-8-F 4P M8 PUR 10M
    CP SNT 250W 48V 5A          Metal foot
    WAS2 CMA 20/25/30A uc
    FBCon PA CG/M12 2way Limiter
    WAZ2 CMA 40/50/60A uc
    WAS2 CMA 5/10A uc
    WAZ2 CMA 5/10A uc
    WAZ2 CMA 20/25/30A uc
    CP-SNT 380-480VAC/24V
    IE-C5ED8UG0260A40A40-E
    SAIL-M23BG-17-10SB
    VPU II 3 R 280V/40KA
    VPU II 3 R 400V/40KA
    IE-C5ES8VG0600A40A40-E
    MAS RPSH
    E1XZSF/20S/M20&washer+locknut
    THM MT30x 15/5,08 GE
    THM MT30x 17/9 WS
    THM MT30x 8/8 WS
    THM MT30X 101/74 GE/G
    SAIB-M23-19P-AN-20M
    SAI-8-MMS 5P M12
    Screwty-M12-DM
    SAI-8-SHB 5P FC
    SMS SIZA EG4 24VDC
    SAI-8-F 5P 10M 0.5/1.0U
    Screwty-M8 F-DM
    CP SNT 300W 24V 12.5A       Metal foot
    IE-FM6D2UE0023MLD0LD0X
    TT 864 RS
    WAS5 DC/Alarm
    WAZ5 DC/Alarm
    CP M SNT 250W 24V 10A       Plastic foot
    A2LCS/40/M40-M40F-WM
    Screwty-M12 F-DM
    SAI-10-F 3P M8 L 5M
    NexT 98/74 LID KIT
    SERVICE CASE
    QM 40/30/12 7032
    FBCon SS DP PCG Term 24V
    757 TYPE M40 ss &locknut&washer
    KES CF 8/9 Ex
    RSM 16-NV/1RT 24V(+/-)
    WAZ5 PRO RTD
    WAS5 PRO RTD
    WTZ4 PT100/2 V 0-10V  variabel
    WTS4 PT100/2 C 0/4-20mA variabel
    E1WSF/20/M20 +locknut &IP washer
    ADAP EX 2 1/2NPT-M40
    SAIB-M23-19P-ST-30M
    KTB MOPL 7650 S2N
    SAIL-M12BG-4S45Q
    SAIL-M12BW-4S45Q
    CP T SNT 70W 12V 6A
    E1W/50/M50-WM/KIT
    PJ PRO VP SET
    ADAP EX M50-1 1/4NPT
    CP M SNT 250W 24V 10A       Metal foot
    50S A2FRC M50(M)/ 1 1/2"NPT(F) &washer+locknut
    ADAP EX 2 1/2NPT-1 1/2
    ADAP EX 2 1/2NPT-1 1/4
    ADAP EX 2 1/2NPT-1/2
    ADAP EX 2 1/2NPT-1NPT
    ADAP EX 2 1/2NPT-2NPT
    ADAP EX 2 1/2NPT-3/4NPT
    ADAP EX 2 1/2NPT-M16
    ADAP EX 2 1/2NPT-M20
    ADAP EX 2 1/2NPT-M25
    ADAP EX 2 1/2NPT-M32
    ADAP EX 2 1/2NPT-M50
    ADAP EX 2 1/2NPT-M63
    SAI-4-F 5P PUR 20M
    E1XZ/50/M50-WM/KIT
    TBY-C3-DI32-AKB ADV 151
    IE-FM6B2VE0025MSD0SD0X
    WTS4 PT100/2 V 0-10V  variabel
    K8
    Screwty-M8-DM
    WZTE 2
    FBCon SS PCG 4way Limiter
    IE-C5ES8UG0200A45A45-X
    50S E1FW NP 2"NPT &washer
    CP M SNT3 250W 24V 10A      Plastic foot
    THM MT30X 20/100 WS
    EINSATZ MTR 160 10DIN
    EINSATZ MTR 160 16DIN
    EINSATZ MTR 160 25DIN
    EINSATZ MTR 160 35DIN
    EINSATZ MTR 160 50DIN
    EINSATZ MTR 160 70DIN
    SAI-4-MMS 5P M12 1:1
    SAI-4-FMM-4P M12 5MA
    FBC PA M12 M-FM 15M
    SAI-6-F 4P PUR 20M
    RSM16C-1RT H/Z
    MAS DC/DC select HI
    C024-04 WAS5 PRO RTD
    CRIMP-SET 6 Z ATORN
    SAI-ASI-L-M12-4I V3
    SAI-ASI-L-M8-4I V3
    ACT20M-CI-CO-S
    ACT20M-AI-AO-E-S
    VPU I 1 N-PE 260V/50KA
    TBF 49/30/21 trsp
    SAI-4/6/8-MHF 5P PUR16M
    SAI-8-F 5P NPN-PNP 5M
    IE-C5ES8UG0300A40A40-E
    DMSI manuell 2,0-8,0
    CP M SNT3 250W 24V 10A      Metal foot
    KTB GP 624520 CD S4 6MM
    IE-C5ES8UG0300A20A20-E
    THM MT30X 65/35 SI/M
    SAIL-M12GM12G-CD-25A
    IE-FM5B2VE0010MSD0SD1X
    CR-1B/NP/40/M40 £?lucknut &washer
    THM MT30x 101/150 SI/G
    THM MT30X 101/48 GE/M
    THM MT30X 101/48 SI/M
    THM MT30X 101/48 WS/M
    THM MT30x 101/74 si
    THM MT30X 15/6 GE/M
    THM MT30X 15/6 SI/M
    THM MT30X 15/6 WS/M
    THM MT30x 16/7 GE
    THM MT30X 18/6 GE/M
    THM MT30X 18/6 SI/M
    THM MT30X 18/6 WS/M
    THM MT30X 18/9 GE/M
    THM MT30X 18/9 SI/M
    THM MT30X 18/9 WS/M
    THM MT30X 20/8 GE/M
    THM MT30X 20/8 SI/M
    THM MT30X 20/8 WS/M
    THM MT30X 25/12 GE/M
    THM MT30X 25/12 SI/M
    THM MT30X 25/12 WS/M
    THM MT30X 26/10 GE/M
    THM MT30X 26/10 SI/M
    THM MT30X 26/10 WS/M
    THM MT30X 30/20 GE/M
    THM MT30X 30/20 SI/M
    THM MT30X 30/20 WS/M
    THM MT30X 32/9 SI/M
    THM MT30X 32/9 WS/M
    THM MT30x 38,1/31,75 SI
    SAI-4-F 5P CNOMO 10M
    SAI-8-F 5P CNOMO 5M
    IE-C5DB4RE0140MCSMCS-E
    RSM16-NV/2RT 24V (+/-)
    RSM 16C-1RT H/V
    VSPC RS485 2CH
    ERME KT 55
    CTI 6 G
    SAIB-M23-19P-AN-30M
    GP, CB767630, 316L
    SAI-4/6/8-MHF 4P PUR14M
    IE-C6FS8UG0350A40A40-G
    ACT20P-RTI-2AO-S -50-100
    ACT20P-RTI-2AO-S -50-150
    ACT20P-RTI-2AO-S 0-100
    ACT20P-RTI-2AO-S 0-200
    ACT20P-RTI-2AO-S 0-250
    ACT20P-RTI-2AO-S 0-300
    ACT20P-RI-2AO-S 0-5K
    ACT20P-RI-2AO-S 0-10K
    ACT20P-TCI-2AO-S K 0-250
    ACT20P-TCI-2AO-S K 0-500
    ACT20P-TCI-2AO-S K 0-1000
    ACT20P-TCI-2AO-S K 0-1200
    ACT20P-TCI-2AO-S J 0-250
    ACT20P-TCI-2AO-S J 0-500
    ACT20P-TCI-2AO-S J 0-1000
    ACT20P-TCI-2AO-S J 0-1200
    WAS1 CMA 1A ac /4-20mA
    KLIPPON STB 2.1 SS
    WTZ4 PT100/4 C 0/4-20mA variabel
    WAS5 CCC HF 0-20/0-20MA
    WAS5 CVC HF 0-20/0-10V
    WAS5 CCC HF 4-20/0-20MA
    WAS5 CVC HF 4-20/0-10V
    WAS5 VCC HF 0-10/4-20MA
    WAS5 VVC HF 0-10/0-10V
    WAZ5 VVC HF 0-10/0-10V
    WAS5 PRO Thermo
    WAZ5 PRO Thermo
    WAS5 VVC HF +-10V/+-10V
    FBC PA M12 MA-FM 10M
    FBC PA M12 MA-FMA 10M
    FBC PA M12 M-FMA 10M
    FBCEX PA M12 MA-FM 10M
    FBCEX PA M12 MA-FMA 10M
    FBCEX PA M12 M-FMA 10M
    FBC-PA M12 M-M 10M
    SAIB-M23-12P-AN-30M
    RS F40 16RS OUT 24VDC
    WAS5 DIX DOS DCS
    WAS5 DOX1 DIS DCS
    WAS5 DOX2 DIS DCS
    WAS5 DIX DOS DCT
    SAI-8-F 5P 15M 0.5/1.0U
    A2LF/50/200NPT + ACNSW
    A2LF/50S/200NPT + ACNSW
    E1WF/NP/50/M50 + Locknut & IP Washer
    E1WF/NP/50s/M50 + Locknut & IP Washer
    VSPC 2SL 12VAC
    VSPC 2SL 12VDC
    VSPC 2SL 24VAC
    VSPC 2SL 24VDC
    VSPC 2SL 48VAC
    VSPC 2SL 5VDC
    VSPC 2SL 60VAC
    A2LC/63S/NPT2-NPT2F-WM
    DME 100TX-4RJ TS35 Ether. Cat5
    SAI-8-F 4P PUR 3M
    KTB GP 624515 AB S4 6MM
    IE-OM-V05M-K21-2L
    IE-OM-V05M-K21-2R
    IE-OM-V05M-K21-2S
    Powerbox 24V
    PowerBox-01
    SAIS-M23-19P-AN-10M
    SAIS-M23-19P-ST-10M
    TBY-RS-DI16-AKB SDV 144
    HDC IP68  24B TO
    KES C RS T 50 EX
    EINSATZ MTR35 10HEX
    EINSATZ MTR35 16HEX
    EINSATZ MTR35 16WM
    EINSATZ MTR35 25ALUHEX
    EINSATZ MTR35 25HEX
    EINSATZ MTR35 25WM
    EINSATZ MTR35 35ALUHEX
    EINSATZ MTR35 35HEX
    EINSATZ MTR35 35WM
    EINSATZ MTR35 50WM
    EINSATZ MTR35 6HEX
    IE-C6ES8UG0120A45A40-X
    FPL 4G4/CUT/HQ4-2/5
    FPL 4G4/CUT/HQ4-2L/5
    SAI-8-M 5P FC
    SAI-8-M 5P M12 OL2
    SAI-8-M 5P M12 ZF III
    SAI-8-SH 5P FC
    SAIB-M23-19P-ST-10M
    GP KLIPPON JB525025SSBU
    EINSATZ MTR35 50HEX
    EINSATZ MTR35 6WM
    AM ASI-Spezial
    IE-C5DD4UG0130A20A20-E
    TBF 30/30/18 trsp
    A2LC/63S/NPT2-M63F-WM
    EINSATZ MTR35 10WM
    E1XZ/40/M40-WM/KIT
    DMS manuell 0,5-1,7
    IE-C5ED8UG0100A46A46-X
    SAIL-M12GM12G-PB-15D
    MAZ DC/DC select
    SAI-4/6/8-MHF 5P PUR 6M
    SAI-8-F 5P FC 2M
    IE-C5DB4RE0080MCSMCS-E
    IE-C6FS8UG0200A40A40-G
    CP M SNT 180W 24V 7.5A      Plastic foot
    ACT20P-CI-2CO
    Ribbon HSS WR 90/300
    IE-C5DD4UG0100MCSA20-E
    RS D8-U +-10V
    RS D8-U 0...10V
    SAI-6-MHD-4P M12
    KTB GP 553520 AB S4 6MM
    KTB GP 765020 CD S4 6MM
    K72 (KEMA)
    VSSC6  CL 24VAC/DC 0.5A
    VSSC6  CL 48VAC/DC 0.5A
    VSSC6 CL 12VDC 0.5A
    VSSC6 CL 60VAC/DC 0.5A
    CR-1B/NP/32/M32 £?lucknut &washer
    SAI-8-F 3P M8 PUR 5M
    SAI-8-M23 4P M8
    A3LSF /20/M20c/w Nut & TP Washer
    SERVICEPACK MCP PLUS
    KTB GP 403020 CD S4 6MM
    VGM40-SS68 20-32 BG
    KLEMMBACKE OB. CRIMPFIX
    ADAP EX 2NPT-1NPT
    IE-C5ES8UG0100A40A25-X
    CP A Battery 24V DC 3.4Ah
    SAIB-M23-19P-AN-10M
    40 A2FRC 1 1/2"NPT(M)/ 1 1/2"NPT(F) &washer
    CP SNT3 120W 24V 5A
    KES CF 8/5
    SAI-8-S16/19P 4P M5
    FBCon PA CG 2way Limiter
    HTG 58
    HTG 59
    STEMPEL 95-150QMM
    ADAP EX M63-1 1/2NPT
    ADAP EX M63-1 1/4NPT
    ADAP EX M63-1/2NPT
    ADAP EX M63-1NPT
    ADAP EX M63-3/4NPT
    Klippon POK 12 Ex
    WAS2 CMA 40/50/60A uc
    THM MT30X 101/48 VAR.
    THM MT30X 101/74 VAR.
    THM MT30X 15/6 VAR.
    THM MT30X 17/9 GE/M
    THM MT30X 18/6 VAR.
    THM MT30X 18/9 VAR.
    THM MT30X 20/8 VAR.
    THM MT30X 26/10 VAR.
    THM MT30X 30/20 VAR.
    THM MT30X 32/9 VAR.
    CP M SNT 180W 24V 7.5A      Metal foot
    ACT20P-CI-2CO-OLP
    FBCon PA CG/M12 1way OVP
    HTG 58/59
    PZ 4
    KLIPPON K71 VMQ
    WAS5 CCC 2OLP
    IE-C6ES8UG0150A46A40-X
    ADAP EX 1 1/2NPT-M63
    MAZ Thermo-K 0...1000°C Output select
    MAZ Thermo-J 0...700°C Output select
    ADAP EX M32-1NPT
    HTG 174
    HTG 58/59 RADIALL
    IE-C6ES8VG0200A41A40-X
    M-D-STRIPAX +6 MEHA
    SAIB-M23-12P-ST-15,0M
    SAIL-M12GM12G-CD-10B
    SAIL-M12GM12G-PB-10E
    SAIL-M12GM12W-CD-10B
    SAIL-M12GM12W-PB-10E
    SAIL-M12WM12G-CD-10B
    SAIL-M12WM12G-PB-10E
    SAIL-M12WM12W-CD-10B
    SAIL-M12WM12W-PB-10E
    KES CF 8/8
    RS32ES-D-L H/Z
    EINSATZ MTR110 16+35ALU
    EINSATZ MTR110 25+50ALU
    EINSATZ MTR110 70HEX
    ADAP EX M50-M32
    ADAP EX 2NPT-1/2NPT
    ADAP EX 2NPT-3/4NPT
    ADAP EX 2NPT-M16
    ADAP EX 2NPT-M20
    ADAP EX 2NPT-M25
    ADAP EX 2NPT-M32
    ADAP EX 2NPT-M40
    ADAP EX 2NPT-M50
    A2LCS/40/M40-NPT1-1/2F
    757 TYPE M32 ss &locknut&washer
    VPU II 2 R 280V/40KA
    VPU II 2 R 400V/40KA
    IE-C5ES8UG0210A46A40-X
    RS8ESA/I-M-DP SD/V
    LASERAUFKLEBER TOOLOVA
    CP SNT3 120W 24V 5A         Metal foot
    MCZ VFC 0-10V
    IE-C5ED8UG0100A44A44-X
    MCZ CFC 0-20MA
    FBC PA M12 MA-FM 2M
    FBC PA M12 MA-FMA 2M
    FBC PA M12 M-FMA 2M
    FBCEX PA M12 MA-FM 2M
    FBCEX PA M12 MA-FMA 2M
    FBCEX PA M12 M-FMA 2M
    FBC-PA M12 M-M 2M
    LP-Bgr. PJ Steuerung
    VPU I 1 280V/12,5KA
    D1.5/2.5-4 BP
    IE-FM5D2UE0010MSD0SD0X
    SAI-6-F 4P IDC PUR 5M
    IE-C5DB4RE0100MSSXXX-E
    IE-C5DD4UG0140A20A20-E
    KTB GP 987420 AB S4 6MM
    WSM SERVICE BOX KOMP.
    IE-FM6D2UE0010MST0ST0X
    SAI-4-M 5P M12 Ex ia
    SAIL-7/8"BG-4-10U
    SAIL-7/8"BW-4-10U
    SAIL-7/8"G-4-10U
    SAIL-7/8"W-4-10U
    SIM S7/300 FB40 5.0M
    IE-FM5D2UE0008MSD4SD4X
    Adaptor 737  M40(M) x1 1/2”NPT(F)
    GP, CB636025, 316L
    SAI-8-M-4P M12 DIP
    VPU II 2 R 600V/25KA
    VPU II 2 R PV 600V DC
    SAI-8-F 5P PUR 5M
    THM MT30X 101/48 GE/G
    IE-FM5B2VE0010MLD0LD0X
    Adaptor737 M32(M)x1"NPT(F)
    SAI-8-F 4P FC 10M GR
    D1.5/2.5-5 BP
    DKPL 35 24VDC SW-0001
    WAZ5 CCC LP 0-20/0-20mA
    E2WF/NP/32/M32 + Locknut & IP Washer
    SAI-4-F 4P M5 L10M
    SAI-4-M 5P Ex Z22
    SAI-8-F 3P M5 L5M
    SAI-8-F 5P FC 5M
    SAI-8-M 4P M8
    SAI-4/6/8-MHF 4P PUR 6M
    KLIPPON STB 5 MS HT
    SAIL-M12BW-4S40Q
上海博谊自控电气设备有限公司是专门从事工业自动化产品的销售、服务和系统集成的高科技公司。经销全系列罗克韦尔PLC,伺服系统,低压电器,开关,传感器,变频器,电源,气动元件,工业以太网,编码器,仪器仪表,工具,人机界面自动化产品。公…  更多>>
上海博谊自控电气设备有限公司
联系人:陈一非
地址:上海市延长西路25号
邮编:200072
电话:021-66100983
传真:021-66100983
公司网址:http://boyi1010.net114.com/
  • 林海 在2025/2/24 16:35:00留言
  • 详细留言:你好!我询价洛克韦尔的产品,请帮我联系销售人员或者技术人员
  • 李娜 在2025/2/12 17:33:00留言
  • 陈女士 在2024/9/26 19:58:00留言
  • 详细留言:AB 700-KL22Z-KQ,询价
  • 谢小月 在2024/8/1 14:37:00留言
  • 详细留言:断路器;COM-E-02-01/CE
  • 李志凡 在2024/7/19 10:35:00留言
  • 详细留言:1485G-P5R5-C 20 1485G-P2R5-C 10
