昆山德旭鼎进出口贸易有限公司
  • FAIRCHILD减压阀/FAIRCHILD调压阀
  • 发布时间:2007/8/11 1:07:11   修改时间:2007/8/11 1:07:11 浏览次数:4612
  • FAIRCHILD电气转换器
    FAIRCHILD是一家生产精密仪器的美国公司, 它有两个分部:工业控制部和 机械动力变换部。 它的技术和产品质量在世界上是领先的, 它已有50多年的制造经验了。它一直为加工业和机床工业提供高精度、高质量及高可靠性的产品。它的产品主要有:
    ·FAIRCHILD气压调节器
    ·FAIRCHILD过滤调节器
    ·FAIRCHILD M/P 转换器
    ·FAIRCHILD空气体积增压器
    ·FAIRCHILD气体继电器
    ·FAIRCHILD电流-压力变换器
    ·FAIRCHILD电压-压力变换器
    ·FAIRCHILD压力-电流变换器
    FAIRCHILD在全世界范围内都有经销商,提供本地化服务。我们工厂的工程师可为您解决个种疑难问题。提供最适合您需求的产品。我们的信誉是建立在高质量的产品、优质的服务以及对客户需求的快速响应上.
    我们的能量变送器可提供高质量的机械变速,变速差。这项技术是我们发展的基础,它使公司在能量变送领域处于领先地位。
    50年来,工业界信赖我们的能量变送设备,因为它在速度控制和位置控制方面的可靠性能。我们的变送器广泛应用于印刷、造纸、包装和纺织的联合张力控制和精确的速度调整。另外我们的变送器还用于机床、输送机、同步及其它OEM应用。出厂的每一个变送器都经过了针对其应用的优化。
    FAIRCHILD已在业界建立了良好的声誉,因为它有高质量的产品、精湛的客户服务、交货及时、有竟争力的价格以及对客户需求的及时响应。
       For 50 years, Fairchild Industrial Products Company has maintained an excellent reputation as a leading manufacturer of precision, high quality, pneumatic and electro-pneumatic controls and precision power transmission equipment. Fairchild has built its reputation by providing quality products, excellent customer service, quick delivery, and immediate response to our customers.
    The Industrial Controls Division designs and manufactures the most complete line of precision pneumatic pressure regulators, filter regulators, M/P converters, air volume boosters, pneumatic relays and current to pressure, voltage to pressure, and pressure to current transducers in the industry.
    The Power Transmission Division offers the highest quality mechanical variable speed, variable speed differential, and phase/timing/position correction differentials in the industry.
    About Fairchild Industrial Products Company
    Electro-Pneumatic Transducers
    Fairchild precision I/P, E/P, D/P & P/I transducers are accurate, compact, lightweight and have fast response. The extensive combinations of inputs and outputs available let you make the ideal choice for your control applications. Most models carry standard agency approvals and many are approved for outdoor, explosion-proof and intrinsically safe applications.
    Fairchild Products offers an Automatic Drain Filter Series including Pre-filters .5 microns, Coalescing Filters 0.3 micron and 0.01 micron to remove 99.9% of oil mist in an aluminum or zinc body. Fairchild Industrial Products Company is best known for the Precision, High Quality, Pneumatic, and Electro-Pneumatic Control.
    Fairchild's Product mix consists of: I/P Transducers, E/P Transducers, Precision Pressure Regulators, Pneumatic Relays and Pneumatic Volume Boosters. The Regulators include: Vacuum Regulators, High Flow Precision Regulators, Midget Precision Regulators, Subminiature Precision Regulators, Stainless Steel Pressure Regulators, Corrosion Resistant Precision Regulators and Multistage Multipurpose Precision Regulators.
    Fairchild仙童T5700系列变送器
    Model T5700 Transducer
    T5700-4, T5700-40 4-20mA & 10-50mA, 3-15 psig
    T5700-9, T5700-90 1-5 VDC & 1-9VDC, 3-15 psig
    Fairchild仙童T5200 变送器
    Model T5200 Transducer
    T5200-4, T5200-40 4-20mA & 10-50mA, 3-15 psig
    T5200-5, T5200-50 1-5 VDC, 3-15 psig
    T5200-9, T5200-90 1-9VDC, 3-15 psig
    Fairchild仙童T5220 变送器
    Model T5220 Transducer
    T5220-4, T5220-40 4-20mA & 10-50mA, 3-15 psig
    T5220-5, T5220-50 1-5 VDC, 3-15 psig
    T5220-9, T5220-90 1-9VDC, 3-15 psig
    Fairchild仙童T6000标准变送器
    Model T6000 Standard Transducer
    ELECTRICAL CONNECTION:1/2"FNPT Conduit
    DIN Connector Terminal Strip
    Fairchild仙童T7800高性能变送器
    Model T7800 High Performance Transducer
    Fairchild仙童TFXI7800防爆变送器
    Model TFXI7800 Explosion Proof Nema 4X I/P Transducer
    TFXI7800-401 4-20mA, 3-15 & 3-27 & 6-30 psig 1/2"FNPT Conduit
    Pneumatic Pressure Regulators
    A wide selection of pressure ranges and flow capacities let you specify the pneumatic pressure regulator model that exactly meets the needs of instrument or general industrial control application. Engineering and manufacturing excellence assure the sensitivity, accuracy, low output droop, drift-free settings, and immunity from supply pressure variations required in a precision pressure regulator.
    Model 10系列
    Part Number Description
    10202 1/4"NPT, 0-20 psig Adjustable Output
    10203 3/8"NPT, 0-20 psig Adjustable Output
    10212 1/4"NPT, 0-2 psig Adjustable Output
    10213 3/8"NPT, 0-2 psig Adjustable Output
    10222 1/4"NPT, 0-10 psig Adjustable Output
    10223 3/8"NPT, 0-10 psig Adjustable Output
    10232 1/4"NPT, 0.5-30 psig Adjustable Output
    10233 3/8"NPT, 0.5-30 psig Adjustable Output
    10242 1/4"NPT, 1-60 psig Adjustable Output
    10243 3/8"NPT, 1-60 psig Adjustable Output
    10262 1/4"NPT, 2-150 psig Adjustable Output
    10263 3/8"NPT, 2-150 psig Adjustable Output
    10272 1/4"NPT, 3-200 psig Adjustable Output
    10273 3/8"NPT, 3-200 psig Adjustable Output
    10282 1/4"NPT, 5-300 psig Adjustable Output
    10283 3/8"NPT, 5-300 psig Adjustable Output
    10292 1/4"NPT, 5-400 psig Adjustable Output
    10293 3/8"NPT, 5-400 psig Adjustable Output
    Fairchild仙童10系列高流量精确调节器
    Model 10 High Flow Capacity Precision Regulator
    Fairchild仙童30系列小型精确调节器
    Model 30 Midget Precision Regulator
    30212 1/4"NPT, 0-2 psig Adjustable Output
    30213 3/8"NPT, 0-2 psig Adjustable Output
    30222 1/4"NPT, 0-10 psig Adjustable Output
    30223 3/8"NPT, 0-10 psig Adjustable Output
    30232 1/4"NPT, 0.5-30 psig Adjustable Output
    30233 3/8"NPT, 0.5-30 psig Adjustable Output
    30242 1/4"NPT, 1-60 psig Adjustable Output
    30243 3/8"NPT, 1-60 psig Adjustable Output
    30252 1/4"NPT, 2-100 psig Adjustable Output
    30253 3/8"NPT, 2-100 psig Adjustable Output
    Fairchild仙童4000A系列 超高流量/低泄漏 精确调节器
    Model 4000A Very High Flow / Low Bleed Precision Regulator
    4023, 4023A 3/8"NPT, 0.5-10 psig Adjustable Output
    4024, 4024A 1/2"NPT, 0.5-10 psig Adjustable Output
    4026, 4026A 3/4"NPT, 0.5-10 psig Adjustable Output
    4033, 4033A 3/8"NPT, 0.5-30 psig Adjustable Output
    4034. 4034A 1/2"NPT, 0.5-30 psig Adjustable Output
    4036, 4036A 3/4"NPT, 0.5-30 psig Adjustable Output
    4043, 4043A 3/8"NPT, 1-60 psig Adjustable Output
    4044, 4044A 1/2"NPT, 1-60 psig Adjustable Output
    4046, 4046A 3/4"NPT, 1-60 psig Adjustable Output
    4063, 4063A 3/8"NPT, 2-150 psig Adjustable Output
    4064, 4064A 1/2"NPT, 2-150 psig Adjustable Output
    4066, 4066A 3/4"NPT, 2-150 psig Adjustable Output
    4073, 4073A 3/8"NPT, 5-250 psig Adjustable Output
    4074, 4074A 1/2"NPT, 5-250 psig Adjustable Output
    4076, 4076A 3/4"NPT, 5-250 psig Adjustable Output
    High capacity, fast response and stability are important features of these Fairchild Industrial air volume boosters. A wide range of signal to output pressure ratios, pipe sizes, and flow capacities provide a versatile selection to meet your specific needs. All Fairchild pneumatic volume boosters have a balanced supply valve, the ability to add gages and the option to add a tapped exhaust to most models in our pneumatic volume booster product offering.
    Fairchild仙童20系列高容量体积放大器
    Model 20 High Capacity Volume Booster
    208102 1/4"NPT, 1:6 Input to Output Ratio
    208103 3/8"NPT, 1:6 Input to Output Ratio
    20812 1/4"NPT, 1:1 Input to Output Ratio
    20813 3/8"NPT, 1:1 Input to Output Ratio
    20822 1/4"NPT, 1:2 Input to Output Ratio
    20823 3/8"NPT, 1:2 Input to Output Ratio
    20832 1/4"NPT, 1:3 Input to Output Ratio
    20833 3/8"NPT, 1:3 Input to Output Ratio
    20842 1/4"NPT, 2:1 Input to Output Ratio
    20843 3/8"NPT, 2:1 Input to Output Ratio
    20852 1/4"NPT, 3:1 Input to Output Ratio
    20853 3/8"NPT, 3:1 Input to Output Ratio
    20862 1/4"NPT, 1:4 Input to Output Ratio
    20863 3/8"NPT, 1:4 Input to Output Ratio
    20872 1/4"NPT, 4:1 Input to Output Ratio
    20873 3/8"NPT, 4:1 Input to Output Ratio
    20882 1/4"NPT, 1:5 Input to Output Ratio
    20883 3/8"NPT, 1:5 Input to Output Ratio
    20892 1/4"NPT, 5:1 Input to Output Ratio
    20893 3/8"NPT, 5:1 Input to Output Ratio
    Fairchild仙童4500A系列超高容量体积放大器
    Model 4500A Very High Capacity Volume Booster
    4513, 4513A 3/8"NPT, 1:1 Input to Output Ratio
    4514, 4514A 1/2"NPT, 1:1 Input to Output Ratio
    4516, 4516A 3/4"NPT, 1:1 Input to Output Ratio
    4523, 4523A 3/8"NPT, 1:2 Input to Output Ratio
    4524, 4524A 1/2"NPT, 1:2 Input to Output Ratio
    4526, 4526A 3/4"NPT, 1:2 Input to Output Ratio
    4533, 4533A 3/8"NPT, 1:3 Input to Output Ratio
    4534, 4534A 1/2"NPT, 1:3 Input to Output Ratio
    4536, 4536A 3/4"NPT, 1:3 Input to Output Ratio
    4543, 4543A 3/8"NPT, 2:1 Input to Output Ratio
    4544, 4544A 1/2"NPT, 2:1 Input to Output Ratio
    4546, 4546A 3/4"NPT, 2:1 Input to Output Ratio
    4553, 4553A 3/8"NPT, 3:1 Input to Output Ratio
    4554, 4554A 1/2"NPT, 3:1 Input to Output Ratio
    4556, 4556A 3/4"NPT, 3:1 Input to Output Ratio
    Pneumatic Relays
    This extensive line of Fairchild air relays serve a multitude of pneumatic control applications: positive biasing, positive and negative biasing, infinitely adjustable ratio, reversing, averaging and computing, high and low pressure selectors, and high and low pressure limiting, and other options are available for these pneumatic relays.
    Fairchild Accessories
    These Fairchild accessories have been designed and selected to complement and function with units from our complete line of control products. Transducer manifold and rack kits, pressure gages, panel loading stations, calibrators, and automatic drain filters, offer the same high quality and precision typical of all Fairchild Industrial Division products.
    100508__REGULATOR
    10202L__REGULATOR
    10202-T__PRESSURE REGULATOR 0-20PSIG 1/4IN NPTF TAMPERPROOF
    10203__REGULATOR
    10212__REGULATOR
    10222-T__PRESSURE REGULATOR 0-10PSIG 1/4IN NPTF TAMPERPROOF
    10232__PRESSURE REGULATOR 0.5-30PSIG 1/4IN NPTF
    10232-T__PRESSURE REGULATOR .5-30PSIG 1/4NPTF TAMPERPROOF
    10233__REGULATOR
    10242__PRESSURE REGULATOR 1-60PSIG 1/4IN NPTF
    10242-E__PRESSURE REGULATOR 1-60PSIG 1/4IN NPTF TAPPED EXHA
    10242-T__PRESSURE REGULATOR 1-60PSIG 1/4IN NPTF TAMPERPROOF
    10243__PRESSURE REGULATOR
    10263__MODULE
    10264T__REGULATOR
    10282E__PRESSURE REGULATOR 5-300PSIG 3/8NPTF TAMPER PROOF
    10282-T__PRESSURE REGULATOR 5-300PSIG 1/4NPTF TAMPER PROOF
    1062__REGULATOR
    15KE47CA__DIODE
    1600__REGULATOR 250PSIG
    16212__REGULATOR VACUUM MOD 16
    16213__REGULATOR VACUUM 3/8INCH NPT
    16223__REGULATOR VACUUM 3/8INCH NPT
    16233__PRESSURE REGULATOR
    18338-5__MANIFOLD AND ADAPTOR
    2012__VLME BOOSTR RL
    20712__CONTROL
    20713__VOLUME BOOSTER
    20732__RELAY
    20742__PART
    208102__REGULATOR
    20813__PART
    20832__RELAY
    20833__VOLUME BOOSTER MODEL 20
    20873__REGULATOR
    21312__REGULATOR MODEL 21
    21312DE__PART
    21625__CIRCUIT BOARD
    231__CHAIN
    24XFS10840002__CONVERTER
    2N7000FSND__ELEC COMPONENT
    30222__PRESSURE REGULATOR
    30232__REGULATOR
    30233__PRESSURE REGULATOR
    30233-R__PRESSURE REGULATOR 0.5-30PSIG 3/8NPTF PLUNGER OPER
    30242__PRESSURE REGULATOR 1-60PSIG 1/4NPTF
    30252__PRESSURE REGULATOR MIDGET 2-100PSIG 1/4NPTF
    30252-N__PRESSURE REGULATOR MIDGET 2-100PSIG 1/4NPTF NONREL
    3MDD8458__TRANSMISSION
    4064__REGULATOR
    4514A__AIR VOLUME BOOSTER
    4516A__BOOSTER
    4516AU__BOOSTER
    4526A__REGULATOR
    4536A__REGULATOR
    64732__VALVE
    64742__REGULATOR
    65832FT__REGULATOR
    65832G__REGULATOR
    65842__REGULATOR
    65842FG__CONTROL
    66162EK__REGULATOR 2-150PSIG 1/4INCH NPT KNOB ADJ
    70240__REGULATOR
    80441__PRESSURE REGULATOR MULTISTAGE 1-60PSIG 1/8NPTF
    81412P__REGULATOR
    81452__REGULATOR
    91__RELAY HIGH PRESSURE SELECTOR
    91052__HIGH PRESSURE SELECTOR RELAY
    950082__GAUGE 0-300 MODEL 95
    D1N960B__DIODE
    D70A2031519__TENSIONER SHOE
    DF2314ST2__BASE
    DS1B__DIODE
    DS2B__DIODE
    EA121251__REPAIR KIT
    EA-12144-1__REPAIR KIT
    EA-12200__REGULATOR KIT MODEL 4000
    EA-16893__CLIP
    EA-18338-5__MANIFOLD AND ADAPTOR
    EA-19513-11__KIT REBUILD FOR MODEL 20 VACUUM BOOSTER
    EB041241__KNOB
    EB09921__MOUNTING BRKT
    EB161041__KNOB ASSEMBLY
    EB4124__KNOB
    ECR122S420V__VALVE
    FDT458P__HARDWARE
    FND367__LED DISPLAY
    FTP130B__SENSOR
    GBPC3506__BRIDGE RECTIFR
    H22A2__SENSOR
    HGT1S12N60B3D__IGBT N-CHAN
    HGTG30N60B3D__IGBT N-CH UFS 600V 30A TO-247
    HUF75345P3__MOSFET N-CHAN 55V 75A TO-220AB
    IC11F1__OPTO COUPLER
    IC27C010Q150__EPROM
    IC88C30N__IC-LINE DRIVER DUAL DIFF 14-DIP
    IC9001__OPTOCOUPLER TRANS-OUT 2CH 8-DIP
    IN4148__DIODE
    L14P2__LED
    LED55C__LED
    LED55CF__LED
    MAN3910A__DISPLAY
    MAN6140E__LED
    MAN8610__7 SEGMENT DISPLAY
    MM74HC164N__IC 8BIT SHIFT REGISTER 14 PIN DIP
    MST4911C__DISPLAY
    NPLT-70-DRV-15-15__INDICATING STATION MINI REGULATOR
    OPSD-100__GEAR BOX
    PLT810DP3030__PART
    SPCA230SE__REPL CHAIN 4
    T2N5172__TRANSISTOR
    T-5000-04__TRANSDUCER ELECTRIC TO PNEUMATIC
    T52001__TRANSDUCER
    T5200-4__TRANSDUCER SUPPLY 4-20MA/10-50MA 3-15 PSIG
    T5200-40__TRANSDUCER SUPPLY 4-20MA/10-50MA 3-15 PSIG
    T5200-5__TRANSDUCER SUPPLY 1-5 VDC 3-15 PSIG
    T5200-50__TRANSDUCER SUPPLY 1-5 VDC 3-15 PSIG
    T5200-9__TRANSDUCER SUPPLY 1-9VDC 3-15 PSIG
    T5200-90__TRANSDUCER SUPPLY 1-9VDC 3-15 PSIG
    T52204__TRANSDUCER
    T52209__CONTROL
    T57004__TRANSDUCER
    T570040__PRESSURE TRANS
    TA6000-006__TRANSDUCER EXT. RANGE 0-120PS 1/2CONDUIT W/PIGTAIL
    TA6000401__TRANSDUCER
    TA6000405__TRANSDUCER
    TB5226-50__TRANSDUCER
    TBCX70J__TRANSISTOR
    TCI52004__TRANSDUCER
    TD6000401__TRANSDUCER
    TD6000404__VALVE
    TD6000406__VALVE
    TD6000415__TRANSDUCER
    TD6000424U__TRANSDUCER
    TF1520040__TRANSDUCER
    TFQP6N90__TRANSISTOR
    THGTG30N60A4D__TRANSISTOR
    THGTG30N60B3D__IGBT
    TT6000-001__TRANSDUCER 4-20MA 3-15PSIG
    TT6000401__TRANSDUCER 4-20 MA INPUT 3-15 PSIG OUTPUT
    TT6000405__SENSOR
    TT6000406__TRANSDUCER
    TT60041__TRANSDUCE 4-20
    TTCI6000401__TRANSDUCER
    TTFI7800-402__PNEUMATICE TRANSDUCER
    TUA78HGAKC__TRANSISTOR
    TUA78HGASC__TRANSISTOR
    Z14318__TRANSDUCER
    Z15312__TRANSDUCER ELECTRO-PNEUMATIC
    Z15312-TB5220-4__TRANSDUCER ELECTRO-PNEUMATIC
    Z166201__UNIT
    Z195844516A__PART
    Explosion-Proof I/P Transducer Model TXI7800
    The TXI7800 Electro-Pneumatic Transducer transmits a pneumatic signal that is directly proportional to a DC current input signal.
    The unit uses low powered microelectronics and pressure feedback control to provide a stable, accurate pneumatic output for the operation of actuated valves.
    The compact size reduces weight and space requirements to simplify the piping layout to the unit. External access to the restrictor orifice simplifies unit maintenance. The unit is ideally suited for hazardous environments.
    The Model TXI7800 has the following features:
    • Internal Electronic Feedback maintains precise output pressure control.
    • Piezoelectric Actuator Disk provides stability regardless of vibration or position.
    • RFI/EMI Protection eliminates susceptibility to electromagnetic interference.
    • 4-20 mA Input.
    • Field Selectable Outputs in three pressure ranges match final control element requirements.
    • Field Reversible Feature provides output that is directly or inversely proportional to input signal.
    • Split Range Operation lets a common signal source control two or more functions.
    • Damping Adjustment lets you tune the unit for optimum response.
    • Compact size for use in space restricted areas.
    • Input and Output Ports on the same side simplify pneumatic piping.
    • Conduit fitting for easy wiring.
    • Various mounting configurations allow installation flexibility for most applications.
    • Explosion-Proof, NEMA 4X, IP65, Type 4 Enclosure for outdoor and indoor installations.
    • Optional Tapped Exhaust Port allows venting of exhaust gas.
    • A Stainless Steel Mounting Kit is available.
    HighFlow Electro-Pneumatic Transducer Model T7900
    The Model T7900 High flow Electro-Pneumatic Transducer controls an output pressure in proportion to an analog electrical control signal. An internal feedback sensor monitors output pressure to achieve high accuracy. Model T7900 applications include machine tool automation and robotics.
    The Model T7900 has the following features:
    • RFI/EMI protection eliminates electromagnetic and radio interference.
    • Output pressure displays in psig, BAR, or kPa.
    • Reverse acting capability for input and feedback output signals
    • Select Current or Voltage input signals using the keypad.
    • Select Current or Voltage feedback output signal using the keypad.
    • Independently adjustable PID tuning coefficients.
    • Set operation parameters with the keypad.
    • Backlit Liquid Crystal display screen.
    • High and Low Alarm indicator lights.
    The Model T7900 has the following options:
    • Adjustable high and low alarm relays are available in place of Current or Voltage feedback signal.
    • External Pneumatic Feedback port is available.
    Pneumatic Volume Booster Model 200
    The Model 200 Pneumatic Volume Booster reproduces a pneumatic signal in a 1:1 ratio. It is ideally suited for systems that require input isolation or increased forward flow capacity.
    The Model 200 has the following features:
    * Control sensitivity to 1" water column variation.
    * Large Supply and Exhaust Valves provide high forward and exhaust flows.
    * A balanced Supply Valve minimizes the effect of supply pressure variation.
    * An Aspirator Tuve minimizes downstream pressure droop under flow conditions.
    * A separate Control Chamber isolates the diagphragm from the main flow to eliminate hunting and buzzing.
    * Optional increased sensitivity configuration with larger Control Diaphragm for more precision control at low setpoints.
    * Unit construction lets you service the Model 200 without removing it from the line.
    * A mounting bracket is available.
    网站首页   |   产品目录   |   公司新闻   |   UNIVER电磁阀   |   FAIRCHILD电气转换器   |   TOYOOKI   |   TAIYO/TAIYO油缸   |   NEW-ERA电磁阀/气缸   |   自动消泡机/自动消泡设备   |   文件下载   |   供求信息   |   联系我们   |   网站地图
      简体中文     繁體中文     English
昆山德旭鼎进出口贸易有限公司是集贸易.技术.服务于一体的工业器材专业代理、销售的明星企业。 公司成立于2005年,是一支年轻而富有朝气的团队。我们秉承:用户至上,信誉第一的宗旨为广大客户提供一流的产品、一流的服务。 由于全球一体化,在工业发…  更多>>
昆山德旭鼎进出口贸易有限公司
联系人:DANY
地址:昆山市高新区宝益路89号3楼
邮编:215300
电话:0512-86171188 57382299
传真:0512-50128868
公司网址:http://www.57382299.com
  • 尹风育 在2013/4/22 14:05:00留言
  • 详细留言:请你帮我查一下FAIRCHILD阀 EHS629-4KW 4026AE价格及货期,数量3个
  • abilify 在2010/7/16 18:53:00留言
  • 留言类型:
  • 详细留言:Aloha! abilify, )) - 5198
