工控事业部
  • 010-82612039 GETAC B300 军用加固笔记本 加固计算机 车载笔记本
  • 发布时间:2008/10/10 15:09:29   修改时间:2008/11/4 11:03:17 浏览次数:1056
  • 010-82612039 81677922 13910532255 工控部提供
    产品简介
    ·业内第一款可选1200流明亮度的屏幕
    ·屏幕显示器13.3"(标准 500 Nits)
    ·满足美军标MIL-STD 810F标准
    ·防护级别达到IP54
    ·高防震、抗震动和跌落
    ·工作温度:0度~55度,-20度~55度(可选)
    ·贮存温度:-40度~70度
    ·整机采用无风扇散热设计
    ·全密封防水连接器和接口
    产品特点
    ·选配满足MIL-STD 461E电磁兼容标准
    ·可根据客户需求,弹性选配扩展选件
    详细介绍
    Ruggedness Fully rugged
    MIL-STD 810F and IP54 compliance
    Full magnesium alloy case
    Sealed ports and connectors
    Shock-protected removable HDD
    Vibration & drop-shock resistant
    Optional salt fog compliance
    Optional MIL-STD 461E compliance
    CPU Intel®Core™2 Duo Merom L7500 1.6GHz processor
    800 MHz FSB
    4MB L2 cache
    Memory 512MB DDR2 expandable to 4GB
    VGA Controller Integrated in Intel® GM965, 384MB shared memory
    Display 13.3" XGA (1024 x768) TFT LCD (standard 500 Nits)
    Optional touch screen
    Optional 1200 nit sunlight readable display with touchscreen
    Storage SATA 80GB expandable to 160GB
    Keyboard Waterproof membrane keyboard
    Optional water-proof LED back-lit membrane keyboard
    Optional water-proof LED back-lit rubber keyboard
    Media Bay DVD Super Multi Drive
    Optional 2nd battery
    Optional 2nd HDD 80/120 GB
    Pointing Device
    Pressure sensitive touch screen
    Glide touchpad with scroll bar
    Expansion Slots PCMCIA Type II x 2 or Type III x 1
    Optional express card 34/54mm (occupies one PCMCIA type-II slot )
    Smart Card reader Optional smart card reader(occupies one PCMCIA type-II slot )
    Communication Interface 10/100/1000 base-T Ethernet
    56K ITU V.92 modem
    Intel® PRO/Wireless 4965a/g/n
    Optional GPS (with internal antenna)
    Bluetooth(v2.0+EDR class 2)
    Optional EV-DO/GSM/GPRS/EDGE/UMTS/HSDPA
    Security Fingerprint Scanner
    TPM 1.2
    Kensington lock
    Power AC Adapter (90W, 100-240V, 50/60Hz)
    Li-Ion Smart battery (7650mAh) (Up to 12 hours of battery life)**
    Optional Media Bay 2nd Li-Ion battery (7650mAh)
    Dimension & Weight
    11.9" (303.5mm) x 10.35" (263mm) x 2.36"(60mm), 7.7 lbs (3.5 Kg)
    Temperature
    According to IEC 68-2-1,2,14 / MIL-STD-810F, Method 501.4, 502.4
     • Operating:              0°C (32°F) to 55°C (131°F)
                                      -20°C (4°F) to 55°C (low temperature option)
     • Non-operating:   -40°C (-40°F) to 70°C (158°F)
    Humidity
    According to IEC 68-2-30 / MIL-STD-810F, Method 507.4
    5% to 95% RH, non-condensing
    Altitude According to IEC 68-2-13/ MIL-STD-810F, Method 500.4
     • Operating: 15,000ft
     • Non-operating: 40,000ft
     • Altitude change rate: 2,000ft/min
    Shock According to IEC 68-2-27/ MIL-STD-810F, Method 516.5
    Drop According to IEC 68-2-32 / MIL-STD-810F, Method 516.5
    Vibration According to IEC 68-2-6 / MIL-STD-810F, Method 514.5
    ESD According toIEC1000-4-2
    Enclosure
    IP 54 compliance
    Regulation FCC, UL, TUV, CE, CB,
    Others MIL-STD-461E (option)
    联系电话:010-82612039 81677922 13910532255   Skype业务咨询:ipc406 . MSN业务咨询:ipc406@hotmail.com 公司网址:www.gtdtech.com.cn
工控部位于北大创业园,自成立以来,始终致力于军用加固笔记本(Getac M230,Getac A790,Getac B300,Getac V100,Getac W130;松下CF-30,CF-19 加固笔记本 加固计算机)、便携工控机、CompactPCI产品(CPCI整体平台到客制机箱及相关配件、CPCI便携机、背板…  更多>>
工控事业部
联系人:张
地址:北京市海淀区海淀路50号
邮编:100080
电话:010-82612039 13910532255
传真:010-81677922
公司网址:http://www.gtdtech.com.cn
