深圳市汉润电子有限公司
  • 福禄克F199示波表 Fluke199手持式万用示波表
  • 发布时间:2007/9/8 18:53:02   修改时间:2007/9/8 14:39:58 浏览次数:1106
    190系列示波表为许多苛刻的应用环境提供了通常台式高性能示波器才具有的性能。如高达200MHz的带宽、2.5GS/s的实时采样率和每通道27500点的深度存储器。它将高性能数字存储示波器、万用表和记录仪集合成一个手持式的仪器,可电池供电工作,用选件还可对温度、压力进行测试,是所有现场工程师必备的理想测试工具。
    福禄克FLUKE 199示波器的主要技术参数
    带宽:
    Fluke 199C, 199B: 200 MHz
    Fluke 196C, 196B: 100 MHz
    Fluke 192B: 60 MHz
    最大实时采样率:
    Fluke 199C, 199B: 2.5 GS/s
    Fluke 196C, 196B: 1.0 GS/s
    Fluke 192B: 500 MS/s
    显示:
    Fluke 19xC: 144 mm 全彩色LCD
    Fluke 19xB: 144 mm
    黑白 LCD
    Digital Persistence
    Fluke 19xC: Yes, gives analog oscilloscope like waveform decay (user selectable)
    Fluke 19xB: Persistence on/off
    Envelope mode
    Yes
    波形比较:
    Fluke 19xC: Visual Reference and Automatic ‘Pass / Fail’ testing
    Fluke 19xB: Visual Reference
    最大记录长度:
    1200 points 每通道
    在示波器记录模式下:
    27,000 points per input or more (5 ms/div…2 min/div.)
    输入通道:
    2 plus external / DMM input, all isolated from each other and from ground
    灵敏度:
    Fluke 19xC: 2 mV/div. … 100 V/div.
    Fluke 19xB: 5 mV/div. … 100 V/div.
    Glitch capture
    Up to 3 ns using Pulse Width triggering; 50 ns peak detect at 5 ms/div. to 1 min/div.
    Timebase range in Scope mode
    Fluke 199C, 199B, 196C, 196B: 5 ns/div to 2 min/div
    Fluke 192B: 10 ns/div to 2 min/div.
    Connect-and-View®, Free Run, Single Shot, Edge, Delay, Video Frame, Video line, Selectable pulse width and External
    Scope Measurements
    7 cursors measurements, 30 automatic measurements
    Waveform Mathematics
    A + B, A – B, A x B, A versus B (X-Y-mode, giving Lissajous diagrams)
    Scope-Record Trigger modes
    Start on Trigger, Stop on Trigger
    Capture last 100 screens
    Automatic, with Replay capability
    Dual input TrendPlot
    Yes, with Cursors and Zoom
    Memory for screens and set-ups
    10 screens with set-up;
    5 more memories are made available upon registration of theScopeMeter
    Memory for recordings
    Two, each can store 100 scope screens, a ScopeRecord or a TrendPlot
    真有效值万用表
    5000 counts, Volts, Amps, Ohms, Continuity, Diode, Temp
    安全标准 (EN61010-1)
    1000 V CAT II / 600 V CAT III (instrument and included accessories)
    电池 (installed)
    4小时
    电源:
    尺寸:
    25.6 x 16.9 x 6.4 cm (10.1 x 6.7 x 2.5 inch)
    重量:
    2 kg
    PC打印接口:
    Using optional Optically Isolated RS-232 adapter / cable
    保修:
    主机3 ,附件一年
深圳市汉润电子有限公司是集电子仪器销售、测试方案提供、售前售后服务、仪器设备维修为一体的专业性公司。 我们结合珠三角地区生产商仪器 淘汰更新快的特点,我公司另辟有专门服务,解决生产厂商仪器的更新换代。 我们立足于深圳、面向全国。我公…  更多>>
深圳市汉润电子有限公司
联系人:唐元
地址:深圳市华发北路30号电子设计院4号楼601 QQ:20988225
邮编:518031
电话:0755-81939173
传真:0755-83356908
公司网址:http://139.17430.com
