福州恒拓工业自动化有限公司 童小姐 电话:0591-83995995 传真:0591-83663000-820
BERTHOLD TECHNOLOGIES GmbH & Co KG位于德国Black Forest的Bad Wildbad。自从1949年创始以来,我们一直在传感器、监测系统和仪器等领域坚持不断的创新,并一直秉持为客户提供高品质产品的理念。随着客户需求的变化及科技进步,我们已经延伸到发光测量及微波辐射的应用等高新领域。
而今我们能为客户提供全球经销网络,更便于满足客户产品维护等反面的需求。期待与您的合作
产品介绍 :
BERTHOLD业过程控制、BERTHOLD生物分析仪器、BERTHOLD辐射防护仪表、BERTHOLD监测仪器等
常用型号:
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB4401-03 CRYSTAL:50/50
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB490 95-250V
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB444-K40
BERTHOLD TECHNOLOGIES GmbH & Co.KG Id.81037 LB3940
BERTHOLD TECHNOLOGIES GmbH & Co.KG Id.81078/LB 3998-11 SNR:0817029 Rev:01
BERTHOLD TECHNOLOGIES GmbH & Co.KG CODICE 04497
BERTHOLD TECHNOLOGIES GmbH & Co.KG 748063
BERTHOLD TECHNOLOGIES GmbH & Co.KG CODICE 09726
BERTHOLD TECHNOLOGIES GmbH & Co.KG CODICE 09794
BERTHOLD TECHNOLOGIES GmbH & Co.KG CODICE 09792
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB6651
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB 6639 CsI 40/50
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB440(the whole set)
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB2018 Pre-amplifier for LB 7410 or LB 5471(Nr:80139)
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB350-1 Moisture measurement unit 230V(Nr:81066-1)
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB 3961-1 Operation panel(for 19"rack)
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB123N With a neutron probe LB6411
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB3940 CPU15 ID:81037/LB3940 SNR:0527077
BERTHOLD TECHNOLOGIES GmbH & Co.KG Daul Current Output LB3971 ID:80824/LB3971 SNR:0517073 REV:01
BERTHOLD TECHNOLOGIES GmbH & Co.KG Operation Board ID 81036/LB3961-1 Nr:60006651-10058 REV:03
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB440-01
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB4405-01
BERTHOLD TECHNOLOGIES GmbH & Co.KG TowerSens Electronic Block 95-250V HART Ex-I P/N:53909
BERTHOLD TECHNOLOGIES GmbH & Co.KG Photomultiplier XP 3240/B02 P/N:05295
BERTHOLD TECHNOLOGIES GmbH & Co.KG Multiplier for rod detector P/N:37133
BERTHOLD TECHNOLOGIES GmbH & Co.KG Fuse for LB490-11 24586
BERTHOLD TECHNOLOGIES GmbH & Co.KG radioactive source security lock(large handle)
BERTHOLD TECHNOLOGIES GmbH & Co.KG radioactive source security lock(small handle)
BERTHOLD TECHNOLOGIES GmbH & Co.KG ID:81962-7/LB 332-2 , Nr 7448-1054
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB5441-02
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB? 6639W-CSJ-40X50 ID:34630-12PA-60046220 8157
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB352,81072-7
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB352,81072-1
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB6639W-CsL-40*50 10m cable,34630-15
BERTHOLD TECHNOLOGIES GmbH & Co.KG YBERTH34099-05
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB 352-2
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB 6639-CSJ-40X50(with 15m cable)
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB 490 Level 24V HART/ATEX,CSA,FM,PI-SZ.500 38477-330
BERTHOLD TECHNOLOGIES GmbH & Co.KG electr.-block for Uni-Probe LB 490 Level,PI.Sz.24V,HART 50607
BERTHOLD TECHNOLOGIES GmbH & Co.KG Towersens Electronic Block 24V HART Ex-d 54346
BERTHOLD TECHNOLOGIES GmbH & Co.KG Multilplier crystal combination NaJ/TI 50x50,cpl 04497
BERTHOLD TECHNOLOGIES GmbH & Co.KG Photomultiplier XP 3240/B02 05295
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB 4710-180 Level switch Scinti,4TE 40167-180
BERTHOLD TECHNOLOGIES GmbH & Co.KG 24V filiter,8TE for wall mounted housing and for 19" rack 42855
BERTHOLD TECHNOLOGIES GmbH & Co.KG electr.-block for Uni-probe LB 491 DENSITY,Nal 24V ,HART 50625
BERTHOLD TECHNOLOGIES GmbH & Co.KG Probe of LB491, 50*50
BERTHOLD TECHNOLOGIES GmbH & Co.KG P/N:17470
BERTHOLD TECHNOLOGIES GmbH & Co.KG CB.9144:Scintilalion counter LB6639 Cs140/50(with 10m special cable)
BERTHOLD TECHNOLOGIES GmbH & Co.KG Micro-Polar Brix LB 565
BERTHOLD TECHNOLOGIES GmbH & Co.KG Type: LB 3375-DE
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB3940,CPU15(concast)
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB491-CPU
BERTHOLD TECHNOLOGIES GmbH & Co.KG Tower-Sens LB 490-TS basic modul Level Gauge Plastic scintillator length 1000mm Power supply 24VAC/DC Signal output: HART automatic drift compensation automatic decay compensation Error indication Ambient temp: -40 to +50°C - 1 a
BERTHOLD TECHNOLOGIES GmbH & Co.KG Tower-Sens LB 490-TS extension modul Plastic scintillator length 2000mm Ambient temp: -40 to +50°C stainless steel housing
BERTHOLD TECHNOLOGIES GmbH & Co.KG clamps SPGU 85/25 - 1.4571 for Tower-Sens rod detector (no water jacket) one clamp per module
BERTHOLD TECHNOLOGIES GmbH & Co.KG Point Source Isotope Cs-137 Activity: 37 MBq (1 mCi) Classification: ISO/C 66646
BERTHOLD TECHNOLOGIES GmbH & Co.KG Point Source Isotope Cs-137 Activity: 74 MBq (2 mCi) Classification: ISO/C 66646
BERTHOLD TECHNOLOGIES GmbH & Co.KG Point Source Shielding for Rod Detector Arrangement acc to drg No 21 158.401 shielding with rotating shutterAngle of radiation beam: vertical: approx 45° horizontal: approx 10° Model 100 P
BERTHOLD TECHNOLOGIES GmbH & Co.KG 02LT-0103~1503 Equipment No.S-02002A~Q Radiation Source: Cs137 Enclosure Proof:IP65 Explosion Proof Class :Ex dIICT4 Output Signal:4~20mADC Mounting:Ingrate Electrical Connections:3/4"NPT Compensator
BERTHOLD TECHNOLOGIES GmbH & Co.KG LB491-CPU,13DT-0001
BERTHOLD TECHNOLOGIES GmbH & Co.KG Uniprobe LB 490 Level 95-250V HART/ATE,CSA,FM,PI.-Sz.2000 ID:38477—190
