伊玛精密电子(苏州)有限公司
  • 伊玛的01系列16m/m 新型紧急开关上市
  • 发布时间:2008/3/1 10:54:17   修改时间:2008/2/29 14:13:27 浏览次数:1345
    如同以往开关设计的高品质水平,伊玛的16m/m 紧急开关一上市就颇受各界的瞩目,此新型设计已受到市场的热烈响应。两种规格供选择:照光式和非照光式,性能坚固,可广泛应用在工业及商用产品上。
    此款紧急开关符合保护等级IP65,对灰尘和潮湿具有密封保护作用,这样的组件即使在环境恶劣的条件下仍能安全的使用。其中照光式的紧急开关,中间的透光部分可按照您的使用情况选择LED灯或是氦氖灯,电压可使用DC或是AC。
    .  16 m/m孔径
    . 照光式和非照光式
    . 具IP40及IP65保护等级要求
    .  LED灯和氦氖灯可供您选择 (6 VDC/ 12 VDC/ 24 VDC/ 110 VAC/220 VAC)
    . 与德国工艺同级的设计,提供应用价值与美感
    . 专业的工程材料选择,克服您作业环境的挑战
    . 滑切式的接点触动设计,避免积碳污染提供讯号的可靠度
    . 取得UL、ULc、CQC、CE与RoHs的安规认证,提供您安全可靠的产品服务
    . 开关单元使用防火级UL94V0加纤塑料,具自熄性确保安全
    EMA launches 01 series 16m/m Emergency-Stop Switch
    Create to EMA's renowned high standards, this new design has been highly expected and it has acquired positive comment from customers. Two types are available: LED illumination, or non-illumination. These emergency stop switches are suited for industrial and commercial products, such as robots, production lines, moving platforms, cranes, moving platforms, as well as security systems and emergency exits.
    With protection rating IP40 and IP65, Series 01 16m/m emergency-stop switch features precise and reliable function. Actuator head that provides visible illumination from middle view that indicates actuated position. You can choose LED or discharged lamps. Rated for 50,000 operations, unit accepts supply voltages of DC/AC.
    . Mounting hole diameter 16m/m
    . LED illumination / non-illumination
    . Protection Rating: IP40 /IP65
    . Lamp: LED or discharged
    . Elegant and sophisticated design, add the value and enthetic feeling into applications
    .Professional selection of engineering materials, overcome the harshest of your environment
    .Approved by safety standards UL、ULc、CQC、CE and RoHs
    .Snap-action which accelerates on-off switching·
    .UL94V0 class plastics to make self-extinguished
  伊玛电子,全方面的解决方案来连接您的系统   伊玛电子为传感技术和工业开关的专业制造商,产品分为三大类:流程自动化、工厂自动化和人机界面,并且区分为五大系列:位移传感器、流体传感器、位移传感器、AS-i总线系统和控制开关。其中, 流程…  更多>>
伊玛精密电子(苏州)有限公司
联系人:EMA
地址:苏州市相城经济开发区澄阳路566号
邮编:215131
电话:0512-65868166
传真:0512-65860966
公司网址:http://www.ema-electronic.com
  • 周经理 在2024/9/13 9:48:00留言
  • 详细留言:急停开关,依玛EMA,规格:2SWB600V/10A,22mm用触点,2常开触点,带开关保护罩。请销售人员联系
  • 张庆 在2024/9/3 16:05:00留言
  • 详细留言:01P-CA40.S1P按钮的询价
  • 刘经理 在2024/8/31 13:47:00留言
  • 详细留言:流量计(温度一体)
  • 丰化东 在2024/5/30 16:44:00留言
  • 详细留言:01P-RA40.S1P+R+L24质量问题; 01K-R01P-RA40.S1P+R+L24质量问题; 01P-RA65.Q1P+Y+L24质量问题; 01P-RA40.S1P+W+L24质量问题;
  • 黄正波 在2019/8/27 11:29:00留言
  • 详细留言:我公司有两台雷达物位计,型号RAEB03241S1Y(伊玛精密电子(苏州)有限公司生产),生产日期2011年9月22日,出厂编号:110922
