上海欧桥电子科技有限公司
  • SyncServer S200
  • 发布时间:2008/10/28 10:50:35   修改时间:2008/10/28 10:50:35 浏览次数:1503
  • SyncServer S200
  • 点击查看详细信息
    产品编号:
    122815403616
    产品名称:
    SyncServer S200
    规  格:
    产品备注:
    产品类别:
    GPS定位及时钟基准系统
        产 品 说 明
    Easy To Set Up – Easy To Maintain
    The S200 is the easiest to set up and maintain network time server in the world. The front panel is designed to quickly bring the time server online with a few front panel keystrokes or DHCP. To fully configure the unit, use the very intuitive web interface. The S200 is also the first network time server to offer Wizard step-by-step set-ups for the most common time server operations. The state-of-the-art user interface offers the network administrator ease-of-use and remote access, with intuitive web pages and full control of the server via a standard browser interface.
    Highly Robust And Secure
    The S200 provides reliable and secure network synchronization technology by combining multi-port, high-speed/ high-capacity network interfaces and versatile GPS timing receiver technology. It supports a wide range of network protocols including IPv4 and IPv6, for easy management and seamless integration into your existing and future network.
    Unmatched High Performance With Unparalleled Flexibility
    The SyncServer S200 has three dedicated and isolated 10/100Base-T Ethernet ports, each with their own Ethernet processor. These multiple ports provide the flexibility to adapt to different network topologies as networks grow and change. Security sensitive networks have the option of using one port for secure maintenance and control functions and the other two for NTP timing functions. And all of this is connected to a high speed processor and a nanosecond clock to assure high bandwidth NTP performance for hundreds of thousands of network clients.
    Perfect Timing
    The Stratum 1 level SyncServer S200 derives its time directly from the atomic clocks aboard the GPS satellite system. By using the integrated, 12-channel GPS receiver, every visible satellite can be tracked and used to maintain extremely accurate and reliable time. If the GPS reference signal is ever lost, the S200 can automatically revert to a Stratum 2 mode and retrieve time from other user-designated time servers. Another option is that the S200 can be upgraded to an internal Rubidium atomic oscillator that keeps the S200 accurate to 25 microseconds per day.
    Customer Tested Design
    As a 5th generation Symmetricom time server, the S200 has decades of design experience behind it. Customer input is evident in every detail. The front panel is designed for quick setup, informative clear presentation of time and status, and convenient physical access to the console ports. The rear panel is configured with those connections that are changed infrequently, such as power, GPS antenna, and network ports. Keypad operation is quick and easy when using the full numeric keypad and control keys
欧桥电子科技发展有限公司是英国Universal Corporate Ltd. (UK)在中国的分公司,旗下包含上海欧桥电子、天津欧桥、杭州欧桥等多个分支机构,从事涵盖电子通信产品、仪器、工业及机电产品等不同领域的业务与技术服务。公司本着良好的信誉和出色的售后服…  更多>>
上海欧桥电子科技有限公司
联系人:瞿建
地址:上海市浦东新区康桥路1100号保康大厦1103室
邮编:201315
电话:021-58126804
传真:021-58126844
公司网址:http://www.ouqiao.com/
  • 张克雄 在2025/6/26 17:30:00留言
  • 详细留言:产品尺寸图
  • 何先生 在2023/10/16 18:46:00留言
  • 详细留言:UCL-HP2000-A(B)
  • 李小姐 在2021/9/22 12:16:00留言
  • 详细留言:UCL-HT80GH-18,5PCS
  • huyiping 在2011/5/17 15:20:00留言
  • 详细留言:4142b+41420A+41420A
  • 李永珍 在2010/9/28 19:41:00留言
  • 详细留言:True Time XL-AK GPS Receiver (600-000-03)
