![](http://www.cechina.cn/Upload/companyfile/2008/7/29/1d77002a-33b9-4b1f-83ea-f1fc7d3e2c6a.JPG)
CC2430长距离模块主要参数:
功能 |
参数 |
备注 |
Frequency |
2400-2483.5 MHz |
RF Data Rate |
250Kbps |
Serial Interface Options |
3V TTL |
Serial Interface Data Rate |
Up to 115.2Kbps |
Variable Output Power |
+10 to +20dBm |
Power Consumption
Tx
Rx
Standby
Sleep
Hibernate |
140mA @3.3V,+18dBm
27mAA@3.3V
<=300uA
<=1uA
<=0.7uA |
Coonducted |
Security |
128 bit AES&SSP |
Sensitivity (BER 10) |
-99dB |
Typical |
Voltage |
3.0-3.5V |
Indoor Range |
200 meters |
Outdoor Range |
4.8 kilometers |
可视 |
Temperature |
-40 to +85℃ |
Dimensions |
~25.4 X 34.3 X 5.5 mm |
Antenna |
U.FL connector or chip antenna |
中短距离CC2430模块
功能 |
参数 |
备注 |
Frequency |
2400-2483.5 MHz |
RF Data Rate |
250Kbps |
3V TTL |
Up to 115.2Kbps |
11dBm |
Power Consumption
Tx
Rx
Standby
Sleep
Hibernate |
160mA @3.3V,+11dBm
27mA@3.3V
<=300uA
<=1uA
<=0.7uA |
Coonducted |
Security |
128 bit AES&SSP |
-89dB |
Typical |
Voltage |
3.0-3.5V |
Indoor Range |
100 meters |
Outdoor Range |
0.8kilometers |
可视 |
Temperature |
-40 to +85℃ |
Dimensions |
~62 X 42 X 62 mm |
Antenna |
SMA connector or chip antenna |
注:
参数表内数据为实验室测试数据。实现应用可能有差别。
长距离CC2430模块现场测试通信距离为1Km。
中短距离CC2430模块现场测试通信距离为300-400m。
此模块价格为360元/块
