深圳市德威达科技有限公司
  • Dwyer PMT系列尘埃浓度变送器
  • 发布时间:2008/7/23 13:12:11   修改时间:2008/7/23 13:12:11 浏览次数:1202
  • 产品名称:  PMT系列尘埃浓度变送器
    产品型号:  PMT
    Service: Air and compatible gases, any type particulate conductive or nonconductive.
    Wetted Materials: 304 SS and PTFE.
    Air Velocity Range: 300 ft/min and higher.
    Minimum Detection: Standard: 10.0 pA, Optional: 5.0 pA and 0.5 pA.
    Temperature Limits: Ambient: -15 to 160°F (-25 to 70°C); Process: Standard: -40 to 250°F (-40 to 120°C); Optional: -40 to 450°F (-40 to 232°C).
    Pressure Limit: 10 psi (0.69 bar).
    Power Requirement: 18-28 VDC (24V Nominal).
    Output Signal: 4-20 mA.
    Loop Resistance: 300 Ohms maximum.
    Current Consumption: Powered from 4-20 mA loop.
    Electrical Consumption: Terminal Block.
    Process Connection: See Model Chart on Ordering Page.
    Enclosure Rating: Weatherproof, NEMA 4X (IP 66).
    Mounting Orientation: Any.
    Weight: Varies with length of probe and type of mount.
    Agency Approvals: CE Ordinary locations only, CSA
    选型表
    Example
    PMT
    A1
    1
    T1
    P1
    1
    L1.5
    PMT-A11T1P1-L1.5 Particulate Transmitter, ordinary/general purpose locations,
    CE approval, NEMA 4X, CSA, , 1/2" NPT connection, 250°F max. temp., 10 psi
    max. pressure, 10.0-5000 pA, 1.5" probe.
    Series Designator
    PMT
    PMT Particulate Transmitter (1-piece configuration, sensor included in price)
    Enclosure Rating
    A1
    AHZ2
    Ordinary/General Purpose Locations, CE Approval, NEMA 4X, CSA
    Hazardous Location, CSA Approval, Class I, Division II, Groups A-D; Class II,
    Groups F,G
    Process Connection
    1
    2
    3
    4
    1/2" NPT
    1.5" Sanitary Connection
    2" 150# ANSI Flange
    2" 150# ANSI Flange with Process Mating Flange and Installation Kit.
    Maximum Process
    Temperature
    T1
    T2
    250°F (121°C)
    450°F (232°C)
    Maximum Process
    Pressure
    P1
    10 psi
    Range
    1
    2
    3
      10.0-5000 pA
    5.0-5000 pA
    0.5-5000 pA (required for low levels or EPA leak detection)
    Insertion Length
    (recommended at
    least 1/2 duct diameter)
    L1.5
    L03
    L05
    L10
    L15
    L20
    L30
    L36
    1.5" Probe
    3" Probe
    5" Probe
    10" Probe
    15" Probe
    20" Probe
    30" Probe
    36" Probe
深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动控制经验 ,技术力量雄厚。公司代理品牌有 美国 DWYER、ANDERSON、MERC…  更多>>
深圳市德威达科技有限公司
联系人:李小姐
地址:深圳市福田区福田大厦1109
邮编:518033
电话:0755-83692637
传真:-
公司网址:http://www.szdwd.com
