产品名称: DPM系列尘挨浓度监视报警器产品型号: DPM实时监测尘埃浓度,可调整报警设定点
Inputs: From PMS Sensor.Output Ratings: Alarm Relays: 2 Form A (SPST) rated 5A @ 240V res. (must provide an 8A (maximum) fuse in series with relay load); Analog: 4 to 20 mA (Option RC).Power Requirements: 115 VAC 50/60Hz, 230 VAC 50/60Hz, or 24 VDC.Power Consumption: 6 Watts Max.Accuracy: Standard: ±5% of range; Optional: ±1% of range.Display: LCD.Display Resolution: Standard: 5 pA; Optional: 0.5 pA.Memory Backup: For set point storage only.Temperature Limits: -13 to 160°F (-25 to 70°C).Weight: 4.5 lbs (2.0 kg).Enclosure: Cast Aluminum, Weatherproof, NEMA 4X.Loop Power Supply (Isolated): 17 VDC loop supply provided by DPM control unit for PMS Sensor.Agency Approvals: Standard, Ordinary/General Purpose Locations (CE and CSA) or Optional, Class I, II, III, Div. I & II, All Groups (Intrinsically Safe- CSA).
选型表
联系人:李小姐
地址:深圳市福田区福田大厦1109
邮编:518033
电话:0755-83692637
传真:-
公司网址:http://www.szdwd.com
