深圳市德威达科技有限公司
  • Dwyer STC系列管道安装式双金属温度计
  • 发布时间:2008/7/23 13:31:09   修改时间:2008/7/23 13:31:09 浏览次数:1489
  • 产品名称:  STC系列管道安装式双金属温度计
    产品型号:  STC
    技术指标
    精度:
    ±2%.
    分辨率: 小于满量程的4% .
    环境温度: 14 302°F (-10 to 150°C).
    刻度盘尺寸: 2˝.
    镜面: 玻璃.
    接液材质: .
    重量: 3.4 oz (95 g).
    型号 描述
    STC151 Pipe-mount bimetal surface thermometer, range -50 to 250°F, 3/4" to 7/8" spring.
     STC141 Pipe-mount bimetal surface thermometer, range 0 to 150°F, 3/4" to 7/8" spring.
     STC161 Pipe-mount bimetal surface thermometer, range 70 to 370°F, 3/4" to 7/8" spring.
     STC171 Pipe-mount bimetal surface thermometer, range 70 to 500°F, 3/4" to 7/8" spring.
     STC152 Pipe-mount bimetal surface thermometer, range -40 to 120°C, 3/4" to 7/8" spring.
     STC162 Pipe-mount bimetal surface thermometer, range 20 to 180°C, 3/4" to 7/8" spring.
     STC172 Pipe-mount bimetal surface thermometer, range 20 to 260°C, 3/4" to 7/8" spring.
     STC351 Pipe-mount bimetal surface thermometer, range -50 to 250°F, 1" to 1-5/8" spring.
     STC341 Pipe-mount bimetal surface thermometer, range 0 to 150°F, 1" to 1-5/8" spring.
     STC361 Pipe-mount bimetal surface thermometer, range 70 to 370°F, 1" to 1-5/8" spring.
     STC371 Pipe-mount bimetal surface thermometer, range 70 to 500°F, 1" to 1-5/8" spring.
     STC352 Pipe-mount bimetal surface thermometer, range -40 to 120°C, 1" to 1-5/8" spring.
     STC362 Pipe-mount bimetal surface thermometer, range 20 to 180°C, 1" to 1-5/8" spring.
     STC372 Pipe-mount bimetal surface thermometer, range 20 to 260°C, 1" to 1-5/8" spring.
     STC451 Pipe-mount bimetal surface thermometer, range -50 to 250°F, 1-5/8" to 2-3/8" spring.
     STC441 Pipe-mount bimetal surface thermometer, range 0 to 150°F, 1-5/8" to 2-3/8" spring.
     STC461 Pipe-mount bimetal surface thermometer, range 70 to 370°F, 1-5/8" to 2-3/8" spring.
     STC471 Pipe-mount bimetal surface thermometer, range 70 to 500°F, 1-5/8" to 2-3/8" spring.
     STC452 Pipe-mount bimetal surface thermometer, range -40 to 120°C, 1-5/8" to 2-3/8" spring.
     STC462 Pipe-mount bimetal surface thermometer, range 20 to 180°C, 1-5/8" to 2-3/8" spring.
     STC472 Pipe-mount bimetal surface thermometer, range 20 to 260°C, 1-5/8" to 2-3/8" spring.
     BACK
深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动控制经验 ,技术力量雄厚。公司代理品牌有 美国 DWYER、ANDERSON、MERC…  更多>>
深圳市德威达科技有限公司
联系人:李小姐
地址:深圳市福田区福田大厦1109
邮编:518033
电话:0755-83692637
传真:-
公司网址:http://www.szdwd.com
