深圳市德威达科技有限公司
  • Dwyer BTO系列带变送器的双金属温度计
  • 发布时间:2008/7/23 13:32:10   修改时间:2008/7/23 13:32:10 浏览次数:1524
  • 产品名称:  BTO系列带变送器的双金属温度计
    产品型号:  BTO
    技术指标
    接液材质:
    304 SS.
    镜面: 玻璃.
    精度: 温度计: ±1%; 传感器: ±0.2%.
    环境温度: -58 185°F (-50 85°C).
    刻度盘尺寸: 5˝.
    连接: 1/2˝ NPT.
    分辨率: 2°F (50 400°F 50 550°F的分辨率为5°F).
    传感器电源: 8-36 VDC.
    输出: 4 to 20 mA.
    重量: 1.95 lb (885 g)
    3"刻度盘
    型号 描述
    BTO325101 Bimetal thermometer with transmitter output, 2.5" stem length, range 0-200°F.
     BTO32551 Bimetal thermometer with transmitter output, 2.5" stem length, range 0-250°F.
     BTO32561 Bimetal thermometer with transmitter output, 2.5" stem length, range 50-300°F.
     BTO325121 Bimetal thermometer with transmitter output, 2.5" stem length, range 50-400°F.
     BTO32571 Bimetal thermometer with transmitter output, 2.5" stem length, range 50-550°F.
     BTO340101 Bimetal thermometer with transmitter output, 4" stem length, range 0-200°F.
     BTO34051 Bimetal thermometer with transmitter output, 4" stem length, range 0-250°F.
     BTO34061 Bimetal thermometer with transmitter output, 4" stem length, range 50-300°F.
     BTO340121 Bimetal thermometer with transmitter output, 4" stem length, range 50-400°F.
     BTO34071 Bimetal thermometer with transmitter output, 4" stem length, range 50-550°F.
     BTO360101 Bimetal thermometer with transmitter output, 6" stem length, range 0-200°F.
     BTO36051 Bimetal thermometer with transmitter output, 6" stem length, range 0-250°F.
     BTO36061 Bimetal thermometer with transmitter output, 6" stem length, range 50-300°F.
     BTO360121 Bimetal thermometer with transmitter output, 6" stem length, range 50-400°F.
     BTO36071 Bimetal thermometer with transmitter output, 6" stem length, range 50-550°F.
     BTO390101 Bimetal thermometer with transmitter output, 9" stem length, range 0-200°F.
     BTO39051 Bimetal thermometer with transmitter output, 9" stem length, range 0-250°F.
     BTO39061 Bimetal thermometer with transmitter output, 9" stem length, range 50-300°F.
     BTO390121 Bimetal thermometer with transmitter output, 9" stem length, range 50-400°F.
     BTO39071 Bimetal thermometer with transmitter output, 9" stem length, range 50-550°F.
     BTO312101 Bimetal thermometer with transmitter output, 12" stem length, range 0-200°F.
     BTO31251 Bimetal thermometer with transmitter output, 12" stem length, range 0-250°F.
     BTO312061 Bimetal thermometer with transmitter output, 12" stem length, range 50-300°F.
     BTO312121 Bimetal thermometer with transmitter output, 12" stem length, range 50-400°F.
     BTO31271 Bimetal thermometer with transmitter output, 12" stem length, range 50-550°F.
    5"刻度盘
    型号 描述
     BTO525101 Bimetal thermometer with transmitter output, 2.5" stem length, range 0-200°F.
     BTO52551 Bimetal thermometer with transmitter output, 2.5" stem length, range 0-250°F.
     BTO52561 Bimetal thermometer with transmitter output, 2.5" stem length, range 50-300°F.
     BTO525121 Bimetal thermometer with transmitter output, 2.5" stem length, range 50-400°F.
     BTO52571 Bimetal thermometer with transmitter output, 2.5" stem length, range 50-550°F.
     BTO540101 Bimetal thermometer with transmitter output, 4" stem length, range 0-200°F.
     BTO54051 Bimetal thermometer with transmitter output, 4" stem length, range 0-250°F.
     BTO54061 Bimetal thermometer with transmitter output, 4" stem length, range 50-300°F.
     BTO540121 Bimetal thermometer with transmitter output, 4" stem length, range 50-400°F.
     BTO54071 Bimetal thermometer with transmitter output, 4" stem length, range 50-550°F.
     BTO560101 Bimetal thermometer with transmitter output, 6" stem length, range 0-200°F.
     BTO56051 Bimetal thermometer with transmitter output, 6" stem length, range 0-250°F.
     BTO56061 Bimetal thermometer with transmitter output, 6" stem length, range 50-300°F.
     BTO560121 Bimetal thermometer with transmitter output, 6" stem length, range 50-400°F.
     BTO56071 Bimetal thermometer with transmitter output, 6" stem length, range 50-550°F.
     BTO590101 Bimetal thermometer with transmitter output, 9" stem length, range 0-200°F.
     BTO59051 Bimetal thermometer with transmitter output, 9" stem length, range 0-250°F.
     BTO59061 Bimetal thermometer with transmitter output, 9" stem length, range 50-300°F.
     BTO590121 Bimetal thermometer with transmitter output, 9" stem length, range 50-400°F.
     BTO59071 Bimetal thermometer with transmitter output, 9" stem length, range 50-550°F.
     BTO512101 Bimetal thermometer with transmitter output, 12" stem length, range 0-200°F.
     BTO51251 Bimetal thermometer with transmitter output, 12" stem length, range 0-250°F.
     BTO512061 Bimetal thermometer with transmitter output, 12" stem length, range 50-300°F.
     BTO512121 Bimetal thermometer with transmitter output, 12" stem length, range 50-400°F.
     BTO51271 Bimetal thermometer with transmitter output, 12" stem length, range 50-550°F.
深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动控制经验 ,技术力量雄厚。公司代理品牌有 美国 DWYER、ANDERSON、MERC…  更多>>
深圳市德威达科技有限公司
联系人:李小姐
地址:深圳市福田区福田大厦1109
邮编:518033
电话:0755-83692637
传真:-
公司网址:http://www.szdwd.com
