产品名称: UF系列超声波流量计产品型号: UF非浸入式,显示流速和流量累加值,便携
范围: UF10A: 0.13 to 26 ft/sec (0.04 to 8 m/s); UF35A: 1.6 to 26 ft/sec (0.5 to 8 m/s).管径: UF10A: 1/2" to 4-1/2" (13 to 115 mm) nominal bore. UF35A: 2" to 15.75" (50 to 400 mm) nominal bore.精度: ±2% of reading.重复性: ±0.5% or ±0.1 LPM (whichever is greater).显示: 7-digit flow rate in GPM, LPM, LPS, m³/hr, ft/sec and m/s; 7-digit totalization in gallons, liters, or m³.显示分辨率: 0.1% of reading.反应时间: <2 seconds.操作温度: 32 to 113°F (0 to 45°C).储藏温度: -4 to 131°F (-20 to 55°C).变送器操作温度: -4 to 257°F (-20 to 125°C).电源: Four AA rechargeable batteries.导轨长度: UF35A: 15.6" x 1.3" x 1.7" (395 x 33 x 42 mm). UF10A: 8.25" x 1.4" x 1.06" (210 x 36 x 27 mm).电缆长度: 6.5 feet (2 m).封装: ABS, IP55 rating.重量: 17.5 oz (500 g) including transducers.输出信号: Pulse 0-5V and 4-20 mA.认证: CE.
联系人:李小姐
地址:深圳市福田区福田大厦1109
邮编:518033
电话:0755-83692637
传真:-
公司网址:http://www.szdwd.com
