产品名称: 45000系列风速/温湿度/风冷量/露点仪产品型号: 4500045118:检测风速,温度,风冷量
45158:检测风速,温度,湿度,风冷量,露点
风速范围: 100 to 5500 ft/min, 0.5 to 28 m/s, 2 to 100 km/h, 1 to 62 mph, 1 to 54.3 knots, 1 to 17 Beaufort.温度/风冷量范围: 0 to 122°F (0.1°)/-18 to 50°C (0.1°).湿度范围: 10% to 95% (model 45158 only).精度: Wind speed: ±3% of reading; Temperature: ±1.8°F/±1°C; Relative Humidity: ±5% RH.风速单位: m/s, mph, knots, km/hr, ft/min, Beaufort.分辨率: 0.2 mph.采样时间: 1 reading per second.平均值: 5, 10, or 13 second intervals.防水: to 3 ft (1 meter).风速低限: Limits: 0.5 to 89 mph.电源: Lithium battery (CR-2032 or equivalent) 400 hour life expectancy, replaceable.自动关闭: 30 minutes after last key is pressed. 叶轮: Plastic, replaceable. 外壳: Plastic.重量: 3 oz (95 g).认证: CE.
联系人:李小姐
地址:深圳市福田区福田大厦1109
邮编:518033
电话:0755-83692637
传真:-
公司网址:http://www.szdwd.com
