产品名称: MTL20/MTL30温度/湿度/露点记录仪产品型号: MTL20/MTL30技术指标温度范围: MTL20: -40 至 185°F (-40 至 85°C); MTL30: -40 至 160°F (-40 至 70°C), 0% 至 99% RH (无结露).精度: MTL20: ±1°F (±0.5°C); MTL30: ±1°F (±0.5°C), ±2% RH from 10% to 90% RH.分辨率: MTL20: 0.01°F (0.01°C); MTL30: 0.01°F (0.01°C), 0.01% RH.记忆容量: 43,334 temperature; 21,672 each temperature and RH.采样方式: Stop on memory full or memory rollover for continuous recording.采样速度: 1 sec. to 18 hrs.计算机配置: Windows®-based application software included.电源: 3.0 V lithium battery (included).报警: Programmable high/low.介面: USB port (cable included).重量: 1 oz (28 g).认证: CE
联系人:李小姐
地址:深圳市福田区福田大厦1109
邮编:518033
电话:0755-83692637
传真:-
公司网址:http://www.szdwd.com
