产品名称: FTS热导式温度开关流量开关产品型号: FTS特性介质: 水基液体.低流量设定: .4 m/s (1.2 fps) (water related) typical.温度设定: 122°F (50°C) or 158°F (70°C), other settings possible on OEM demand.温度范围: -4 to 176°F (-20 to 80°C).反应时间: 5 to 10 seconds.重复性: 0.5%.滞差s: <20% of set-point value.压力限制: 150 psi (10 bar).封装: NEMA 6 (IP 67).接液材质: 303 SS.连接: 1/2˝ Male NPT.电气连接: M12 male socket 4 pin with 6 ft (2 m) connection cable with M12 connector sold separately.电源: 18-30 VDC.电气额定: <200 mA.功耗: 4 W max.初始操作: After 15 seconds.开关类型: PNP N.O. (switch closes with flow).
联系人:李小姐
地址:深圳市福田区福田大厦1109
邮编:518033
电话:0755-83692637
传真:-
公司网址:http://www.szdwd.com
