欧姆龙旋转编码器E6B2系列产品介绍:Φ40的通用型,低、中分辨率型,行驱动线输出密封轴承的采用,实现了IP65f的防滴、防油构造。采用φ8mm不锈钢旋转轴。达到80N/50N(径向/推力)的轴允许力。实施CE标识(EMC指令)、适合EN/IEC规格,输出有- A, A及B, 或A 及 B 及 Z 方向输出有集电极开路输出,电压输出,线性驱动器输出可以配一些耦合器。
欧姆龙旋转编码器应用范围:用在一些需要计数,变速等场合如汽车制造,电子产品包装业,汽车运输,家电药业,保健金属加工,食品等行业。
欧姆龙旋转编码器E6B2系列型号:
E6B2-CWZ6C 1000P/R 0.5M BY OMS
E6B2-CWZ6C 1000P/R 2M BY OMS
E6B2-CWZ6C 100P/R 0.5M BY OMS
E6B2-CWZ6C 100P/R 2M BY OMS
E6B2-CWZ6C 1024P/R 0.5M BY OMS
E6B2-CWZ6C 1024P/R 2M BY OMS
E6B2-CWZ6C 10P/R 0.5M BY OMS
E6B2-CWZ6C 10P/R 2M BY OMS
E6B2-CWZ6C 1200P/R 0.5M BY OMS
E6B2-CWZ6C 1200P/R 2M BY OMS
E6B2-CWZ6C 1500P/R 0.5M BY OMS
E6B2-CWZ6C 1500P/R 2M BY OMS
E6B2-CWZ6C 1800P/R 0.5M BY OMS
E6B2-CWZ6C 1800P/R 2M BY OMS
E6B2-CWZ6C 2000P/R 0.5M BY OMS
E6B2-CWZ6C 2000P/R 2M BY OMS
E6B2-CWZ6C 200P/R 0.5M BY OMS
E6B2-CWZ6C 200P/R 2M BY OMS
E6B2-CWZ6C 20P/R 0.5M BY OMS
E6B2-CWZ6C 20P/R 2M BY OMS
E6B2-CWZ6C 300P/R 0.5M BY OMS
E6B2-CWZ6C 300P/R 2M BY OMS
E6B2-CWZ6C 30P/R 0.5M BY OMS
E6B2-CWZ6C 30P/R 2M BY OMS
E6B2-CWZ6C 360P/R 0.5M BY OMS
E6B2-CWZ6C 360P/R 2M BY OMS
E6B2-CWZ6C 400P/R 0.5M BY OMS
E6B2-CWZ6C 400P/R 2M BY OMS
E6B2-CWZ6C 40P/R 0.5M BY OMS
E6B2-CWZ6C 40P/R 2M BY OMS
E6B2-CWZ6C 500P/R 0.5M BY OMS
E6B2-CWZ6C 500P/R 2M BY OMS
E6B2-CWZ6C 50P/R 0.5M BY OMS
E6B2-CWZ6C 50P/R 2M BY OMS
E6B2-CWZ6C 600P/R 0.5M BY OMS
E6B2-CWZ6C 600P/R 2M BY OMS
E6B2-CWZ6C 60P/R 0.5M BY OMS
E6B2-CWZ6C 60P/R 2M BY OMS
E6B2-CWZ6C 720P/R 0.5M BY OMS
E6B2-CWZ6C 720P/R 2M BY OMS
E6B2-CWZ6C 800P/R 0.5M BY OMS
E6B2-CWZ6C-1 100P/R 0.5M BY OM
E6B2-CWZ6C-1 200P/R 0.5M BY OM
E6B2-CWZ6C-1 200P/R 2M BY OMS
E6B2-CWZ6C-1 300P/R 0.5M BY OM
E6B2-CWZ6C-1 500P/R 0.5M BY OM
E6B2-CWZ6C-1 50P/R 0.5M BY OMS
E6B2-CWZ6C-1 600P/R 0.5M BY OM
E6B2-CWZ6C-10 1000P/R 5M BY OM
E6B2-CWZ6C-10 100P/R 5M BY OMS
E6B2-CWZ6C-10 10P/R 5M BY OMS
E6B2-CWZ6C-10 1200P/R 5M BY OM
E6B2-CWZ6C-10 1500P/R 5M BY OM
E6B2-CWZ6C-10 2000P/R 5M BY OM
E6B2-CWZ6C-10 200P/R 5M BY OMS
E6B2-CWZ6C-10 20P/R 5M BY OMS
E6B2-CWZ6C-10 300P/R 5M BY OMS
E6B2-CWZ6C-10 30P/R 5M BY OMS
E6B2-CWZ6C-10 360P/R 5M BY OMS
E6B2-CWZ6C-10 400P/R 5M BY OMS
E6B2-CWZ6C-10 40P/R 5M BY OMS
E6B2-CWZ6C-10 500P/R 5M BY OMS
E6B2-CWZ6C-10 50P/R 5M BY OMS
E6B2-CWZ6C-10 60 P/R 5M BY OMS
E6B2-CWZ6C-10 600P/R 5M BY OMS
E6B2-CWZ6C-12 100P/R 10M BY OM
E6B2-CWZ6C-12 200P/R 10M BY OM
E6B2-CWZ6C-12 20P/R 10M BY OMS
E6B2-CWZ6C-12 300P/R 10M BY OM
E6B2-CWZ6C-12 30P/R 10M BY OMS
E6B2-CWZ6C-12 360P/R 10M BY OM
E6B2-CWZ6C-12 40P/R 10M BY OMS
E6B2-CWZ6C-12 50P/R 10M BY OMS
E6B2-CWZ6C-12 600P/R 10M BY OM
E6B2-CWZ6C-12-N 1000P/R 10M BY
E6B2-CWZ6C-17 100P/R 20M BY OM
E6B2-CWZ6C-17 50P/R 20M BY OMS
E6B2-CWZ6C-4 100P/R 0.5M BY OM
E6B2-CWZ6C-6 600P/R 0.5M BY OM
E6B2-CWZ6C-6 600P/R 10M BY OMS
E6B2-CWZ6C-6 600P/R 5M BY OMS
E6B2-CWZ6C-8 125P/R 0.5M BY OM
E6B2-CWZ6C-UL 1000P/R 2M BY OM
更多信息请访问福州力乐电气有限公司网站:http://www.lectron.cn
