DFS Digital force tester is a more economical digital force tester but thus, provide a and are available for all testing requirements, with capacities starting from 5 N to 2,500 N (0.5 to 250 Kg, 1.1 to 550 lbs). The DFS offers a far more functionality within its price range, with an accuracy of ±0.2%, and a lot of more features.
NEXTECH® DFS ForceTester is a more economical digital force tester but thus,provide a and are available for all testing requirements, withcapacities starting from 5 N to 2,500 N (0.5 to 250 Kg, 1.1 to 550lbs). The DFS Force Tester are compact, easy to use and measureboth the load of tension and compression. Units of measurement canbe displayed with any units (lb, Kg, N) of measurement desired, bya buttons click. The DFS offers a far more functionality within itsprice range, with an accuracy of ±0.2%, and a lot of morefeatures.
Features:
• Large LCD display • Economic design • Ease of use ofSoftware • Easy RS232 data connectivity • Highly accuratemeasurement • Check both Tension and Compression • Real time and peak mode (selectable) • NIST traceable calibration • Overloadalarm, low battery indicator • Interchangeable units between lb, kg and Newton • Compatible with common test stands and grips • Operates on rechargeable batteries or from direct ACpower supply • Full set of accessories including hook, plateextension rod, batteries,
| carrying case andAC Charger/Adapter and a user's manual |
Specification:
- Capacity Range: 9 Model, 5N to 2500N
- Accuracy + 0.2%
- Resolution 2500 divs
- A/D Rate 1000 Hz
- Effective Peak 0.1 sec
- Tension and Compression Testing: Both
- Overload Protection: 120% minimum
- Power: Rechargeable Battery or AC Power
- Display Type: Dot Matrix LCD
- Data Collection: RS232
- Weight: 27 oz (775 g) 500 N and below 37 oz(1060 g) 1000N and above
- Operating Temperature: 60ํ - 95 F (15-35 C)
- Includes: Hook, plate, extension rod, carrycase, batteries, charger, user’s manual, calibration certificate
- Load Bar: Shows load percentage to minimizeoverloads
- Battery Charge: 20 hours full operationfrom full charge
- Accessories Available: Universal test standmounting plate, serial cable, software, quick couplers andadapters, test stands, popular grip assortment
- Warranty: One years parts andLabor
Model DFS Capacity and Divisions:
Model No:
| mN
| N
| kN
| g-f
| kg-f
| oz-f
| lb-f
DFS 5
| 5000 x2
| 5 x0.002
| 500 x0.2
| 0.5 x0.0002
| 17.5 x0.010
| 1.1 x0.0005
DFS 10
| 10000 x5
| 10 x0.005
| 1000 x0.5
| 1 x0.0005
| 35 x0.02
| 2.2 x0.0010
DFS 25
| 25000 x10
| 25 x0.010
| 2500 x1.0
| 2.5 x0.0010
| 87.5 x0.05
| 5.5 x0.002
DFS 50
| 50000 x20
| 50 x0.02
| 5000 x2
| 5 x0.002
| 175 x0.10
| 11 x0.005
DFS 100
| 100 x0.05
| 10000 x5
| 10 x0.005
| 350 x0.2
| 22 x0.010
DFS 250
| 22 x0.010
| 25000 x10
| 25 x0.010
| 875 x0.5
| 55 x0.02
DFS 500
| 500 x0.2
| 50000 x20
| 50 x0.02
| 1750 x1.0
| 110 x0.05
DFS 1000
| 1000 x0.5
| 1 x0.0005
| 100 x0.05
| 220 x0.10
DFS 2500
| 2500 x1.0
| 2.5 x0.0010
| 100 x0.05
| 550 x0.2 | |
