SMD 1KN Digital Motorized Test Stand is a motorized test stand controlled by a single ballscrew-driven with a load rating of up to 1000N (220lbs), both upward and downward movement can be adjusted at multiple speeds. Together with our DFS and DFT force gauges and necessary accessories by NEXTECH? the SMD 1KN completes a force measurement system for accurately and efficiently testing a wide range of products.
The NEXTECH?SMD 1KN is a motorizedteststandcontrolled by a single ballscrew-driven with a load ratingofup to1000N (220lbs), both upward and downward movement canbeadjustedat multiple speeds. Together with our DFS and DFTforcegauges andnecessary accessories by NEXTECH? the SMD 1KNcompletesa forcemeasurement system for accurately and efficientlytesting awiderange of products.
Feature:
?Tensile or Compressionloadcapacity1000kN, 220lbsf, 100kgf ?Speed can be adjusted to 0.2" - 39.4"/Min(5-1000mm/Min) ?20.5?520mm) crosshead travel ?Large working area 9.6"X10.4" (243X265mm) ?慚anual', 'Single' and 慍ontinuous'Cyclecontrolmode ?Adjustable upper and lower limit switches ?7 digit LED speed indicator |
The Nextech SMD1000N is a ball-screw driven digital test frame with impressive abilities. The
dimensions, speed range and capacity have been carefully optimized to cover the test procedures and specimen sizes most often needed by quality departments within R&D and production industry.
The digital controls produce accurate testing speed and intuitive operation. The large slotted workspace secures awkward samples and f ixtures.
Two test modes increase productivity and enhanced stand control is available with the force gauge. Nextech offers a wide assortment of gauges, grips,accessories and software for a system that meets your needs at the best price.
Specifications:
Adjustable throat opening for the best combination of
opening and ultimate capacity.
Capacity
1000 N
220 lbf
100 kgf
7 5 0 N
1 6 5 l b f
75 kgf
500 N
110 lbf
50 kgf
Throat opening
2.6 inch
67 mm
3.8 inch
97mm
5.0 inch
127 mm |
Speed:0.2?0in/min /5 ?1000 mm/min
Speed accuracy:+4%of indicated speed
Mount holes:Two2.25 in /57 mm vertically spaced.
Travel:19.3inch / 490 mm
Warranty:1year parts and labor
Weight:54lb/25 kg
Dimensions:
Inches (mm)
![](http://admin.yi-z.cn/ComFolder/32714/SMD-1000N02.jpg)
