北京中瑞能仪表技术有限公司
  • PT100分度表、热电阻对照表,热电阻主要性能指标,温度传感器、PT100、热电阻精度、技术参数
  • 发布时间:2012/8/1 11:34:23   修改时间:2012/8/1 11:34:23 浏览次数:1658
  • PT100分度表、热电阻对照表,热电阻主要性能指标,温度传感器、PT100、热电阻精度、技术参数  热电阻主要性能指标 -北京中瑞能仪表技术有限公司专业生产PT100、热电阻、铂电阻、PT100温度传感器
    名称
    铂电阻
    铜电阻
    分度号
    Pt100
    Cu50
    Cu100
    测温范围
    -200~< XMLNAMESPACE PREFIX ="ST1" />500
    -50100
    允许偏差
    A
    ±(0.15+0.002-t)
    ±(0.30+0.006-t)
    B
    ±(0.30+0.005-t)
    pt 100分度表
    ℃  0 1 2 3 4 5 6 7 8 9 10
    -100 60.25 59.85 59.44 59.04 58.63 58.22 57.82 57.41 57 56.6 56.19
    -90 64.3 63.9 63.49 63.09 62.68 62.28 61.87 61.47 61.06 60.66 60.25
    -80 68.33 67.92 67.52 67.12 66.72 66.31 65.91 65.51 65.11 64.7 64.3
    -70 72.33 71.93 71.53 71.13 70.73 70.33 69.93 69.53 69.13 68.73 68.33
    -60 76.33 75.93 75.53 75.13 74.73 74.33 73.93 73.53 73.13 72.73 72.33
    -50 80.31 79.91 79.51 79.11 78.72 78.32 77.92 77.52 77.13 76.73 76.33
    -40 84.27 83.88 83.48 83.08 82.69 82.29 81.89 81.5 81.1 80.7 80.31
    -30 88.22 87.83 87.43 87.04 86.64 86.25 85.85 85.46 85.06 84.67 84.27
    -20 92.16 91.77 91.37 90.93 90.59 90.19 89.8 89.4 89.01 88.62 88.22
    -10 96.09 95.69 95.3 94.91 94.52 94.12 93.73 93.34 92.95 92.55 92.16
    0 100 100.39 100.78 101.17 101.56 101.95 102.34 102.73 103.12 103.51 103.9
    10 103.9 104.29 104.68 105.07 105.46 105.85 106.24 106.63 107.02 107.4 107.79
    20 107.79 108.18 108.75 108.96 109.35 109.73 110.12 110.51 110.9 111.28 111.67
    30 111.67 112.06 112.45 112.83 113.22 113.61 114.99 114.38 114.77 115.15 115.54
    40 115.54 115.93 116.31 116.7 117.08 117.47 117.85 118.24 118.62 119.01 119.4
    50 119.4 119.78 120.16 120.55 120.93 121.32 121.7 122.09 122.47 122.86 123.24
    60 123.24 123.62 124.01 124.39 124.77 125.16 125.54 125.92 126.31 126.69 127.07
    70 127.07 127.45 127.84 128.22 128.6 128.98 129.37 129.75 130.13 130.51 130.89
    80 130.89 131.27 131.66 132.04 132.42 132.8 133.18 133.56 133.94 134.32 134.7
    90 134.7 135.08 135.46 135.84 136.22 136.6 136.98 137.36 137.74 138.12 138.5
    100 138.5 138.88 139.26 139.64 140.02 140.39 140.77 141.15 141.53 141.91 142.29
    110 142.29 142.66 143.04 143.42 143.8 144.17 144.55 144.93 145.31 145.68 146.06
    120 146.06 146.44 146.81 147.19 147.57 147.94 148.32 148.7 149.07 149.45 149.82
    130 149.82 150.2 150.57 150.95 151.33 151.7 152.08 152.45 152.83 153.2 153.58
    140 153.58 153.95 154.32 154.7 155.07 155.45 155.82 156.19 156.57 156.94 157.31
    150 157.31 157.69 158.06 158.43 158.81 159.18 159.55 159.93 160.3 160.67 161.04
    160 161.04 161.42 161.79 162.16 162.53 162.9 163.27 163.65 164.02 164.39 164.76
    170 164.76 165.13 165.5 165.87 166.24 166.61 166.98 167.35 167.72 168.09 168.46
    180 168.46 168.83 169.2 169.57 169.94 170.31 170.68 171.05 171.42 171.79 172.16
    190 172.16 172.53 172.9 173.26 173.63 174 174.37 174.74 175.1 175.47 175.84
    200 175.84 176.21 176.57 176.94 177.31 177.68 178.04 178.41 178.78 179.14 179.51
    210 179.51 179.88 180.24 180.61 180.97 181.34 181.71 182.07 182.44 182.8 183.17
    220 183.17 183.53 183.9 184.26 184.63 184.99 185.36 185.72 186.09 186.45 186.82
    230 186.32 187.18 187.54 187.91 188.27 188.63 189 189.36 189.72 190.09 190.45
    240 190.45 190.81 191.18 191.54 191.9 192.26 192.63 192.99 193.35 193.71 194.07
    250 194.07 194.44 194.8 195.16 195.52 195.88 196.24 196.6 196.96 197.33 197.69
    260 197.69 198.05 198.41 198.77 199.13 199.49 199.85 200.21 200.57 200.93 201.29
    270 201.29 201.65 202.01 202.36 202.72 203.08 203.44 203.8 204.16 204.52 204.88
    280 204.88 205.23 205.59 205.95 206.31 206.67 207.02 207.38 207.74 208.1 208.45
    290 208.45 208.81 209.17 209.52 209.88 210.24 210.59 210.95 211.31 211.66 212.02
    300 212.02 212.37 212.73 213.09 213.44 213.8 214.15 214.51 214.86 215.22 215.57
    310 215.57 215.93 216.28 216.64 217.99 217.35 217.7 218.05 218.41 218.76 219.12
    320 219.12 219.47 219.82 220.18 220.53 220.88 221.24 221.59 221.94 222.29 222.65
    330 222.65 223 223.35 223.7 224.06 224.41 224.76 225.11 225.46 225.81 226.17
    340 226.17 226.52 226.87 227.22 227.57 227.92 228.27 228.62 228.97 229.32 229.67
    350 229.62 230.02 230.42 230.82 231.22 231.62 232.02 232.42 232.82 233.22 233.62
    360 233.17 233.52 233.87 234.22 234.56 234.91 235.26 235.61 235.96 236.31 236.65
    370 236.65 237 237.35 237.7 238.04 238.39 238.74 239.09 239.45 239.78 240.13
    380 240.13 240.47 240.82 241.17 241.51 241.86 242.2 242.55 242.9 243.24 243.59
    390 243.59 243.93 244.28 244.62 244.97 245.31 245.66 246 246.35 246.69 247.04
    400 247.04 247.38 247.73 248.07 248.41 248.76 249.1 249.45 249.79 250.13 250.48
    410 250.48 250.82 251.16 251.5 251.85 252.19 252.53 252.55 253.22 253.56 253.9
    420 253.9 254.24 254.59 254.93 255.27 255.61 255.95 256.29 256.64 256.98 257.32
    430 257.32 257.66 258 258.34 258.68 259.02 259.36 259.7 260.04 260.38 260.72
    440 260.72 261.06 261.4 261.74 262.08 262.42 262.76 263.1 263.43 263.77 264.11
    450 264.11 264.45 264.79 265.13 265.47 265.8 266.14 266.48 266.82 267.15 267.49
    460 267.49 267.83 268.17 268.5 268.84 269.18 269.51 269.85 270.19 270.52 270.86
    470 270.86 271.2 271.53 271.87 272.2 272.54 272.88 273.21 273.55 273.88 274.22
    480 274.22 274.55 274.89 275.22 275.56 275.89 276.23 276.56 276.89 277.23 277.56
    490 277.56 277.9 278.23 278.56 278.9 279.23 279.56 279.9 280.23 280.56 280.9
    500 280.9 281.23 281.56 281.89 282.23 282.56 282.89 283.22 283.55 283.89 284.22
    510 284.22 284.55 284.88 285.21 285.54 285.87 286.21 286.54 286.87 287.2 287.53
    520 287.53 287.86 288.19 288.52 288.85 289.18 289.51 289.84 290.17 290.5 290.83
    530 290.83 291.16 291.49 291.81 292.14 292.47 292.8 293.13 293.46 293.79 294.11
    540 294.11 294.44 294.77 295.1 295.43 295.75 296.08 296.41 296.74 297.06 297.39
    550 297.39 297.72 298.04 298.37 298.7 299.02 299.35 299.68 300 300.33 300.65
    560 300.65 300.98 301.31 301.63 301.96 302.28 302.61 302.93 303.26 303.58 303.91
    570 303.91 304.23 304.56 304.88 305.2 305.53 305.85 306.18 306.5 306.82 307.15
    580 307.15 307.47 307.79 308.12 308.44 308.76 309.09 309.41 309.73 310.05 310.38
    590 310.38 310.7 311.02 311.34 311.67 311.99 312.31 312.63 312.95 313.27 313.59
    600 313.59 313.92 314.24 314.56 314.88 315.2 315.52 315.84 316.16 316.48 316.8
    610 316.8 317.12 317.44 317.76 318.08 318.4 318.72 319.04 319.36 319.68 319.99
    620 319.99 320.31 320.63 320.95 321.27 321.59 321.91 322.22 322.54 322.86 323.18
    630 323.18 323.49 323.81 324.13 324.45 324.76 325.08 325.4 325.72 326.03 326.35
    640 326.35 326.66 326.98 327.3 327.61 327.93 328.25 328.56 328.88 329.19 329.51
    650 329.51 329.82 330.14 330.45 330.77 331.08 331.4 331.71 332.03 332.34 332.66
    660 332.66 332.97 333.28 333.6 333.91 334.23 334.54 334.85 335.17 335.48 335.79
    670 335.79 336.11 336.42 336.73 337.04 337.36 337.67 337.98 338.29 338.61 338.92
    680 338.92 339.23 339.54 339.85 340.16 340.48 340.79 341.1 341.41 341.72 342.03
    690 342.03 342.34 342.65 342.96 343.27 343.58 343.89 344.2 344.51 344.82 345.13
    700 345.13 345.44 345.75 346.06 346.37 346.68 346.99 347.3 347.6 347.91 348.22
    710 348.22 348.53 348.84 349.15 349.45 349.76 350.07 350.38 350.69 350.99 351.3
    720 351.3 351.61 351.91 352.22 352.53 352.83 353.14 353.45 353.75 354.06 354.37
    730 354.37 354.67 354.98 355.28 355.59 355.9 356.2 356.51 356.81 357.12 357.42
    740 357.42 357.73 358.03 358.34 358.64 358.95 359.25 359.55 359.86 360.16 360.47
    750 360.47 360.77 361.07 361.38 361.68 361.98 362.29 362.59 362.89 363.19 363.5
    760 363.5 363.8 364.1 364.4 364.71 365.01 365.31 365.61 365.91 366.22 366.52
    770 366.52 366.82 367.12 367.42 367.72 368.02 368.32 368.63 368.93 369.23 369.53
    780 369.53 369.83 370.13 370.43 370.73 371.03 371.33 371.63 371.93 372.22 372.52
    790 372.52 372.82 373.12 373.42 373.72 374.02 374.32 374.61 374.91 375.21 375.51
    800 375.51 375.81 376.1 376.4 376.7 377 377.29 377.59 377.89 378.19 378.48
北京中瑞能仪表技术有限公司,是北京市科委认证的高新技术企业。公司主要从事工业自动化仪表的开发、研制、生产,主要产品有:电磁流量计、超声波流量计、扭矩、称重、压力变送器和压力传感器、位移、流量、液位、温度、湿度、显示表等系列.产…  更多>>
北京中瑞能仪表技术有限公司
联系人:赵凯
地址:北京中关村
邮编:100000
电话:010-62101662
传真:010-58857017
公司网址:http://www.zrn360.com
  • 裴先行 在2019/3/30 11:27:00留言
  • 详细留言:电机外形尺寸277.8(厚)*518(直径) 安装孔中心位置44*214 转速6000,扭矩4000N.m
  • 周情 在2018/12/13 10:37:00留言
  • 详细留言:了解及购买扭矩仪
  • 周情 在2018/12/13 8:09:00留言
  • 详细留言:了解及购买扭矩仪
  • 仇学军 在2018/7/27 15:51:00留言
  • 详细留言:无需串联在传动系统中的测量扭矩的传感器
  • 王兰群 在2018/6/15 13:56:00留言
  • 详细留言:我想咨询贴片式温度传感器的具体信息
