西安浩南电子电子科技有限公司
  • ASTRODYNE多路输出电源REL185系列
  • 发布时间:2010/12/28 16:24:05   修改时间:2014/5/11 17:57:05 浏览次数:1413
  • REL185 185w Power Supplies
    *185 Watt Open Frame Switching Power Supply with PFC
     *Universal 85-265VAC Input
     *Single, Dual, Triple, and Quad Outputs
     *Active Power Factor Correction
     *2.5VDC to 48VDC Outputs
    *Model Number
    *Output Voltage
    *Output Amps
    *Remote Sense
    REL185-1001
     2.5V (Output # 1)
     37 Amps (Output # 1)
     250mV compensation
    REL185-1002
     3.3V (Output # 1)
     /37 Amps (Output # 1)
     250mV compensation
    REL185-1003
     5V (Output # 1)
     250mV compensation
    REL185-1004
     12V (Output # 1)
     15 Amps (Output # 1)
     250mV compensation
    REL185-1005
     15V (Output # 1)
     12 Amps (Output # 1)
     250mV compensation
    REL185-1006
     24V (Output # 1)
     7.7 Amps (Output # 1)
     250mV compensation
    REL185-1007
     28V (Output # 1)
     6.6 Amps (Output # 1)
     250mV compensation
    REL185-1008
     48V (Output # 1)
     3.8 Amps (Output # 1)
     250mV compensation
    REL185-2001
     3.3V (Output # 1)/5V (Output # 2)
     20 Amps (Output # 1)/10 Amps (Output # 2)
    REL185-2002
     5V (Output # 1)/12V (Output # 2)
     20 Amps (Output # 1)/8 Amps (Output # 2)
    REL185-2003
     5V (Output # 1)/24V (Output # 2)
     20 Amps (Output # 1)/4 Amps (Output # 2)
    REL185-2004
     12V(Output # 1)/-12V (Output #2)
     10 Amps (Output # 1)/6 Amps (Output #2)
    REL185-2005
     15V (Output # 1)/-15V (Output # 2)
     8 Amps (Output # 1)/5 Amps (Output # 2)
    REL185-3001
     5V (Output # 1)/12V (Output # 2)/-12V (Output # 4)
     20 Amps (Output # 1)/5 Amps (Output # 2)/3 Amps (Output # 4)
    REL185-3002
     5V (Output # 1)/15V (Output # 2)/-15V (Output # 4)
     20 Amps (Output # 1)/4 Amps (Output # 2)/3 Amps (Output # 4)
    REL185-4001
     3.3V (Output # 1)/5V (Output #2)/12V (Output # 3)/-12V (Output # 4)
     20 Amps (Output # 1)/10 Amps (Output #2)/2 Amps (Output # 3)/2 Amps (Output # 4)
    REL185-4002
     5V (Output # 1)/3.3V (Output # 2)/12V (Output # 3)/-12V (Output # 4)
     20 Amps (Output # 1)/10 Amps (Output # 2)/2 Amps (Output # 3)/2 Amps (Output # 4)
    REL185-4003
     5V (Output # 1)/3.3V (Output # 2)/15V (Output # 3)/-15V (Output # 4)
    REL185-4004
     5V (Output # 1)/-5V (Output # 2)/12V (Output # 3)/-12V (Output # 4)
    REL185-4005
     5V (Output # 1)/-5V (Output # 2)/15V (Output # 3)/-15V (Output # 4)
    REL185-4006
     5V (Output # 1)/24V (Output # 2)/12V (Output # 3)/-12V (Output # 4)
     20 Amps (Output # 1)/3 Amps (Output # 2)/2 Amps (Output # 3)/2 Amps (Output # 4)
    REL185-4007
     5V (Output # 1)/24V (Output # 2)/15V (Output # 3)/-15V (Output # 4)
    REL185 series
    Input Specifications
    Input Voltage Range
     85-264 VAC
    Frequency Range
     47-63Hz.
    Inrush Current
     30A @ 115VAC, typ, 40A @ 230VAC, typ (note 4)
    Leakage Current
     <300uA @ 240VAC
     >0.95@115VAC
    Environmental Specifications
    Operating Temperature
     0 to +60 °C (note 4)
    EMC
     EN55022/B, EN61000-3-2,3/A, EN61000--4-2,3,4,5,6,8,1 1/Cr A
    Storage Temperature
     -40 to +85 °C (note 4)
    Relative Humidity
     10-95%, Description (note 4)
    MTBF
     100KHrs, MIL-Std 217F
    Vibration
     To MIL-Std 810E
    Notes
    1. All specifications typical @ 25°C, Nominal Line & Load, unless otherwise noted.
    2. O/P noise measured directly at pins/terminals with 0.1uFbypass, pk-pk @ 20MHz bandwidth.
    3. Ripple and Noise dependant upon output voltage as specified per particular model.
    4. These are stress ratings. Exposure of the devices to any of these conditions may adversely affect long term reliability. Proper operation under conditions other than the standard operating conditions is neither warranteed or implied.
    5. Isolation for up to 1 minute duration.
    6. No termination necessary with control pin to maintain constant “ON” operation (if applicable to this model)
    7. Max load (peak) specified for 10mS max, 20% duty cycle, minimum load on all outputs.
    All specifications are typical at nominal input, full load, and 25°C unless otherwise noted
    Astrodyne products are not authorized or warranteed for use as critical components in life support systems, equipment used in hazardous environments, nuclear controls systems, or other mission-critical applications.
     Physical Specifications
    *Size (mm)
     177.79 x 108.2 x 33.27 mm
    *Size (Inches)
     7”x4.26”x1.31”
    *Construction
     Open Frame
    *Weight (g)
     771.1g
    Weight (oz)
     27.2oz
    *Output Specifications
    Output Voltage
     2.5V (Output # 1)
    *Output Amps
    Minimum Load Requirement
     10%
    Load Regulation
     ± 1%, typ
    Line Regulation
     ± 0.5%, typ
    Cross Regulation
     ±5%
    Preset Accuracy
     ±1%, typ
    Temperature Coefficient
     ± 0.02%/°C
    Ripple and Noise
     100mV Pk-Pk, typ
    Voltage Tolerance
    Over Voltage Protection
     110-150%, Type 2 & 3
    Over Current Protection
     110-160% typ, Auto Recovery
    Start Up
     5Sec, typ
    Short Circuit Protection
     Continuous (note 4)
    Peak Load
     See Model Selection Chart 7
    Hold Up Time
     16mS
    DC Voltage Adjust (typ.)
     ± 5%, typ
    Remote Sense
     250mV compensation
    General Specifications
    Isolation
     3000VAC (note 5)
    Isolation Input-Ground
     1500VAC
    Isolation Output-Ground
     500VAC
    Efficiency
     82%, typ (or See Chart/Curve)
    Safety Approvals
     UL60950/EN60950 Approved
西安浩南电子科技有限公司是一家销售电源,滤波器及电流电压传感器的贸易公司.公司为国内工业企业,船舶,电子通讯,仪器仪表,工控通讯及新能源等企业提供配套产品.   公司主要销售的电源模块,电流电压传感器及EMI/EMC滤波器等产品品牌有: Gaia,…  更多>>
西安浩南电子电子科技有限公司
联系人:刘彦成
地址:西安市高新一路6号
邮编:710075
电话:029-88231631
传真:029-88231651
公司网址:http://www.haonpower.com
  • 黄先生 在2015/9/1 12:34:00留言
  • 详细留言:我司有全新原装VICOR电源模块 型号V300A12M500BL,50片,现在低价处理,贵公司若有这方面的订单随时与我联系,谢谢!
  • 王力 在2014/12/15 17:50:00留言
