越华电容器 BSMJ /MKPg/CLMD系列
1.真空灌封技术:电容器内充特殊的保护介质,不泄漏、安全环保;避免环境污染、火灾等风险。
Vacuum casting technology: special protective medium filled in capacitor, not leak, security and environmental; to avoid environmental pollution, fire and other risks
2.自愈性:优良的自愈性能,当过电压所造成的介质局部击穿能迅速自我修复,恢复正常工作。
Self-healing: excellent self-healing capability can self-repair quickly and renew to working when over pressure destroy the part of medium.
3.安全保护装置:(获得专利)过压拉断可防止电容器在邻近寿命服务期限或由于电器过载及过热而引发事故。
Security installation :( Patented)over pressure snap can prevent capacitor to bring accident when close to use life or capacitor’s over heat.
4.新型、安全、可靠的接线端子可以更方便地连接,隐藏式设计,防止意外触摸,结构独特:
new type, security and dependable terminal lead connect more convenience, Perdue design prevent accidental touch, unique structure
.电容器的输入端简化了并联应用方式。
Capacitor’s terminal predigest the Parallel application form
.防电击危险保护
Prevent tip-and-run protection
.内置放电电阻和保险装置,使用安全可靠
Building-in discharge resistance and safety installation, the use of safe and reliable
.电缆横截面可高达16mm2
cable’s cross section can up to 16mm2
*优越电性能
对于无功功率,CLMD低压电容器可极大地改进功率质量和降低能量损失:
Reactive power, CLMD low-voltage capacitor can improve power quality and reduce loss of energy
★降低或消除因低功率因数而带来的昂贵代价
Reduce or eliminate the high cost
★降低电缆和变压器中的功率损失,增加电缆电力传输能力
Reduce the power loss of cable and transformer
★增加变压器容量
Increase transformer capacity
★改善长电缆中的电压稳定性
Improve long cable’s voltage stability
★节能、环保、安全、可靠
Economize, environmental, security and reliable
