BSMJ、MKPg、CLMD越华电容器
镀锌钢板,坚固耐用Galvanized steel sheet,durable
优良电器性能Excellent electrical capability
最优介质薄膜The best quality medium membrane
多元件结构Multi-component structure
发热少Less fever heat
温升低Low Temperature Rise
超强自愈性能Excellent Self-healing capability
使用寿命长Long using life
固定安装脚,方便简洁Fixed setting foot, convenience and concision
M5安全接地引线 M5 secure earthing down-lead
内装放电电阻 building-in discharge resistance
三分钟放电至50V以下 voltage drop to 50Vafter cutting out 3 min
单独密封individual airproof
整体安装products wholes install
双重电气保护 dual electrical protection.
