上海明想电子
  • ASCO-电磁阀-064982-006-D
  • 发布时间:2009/4/11 9:37:36   修改时间:2009/4/11 9:37:36 浏览次数:3677
  • 上海明想电子科技有限公司
    我公司所有的产品直接从境外进货,能够提供不同国别、厂商的设备配件,
    解决您多处寻找的麻烦和对产品质量的担心等,在价格上我们有很大的优势,
    欢迎来电咨询,我们将会给您最优质的服务!
    产品详细信息,欢迎来电查询! 上海明想电子科技有限公司
    主要业务:提供日立,HUBELL,HOFFMAN,HAMMOND,HP,AGILENT,EFECTOR,ICP DAS USA,
    INDRAMAT,JOHNSON YOKOGAWA,KEYENCE CORP,JOHNSON CONTROLS
    PLC联系人:秦先生 TEL:021-31261686 FAX:021-31059032
    E-mail:712736091@qq.com    MSN icedrak@msn.com   QQ:712736091
    Manufacturer Part No. Description
    ASCO 027466-001-120 COIL KIT
    ASCO 027466001120V VALVE
    ASCO 027476-001-D-120 COIL 115/60 FOR SOLENOID VALVE
    ASCO 027476-002-D-240 COIL 230/60 FOR SOLONOID VALVE
    ASCO 64982001 COIL
    ASCO 064982-002-D REPLACEMENT COIL FOR SOLENOID
    ASCO 064-982-004-D COIL 120VAC
    ASCO 064982-004-D-120 COIL KIT
    ASCO 064982-005-D COIL FOR SOLENOID VALVE 240V FT
    ASCO 064982-006-D REPAIR KIT
    ASCO 064-982-5-D COIL FOR SOLENOID VALVE 240V FT
    ASCO 066611-002-D COIL REPLACEMENT 120VDC
    ASCO 067179-002-240 COIL SWITCH KIT
    ASCO 068-038 KIT SOLENOID VALVE
    ASCO 90683 KIT SOLENOID VALVE
    ASCO 93609 REPAIR KIT
    ASCO 096619-001-D REPLACEMENT COIL
    ASCO 096619-002-D COIL
    ASCO 096817-001-D-120 COIL KIT 110/50 120/60
    ASCO 096-875 KIT SOLENOID VALVE
    ASCO 97813 VALVE
    ASCO 099-216-001-D-120 COIL 120VAC
    ASCO 099216002D COIL
    ASCO 099216-003-D-120 COIL
    ASCO 099216005D COIL
    ASCO 099257001D COIL
    ASCO 099257-001-D-120 COIL REPLACEMENT 120V 60HZ
    ASCO 099257-005-D COIL 120VAC WITH 18IN LEADS
    ASCO 099257-005-D-120 COIL KIT 120VAC
    ASCO 099257-006-D-240 COIL KIT
    ASCO 099257006D240V COIL
    ASCO 100424 MAINTENANCE KIT FOR VALVE
    ASCO 100-691 KIT VALVE REPAIR
    ASCO 100-833-5D-24DC COIL REPLACEMENT 24 VDC
    ASCO 102-839 KIT VALVE REPAIR
    ASCO 102-855 REPAIR KIT
    ASCO 103-833-005-D-120 COIL REPLACEMENT FOR VALVE
    ASCO 103-832-005-D-12/24DC COIL REPLACEMENT FOR VALVE 12/24VDC
    ASCO 103-833-005-D COIL 24 VDC
    ASCO 103-833-005-D-24DC VALVE COIL 24VDC
    ASCO 10700127 VALVE
    ASCO 108D10C PANEL
    ASCO 1125892 VALVE 1/4 3 WAY 120VAC
    ASCO 11490516 SOLENOID
    ASCO 1179237 VALVE 1/8 PIPE 120VAC 200 PSI
    ASCO 1179237-110 VALVE 1/8 3PORT
    ASCO 12600008 SOLENOID VALVE
    ASCO 131201 REBUILD KIT
    ASCO 131204 REBUILD KIT
    ASCO 158929 VALVE REPAIR KIT
    ASCO 158-959 VALVE REPAIR KIT
    ASCO 160098 REPAIR KIT
    ASCO 160855 REPAIR KIT
    ASCO 164-931 VALVE REPAIR KIT
    ASCO 16500089 VALVE
    ASCO 166-249 REPAIR KIT
    ASCO 16630C CONTACTOR WITH ENCLOSURE 120VAC COIL 3POLE
    ASCO 168-134-5 COIL REPLACEMENT
    ASCO 168699 REPAIR KIT
    ASCO 168858 REPAIR KIT
    ASCO 172827 REPAIR KIT
    ASCO 172828 KIT
    ASCO 174038 REPAIR KIT
    ASCO 174957-001 COIL 120V
    ASCO 176-447 REPAIR KIT
    ASCO 176-911 KIT BULL F210
    ASCO 178-417 VALVE KIT
    ASCO 178-418 VALVE KIT
    ASCO 180-466 VALVE
    ASCO 18193 FLAME ROD
    ASCO 182032 REPAIR KIT
    ASCO 19000006 24VDC
    ASCO 190073 SOLENOID VALVE 24VDC
    ASCO 19200002 VALVE
    ASCO 197660 RELAY
    ASCO 1982182D COIL
    ASCO 204-556-001 COIL REPLACEMENT KIT
    ASCO 204-558-001 VALVE COIL KIT
    ASCO 204-945-1 REPAIR KIT COILS
    ASCO 206409011D COIL
    ASCO 208-056-120 SOLENOIND VALVE 120AC EXPLOSION PROOF
    ASCO 208544 KIT
    ASCO 21100140 VALVE
    ASCO 212392 KIT
    ASCO 214A293-480 UNDER VOLTAGE CONTROL 480VAC 10%W/DROP OUT RELAY
    ASCO 214B281 SEQUENCE CTRL
    ASCO 216B89 SWITCH ASSY
    ASCO 216C89 PART
    ASCO 218-941 REPAIR KIT SOLENOIND
    ASCO 218-956 VALVE REPAIR KIT
    ASCO 220-931 REPAIR KIT
    ASCO 222184015D COIL
    ASCO 222641 VALVE KIT
    ASCO 224195-001-D COIL 120/60HZ 110/50HZ
    ASCO 226188 REPAIR KIT
    ASCO 238210-032D COIL 120V
    ASCO 238210-088-D-480 COIL 480/60 440/50 HZ
    ASCO 238214-032-D SOLENOID COIL 120V 60HZ
    ASCO 238514335D COIL
    ASCO 238610005D COIL
    ASCO 238610032 COIL
    ASCO 238610-032-D REPLACEMENT COIL
    ASCO 238610132-D COIL
    ASCO 23861032 SOLENOID
    ASCO 238612032 COIL
    ASCO 238614-032-D 120V COIL
    ASCO 238614-132-D COIL REPLACEMENT
    ASCO 23861432D SOLENOID
    ASCO 238864 KIT
    ASCO 238-910-004-D VALVE COIL KIT
    ASCO 238910-006-D COIL EXPLOSION PROOF
    ASCO 258851 RETAINING CLIP
    ASCO 262964 REPAIR KIT
    ASCO 2.63E+13 SOLENOID VALVE
    ASCO 263900003 SOLENOID VALVE
    ASCO 263C02D11X03 UNIT
    ASCO 266762 COIL
    ASCO 270110032D COIL
    ASCO 2705TBTD2 DIAPHAGM VALVE F3/T 1 1/4INCH 3/2 166
    ASCO 272873 REPAIR KIT DIN CONNECTOR
    ASCO 27-462-2-D COIL FOR SOLENOID VALVE 240/60 220/50
    ASCO 27-463-3 COIL FOR SOLENOID VALVE 12VDC
    ASCO 274662 COIL
    ASCO 27-477-1-D COIL FOR SOLENOID VALVE 110-125VDC
    ASCO 27-478-3-B COIL
    ASCO 276886 REPAIR KIT
    ASCO 28400025 VALVE
    ASCO 28490041 VALVE
    ASCO 29A-120 COIL 115/60
    ASCO 302018 REBUILD KIT
    ASCO 302037 VALVE REPAIR KIT
    ASCO 302100 REPAIR KIT
    ASCO 302-116 VALVE REPAIR KIT
    ASCO 302118 VALVE REPAIR KIT
    ASCO 302-120 VALVE REPAIR KIT
    ASCO 302-121 VALVE REPAIR KIT
    ASCO 302143 KIT SOLENOID VALVEREBUILD AC FOR 8320G186
    ASCO 302144 REPAIR KIT
    ASCO 302148 KIT
    ASCO 302168 REPAIR KIT FOR 8320SERIES
    ASCO 302183 KIT
    ASCO 302184 REPAIR KIT
    ASCO 302185V KIT
    ASCO 302227 SOLENOID VALVE REPAIR KIT
    ASCO 302234J REBUILD KIT
    ASCO 302270 REBUILD KIT
    ASCO 302-272 REPAIR KIT FOR SOLENOID VALVE
    ASCO 302-273 REPAIR KIT FOR SOLENOID VALVE
    ASCO 302273MO REPAIR KIT
    ASCO 302-275 VALVE REPAIR KIT
    ASCO 302276 VALVE REPAIR KIT
    ASCO 302276VH REPAIR KIT
    ASCO 302-277 KIT SOLENOID VALVE
    ASCO 302279 REBUILD KIT 8210 AC
    ASCO 302283 REBUILD KIT/VALVE/ #R02-1246
    ASCO 302-284 REPAIR KIT
    ASCO 302289V REBUILD KIT
    ASCO 302-290 VALVE REPAIR KIT
    ASCO 302297 REPAIR KIT
    ASCO 302-300 VALVE REPAIR KIT
    ASCO 302305 REPAIR KIT
    ASCO 302313 REPAIR KIT
    ASCO 302314N REPAIR KIT
    ASCO 302315 KIT
    ASCO 302326 REPLACEMENT STEM AND SEAL KIT
    ASCO 302-328 REPAIR KIT FOR SOLENOID VALVE
    ASCO 302328V KIT
    ASCO 302329V KIT
    ASCO 302-334 REBUILD KIT
    ASCO 302337 REPAIR KIT
    ASCO 302-339 KIT VALVE REBUILD
    ASCO 302-344 REPAIR KIT
    ASCO 302-345 VALVE REPAIR KIT
    ASCO 302350 KIT
    ASCO 302361 REBUILD KIT
    ASCO 302377 REPAIR KIT
    ASCO 302390 VALVE KIT FOR REBUILT 8211
    ASCO 302392 KIT
    ASCO 302394 REPAIR KIT
    ASCO 302-423 VALVE REPAIR KIT
    ASCO 302-697 REPAIR KIT
    ASCO 302698 KIT
    ASCO 302710 VALVE REPAIR KIT
    ASCO 302712 REPAIR KIT
    ASCO 302716 KIT
    ASCO 302749 VALVE
    ASCO 302757 REPAIR KIT
    ASCO 302787 REPAIR KIT
    ASCO 302791 REPAIR KIT
    ASCO 302798 REPAIR KIT
    ASCO 302-847 VALVE REPAIR KIT
    ASCO 302898 REPAIR KIT
    ASCO 302-912 VALVE REPAIR KIT
    ASCO 302926 KIT SOLENOID VALVE
    ASCO 302929 KIT
    ASCO 304-006 REPAIR KIT FOR SOLENOID VALVES
    ASCO 304-023 VALVE REPAIR KIT
    ASCO 304-031 VALVE REPAIR KIT
    ASCO 304035 KIT
    ASCO 304-057 REPAIR KIT
    ASCO 304063 REBUILD KIT
    ASCO 304064 REBUILD KIT
    ASCO 304076 SOLENOID VALVE REPAIR KIT FOR 8210SERIES
    ASCO 304-323 REPAIR KIT
    ASCO 304-354 VALVE REPAIR KIT
    ASCO 304354-J REBUILD KIT
    ASCO 304355 REBUILD KIT
    ASCO 304357 REPAIR KIT
    ASCO 304364 KIT
    ASCO 304393 KIT
    ASCO 304419 KIT
    ASCO 304-669 REPAIR KIT
    ASCO 304877 REPAIR KIT
    ASCO 304941 SOLENIOD VALVE SERIES 8215 2-WAY INT PILOT
    ASCO 304943 KIT
    ASCO 304-949 VALVE REPAIR KIT
    ASCO 306164 REPAIR KIT
    ASCO 306191 REPAIR KIT
    ASCO 306192 KIT
    ASCO 306329 REPAIR KIT
    ASCO 306-684-U VALVE REPAIR KIT
    ASCO 306686RU KIT
    ASCO 310304 KIT
    ASCO 310-306 REPAIR KIT
    ASCO 310398-HW REPAIR KIT WITH HOT WATER OPTION
    ASCO 310421 KIT
    ASCO 310422 KIT
    ASCO 314453 VALVE MAINTENANCE KIT
    ASCO 314455 REPAIR KIT
    ASCO 314491 VALVE REPAIR KIT
    ASCO 314492 KIT
    ASCO 314496Q KIT
    ASCO 314546 VALVE
    ASCO 314633 REPAIR KIT
    ASCO 316090 VALVE
    ASCO 316372 REBUILD KIT
    ASCO 320341 KIT
    ASCO 321A36 BOARD ASSEMBLY
    ASCO 331700005 CONTROL
    ASCO 34201403 PNEUMATIC VALVE 0-150PSI TWO-1/4 ONE-1/8 NPT
    ASCO 34201422 REGULATOR MIN W/GAGUE
    ASCO 34203052 PRESSURE REGUL
    ASCO 34203082 VALVE
    ASCO 3420327 REGULATOR
    ASCO 34225027 REGULATOR MIN W/GAGUE
    ASCO 34300004 MOUNTING RING TOP
    ASCO 34300016 MOUNTING BRACKET 105 OR 107
    ASCO 34300017 MOUNTING BRACKET
    ASCO 34600156 FLOW CONTROL
    ASCO 3636701 COIL ASSEMBLY
    ASCO 3636714 CONTACT BLOCK
    ASCO 37300017 MOUNTING BRACKET
    ASCO 400-215-121-D-120 VALVE
    ASCO 400-215-125-D-120 COIL REPLACEMENT 120VAC 6.2W
    ASCO 454-9004 SOLENOID AIR VALVE 120VAC
    ASCO 47 RELAY
    ASCO 48 RELAY
    ASCO 55100083 SOLENOID
    ASCO 6080-551-120 SOLENOID AIR VALVE 120VAC
    ASCO 6080-551-24 SOLENOID AIR VALVE 24VAC
    ASCO 6080-551-24DC SOLENOID AIR VALVE 24VDC
    ASCO 64-982-005D-240 COIL 240VAC
    ASCO 649821 COIL
    ASCO 64-982-1-D-120 COIL REPLACEMENT120VAC
    ASCO 649824 COIL
    ASCO 68051 REPAIR KIT
    ASCO 758-929-821-0095-C95-AC REPAIR KIT FOR 8210 AND 8211 VALVE
    ASCO 78ATSA3400C5C TRANSFER SW
    ASCO 7ACTS3400N5X TRANSFER SW
    ASCO 7ACTS3400N5X6D TRANSFER SW
    ASCO 7ATSA3150 SWITCH ASSY
    ASCO 7ATSA3150C5C SWITCH
    ASCO 8014G2 SOLENOID VALVE
    ASCO 8017 ACTUATOR VALVE KIT
    ASCO 8025-A204-120 SOLENOID VALVE 5-125PSI 110/120VAC 50/60HZ
    ASCO 8030-A017-120 SOLENOID VALVE 120VAC
    ASCO 8030-A082-120 VALVE SOLENOID GENERAL PURPOSE 120/50-60HZ 1/2INCH
    ASCO 8030A17 SOLENOID VALVE 120VAC
    ASCO 8030-B083-120 VALVE SOLENOID 110-120VAC 50/60HZ
    ASCO 8030-G003-12DC SOLENOID VALVE 12VDC INERT GASES/WATER
    ASCO 8030-G017-120 SOLENOID VALVE .5INCH NC INLINE 2WAY 120VAC 50/60H
    ASCO 8030G017VH VALVE
    ASCO 8030-G071-120 VALVE SOLENOID STEAM 1/2INCH 110-120VAC 50/60HZ
    ASCO 8030-G083-120 VALVE 1/2INCH NPT
    ASCO 8030G10 VALVE
    ASCO 8030G16 VALVE
    ASCO 8030G17 SOLENOID
    ASCO 8030G174VH SOLENOID VALVE
    ASCO 8030G17VH VALVE
    ASCO 8030G3 VALVE
    ASCO 8030G63 VALVE
    ASCO 8040-C005-120 SOLENOID VALVE 110/120V 50/60HZ
    ASCO 8040-H008-120 VALVE FOR 3/8TH INCH PIPE WR/CCI IS 6.1/F
    ASCO 8040H7120V VALVE ASSEMBLY
    ASCO 8042C65 VALVE
    ASCO 8042C75 VALVE
    ASCO 8042C95 SOLENOID
    ASCO 8043A67 CONTROL
    ASCO 8043-B037-120 VALVE SOLENOID GENERAL PURPOSE 120/50-60HZ 3/4INCH
    ASCO 8210018-120 VALVE 1 1/4 2WAY NORM. OPEN 120VAC
    ASCO 8210-035-120 VALVE SOLENOID NO 3/4NPT
    ASCO 8210-04-120 VALVE
    ASCO 8210103 CONTROL
    ASCO 82102100MO SOLENOID VALVE
    ASCO 8210-A012-120 VALVE SOLENOID GENERAL PURPOSE 120/50-60HZ 1/2INCH
    ASCO 8210-B020-120 VALVE GENERAL SERVICE SOLENOID 120/60 110/50
    ASCO 8210-B027-120 SOLENOID VALVE
    ASCO 8210-B034-120 VALVE
    ASCO 8210-B055-120 SOLENOID VALVE
    ASCO 8210B20 VALVE
    ASCO 8210B20-120 SOLENOID VALVE 120V 60HZ
    ASCO 8210B20MB BRACKET
    ASCO 8210B54 SOLENOID VALVE
    ASCO 8210B57 VALVE
    ASCO 8210B58 VALVE
    ASCO 8210B59 CONTROL
    ASCO 8210-C034-120 VALVE
    ASCO 8210-C046-120 VALVE
    ASCO 8210-D090-120 SOLENOID VALVE 6WATTS 3/4 PIPE
    ASCO 8210D2 SOLENOID VALVE
    ASCO 8210D4 SOLENOID VALVE
    ASCO 8210G002 VALVE
    ASCO 8210-G002-120 VALVE 1/2 PORTS 120VAC 6.1 WATT 150 PSI
    ASCO 8210-G002-12DC VALVE SOLENOID GENERAL SERVICE 12VDC 1/2INCH
    ASCO 8210-G003-120 SOLENOID VALVE 2WAY 2POSITION
    ASCO 8210-G004-24DC VALVE 2-WAY 1-INCH WITH 24VDC COIL
    ASCO 8210-G006-120 SOLENOID VALVE
    ASCO 8210-G009-120 VALVE SOLENOID 120VAC HOT WATER 2WAY 3/4 INCH ORIF
    ASCO 8210G022220VAC VALVE
    ASCO 8210-G022-24DC SOLENOID VALVE 24VDC
    ASCO 8210-G033-120 VALVE 2-WAY 3/8- INCH W/120VAC COIL
    ASCO 8210G034 VALVE
    ASCO 8210-G034-120 VALVE SOLENOID
    ASCO 8210-G054-120 VALVE FOR 1 INCH PIPE WR/CCI IS 15.4/F
    ASCO 8210G055 SOLENOID VALVE
    ASCO 8210-G055-120 SOLENOID VALVE 120VAC 2-WAY N.C, 1-1/4IN. NPT
    ASCO 8210-G087-120 SOLENOID VALVE 2 WAY 1/2" STAINLESS STEEL
    ASCO 8210-G093-120 VALVE 3/8 NPT 2-WAY 300 PSI 120V
    ASCO 8210G093HW VALVE
    ASCO 8210G094 VALVE
    ASCO 8210-G094-120 SOLENOID VALVE 110-120VAC 50/60HZ
    ASCO 8210-G095-120 SOLENOID VALVE 3/4INCH NPT 2-WAY 120V
    ASCO 8210G1 VALVE
    ASCO 8210G100 SOLENOID VALVE
    ASCO 8210-G1-120 SOLENOID VALVE 3/8IN 110/120VAC 50/60HZ 2W
    ASCO 8210G13 SOLENOID VALVE
    ASCO 8210G14120 VALVE
    ASCO 8210G15 SOLENOID VALVE
    ASCO 8210G15120 SOLENOID VALVE
    ASCO 8210G2 VALVE
    ASCO 8210-G2-120 SOLENOID VALVE 1/2INCH NPT 2WAY 120VAC
    ASCO 8210G2120VAC VALVE
    ASCO 8210-G2-12DC SOLENOID VALVE GENERAL SERVICE 12VDC 1/2INCH
    ASCO 8210G22 120 VAC SOLENOID VALVE
    ASCO 8210G2224VDC CONTROL
    ASCO 8210G22460 SOLENOID
    ASCO 8210G224VDC SOLENOID
    ASCO 8210G26 VALVE
    ASCO 8210G27 SOLENOID VALVE
    ASCO 8210G2HW VALVE
    ASCO 8210G3 VALVE
    ASCO 8210G30 VALVE
    ASCO 8210G32 VALVE
    ASCO 8210G33 VALVE
    ASCO 8210G34 VALVE
    ASCO 8210G35 120/60 110/50
    ASCO 8210G35AC120 UNIT
    ASCO 8210G36 SOLENOID VALVE
    ASCO 8210G37 SOLENOID VALVE
    ASCO 8210G4 VALVE
    ASCO 8210G54 SOLENOID VALVE/REPLACES 8210B54
    ASCO 8210G5412060 VALVE
    ASCO 8210G55 SOLENOID DRIVE
    ASCO 8210G6 SOLENOID VALVE
    ASCO 8210G73 VALVE
    ASCO 8210G74 VALVE
    ASCO 8210G75 VALVE
    ASCO 8210G78 VALVE
    ASCO 8210G8 SOLENOID VALVE
    ASCO 8210G812060 SOLENOID VALVE
    ASCO 8210G87 VALVE
    ASCO 8210G87E VALVE
    ASCO 8210G87N VALVE
    ASCO 8210G88 VALVE
    ASCO 8210G9 SOLENOID 120VAC
    ASCO 8210G93 VALVE
    ASCO 8210G93HW VALVE
    ASCO 8210G94 VALVE
    ASCO 8210G94V SOLENOID VALVE
    ASCO 8210G95 VALVE- 3/4" NPT 2-WAY 120V/60HZ BRONZE BODY
    ASCO 8210-G95-120 VALVE 3/4 NPT 2-WAY 120V/60HZ BRONZE BODY
    ASCO 8210G9524VDC VALVE
    ASCO 8210G95HW VALVE
    ASCO 8210G95V VALVE
    ASCO 8210GB54 SOLENOID VALVE
    ASCO 8211-B054-120 VALVE
    ASCO 8214-G010-120 SOLENOID VALVE 3/8INCH NC 120VAC
    ASCO 8214-G033-120 SOLENOID VALVE .75INCH 120VAC
    ASCO 8214G33 SOLENOID VALVE
    ASCO 8215-A063-120 VALVE
    ASCO 8215A071-120 SOLENOID VALVE 2 WAY
    ASCO 8215A40 VALVE
    ASCO 8215-B020-120 SOLENOID VALVE
    ASCO 8215-B050-120 SOLENOID VALVE 2-WAY NORMALLY CLOSED
    ASCO 8215-B060-120 SOLENOID VALVE 2-WAY NORMALLY CLOSED
    ASCO 8215-B061-120 SOLENOID VALVE 2-WAY NORMALLY CLOSED
    ASCO 8215-B070-24DC SOLENOID VALVE 24VDC 2WAY 1-1/2
    ASCO 8215-B093-120 SOLENOID VALVE FUEL GAS 5 PSI
    ASCO 8215-B53-120 SOLENOID VALVE 120VAC 15WATT
    ASCO 8215B60120V VALVE
    ASCO 8215-B70-120 SOLENOID VALVE 2-WAY NC 1-1/2", 120/60
    ASCO 8215B80VH CONTROL
    ASCO 8215-C020-B-120 VALVE SOLENOID 10.5W 120VAC
    ASCO 8215-C030-120 VALVE SOLENOID 110VAC/50-60HZ 3/4INCH
    ASCO 8215-C033-120 VALVE SOLENOID GENERAL PURPOSE 120/50-60HZ 1INCH
    ASCO 8215-C053-120 SOLENOID VALVE 120V
    ASCO 8215-C10-120 SOLENOID VALVE
    ASCO 8215-C30-120 VALVE SOLENOID 110VAC/50-60HZ 3/4INCH
    ASCO 8215C53 SOLENOID VALVE
    ASCO 8215C63 VALVE
    ASCO 8215C83 CONTROL
    ASCO 8215C8312060 CONTROL
    ASCO 8215-G033-120 VALVE SOLENOID 120VAC
    ASCO 8215G10 SOLENOID VALVE
    ASCO 8215G20 VALVE
    ASCO 8215G20120V VALVE
    ASCO 8215G23 VALVE
    ASCO 8215G30 VALVE
    ASCO 8215G33 VALVE
    ASCO 8220G003 VALVE
    ASCO 8220-G003-120 VALVE 1/2INCH NPT 2-WAY NORMALLY CLOSED
    ASCO 8220-G007-120 SOLENOID VALVE 120VAC
    ASCO 8220-G011-120 SOLENOID VALVE 2WAY 1 1/2IN 120V
    ASCO 8220-G095-120 SOLENOID VALVE 2WAY NO 3/4IN 120V
    ASCO 8220G15 CONTROL
    ASCO 8220G21 VALVE
    ASCO 8220G23 CONTROL
    ASCO 8220G25 VALVE
    ASCO 8220G2524VAC CONTROL
    ASCO 8220G27 SOLENOID VALVE
    ASCO 8220G7 SOLENOID VALVE
    ASCO 8221-G005-120 SOLENOID VALVE 3/4 NPT 2-WAY 120V/60HZ
    ASCO 8221-G500-HW-120 VALVE- 120V 3/4NPT SOLENOID
    ASCO 8221-G007-120 SOLENOID VALVE 1INCH NPT 2-WAY 120V/60HZ
    ASCO 8221-G009-HW-120 VALVE BRASS HOT WATER NC 1 1/4NPT
    ASCO 8221G11 SOLENOID
    ASCO 8221G11120V VALVE
    ASCO 8221G1120VAC VALVE
    ASCO 8221G13 CONTROL
    ASCO 8221G13120V VALVE
    ASCO 8221G15 VALVE
    ASCO 8221G20 VALVE
    ASCO 8221G5120V VALVE
    ASCO 8221G5HW VALVE
    ASCO 822299 SOLENOID VALVE
    ASCO 8222-A049-120 VALVE 3/4INCH NC STEAM 2-125 PSI 120VAC
    ASCO 8222A5 VALVE
    ASCO 8222-B052-120 SOLENOID VALVE -STEAM 1/2IN 125V/50-60HZ 5/8ORF
    ASCO 8222-D022-120 SOLENOID VALVE 120V
    ASCO 8222G2 VALVE
    ASCO 8222G3 VALVE
    ASCO 8222G3120V VALVE
    ASCO 8222G324V60HZ VALVE
    ASCO 8222G74 VALVE
    ASCO 8222G95 VALVE
    ASCO 8223-G021-120 SOLENOID VALVE HIGH PRESSURE
    ASCO 8223G023 VALVE
    ASCO 8223-G21-120 SOLENOID VALVE 1/4-INCH NPT 120VAC HI-PRESSURE
    ASCO 8223G23 VALVE
    ASCO 8223-G23-120 SOLENOID VALVE 3/8-INCH NPT 2WAY HI-PRESSURE
    ASCO 8223G3 SOLENOID VALVE
    ASCO 8260-G071-120 SOLENOID VALVE 2WAY NC 1/4IN 120V
    ASCO 8262A132 VALVE
    ASCO 8262A138 SOLENOID VALVE
    ASCO 8262A262 VALVE
    ASCO 8262-A262-120 VALVE
    ASCO 8262-B208-120 SOLENOID VALVE BRASS 1/4IN PIPE 110/120V 50/60
    ASCO 8262-C002-120 VALVE 1/8NPT 2-WAY 120VAC 60 HZ
    ASCO 8262-C013-240 SOLENOID VALVE 240/480VAC 1/4NPT LUBE OIL 15PSI
    ASCO 8262-C044-120 VALVE SOLENOID
    ASCO 8262-C13-12DC SOLENOID 12VDC
    ASCO 8262-C210V-480 VALVE 1/4 2-WAY 460VAC 60HZ
    ASCO 8262-C232Q-120 VALVE
    ASCO 8262-D048-120 SOLONOID VALVE PIPE1/4 ORIFICE1/8 PRESS AIR/GAS140
    ASCO 8262-D232-120 SOLENOID VALVE NORMALLY CLOSED 1/8INCH
    ASCO 8262-G002-120 VALVE
    ASCO 8262-G002-24DC SOLENOID VALVE 24VDC
    ASCO 8262-G019-120 SOLENOID VALVE BRASS 1/4NPT 110/120V 50/60HZ
    ASCO 8262G021-120 VALVE 2 WAY RED HAT
    ASCO 8262-G022-120 SOLENOID VALVE 2WAY NC 1/4IN 120V
    ASCO 8262-G038-120 SOLENOID VALVE 2WAY NC 1/4IN 120V
    ASCO 8262-G078-120 SOLENOID VALVE .25INCH GAS 120VAC
    ASCO 8262-G080-125DC VALVE RED-HAT 125DC 1/4 2W NC 0105
    ASCO 8262G138 VALVE
    ASCO 8262G14 SOLENOID
    ASCO 8262G2 VALVE
    ASCO 8262G20 VALVE
    ASCO 8262G202 SOLENOID VALVE
    ASCO 8262-G202-120 SOLENOID VALVE 120VAC 2WAY NC 1/4INCH NPT
    ASCO 8262G202V SOLENOID VALVE
    ASCO 8262G208 SOLENOID VALVE
    ASCO 8262-G208-120 SOLENOID VALVE BRASS 1/4IN PIPE 110/120V 50/60
    ASCO 8262G210 VALVE
    ASCO 8262-G210-120 VALVE FOR 1/4TH INCH PIPE WR/CCI IS 10.1/F
    ASCO 8262G212 SOLENOID VALVE
    ASCO 8262-G212-120 SOLENOID VALVE NC NBR DISC GENERAL SERVICE
    ASCO 8262G21224VAC SOLENOID VALVE
    ASCO 8262-G212-48DC VALVE 1/4IN 25PSI BRASS 2WAY NC 48VDC
    ASCO 8262G22 VALVE
    ASCO 8262G220 VALVE
    ASCO 8262G22T VALVE
    ASCO 8262-G232-120 SOLENOID VALVE
    ASCO 8262G262 VALVE
    ASCO 8262-G262-120 SOLENOID VALVE 1/4IN 2WAY NO 120V
    ASCO 8262-G265-120 VALVE MINI GENERAL SERVIC 2WAY 1/4PIPE 9/32ORIFICE
    ASCO 8262G38 VALVE
    ASCO 8262G7EMO VALVE
    ASCO 8262G90VM VALVE
    ASCO 8263-A021-120 VALVE 3/8 STEAM 60PSI 120VAC 16.7WATT
    ASCO 8263A210 VALVE
    ASCO 8263-A211-120 SOLENIOD VALVE 120V COIL
    ASCO 8263A300 SOLENOID VALVE
    ASCO 8263-A300-120 VALVE SOLENOID
    ASCO 8263B232LT SOLENOID VALVE
    ASCO 8263G2 VALVE
    ASCO 8263G206 VALVE
    ASCO 8263G210 SOLENOID
    ASCO 8263G210LT VALVE
    ASCO 8263-G232J-120 VALVE GENERAL SERVICE SOLENOID
    ASCO 8263G300 VALVE
    ASCO 8263G305 SOLENOID VALVE
    ASCO 8263G308 KIT
    ASCO 8263G320 VALVE
    ASCO 8263G33224VDC SOLENOID VALVE
    ASCO 8264G9 SOLENOID VALVE
    ASCO 8266-B203-120 VALVE
    ASCO 8266-C077-120 SOLENOID VALVE
    ASCO 8266-C085-120 VALVE
    ASCO 8266-C215V-120 VALVE SOLENOID GENERAL PURPOSE 120VAC/60HZ 1/2INCH
    ASCO 8266-C219V-120 VALVE SOLENOID 120VAC/60HZ 1/2INCH
    ASCO 8266D169L VALVE
    ASCO 8266D69L VALVE
    ASCO 8266D85V SOLENOID
    ASCO 8290A002 PISTON PUMP
    ASCO 8290-A002-120 PISTON VALVE AUX OPERATED 2 WAY PILOT 240PSI
    ASCO 8290A005 VALVE
    ASCO 8290-A016-120 VALVE BRONZE SOLENOID 90PSI FLUIDS/STEAM 1.25" N.C
    ASCO 8290A016BCX VALVE
    ASCO 8290A020 VALVE
    ASCO 8290A053 SOLENOID VALVE
    ASCO 8290A485 VALVE
    ASCO 8290B010 VALVE
    ASCO 8290B028 SOLENOID VALVE
    ASCO 8300A81F VALVE
    ASCO 8300D003G240VDC VALVE
    ASCO 8300-D058-120 SOLENOID VALVE 1/4INCH NPT
    ASCO 8300D058F VALVE
    ASCO 8300D3G SOLENOID VALVE
    ASCO 8300-D55F-120 VALVE
    ASCO 8300D9F12060 VALVE
    ASCO 8300G81F VALVE
    ASCO 8314-A045-120 UNIVERSAL 3 WAY VALVE
    ASCO 8314B-006-120 SOLENOID VALVE 120VAC
    ASCO 8314-C006-120 VALVE 1/4 PIPE 120VAC
    ASCO 8314-C007-120 VALVE SOLENOID AIR INRT GAS 5-125 3/4IN 120V/50-60
    ASCO 8314-C041-120 VALVE SOLENOID 120VAC/50-60HZ 1/8INCH
    ASCO 8314-G054-120 VALVE 1/4INCH NPT
    ASCO 8314G23120V VALVE
    ASCO 8314G8 3WAY VALVE
    ASCO 8316-055-120 SOLONOID VALVE-WATER TIGHT/HAZ LOCATION DESIGN
    ASCO 8316-C026-120 VALVE
    ASCO 8316-D044-120 VALVE 3/4INCH NPT AIR 250PSI
    ASCO 8316-G054-120 VALVE 3/8INCH NPT AIR-GAS 150PSI
    ASCO 8316G16Q VALVE
    ASCO 8316G44 SOLENOID VALVE
    ASCO 8316G6 VALVE
    ASCO 8316G64 VALVE
    ASCO 8316G64VMB VALVE
    ASCO 8317G23 SOLENOID VALVE
    ASCO 8317G35 VALVE
    ASCO 8317G35120 VALVE
    ASCO 8318 VALVE
    ASCO 8318-D002-120 COIL ONLY REPLACEMENT 120VAC 204558-1
    ASCO 8318-D020-120 SOLENOID VALVE
    ASCO 8318D1MS VALVE
    ASCO 8320-A005-120 VALVE UNIVERSAL SOLENOID
    ASCO 8320-A010-120 VALVE 3 WAY SOLENOID 120VAC
    ASCO 8320-A019-120 VALVE 1/4 NPT 3 WAY 120V/60HZ 125PSI
    ASCO 8320-A023-120 SOLENOID VALVE 1/4NPT 40PSI COIL 120VAC 6W
    ASCO 8320-A089-120 SOLENOID VALVE 1/4 3 WAY 120VAC
    ASCO 8320-A-097-120 SOLENOID VALVE 120VAC
    ASCO 8320-A10-120 VALVE 3 WAY SOLENOID 120VAC
    ASCO 8320-A173-120 VALVE 1/4INCH NPT 125PSI
    ASCO 8320A-187-120 SOLENOID VALVE 120VAC
    ASCO 8320-A195-120 SOLENOID VALVE 120VAC 3WAY
    ASCO 8320-A33-120 SOLENOID VALVE 120VAC
    ASCO 8320A9 VALVE
    ASCO 8320-A90-120 SOLENOID VALVE HAZDTY 1/4IN N/C 3WAY BRASS AIR/H2O
    ASCO 8320-B133-120 VALVE 1/8PORT 120VAC 6WATT RATED 200PSI
    ASCO 8320B15 VALVE
    ASCO 8320-B174-120 SOLENOID VALVE 3WAY
    ASCO 8320-G003-120 VALVE 3 WAY RED HAT
    ASCO 8320-G015-120 VALVE 120VAC N.C. 1/8NPT 2.4MM ORIFIC
    ASCO 8320-G045-120 SOLENOID VALVE 3WAY
    ASCO 8320-G083-120 VALVE 3WAY UNIVERSAL SOLENOID 1/8PIPE 3/32ORIFICE
    ASCO 8320-G136-120 SOLENOID VALVE 1/8IN N/O 3WAY BRASS 120/60 110/50
    ASCO 8320G15 UNIT
    ASCO 8320-G15-120 VALVE 120VAC N.C. 1/8NPT 2.4MM ORIFIC
    ASCO 8320G174 CONTROL
    ASCO 8320G176 SOLENOID VALVE
    ASCO 8320-G176-120 SOLENOID VALVE 3-WAY UNIVERSAL 1/4INCH NPT 120VAC
    ASCO 8320G178 VALVE
    ASCO 8320G184 SOLENOID VALVE
    ASCO 8320G186 VALVE
    ASCO 8320G186MO VALVE
    ASCO 8320-G188-120 VALVE 3WAY 2POSITION SOLENOID 1/4PIPE 11/64ORIFICE
    ASCO 8320G192 SOLENOID
    ASCO 8320-G192-120 SOLENOID VALVE 120VAC 1/4NPT 3-WAY
    ASCO 8320G192120V VALVE
    ASCO 8320G192MS VALVE
    ASCO 8320-G194-120 SOLENOID VALVE UNIVERSAL GENERAL PURPOSE 1/4NPT
    ASCO 8320-G200-120 SOLENOID VALVE 3WAY 1/4 INCH
    ASCO 8320G201 VALVE
    ASCO 8320G202 SOLENOID VALVE
    ASCO 8320G49 VALVE
    ASCO 8320-R144-120 VALVE 1/8 3WAY NORM CLOSED 120VAC
    ASCO 8321-A001-120 VALVE
    ASCO 8321-A021-120 SOLENOID VALVE 120VAC
    ASCO 8321A6 VALVE
    ASCO 8321G002 VALVE
    ASCO 8321-G002-120 SOLENOID VALVE QUICK EXHAUST 110-120/50-60HZ
    ASCO 8321G002120V VALVE
    ASCO 8321G003120V VALVE
    ASCO 8321G1 SOLENOID VALVE
    ASCO 8321G2 CONTROL
    ASCO 8335-B005-120 VALVE
    ASCO 8335-B011-120 VALVE
    ASCO 8340G1 VALVE
    ASCO 8342-B021-120 HAZARDOUS LOCATION SOLENOID
    ASCO 8342C1 VALVE
    ASCO 8342C1120 VALVE
    ASCO 8342G1 VALVE 1/4"
    ASCO 8342G1120 SOLENOID VALVE
    ASCO 8342G1M VALVE
    ASCO 8342G3 VALVE
    ASCO 83440-115 SOLENOID VALVE 4WAY 115VAC 1/4NPT
    ASCO 834444402 VALVE
    ASCO 8344-44-4D2-120 SOLENOID VALVE 120V/60HZ AIR GAS WATER OIL
    ASCO 8344-A070-120 VALVE
    ASCO 8344B0 VALVE
    ASCO 8344-B000-120 VALVE 1/4 -1IN PISTON POPPET
    ASCO 8344-C037-120 VALVE 3/8INCH NPT 250PSI
    ASCO 8344C25 VALVE
    ASCO 8344G0 SOLENOID VALVE
    ASCO 8344G074120V VALVE
    ASCO 8344G076 VALVE
    ASCO 8344G70 SOLENOID VALVE
    ASCO 8344G72 VALVE
    ASCO 8344G82 VALVE
    ASCO 8.35E+14 VALVE
    ASCO 8345-G001-240 VALVE 1/4 240VAC 4 WAY
    ASCO 8345G1 VALVE
    ASCO 8345G1120V VALVE
    ASCO 8345H003 PIPE
    ASCO 8345-H003-120 VALVE 4WAY UNIVERSAL SOLENOID 1/4PIPE 1/16ORIFICE
    ASCO 8345H3 SOLENOID
    ASCO 83497-120 REPLACEMENT COIL INERT GAS SOLENOID VALVE 120VAC
    ASCO 835213 SOLENOID VALVE
    ASCO 835215 VALVE 120VAC/60HZ ANGLE BODY AIR PILOT
    ASCO 8353A41 VALVE
    ASCO 8353-C033 VALVE ALUMINUM DIAPHRAGM / NO SOLENOID
    ASCO 8353C35 VALVE
    ASCO 8353-H038-120 MAIN PULSE VALVE HIGH FLOW 1 1/2 IN PIPE SIZE
    ASCO 8353H38 VALVE
    ASCO 8353J39 VALVE
    ASCO 8360G071 SOLENOID
    ASCO 8360-G071-120 SOLENOID GENERAL PURPOSE OPEN FRAME
    ASCO 8551-A001-MS-120 VALVE 1/4 INCH 4WAY
    ASCO 87-647 KIT SPARE PARTS
    ASCO 890523-001 VALVE REDHAT GAS/DIESEL24VDC 4.5-5.0PSI 890523-001
    ASCO 9092003C CONTACTOR 2POLE 30AMP 120V COIL NEMA 1 ENCLOSURE
    ASCO 9093003C CONTACTOR 3POLE 30AMP 120V COIL NEMA 1 ENCLOSURE
    ASCO 917122031 LIGHTING CTRL
    ASCO 917122031C CONTACTOR
    ASCO 917122031C47L CONTACT ASSY
    ASCO 917122031XC LIGHTING CTRL
    ASCO 917122061C LIGHT CONTROL
    ASCO 917122091 LIGHTING CTRL/480V
    ASCO 917442031C REMOTE CONTROL
    ASCO 91762031 CONTACTOR 20AMP 6POLE
    ASCO 91782031C CONTACTOR LTG, 8P, 120V, NEMA 1
    ASCO 920215031 SWITCH AUTOMATIC TRANSFER REMOTE CONTROL
    ASCO 920310030 SWITCH
    ASCO 920310061 CONTACTOR
    ASCO 920315030 SWITCH
    ASCO 920320071 CONTACTOR
    ASCO 92033031XC SWITCH
    ASCO 92036031 CONTACTOR
    ASCO 92036061 CONTACTOR
    ASCO 92037530 REMOTE CONTROL
    ASCO 9434002 COIL
    ASCO 966191D COIL
    ASCO 96-817-1D REPLACEMENT COIL
    ASCO 97600327 MOUNTING BRACKET FOR SERIES 107 VALVES
    ASCO 992161 COIL
    ASCO 992161D COIL
    ASCO 992162D COIL
    ASCO 992165D COIL
    ASCO 99246002D COIL
    ASCO 992571 COIL
    ASCO 99-257-1D REPLACEMENT COIL FOR 8342G20/22 AC
    ASCO 992576 COIL
    ASCO 99828 REPAIR KIT
    ASCO A263G2102T VALVE
    ASCO AH13D102A4 HYDROMETER
    ASCO AH13D112A4-120 VALVE GAS HYDRAMOTOR 120V
    ASCO AH2B11254 HYDROMETER
    ASCO AH2D112A ACTUATOR
    ASCO AH2D112A5 ACUATOR HYDRAMOTOR W/DAMPER ARM 120VAC 60HZ 6-14S
    ASCO AUTA300B SWITCH ASSY
    ASCO C302447V VALVE
    ASCO D8260G56V SOLENOID
    ASCO DFX8262-013V-09563-240/480VAC SOLENOID VALVE 240/480VAC LUBE OIL 15PSI
    ASCO E290A468 VALVE
    ASCO E290A491 VALVE
    ASCO E290B005 SOLENOID VALVE 2W PILOT OP VALVE 3/4 NC
    ASCO EF8003G1 SOLENOID
    ASCO EF8003G2 VALVE
    ASCO EF8003G2120V VALVE
    ASCO EF8016G001 VALVE
    ASCO EF8017G2 SOLENOID VALVE
    ASCO EF8030G83 VALVE
    ASCO EF8037A8F VALVE
    ASCO EF-8040-G022-120 VALVE SOLENOID 1/2INCH 120/110VAC 60/50HZ
    ASCO EF8120G54 VALVE
    ASCO EF-8210-B5/K REBUILD KIT
    ASCO EF-8210-G-093-120 SOLENOID VALVE 120VAC EXPLOSION PROOF
    ASCO EF8210G094 VALVE
    ASCO EF-8210-G094-120 SOLENOID VALVE EXPLOSION PROOF 2WAY NC 1/2 120V
    ASCO EF8210G1 VALVE
    ASCO EF8210G100 VALVE
    ASCO EF8210G15 VALVE
    ASCO EF-8210-G2-24DC SOLENOID VALVE 24VDC EXP PROOF
    ASCO EF8210G3 VALVE
    ASCO EF8210G30 VALVE
    ASCO EF8210G54 VALVE
    ASCO EF8210G7 SOLENOID
    ASCO EF8210G87 VALVE
    ASCO EF8210G87V VALVE
    ASCO EF8210G88V SOLENOID VALVE
    ASCO EF8210G89 VALVE
    ASCO EF8210G94 SOLENOID VALVE
    ASCO EF8210G95 VALVE
    ASCO EF8210G95MO VALVE
    ASCO EF8215B60 SOLENOID VALVE
    ASCO EF-8215-B080-120 VALVE SOLENOID GENERAL PURPOSE 120/50-60HZ 1/2INCH
    ASCO EF8215G20 VALVE 24/DC SOLENOID VALVE
    ASCO EF8215G202 VALVE
    ASCO EF8215G21 VALVE
    ASCO EF8215G30 VALVE
    ASCO EF8220G29 VALVE
    ASCO EF8223G3120V VALVE
    ASCO EF-8262-G001-24DC SOLENOID VALVE 24VDC EXPLOSION PROOF
    ASCO EF-8262-G020-120 VALVE 120V 1/4NPT SOLENOID
    ASCO EF8262G138 VALVE
    ASCO EF-8262-G142-120 SOLENOID VALVE 120VAC EXPLOSION PROOF
    ASCO EF8262G2 SOLENOID VALVE
    ASCO EF8262G220 VALVE
    ASCO EF8262G262220V VALVE
    ASCO EF-8262-G265-120 SOLENOID VALVE .25INCH NO BRASS
    ASCO EF8300A81RF SOLENOID VALVE
    ASCO EF8300G55G VALVE
    ASCO EF8300G81F VALVE
    ASCO EF8308C41 VALVE
    ASCO EF8308C41F VALVE
    ASCO EF8308C41F240602 VALVE
    ASCO EF-8314-G300-24DC SOLENOID VALVE 24VDC EXPLOSION PROOF
    ASCO EF-8316-G064-120 SOLENOID VALVE 110-120V 50/60HZ EXPLOSION PROOF
    ASCO EF8316G14 VALVE
    ASCO EF-8316-G301-24DC SOLENOID VALVE 24VDC EXPLOSION PROOF
    ASCO EF8316G64 VALVE
    ASCO EF8316G66 VALVE
    ASCO EF-8317-G035-24DC SOLENOID VALVE 24VDC EXPLOSION PROOF
    ASCO EF8317G35 VALVE
    ASCO EF8317G3524VDC VALVE
    ASCO EF-8320-G132-120 VALVE 1/8 3WAY 120VAC
    ASCO EF8320G140 VALVE
    ASCO EF8320G16 SOLENOID VALVE
    ASCO EF8320G172 CONTROL
    ASCO EF8320G174 VALVE
    ASCO EF-8320-G174-120 SOLENOID VALVE 3WAY EXPOSION PROOF
    ASCO EF-8320-G174-24DC VALVE 3 WAY RED HAT
    ASCO EF8320G174MS VALVE
    ASCO EF-8320-G176-120 SOLENOID VALVE 1/4INCH 3-WAY COIL 120VAC EXP PROOF
    ASCO EF-8320-G178-120 SOLENOID VALVE 110-120V 50/60HZ EXPLOSION PROOF
    ASCO EF-8320-G1B4MS-120 SOLENOID VALVE 3WAY
    ASCO EF8320G200 SOLENOID VALVE
    ASCO EF-8320-G200-120 SOLENOID VALVE 1/4NPT 100PSI 120VAC COIL
    ASCO EF8320G20024VDC SOLENOID VALVE
    ASCO EF8320G202 VALVE
    ASCO EF8321G1 SOLENOID VALVE
    ASCO EF-8321-G1-24DC SOLENOID VALVE 1/4INCH BRASS COIL 24VDC 10.6W
    ASCO EF8321G1MS VALVE
    ASCO EF8321G2 VALVE
    ASCO EF8321G2MO SOLENOID VALVE
    ASCO EF834001 SOLENOID VALVE
    ASCO EF-8340-G001-120 VALVE EXPLOSION PROOF AIR ONLY SOLENOID
    ASCO EF8342701 CONTROL
    ASCO EF8342703 VALVE
    ASCO EF-8342-C001-120 SOLENOID VALVE 110-120V 50/60HZ EXPLOSION PROOF
    ASCO EF8342C003 VALVE
    ASCO EF-8342-C022M-120 SOLENOID VALVE DOUBLE ACTING 110/120 50/60 EXPL PR
    ASCO EF8342C1 VALVE
    ASCO EF8342C112060 SOLENOID VALVE
    ASCO EF8342C1MS MAN OPERATOR
    ASCO EF8342G1 OPERATOR
    ASCO EF8342G1MMS VALVE
    ASCO EF8342G3 VALVE
    ASCO EF8342G701 VALVE
    ASCO EF8342G703 VALVE
    ASCO EF-8344-G370-24DC SOLENOID VALVE 24VDC EXPLOSION PROOF
    ASCO EF-8344-G382-24DC SOLENOID VALVE 24VDC EXPLOSION PROOF
    ASCO EF8344G70 VALVE
    ASCO EF-8344-G70MO-240 SOLENOID VALVE EF8344G70MO 240/60
    ASCO EF8344G72 VALVE
    ASCO EF8344G74 SOLENOID VALVE
    ASCO EF-8345-H003-120 SOLENOID VALVE 4WAY 1/4IN
    ASCO EF-8353-H39-240 SOLENOID VALVE EF8353H39 240/60
    ASCO EF8401B202M VALVE
    ASCO EF-8401-B202M-120 SOLENOID VALVE 120/60VAC
    ASCO EF-8432-C20-120 VALVE
    ASCO EFFBX8262G148V23 VALVE
    ASCO EFFBX8262G226V23 VALVE
    ASCO EF-FBX-8263-G33118785-120 VALVE SOLENOID 120/60, 110/50
    ASCO EFHB8210G7 SOLENOID VALVE
    ASCO EFHB8223G10 SOLENOID VALVE
    ASCO EFHC8320G182 VALVE
    ASCO EFHC8321G2 VALVE
    ASCO EFHT8210G30 VALVE
    ASCO EFHT8320G184MB SOLENOID VALVE
    ASCO EF-X8300A82V18809-120 VALVE SOLENOID 3/8INCH 120VAC 90PSI
    ASCO EGSCE04B3D021105 VALVE
    ASCO EIC-HC-8210B-030-120 SOLENOID VALVE 120VAC50/60 BATT CHARGING COIL
    ASCO F262B220K AIR-OPERATED VALVE 2WAY NC STAINLESS STEEL BODY
    ASCO F351427 SOLENIOD VALVE SERIES 8215 2-WAY INT PILOT
    ASCO FBX8262 VALVE
    ASCO FBX8262A203 VALVE
    ASCO FRS46 IGNITION CTRL
    ASCO FV210-335 KIT / RETAINER FOR 8314 VALVE
    ASCO H118AJ122F1 HYDRAMOTOR VAL
    ASCO HB11214 PRESSURE SW
    ASCO HB8262G232120V VALVE
    ASCO HB8302D29RF SOLENOID VALVE 1/2NPT COIL 20W 120VAC
    ASCO HC8262-G080-125DC VALVE RED-HAT 125DC 1/4 2W NC 0105
    ASCO HC8314G8125VDC SOLENOID VALVE
    ASCO HCX8223A1101765 VALVE
    ASCO HCX8320A20813870 SOLENOID VALVE 1/4NPT 125VDC COIL NUKE SPEC
    ASCO HS345-174-C BOARD FOR SEQUENTIAL CONTROLLER 214B281 120V/60HZ
    ASCO HT8210G9 VALVE
    ASCO HT8211A36V SOLENIOD VALVE 120V COIL
    ASCO HT8344G72VMO SOLENOID VALVE
    ASCO HV1744762 SOLENOID VALES 10.7W 120VAC
    ASCO HV1765391120VAC VALVE
    ASCO HV1866601 SOLENOID WATERTIGHT 1/8 120V
    ASCO HV212314 VALVE
    ASCO HV212315 VALVE
    ASCO HV2123151 VALVE
    ASCO HV2143581 SOLENOID VALVE
    ASCO HV2561704 VALVE SOLENOID 24/DC
    ASCO HV2585491 VALVE
    ASCO HV2647003 VALVE SOLENOID 3/8 PORT 15-125PSI 24VDC COIL
    ASCO HZ19B290 PRESSURE SW
    ASCO JB47A215A VALVE
    ASCO JB48A218C PRESSURE SWITCH 125/250VAC 18.5-22PSIG
    ASCO JB8214-035-120 SOLENOID VALVE .75INCH NPT 110V FOR GAS SHUT OFF
    ASCO JB8214-035C-120 SOLENOID VALVE .75INCH NPT 110V W/INDICATOR SWITCH
    ASCO JB8214-035VI-120 SOLENOID VALVE .75INCH NPT 110V W/ INDICATOR
    ASCO JB8214-050VI-120 SOLENOID VALVE 1INCH NPT 110V W/ INDICATOR
    ASCO JB8214-053-120 SOLENOID VALVE 1INCH GAS VENT 120V
    ASCO JB8214-060-120 SOLENOID VALVE 1.25INCH NPT 110V
    ASCO JB8214-060C-120 SOLENOID VALVE 1.25INCH NPT 110V W/SWITCH AND IND.
    ASCO JB8214-060VI-120 SOLENOID VALVE 1.25INCH NPT 110V W/INDICATOR
    ASCO JB8214-070-120 SOLENOID VALVE 1.5INCH NPT 110V
    ASCO JB8214-070VI-120 SOLENOID VALVE 1.5INCH NPT 110V W/ INDICATOR
    ASCO JB8214-080-120 SOLENOID VALVE 2INCH NPT 110V
    ASCO JB8214-080C-120 SOLENOID VALVE 2INCH NPT 110V W/ SWITCH AND IND.
    ASCO JB8214-080VI-120 SOLENOID VALVE 2INCH NPT 110V
    ASCO JB821440CSA VALVE
    ASCO JBEFHT8344G80 VALVE
    ASCO JDF8262D-022E-240/480 SOLENOID VALVE240/480 SPLICE BOX ENCLOSURE
    ASCO JFBX8320A142JMB VALVE
    ASCO JIC-1084SC ENCLOSURE JIC 10X8X4
    ASCO JIC-12105LC ENCLOSURE JIC 12X10X5
    ASCO JIC-24207CH ENCLOSURE JIC 24X20X7
    ASCO JKF8210G94120V SOLENOID VALVE
    ASCO JKF8262-C090-120 SOLENOID VALVE COIL 6W 120VAC JUNCTION
    ASCO JKF8262G2 SOLENOID VALVE 2WAY NC
    ASCO JKF8320G172MB SOLENOID VALVE 120/60VAC
    ASCO JKH8321G1 SOLENOID VALVE
    ASCO JN4-14126LC ENCLOSURE 14X12X6
    ASCO JS2993003M CONTROL PANEL
    ASCO JSP8340G1120V VALVE
    ASCO K069984 REPAIR KIT
    ASCO K176879 KIT
    ASCO K302001E KIT
    ASCO K302-101 VALVE REBUILD KIT
    ASCO K302273 VALVE KIT
    ASCO K302276 VALVE KIT
    ASCO K302282 CONTROL
    ASCO K302283 VALVE KIT
    ASCO K302305 KIT
    ASCO K302328 REPAIR KIT
    ASCO K302352 VALVE KIT
    ASCO K302929 REPAIR KIT
    ASCO K304064 KIT
    ASCO K304354E KIT
    ASCO K304355 VALVE KIT
    ASCO K312530 VALVE
    ASCO K314491 KIT
    ASCO K314492 KIT
    ASCO K314493 REPAIR KIT
    ASCO K322108 KIT
    ASCO K3A782T VALVE
    ASCO K96875 REPAIR KIT
    ASCO L8210G033-28/DC VALVE FOR 3/8TH INCH PIPE WR/CCI IS 10.1/F
    ASCO L8210G2 VALVE
    ASCO L8262G202E SOLENOID VALVE
    ASCO L8262G208E VALVE
    ASCO L8262-G208E-120 SOLENOID VALVE EPDM 110/120 50/60 1/4INCH PIPE
    ASCO MP-C-011-240 SOLENOID 64-982-2D 220/50 240/60
    ASCO MPSP8320B1MS VALVE
    ASCO MUFBX8262218047 VALVE
    ASCO MUX8014205292 VALVE
    ASCO NPL8321A1E SOLENOID VALVE NUKE SPEC 3WAY 120VAC 72INCH LEADS
    ASCO NPX8316A64E17663-120 VALVE 3-WAY SOLENOID 1/2IN NPT
    ASCO OFSF8210G193 VALVE
    ASCO OFSF8210G93 VALVE
    ASCO OPSF8262G2 SOLENOID VALVE 2WAY NC
    ASCO P210C34 VALVE
    ASCO P210C94 CONTROL
    ASCO P222A76 KIT
    ASCO P262B202 VALVE AIR OPERATED NORMALLY CLOSED
    ASCO P8262C2 VALVE
    ASCO P8262G2 VALVE
    ASCO PA16A PRESSURE SWITCH SINGLE STAGE ADJUSTABLE DEADBAND
    ASCO PA31B SWITCH
    ASCO PB11BRN10B42 SWITCH
    ASCO PB30A SWITCH ASSY
    ASCO PB30ARD30A11 SWITCH
    ASCO PB36A HARDWARE
    ASCO PC21B CONTROL
    ASCO PX8262C213121 SOLENOID VALVE 1/4INCH 120VAC
    ASCO QL11A4 TRANSDUCER W/CAPULARY
    ASCO QP03 THERMOWELL BRASS 2.5INCH 1000 PSIG 1/2IN NPT
    ASCO QP13 THERMOWELL BRASS 4.5INCH 1000 PSIG 1/2IN NPT
    ASCO RE10A21 TRANSDUCER P-SERIES 6-60PSIG
    ASCO RQ10B42 TRANSDUCER UNIT FOR PRESSURE SWITCH
    ASCO SA10DQF10A1 SWITCH
    ASCO SB10D PART
    ASCO SB30D PRESSURE SWITCH 1-18 PSIG
    ASCO SB31DV PRESSURE SWITCH FIXED/MANUAL DEADBAND 0.8-9.0 PSIG
    ASCO SC8210G1 VALVE
    ASCO SC8210G2 VALVE
    ASCO SC8210G35 VALVE
    ASCO SC8210G75 VALVE
    ASCO SC8210G87V VALVE
    ASCO SC8210G94 VALVE
    ASCO SC8262G202 VALVE
    ASCO SC8316G6424VDC VALVE
    ASCO SC8344G4424VDC VALVE
    ASCO SC8401B202M24VDC VALVE
    ASCO SCE210103 VALVE
    ASCO SC-E210B154-48DC VALVE 1IN 9PSI BRASS NC 48VDC
    ASCO SCE210D095 VALVE
    ASCO SCE262C093 VALVE SOLENOID 1/8NPT 220/230-50HZ
    ASCO SC-G202A203-24DC VALVE 1/8IN 4PSI BRASS NC 24VDC
    ASCO SC-G262B212-48DC VALVE 1/4IN 6PSI BRASS NC 48VDC
    ASCO SCX-8210-G095-24DC VALVE RED HAT
    ASCO SCX8210G9517607-24DC VALVE RED HAT 24VDC H2O 0-60PSI
    ASCO SD10D PRESSURE SWITCH UNIT W/RESET NEMA-1 ENCLOSE
    ASCO SV311A02N6BF5K VALVE SOLENOID GENERAL PURPOSE 1/4INCH
    ASCO TA31A11 PRESSURE TRANSDUCER
    ASCO TB21A11 TRANSDUCER PRESSURE 15-140 IN.WC 25PSIG PROOF PRES
    ASCO TC11A11 TRANSDUCER PRESSURE 25-400 IN.WC 25PSIG PROOF PRES
    ASCO TD20A11 PRESSURE SWITCH 1.0-18PSI 125/250VAC 125VDC
    ASCO TD20A21 TRANSDUCER 1-18PSI BRASS AND BUNA N FUEL GAS/OIL
    ASCO TD30A32 PRESSURE SWITCH TRANSDUCER
    ASCO TG10A21 VALVE TRI POINT TRANSDUCER
    ASCO TG10A44 TRANSDUCER PRESSURE 6-200PSI
    ASCO TK10A21 TRANSDUCER PRESSURE 30-600PSI
    ASCO TN10B42 PART
    ASCO U-8325-A2U SOLENOID VALVE 3WAY SUBMINATURE
    ASCO U-8325-B2U SOLENOID VALVE 3WAY SUBMINATURE
    ASCO V022-002 VALVE W/ADJUSTABLE FLOW CONTROL 3/8NPN
    ASCO V043-002 VALVE BODY ONLY QUICK EXHAUST
    ASCO V0435 EXHAUST VALVE 1/8NPT
    ASCO V-903-3006-00-77 PNEUMATIC SOLENOID VALVE MI N. 24VDC
    ASCO VO12-014 VALVE CHECK .25INCH 200PSI
    ASCO WSEMETB327A10224 VALVE
    ASCO X8262A26109028 SOLENOID VALVE
明想科技是一家专门从事PLC备件进出口销售、技术咨询、技术服务、自动化设备维修服务为一体的贸易公司。并与世界著名的多家PLC产品维护服务提供商建立了紧密的合作关系,北美、欧洲、亚洲您多能看到我们的身影。我们售出的PLC最长提供两年的…  更多>>
上海明想电子
联系人:曾小姐
地址:上海市松江区文诚路2159弄240号
邮编:201620
电话:021-31261686
传真:021-31059032
公司网址:http://www.shmxdz.com
  • 蔡宗翰 在2017/1/25 12:26:00留言
  • 详细留言:PHOENIX CONTACT 1757268 HEADER 4POSITION 12A 250V SOLDER MOUNT 過爐曲線 SMT or wavesolder?
  • 王力 在2015/3/17 11:00:00留言
  • 王力 在2014/12/10 18:33:00留言
  • 冯秀思 在2014/10/20 11:39:00留言
  • 详细留言:
  • 白万洋 在2014/3/6 16:30:00留言
  • 详细留言:寻址光电侦烟感知器2951J 寻址式差动型探测器5951RJ 寻址式定温型探测器5951J 寻址式定温型探测器(高温型)5951HJ 控制模块M300CJ 迷你监视模块M301MJ 感知器欧式底座B501JCH
