上海明想电子
  • HOFFMAN-机箱-XCS56F
  • 发布时间:2009/4/11 9:50:10   修改时间:2009/4/11 9:50:10 浏览次数:2816
  • 上海明想电子科技有限公司
    我公司所有的产品直接从境外进货,能够提供不同国别、厂商的设备配件,
    解决您多处寻找的麻烦和对产品质量的担心等,在价格上我们有很大的优势,
    欢迎来电咨询,我们将会给您最优质的服务!
    产品详细信息,欢迎来电查询! 上海明想电子科技有限公司
    主要业务:提供日立,HUBELL,HOFFMAN,HAMMOND,HP,AGILENT,EFECTOR,ICP DAS USA,
    INDRAMAT,JOHNSON YOKOGAWA,KEYENCE CORP,JOHNSON CONTROLS
    PLC联系人:秦先生 TEL:021-31261686 FAX:021-31059032
    E-mail:712736091@qq.com    MSN icedrak@msn.com   QQ:712736091
    HOFFMAN 10100001 REPLACEMENT FILTER
    HOFFMAN 10100004 REPLACEMENT FILTER
    HOFFMAN 10100005 REPLACEMENT FILTER
    HOFFMAN 10100013 REPLACEMENT FILTER
    HOFFMAN 10100019 REPLACEMENT FILTER
    HOFFMAN 10100032 REPLACEMENT FILTER
    HOFFMAN 10100040 REPLACEMENT FILTER, 5 INCH
    HOFFMAN 10100041 REPLACEMENT FILTER, 9 INCH
    HOFFMAN 10100042 REPLACEMENT FILTER, 10 INCH
    HOFFMAN 10100043 REPLACEMENT FILTER, 13 INCH
    HOFFMAN 10100044 REPLACEMENT FILTER
    HOFFMAN 10100056 REPLACEMENT FILTER
    HOFFMAN 10100057 REPLACEMENT FILTER
    HOFFMAN 10100060 REPLACEMENT FILTER
    HOFFMAN 10100061 REPLACEMENT FILTER
    HOFFMAN 10100062 REPLACEMENT FILTER
    HOFFMAN 10100063 REPLACEMENT FILTER
    HOFFMAN 14168304SS ENCLOSURE
    HOFFMAN 23200400 REPLACEMENT FILTER
    HOFFMAN 48HX36WX12D ENCLOSURE
    HOFFMAN 87552445 FAN
    HOFFMAN 99411621 FAN
    HOFFMAN A050100GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A050100WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A050125GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A050125WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A050CGR COVER, PVC WIRING DUCT (QTY12)
    HOFFMAN A050CWH COVER, PVC WIRING DUCT (QTY12)
    HOFFMAN A075125GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A075125WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A075150GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A075150WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A075CGR COVER, PVC WIRING DUCT (QTY12)
    HOFFMAN A075CWH COVER, PVC WIRING DUCT (QTY12)
    HOFFMAN A100100GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A100100WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A100125GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A100125WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A100150GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A100150WH WIRE DUCT PVC (1X1.5X72INCH) WHITE
    HOFFMAN A1001YZUMC1 PURGE SYSTEM, UNIV. MOUNT
    HOFFMAN A1001YZUMC2 PURGE SYSTEM, UNIV. MOUNT
    HOFFMAN A100200GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A100200WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A100300GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A100300WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A100400GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A100400WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A10086CH ENCLOSURE STEEL J BOX 10X8X6 WITH HINGED COVER
    HOFFMAN A-10086CHNF ENCLOSURE STEEL 10X8X6 NEMA12 J-BOX W/HINGED COVER
    HOFFMAN A10086H JUNCTION BOX
    HOFFMAN A10086SC ENCLOSURE STEEL JBOX NEMA12 SCREW COVER 10X8X6
    HOFFMAN A-1008CH ENCLOSURE STEEL 10X8X4 NEMA12 J-BOX W/HINGED COVER
    HOFFMAN A1008CHAL J BOX, TYPE 12 HINGED COVER
    HOFFMAN A1008CHEMC ENCLOSURE STEEL 10X8X4 NEMA12 J-BOX W/HINGED COVER
    HOFFMAN A1008CHEMCSS J BOX TYP 4X EMC, HINGED COVER
    HOFFMAN A1008CHFTC J BOX,TYPE 12 HINGED COVER FTC
    HOFFMAN A-1008CHNF ENCLOSURE 10X8X4 NEMA4 J-BOX GRAY
    HOFFMAN A-1008CHNFSS ENCLOSURE 10X8X4 NEMA4X S/S J-BOX W/HINGED COVER
    HOFFMAN A1008CHNFSS6 J BOX, TYPE 4X HINGED COVER
    HOFFMAN A1008CHQR J BOX,TYPE 12 HINGED COVER QR
    HOFFMAN A1008CHS J BOX,TYP12 SHORT HINGED COVER
    HOFFMAN A1008LP J BOX, TYPE 12 LIFT-OFF COVER
    HOFFMAN A1008NF J BOX, TYPE 4 CLAMP COVER
    HOFFMAN A1008NFAL J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A1008NFSS ENCLOSURE 10X8X4 NEMA4X S/S TYPE304 W/CLAMP COVER
    HOFFMAN A1008NFSS6 J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A-1008SC ENCLOSURE STEEL J BOX 10X8X4 TYPE 12 SCREW COVER
    HOFFMAN A100CGR COVER, PVC WIRING DUCT (QTY12)
    HOFFMAN A100CWH DUCT COVER PVC (1X72 INCH) WHITE
    HOFFMAN A100DMC MOUNTING CLIPS (QTY 100)
    HOFFMAN A1010116RT WIRE TROUGH, TYPE 3R
    HOFFMAN A1010120T1T WIRE TROUGH, TYPE 1
    HOFFMAN A101024RT WIRE TROUGH, TYPE 3R
    HOFFMAN A101024T1T WIRE TROUGH, TYPE 1
    HOFFMAN A101036RT WIRE TROUGH, TYPE 3R
    HOFFMAN A101036T1T WIRE TROUGH, TYPE 1
    HOFFMAN A101048RT WIRE TROUGH, TYPE 3R
    HOFFMAN A101048T1T WIRE TROUGH, TYPE 1
    HOFFMAN A10104GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A101060RT WIRE TROUGH, TYPE 3R
    HOFFMAN A101060T1T WIRE TROUGH, TYPE 1
    HOFFMAN A10106CH J BOX, TYPE 12 HINGED COVER
    HOFFMAN A10106GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A10106SC J BOX,TYPE 12 SCREW COVER
    HOFFMAN A101072RT WIRE TROUGH, TYPE 3R
    HOFFMAN A101072T1T WIRE TROUGH, TYPE 1
    HOFFMAN A10108GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A101096RT WIRE TROUGH, TYPE 3R
    HOFFMAN A101096T1T WIRE TROUGH, TYPE 1
    HOFFMAN A1043DSC J BOX, TYPE 12 FLAT COVER/SCR
    HOFFMAN A1045DSC J BOX,TYPE 12 DOME COVER/SCR
    HOFFMAN A1066JFGQRPWR J BOX,TYPE 4X,WINDOW COVER/QR
    HOFFMAN A1066JFGQRR J BOX, TYPE 4X, SOLID COVER/QR
    HOFFMAN A1066JFGR J BOX TYPE 4X, SOLID COVER/SCR
    HOFFMAN A1084DL J BOX,TYPE 12 HINGED COVER QR
    HOFFMAN A1084GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A1086CHQRFG ENCLOSURE TYPE 4X SOLID COVER/QR
    HOFFMAN A1086CHQRFGW TYPE 4X ENCL.,WINDOW CVR/QR
    HOFFMAN A1086CHSCFG TYPE 4X ENCL.,SOLID COVER/SCR
    HOFFMAN A1086CHSCFGW TYPE 4X ENCL.,WINDOW CVR/SCR
    HOFFMAN A1086CQRFGW BOX
    HOFFMAN A1086DL J BOX,TYPE 12 HINGED COVER QR
    HOFFMAN A10AXFN FAN COOLING 560CFM 115V
    HOFFMAN A10AXFN2 AXIAL FAN, 10 IN
    HOFFMAN A10AXFNPG AXIAL FAN, 10IN, COMPACT
    HOFFMAN A-10D84 ENCLOSURE STEEL/GRAY 10X8X4 NEMA9 EXPLOSION PROOF
    HOFFMAN A10JBNS TERMINAL STRIP ASSY, 12 BLOCKS
    HOFFMAN A10JS KIT TERMINAL STRAP STEEL/WHITE FITS 10.0
    HOFFMAN A-10JTMA KIT 2TERMINAL BRACKETS STEEL/WHITE
    HOFFMAN A10JTMAXK BRACKET ASSY (2)/TERMINAL KIT
    HOFFMAN A10N104 SMALL TYPE 1 ENCLOSURE
    HOFFMAN A10N106 SMALL TYPE 1 ENCLOSURE
    HOFFMAN A10N10P PANEL,N1 / 8.25X8.25
    HOFFMAN A10N10PP PANEL,N1, PERF. / 8.25X8.25
    HOFFMAN A-10N84 ENCLOSURE STEEL/GRAY 10X8X4 NEMA1 IP30 16GAUGE
    HOFFMAN A10N86 SMALL TYPE 1 ENCLOSURE
    HOFFMAN A10N8P PANEL,N1 / 8.25X6.25
    HOFFMAN A10N8PP PANEL,N1, PERF. / 8.25X6.25
    HOFFMAN A-10P10 BACK PANEL J BOX STEEL/WHITE 8.75X8.88 FITS 10X10
    HOFFMAN A-10P8 BACK PANEL STEEL/WHITE 8.75X 6.88 FOR J-BOX
    HOFFMAN A10P8AL PANEL, J BOX / 8.75X6.88
    HOFFMAN A10P8C PANEL, J BOX / 8.75X6.88
    HOFFMAN A10P8G PANEL, J BOX / 8.75X6.88
    HOFFMAN A-10P8SS BACK PANEL 8.75X6.88 FOR J-BOX 10X8 SS TYPE 304
    HOFFMAN A10R104NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A10R106 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A10R106NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A10R84 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A10R84NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A10R86 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A10R86HCLO TYPE 3R ENCLOSURE/LIFT-OFF HNG
    HOFFMAN A10R86NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A10SPK8C SWING-OUT PANEL KIT
    HOFFMAN A12064CH J BOX, TYPE 12 HINGED COVER
    HOFFMAN A12106CHAL J BOX, TYPE 12 HINGED COVER
    HOFFMAN A12106CHEMCSS J BOX TYP 4X EMC, HINGED COVER
    HOFFMAN A12106CHNFSS ENCLOSURE 12X10X6 NEMA4X J-BOX SS TYPE304 HC
    HOFFMAN A12106CHNFSS6 J BOX, TYPE 4X HINGED COVER
    HOFFMAN A12106CHQRFG TYPE 4X ENCL.,SOLID COVER/QR
    HOFFMAN A12106CHQRFGW TYPE 4X ENCL.,WINDOW CVR/QR
    HOFFMAN A12106CHSCFG TYPE 4X ENCL.,SOLID COVER/SCR
    HOFFMAN A12106CHSCFGW TYPE 4X ENCL.,WINDOW CVR/SCR
    HOFFMAN A12106GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A12106NFSS J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A12106NFSS6 J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A-12108CH ENCLOSURE STEEL 12X10X8 NEMA12 J-BOX W/HINGED CV.
    HOFFMAN A12108DL J BOX,TYPE 12 HINGED COVER QR
    HOFFMAN A-1210CH ENCLOSURE STEEL 12X10 NEMA12 J-BOX W/HINGED COVER
    HOFFMAN A1210CHEMC J BOX TYP 12 EMC, HINGED COVER
    HOFFMAN A1210CHFTC J BOX,TYPE 12 HINGED COVER FTC
    HOFFMAN A1210CHNF J BOX, TYPE 4 HINGED COVER
    HOFFMAN A1210CHQR J BOX,TYPE 12 HINGED COVER QR
    HOFFMAN A1210CHS J BOX,TYP12 SHORT HINGED COVER
    HOFFMAN A1210LP J BOX, TYPE 12 LIFT-OFF COVER
    HOFFMAN A1210NF J BOX, TYPE 4 CLAMP COVER
    HOFFMAN A1210NFAL J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A-1210SC ENCLOSURE STEEL 12X10 NEMA12 J-BOX W/SCREW COVER
    HOFFMAN A1212116RT WIRE TROUGH, TYPE 3R
    HOFFMAN A1212120T1T WIRE TROUGH, TYPE 1
    HOFFMAN A121212GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A121224RT WIRE TROUGH, TYPE 3R
    HOFFMAN A121224T1T WIRE TROUGH, TYPE 1
    HOFFMAN A121236RT WIRE TROUGH, TYPE 3R
    HOFFMAN A121236T1T WIRE TROUGH, TYPE 1
    HOFFMAN A121248RT WIRE TROUGH, TYPE 3R
    HOFFMAN A121248T1T WIRE TROUGH, TYPE 1
    HOFFMAN A12124GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A121260RT WIRE TROUGH, TYPE 3R
    HOFFMAN A121260T1T WIRE TROUGH, TYPE 1
    HOFFMAN A12126GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A121272RT WIRE TROUGH, TYPE 3R
    HOFFMAN A121272T1T WIRE TROUGH, TYPE 1
    HOFFMAN A121284RT WIRE TROUGH, TYPE 3R
    HOFFMAN A12128GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A121296RT WIRE TROUGH, TYPE 3R
    HOFFMAN A121296T1T WIRE TROUGH, TYPE 1
    HOFFMAN A-1212CH ENCLOSURE STEEL 12X12X6 NEMA12 J-BOX W/ HINGED CV.
    HOFFMAN A1212CHEMCSS J BOX TYP 4X EMC, HINGED COVER
    HOFFMAN A1212CHNF J BOX, TYPE 4 HINGED COVER
    HOFFMAN A1212CHNFSS ENCLOSURE 12X12X6 NEMA4X S/S J-BOX W/HINGED COVER
    HOFFMAN A1212CHNFSS6 J BOX, TYPE 4X HINGED COVER
    HOFFMAN A1212SC JUNCTION BOX STEEL/GRAY TYPE12 12.00X12.00X6.00
    HOFFMAN A122406LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A-122408LP ENCLOSURE WALL-MOUNT TYPE 12/13
    HOFFMAN A1287JFGOR BOX
    HOFFMAN A1287JFGQRPWR J BOX,TYPE 4X,WINDOW COVER/QR
    HOFFMAN A1287JFGQRR J BOX, TYPE 4X, SOLID COVER/QR
    HOFFMAN A1287JFGR J BOX TYPE 4X, SOLID COVER/SCR
    HOFFMAN A12D106 TYPE 9 ENCLOSURE
    HOFFMAN A12D128 TYPE 9 ENCLOSURE
    HOFFMAN A12DLP12 PANEL, NEMA 12 / 9.00X9.00
    HOFFMAN A12JBNS TERMINAL STRIP ASSY, 16 BLOCKS
    HOFFMAN A-12JBR TERMINAL STRIP
    HOFFMAN A-12JS TERMINAL STRAP STEEL WHITE
    HOFFMAN A12JTMA BRACKET ASSY (2)/TERMINAL KIT
    HOFFMAN A-12N104 ENCLOSURE STEEL/GRAY 12X10X4 NEMA1 IP30 16GAUGE
    HOFFMAN A12N106 ENCLOSURE STEEL/GRAY NEMA1 12X10X6 SMALL
    HOFFMAN A12N10P PANEL,N1 / 10.25X8.25
    HOFFMAN A12N10PP PANEL,N1, PERF. / 10.25X8.25
    HOFFMAN A-12N124 ENCLOSURE 12X12X4 NEMA1, IP30 16GAUGE GRAY
    HOFFMAN A12N126 SMALL TYPE 1 ENCLOSURE
    HOFFMAN A12N128 SMALL TYPE 1 ENCLOSURE
    HOFFMAN A12N12P PANEL,N1 / 10.25X10.25
    HOFFMAN A12N12PP PANEL,N1, PERF. / 10.25X10.25
    HOFFMAN A12NTMA2 BRACKET ASSY (2)/TERMINAL KIT
    HOFFMAN A-12P10 BACK PANEL 10.75X8.88 FOR J-BOX 12X10
    HOFFMAN A12P10AL PANEL, J BOX / 10.75X8.88
    HOFFMAN A12P10C PANEL, J BOX / 10.75X8.88
    HOFFMAN A12P10G PANEL 12X10 GALVANIZED
    HOFFMAN A12P10SS PANEL, J BOX / 10.75X8.88
    HOFFMAN A-12P12 BACK PANEL 10.75X10.88 FOR J-BOX 12X12
    HOFFMAN A-12P12SS BACK PANEL 10.75X10.88 FOR S/S J-BOX 12X12
    HOFFMAN A12P24 PANEL, NEMA 12 / 9.00X21.00
    HOFFMAN A12P6 PANEL, J BOX / 10.75X4.88
    HOFFMAN A12R104 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R104NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R106 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R106HCLO TYPE 3R ENCLOSURE/LIFT-OFF HNG
    HOFFMAN A12R106HCR TYPE 3R ENCLOSURE, HNG COVER
    HOFFMAN A12R106NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R1210HCR TYPE 3R ENCLOSURE, HNG COVER
    HOFFMAN A12R124 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R124NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R126 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R126HCLO TYPE 3R ENCLOSURE/LIFT-OFF HNG
    HOFFMAN A12R126HCR TYPE 3R ENCLOSURE, HNG COVER
    HOFFMAN A12R126NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R128 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R128NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R44 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R44NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R84 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R84NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12R86 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A12SPK10C SWING-OUT PANEL KIT
    HOFFMAN A14107JFGQRPWR J BOX,TYPE 4X,WINDOW COVER/QR
    HOFFMAN A14107JFGQRR J BOX, TYPE 4X, SOLID COVER/QR
    HOFFMAN A14107JFGR JUNCTION BOX FIBERGLASS TYPE 4X 13.50X10.00X7.19
    HOFFMAN A-14128CH ENCLOSURE STEEL 14X12X8 J-BOX HINGE CV. NEMA12
    HOFFMAN A14128CHQRFG TYPE 4X ENCL.,SOLID COVER/QR
    HOFFMAN A14128CHQRFGW TYPE 4X ENCL.,WINDOW CVR/QR
    HOFFMAN A14128CHSCFG TYPE 4X ENCL.,SOLID COVER/SCR
    HOFFMAN A14128CHSCFGW TYPE 4X ENCL.,WINDOW CVR/SCR
    HOFFMAN A1412CH ENCLOSURE J-BOX STEEL TYPE 12 14X12X6 HINGED COVER
    HOFFMAN A1412CHAL J BOX, TYPE 12 HINGED COVER
    HOFFMAN A1412CHEMC J BOX TYP 12 EMC, HINGED COVER
    HOFFMAN A1412CHEMCSS J BOX TYP 4X EMC, HINGED COVER
    HOFFMAN A1412CHFTC J BOX,TYPE 12 HINGED COVER FTC
    HOFFMAN A1412CHNF J BOX, TYPE 4 HINGED COVER
    HOFFMAN A1412CHNFSS J BOX, TYPE 4X HINGED COVER
    HOFFMAN A1412CHNFSS6 J BOX, TYPE 4X HINGED COVER
    HOFFMAN A1412CHQR ENCLOSURE STEEL14X12X6 QR J-BOX CONT HINGED NEMA12
    HOFFMAN A1412CHS J BOX,TYP12 SHORT HINGED COVER
    HOFFMAN A1412LP J BOX, TYPE 12 LIFT-OFF COVER
    HOFFMAN A1412NF J BOX, TYPE 4 CLAMP COVER
    HOFFMAN A1412NFAL J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A1412NFSS J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A1412NFSS6 J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A1412SC ENCLOSURE 14X12X6 J-BOX SCREW COVER NEMA12
    HOFFMAN A1414116RT WIRE TROUGH, TYPE 3R
    HOFFMAN A141448RT WIRE TROUGH, TYPE 3R
    HOFFMAN A141472RT WIRE TROUGH, TYPE 3R
    HOFFMAN A141484RT WIRE TROUGH, TYPE 3R
    HOFFMAN A141496RT WIRE TROUGH, TYPE 3R
    HOFFMAN A14JBNS TERMINAL STRIP ASSY, 20 BLOCKS
    HOFFMAN A14JS KIT
    HOFFMAN A14JTMA BRACKET ASSY (2)/TERMINAL KIT
    HOFFMAN A14N124 SMALL TYPE 1 ENCLOSURE
    HOFFMAN A14N126 SMALL TYPE 1 ENCLOSURE
    HOFFMAN A14N128 SMALL TYPE 1 ENCLOSURE
    HOFFMAN A14N12P PANEL,N1 / 12.25X10.25
    HOFFMAN A14N12PP PANEL,N1, PERF. / 12.25X10.25
    HOFFMAN A14P12 BACK PANEL STEEL/WHITE 12.75X10.88 FOR J BOX 14X12
    HOFFMAN A14P12AL PANEL, J BOX / 12.75X10.88
    HOFFMAN A14P12C PANEL, J BOX / 12.75X10.88
    HOFFMAN A14P12G PANEL, J BOX / 12.75X10.88
    HOFFMAN A14P12SS PANEL, J BOX / 12.75X10.88
    HOFFMAN A-14P16 BACK PANELS 14.75X12.88 FOR J-BOX 16X14
    HOFFMAN A14P8 PANEL, J BOX / 12.75X6.88
    HOFFMAN A14SPK12C SWING-OUT PANEL KIT
    HOFFMAN A150100GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A150100WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A150150GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A150150WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A150200GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A150200WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A150300GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A150300WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A150400GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A150400WH PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A150CGR COVER, PVC WIRING DUCT (QTY12)
    HOFFMAN A150CWH COVER, PVC WIRING DUCT (QTY12)
    HOFFMAN A150DMC MOUNTING CLIPS (QTY 100)
    HOFFMAN A15R126 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A15R126NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A15R128 TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A15R128NK TYPE 3R ENCLOSURE, SCREW COVER
    HOFFMAN A16106CH ENCLOSURE 16X10X6 J-BOX HINGED COVER NEMA12
    HOFFMAN A161206FMLP FLUSH-MOUNT TYPE 12 ENCLOSURE
    HOFFMAN A161206LP ENCLOSURE STEEL 16X12X6 WALL MOUNT NEMA12/13
    HOFFMAN A161206LPEMC WALL-MOUNT TYP12 EMC ENCL.
    HOFFMAN A161206LPEMCSS WALL-MOUNT EMC ENCLOSURE
    HOFFMAN A161208LP ENCLOSURE STEEL 16X12X8 WALL MOUNT NEMA12/13
    HOFFMAN A-161210LP ENCLOSURE STEEL 16X12X10 WALL-MOUNT TYPE 12
    HOFFMAN A16126GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A16128JFGQRPWR J BOX,TYPE 4X,WINDOW COVER/QR
    HOFFMAN A16128JFGQRR J BOX, TYPE 4X, SOLID COVER/QR
    HOFFMAN A16128JFGR J BOX TYPE 4X, SOLID COVER/SCR
    HOFFMAN A161406LP BOX
    HOFFMAN A161410CH CONTINUOUS HINGE ENCLOSURE 16X14X10
    HOFFMAN A16148CH ENCLOSURE STEEL 16X14X6 J-BOX HINGED COVER NEMA12
    HOFFMAN A16148CHQF ENCLOSURE
    HOFFMAN A16148CHQRFG TYPE 4X ENCL.,SOLID COVER/QR
    HOFFMAN A16148CHQRFGW TYPE 4X ENCL.,WINDOW CVR/QR
    HOFFMAN A16148CHSCFG TYPE 4X ENCL.,SOLID COVER/SCR
    HOFFMAN A16148CHSCFGW TYPE 4X ENCL.,WINDOW CVR/SCR
    HOFFMAN A1614CH J BOX, TYPE 12 HINGED COVER
    HOFFMAN A1614CHAL J BOX, TYPE 12 HINGED COVER
    HOFFMAN A1614CHEMC J BOX TYP 12 EMC, HINGED COVER
    HOFFMAN A1614CHEMCSS J BOX TYP 4X EMC, HINGED COVER
    HOFFMAN A-1614CHFTC ENCLOSURE 16X14X6 NEMA4 HINGED COVER
    HOFFMAN A1614CHNF ENCLOSURE STEEL/GRAY 16X14X6 NEMA4 HINGED COVER
    HOFFMAN A1614CHNFSS J BOX, TYPE 4X HINGED COVER
    HOFFMAN A1614CHNFSS6 J BOX, TYPE 4X HINGED COVER
    HOFFMAN A-1614CHQR ENCLOSURE STEEL 16X14X6 J-BOX QR HINGED CV. NEMA12
    HOFFMAN A-1614CHS ENCLOSURE 16X14X6 NEMA12 HINGED COVER
    HOFFMAN A1614LP J BOX, TYPE 12 LIFT-OFF COVER
    HOFFMAN A1614NF J BOX, TYPE 4 CLAMP COVER
    HOFFMAN A1614NFAL J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A1614NFSS J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A1614NFSS6 J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A-1614SC ENCLOSURE STEEL 16X14X6 J-BOX SCREW COVER NEMA12
    HOFFMAN A161606LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A161608L BOX
    HOFFMAN A161608LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A161612GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A16166GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A16168GSC GALVANIZED BOX / SCREW COVER
    HOFFMAN A162006LP ENCLOSURE WALL-MOUNT NEMA12/13
    HOFFMAN A162008LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A16D128 TYPE 9 ENCLOSURE
    HOFFMAN A16D168 TYPE 9 ENCLOSURE
    HOFFMAN A16H1206ALLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A16H1206SS6LP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A16H1206SSLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A16H1208SS6LP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A16H1208SSLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A16H12ALP ENCLOSURE STEEL16X12X6 WALL MOUNT NEMA4 LESS PANEL
    HOFFMAN A16H12BLP WALL-MOUNT TYPE 4 ENCLOSURE
    HOFFMAN A16H1606SS6LP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A-16H1606SSLP ENCLOSURE 16X16X6 WALL-MOUNT SS NEMA4X LESS PANEL
    HOFFMAN A16H1608ALLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A16H16ALP WALL-MOUNT TYPE 4 ENCLOSURE
    HOFFMAN A16H2006SS6LP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A16H2006SSLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A16H20ALP WALL-MOUNT TYPE 4 ENCLOSURE
    HOFFMAN A16JBNS TERMINAL STRIP ASSY, 24 BLOCKS
    HOFFMAN A-16JS TERMINAL STRAP STEEL/WHITE FITS 16.00
    HOFFMAN A16N126 SMALL TYPE 1 ENCLOSURE
    HOFFMAN A16N126LP ENCLOSURE STEEL/GRAY WALL MOUNT CONTROL 16X12X6.62
    HOFFMAN A16N128LP WALL-MOUNT CONTROL ENCLOSURE
    HOFFMAN A16N12ALP MEDIUM TYPE 1 ENCLOSURE
    HOFFMAN A16N12BLP MEDIUM TYPE 1 ENCLOSURE
    HOFFMAN A16N12MP PANEL STEEL/WHITE NEMA1 13.00X10.50 FITS 16X12
    HOFFMAN A-16NTMA2 BRACKET ASSEMBLYSTEEL/WHITE 2 PER TERMINAL KIT
    HOFFMAN A16P12 BACK PANEL STEEL 13.00X9.00 FOR NEMA12 16X12 ENCL
    HOFFMAN A-16P14 BACK PANEL J BOXSTEEL WHITE 14.75X12.88
    HOFFMAN A16P14SS PANEL, J BOX / 14.75X12.88
    HOFFMAN A16P16 BACK PANEL STEEL/WHITE 13X13 FOR 16X16 NEMA12 ENCL
    HOFFMAN A19RP2U PANEL
    HOFFMAN A19RP5U PANEL
    HOFFMAN A200300GR PVC WIRING DUCT (CARTON QTY12)
    HOFFMAN A-200300WH WIRE DUCT 2 IN W X 3 IN D (6FT LENGTH PRICE)
    HOFFMAN A200CGR COVER, PVC WIRING DUCT (QTY12)
    HOFFMAN A-200CWH WIRE DUCT COVER 2 IN W (6 FT LENGTH PRICE)
    HOFFMAN A-201606LP ENCLOSURE STEEL 20X16X6 WALL MOUNT NEMA12/13
    HOFFMAN A201608CP ENCLOSURE
    HOFFMAN A-201608LP ENCLOSURE STEEL 20X16X8 WALL MOUNT NEMA12/13
    HOFFMAN A201610LP ENCLOSURE STEEL 20X16X10 WALL MOUNT NEMA12/13
    HOFFMAN A202006LP ENCLOSURE STEEL 20X20X6 WALL MOUNT NEMA12/13
    HOFFMAN A202008LP ENCLOSURE STEEL 20X20X8 WALL MOUNT NEMA12/13
    HOFFMAN A202010LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A20C20ALP ENCLOSURE STEEL 20X20X7 JIC WALL MOUNT
    HOFFMAN A20H1608GQRLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A20H1608SSLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A20N16BLP MEDIUM TYPE 1 ENCLOSURE
    HOFFMAN A20N16MP PANEL,N1 / 17.00X14.50
    HOFFMAN A20N208LP WALL-MOUNT CONTROL ENCLOSURE
    HOFFMAN A20N20BLP MEDIUM TYPE 1 ENCLOSURE
    HOFFMAN A-20N20MP MOUNTING PANEL17.00 X 18.50 STEEL WHITE
    HOFFMAN A20P16 PANEL STEEL 17X13 FOR 20X16 NEMA 3R/4/4X/12/13
    HOFFMAN A20P20 BACK PANEL STEEL/WHITE 17X17 FOR 20X20
    HOFFMAN A-20T TERMINAL STRAP KIT STEEL/WHITE FOR 20INCH ENCL.
    HOFFMAN A21-ABA DISCONNECT ADAPTOR FOR A/B 1494F/D
    HOFFMAN A-21ABVA DISCONNECT ADAPTER STEEL/GRAY FOR A/B 1494V
    HOFFMAN A21GETDA DISCONNECT ADAPTER STEEL/GRAY FOR GE STDA
    HOFFMAN A21ITE OPERATOR ADAPTER,
    HOFFMAN A21K4 TERMINAL
    HOFFMAN A-21SDA DISCONNECT ADAPTER STEEL/GRAY FOR SQUARE D 9422
    HOFFMAN A22BAP ADAPT PLATE,BLANK FOR CUTOUT
    HOFFMAN A241206LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A-241608LP ENCLOSURE 24X16X8 WALL MOUNT NEMA12/13 LESS PANEL
    HOFFMAN A242006LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A242008LP ENCLOSURE STEEL WALL-MOUNT TYPE 12/13
    HOFFMAN A242010LP ENCLOSURE STEEL 24X20X10 NEMA-12 LESS PANEL
    HOFFMAN A242406LP ENCLOSURE STEEL 24X24X6 WALL MOUNT NEMA12/13
    HOFFMAN A242408LP ENCLOSURE STEEL 24X24X8 WALL MOUNT NEMA12/13
    HOFFMAN A242412LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A243008LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A244808WFLP TWO DOOR WALL-MTGTYPE 12 ENCL.
    HOFFMAN A24C20ALP ENCLOSURE 24X20X7 JIC WALL MOUNT NEMA12 LESS PANEL
    HOFFMAN A24C20BLP ENCLOSURE STEEL 24X20X9 JIC WALL MOUNT NEMA12
    HOFFMAN A24H3008SS6LP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A24HS2108LP TYPE 4 DISCONNECT ENCLOSURE
    HOFFMAN A24N20ALP MEDIUM TYPE 1 ENCLOSURE
    HOFFMAN A-24N20MP BACK PANEL STEEL 21X18.50 FOR 24X20 NEMA-1 ENCL
    HOFFMAN A24P16 BACK PANEL STEEL 21X13 FOR 24X16 NEMA12 ENCL
    HOFFMAN A24P20 BACK PANEL STEEL 21X17 FOR 24X20 NEMA12 ENCL.
    HOFFMAN A-24P24 BACK PANEL STEEL 21X21 FOR 24X24 NEMA12 ENCL.
    HOFFMAN A24R2410HCR TYPE 3R ENCLOSURE, HNG COVER
    HOFFMAN A24R248HCR ENCLOSURE NEMA3R 24HX24WX8D CONT HINGED RAINPROOF
    HOFFMAN A24SA2208LP TYPE 12 SA DISCONNECT ENCL.
    HOFFMAN A-24SA2210LP ENCLOSURE 24X21.38X10 W/HANDLE
    HOFFMAN A-300300WH WIRE DUCT 3IN W X 3IN D (6FT LENGTH PRICE)
    HOFFMAN A-300CWH WIRE DUCT COVER 3IN W (6FT LENGTH PRICE)
    HOFFMAN A302006LP ENCLOSURE STEEL 30X20X6 WALL MOUNT NEMA12/13
    HOFFMAN A302008LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A302010LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A-302408LP ENCLOSURE WALL-MOUNT NEMA12/13
    HOFFMAN A302410LP ENCLOSURE STEEL 30X24X10 WALL MOUNT NEMA12
    HOFFMAN A302416LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A302420LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A302424LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A303012LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A-303608LP ENCLOSURE 30X30X8 WALL MOUNT NEMA12/13 LESS PANEL
    HOFFMAN A30AB2610LP TYPE 12 A-B DISCONNECT ENCL.
    HOFFMAN A30H2408GQRLP ENCLOSURE 4X FIBERGLASS WALL MOUNT
    HOFFMAN A30H2408SSLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A30H24BLP ENCLOSURE STEEL 30X24X8 WALL MOUNT NEMA-4
    HOFFMAN A30H24DLP WALL-MOUNT TYPE 4 ENCLOSURE
    HOFFMAN A30H3008SSLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A30P20 BACK PANEL STEEL/WHITE 27X17 FOR 30X20 NEMA12 ENCL
    HOFFMAN A-30P24 BACK PANEL STEEL/WHITE 27X21 FOR 30X24 NEMA12 ENCL
    HOFFMAN A30P30 PANEL, NEMA 12 / 27.00X27.00
    HOFFMAN A30R248HCR TYPE 3R ENCLOSURE, HNG COVER
    HOFFMAN A30SA2208LPPL TYPE 12 SA DISC. ENC. W HANDLE
    HOFFMAN A30SA2608LP TYPE 12 SA DISCONNECT ENCL.
    HOFFMAN A30SA2610LP TYPE 12 SA DISCONNECT ENCL.
    HOFFMAN A31P21 BACK PANEL STEEL/WHITE 31.88X21.75 FOR NEMA12 ENCL
    HOFFMAN A3624 PART
    HOFFMAN A362408LP ENCLOSURE STEEL/GRAY 36X24X8 WALL MOUNT NEMA12
    HOFFMAN A362412LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A-363016LP ENCLOSURE STEEL 36X30X16 WALL-MOUNT NEMA12/13
    HOFFMAN A-363608LP ENCLOSURE 36X36X8 WALL MOUNT NEMA12 LESS PANEL
    HOFFMAN A364812WFLP ENCLOSURE STEEL 2DOOR WALL MTG NEMA12 36X48X12 IN.
    HOFFMAN A366012WFLP TWO DOOR WALL-MTGTYPE 12 ENCL.
    HOFFMAN A36AB3212LP TYPE 12 A-B DISCONNECT ENCL.
    HOFFMAN A36H24BLP WALL-MOUNT TYPE 4 ENCLOSURE
    HOFFMAN A36H3012GQRLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A36H3012SS6LP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A36H3012SSLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A36H30BLP WALL-MOUNT TYPE 4 ENCLOSURE
    HOFFMAN A36H3612GQRLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A36P24 BACK PANEL 33X21 FOR 36X24 NEMA12 ENCL
    HOFFMAN A-36P30 BACK PANEL STEEL/WHITE 33X27 FOR36X30 NEMA12 ENCL
    HOFFMAN A-36P36 BACK PANEL 33X33 FOR 36X36 NEMA12 ENCL
    HOFFMAN A36R3612HCR TYPE 3R ENCLOSURE, HNG COVER
    HOFFMAN A36R3613 BOX
    HOFFMAN A36SA2608LP TYPE 12 SA DISCONNECT ENCL.
    HOFFMAN A36SA2610LP TYPE 12 SA DISCONNECT ENCL.
    HOFFMAN A-400500WH WIRE DUCT 4IN W X 5IN D WHITE (6FT LENGTH PRICE)
    HOFFMAN A-400CWH WIRE DUCT COVER 4IN W WHITE (6FT LENGTH PRICE)
    HOFFMAN A-404CH J BOX TYPE 12 HINGED COVER 4.00X4.00X3.00 STEEL GR
    HOFFMAN A404LP ENCLOSURE 4X4X3 J-BOX N-12 LIFT-OFF COV LESS PANEL
    HOFFMAN A-404NF ENCLOSURE J BOX TYPE4 CLAMP COVER
    HOFFMAN A-404NFSS ENCLOSURE 4X4X3 J-BOX N-4X SS 304 CLAMP COVER
    HOFFMAN A404SC ENCLOSURE 4X4X3 J-BOX NEMA12 SCREW-COVER
    HOFFMAN A423010LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A-423608LP ENCLOSURE 42X36X08 WALL MOUNT NEMA12/13 LESS PANEL
    HOFFMAN A423612LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A424212WFPL ENCLOSURE
    HOFFMAN A42AB3212LP TYPE 12 A-B DISCONNECT ENCL.
    HOFFMAN A-42P30 BACK PANEL STEEL/WHITE 39X27 FOR 42X30 NEMA12 ENCL
    HOFFMAN A-42P36 BACK PANEL 39X33 FOR 42X36 NEMA12 ENCL
    HOFFMAN A42P42 PANEL, NEMA 12 / 39.00X39.00
    HOFFMAN A42SA3208LP TYPE 12 SA DISCONNECT ENCL.
    HOFFMAN A42SA3212LPPL TYPE 12 SA DISC. ENC. W HANDLE
    HOFFMAN A42SA3810LPPL TYPE 12 SA DISC. ENC. W HANDLE
    HOFFMAN A44CCOL STRAIGHT PEDESTAL COLUMN
    HOFFMAN A-483610LP ENCLOSURE 48X36X10 WALL MOUNT NEMA12/13 LESS PANEL
    HOFFMAN A-483612LP ENCLOSURE WALL MOUNT STEEL TYPE 12/13
    HOFFMAN A483616LP WALL-MOUNT TYPE 12/13 ENCL.
    HOFFMAN A484812WFLP TWO DOOR WALL-MTGTYPE 12 ENCL. 48.00X48.00X12.00
    HOFFMAN A48936 PART
    HOFFMAN A48H3612GQRLP ENCLOSURE 48.25X36.25X12 WALL MOUNT N-4X FIBERGLAS
    HOFFMAN A48H3612SSLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A48H3616SS6LP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A48H3616SSLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A48H36DLP WALL-MOUNT TYPE 4 ENCLOSURE
    HOFFMAN A48HS3712DSSLP PANEL
    HOFFMAN A-48P36 BACK PANEL STEEL/WHITE 45X33 FOR 48X36 NEMA12 ENCL
    HOFFMAN A48P48 BACK PANEL 44X44 FOR 48X48 NEMA12 ENCL
    HOFFMAN A48R3616HCR TYPE 3R ENCLOSURE, HNG COVER
    HOFFMAN A-4AXFN FAN 4INCH AXIAL 115V 50/60HZ 4-IN AXIAL
    HOFFMAN A4XFN FAN
    HOFFMAN A533ENM CONTROL
    HOFFMAN A6044CH J BOX, TYPE 12 HINGED COVER
    HOFFMAN A6044CHNFSS J BOX, TYPE 4X HINGED COVER
    HOFFMAN A604812SSLP TWO DOOR FLOOR-MTG TYPE 12 ENC
    HOFFMAN A-604CH ENCLOSURE STEEL 6X4X3 J-BOX NEMA12 HINGED COVER
    HOFFMAN A606012LP TWO DOOR FLOOR-MTG TYPE 12 ENC
    HOFFMAN A-606CH ENCLOSURE 6X6X4 J-BOX NEMA12 HINGED COVER
    HOFFMAN A606CHAL J BOX, TYPE 12 HINGED COVER
    HOFFMAN A606CHFTC J BOX,TYPE 12 HINGED COVER FTC
    HOFFMAN A606EHNF ENCLOSURE
    HOFFMAN A606NFSS J BOX, TYPE 4X CLAMP COVER
    HOFFMAN A-606SC ENCLOSURE STEEL 6X6X4 J-BOX NEMA12 SCREW COVER
    HOFFMAN A60H3612GQRLP WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN A60P30 BACK PANEL STEEL/WHITE 57X27 FOR 60X30 NEMA12 ENCL
    HOFFMAN A60P36 PANEL, NEMA 12 / 57.00X33.00
    HOFFMAN A60P48 PANEL,LG NEMA 12 / 56.00X44.00
    HOFFMAN A60P60 PANEL,LG NEMA 12 / 56.00X56.00
    HOFFMAN A60SA381OLP ENCLOSURE
    HOFFMAN A60SMP14 PANEL, SIDE-MOUNTED
    HOFFMAN A60X6112LPFTC TWO DOOR DISCONNECT ENCLOSURE
    HOFFMAN A664CHQRFG TYPE 4X ENCL.,SOLID COVER/QR
    HOFFMAN A664CHSCFG ENCLOSURE 6X6X4 NEMA-4X FIBERGLASS SCREW COVER
    HOFFMAN A664DL ENCLOSURE 6X6X4 J-BOX N-12 LIFT-OFF HINGED COVER
    HOFFMAN A6ARD6 FAN GUARD
    HOFFMAN A6AXFN FAN 6INCH AXIAL 115V 50/60HZ
    HOFFMAN A-6JTMA BRACKET ASSEMBLY STEEL/WHITE
    HOFFMAN A6N64 SMALL TYPE 1 ENCLOSURE
    HOFFMAN A6P4 PANEL J BOX 4.88X2.88 STEEL/WHITE
    HOFFMAN A-6P6 BACK PANEL STEEL/WHITE 4.88X4.88 FOR 6X6 J-BOX
    HOFFMAN A6R64HCR TYPE 3R ENCLOSURE, HNG COVER
    HOFFMAN A723018FS ONE-DOOR FS ENCLOSURE TYPE 12
    HOFFMAN A723618FS ONE-DOOR FS ENCLOSURE TYPE 12
    HOFFMAN A723624FS ONE-DOOR FS ENCLOSURE TYPE 12
    HOFFMAN A723624SF ENCLOSURE
    HOFFMAN A723636FSDA ONE-DR. DUAL ACC. FS ENCLOSURE
    HOFFMAN A724818FSD TWO-DOOR FS ENCLOSURE TYPE 12
    HOFFMAN A726010ULP TWO DOOR FLOOR-MTG TYPE 12 ENC
    HOFFMAN A726012ULP TWO DOOR FLOOR-MTG TYPE 12 ENC
    HOFFMAN A72FSHDPS HEAVY DUTY PANEL SUPPORTS (QTY 2)
    HOFFMAN A72H3124SSFS ONE-DOOR FS ENCLOSURE TYPE 4X
    HOFFMAN A72H3724FS ONE-DOOR FS ENCLOSURE TYPE 4
    HOFFMAN A72P30F1 PANEL, FULL 60.00X26.00
    HOFFMAN A72P36 PANEL, NEMA 12 / 69.00X33.00
    HOFFMAN A72P36F1 PANEL, FULL 60.00X32.00
    HOFFMAN A-72P48F1 PANEL 60X44
    HOFFMAN A-72P60 BACK PANEL 68X56 FOR 72X60 NEMA12 ENCL
    HOFFMAN A-72P72 BACK PANEL 68X68 FOR 72X72 NEMA12 ENCL
    HOFFMAN A72SMP14 PANEL, SIDE-MOUNTED
    HOFFMAN A72X7318LPFTC TWO DOOR DISCONNECT ENCLOSURE
    HOFFMAN A72XM3EW18FTC DISCONNECT ENCL. 3-DOOR F.S.
    HOFFMAN A72XM4018FTC DISCONNECT ENCL. 1-DOOR F.S.
    HOFFMAN A72XM5418FTC DISCONNECT ENCL. 2-DOOR F.S.
    HOFFMAN A72XM7818FTC DISCONNECT ENCL. 2-DOOR F.S.
    HOFFMAN A7483616LP ENCLOSURE
    HOFFMAN A74H60DULP TWO DOOR FLOOR-MTG TYPE 4 ENC
    HOFFMAN A8064CHAL J BOX, TYPE 12 HINGED COVER
    HOFFMAN A8064NFSS ENCLOSURE 8X6X4 J-BOX N-4X SS W/CLAMP COVER
    HOFFMAN A-8066CH ENCLOSURE 8X6X6 J-BOX NEMA12 W/HINGED COVER
    HOFFMAN A806CHFTC J BOX,TYPE 12 HINGED COVER FTC
    HOFFMAN A806CHNF J BOX, TYPE 4 HINGED COVER
    HOFFMAN A806SC BOX J STEEL 8.00X6.00X3.50 W/SCR. COVER
    HOFFMAN A80864CHNFSS ENCLOSURE
    HOFFMAN A808CH J BOX, TYPE 12 HINGED COVER
    HOFFMAN A-808-SC ENCLOSURE J BOX 8X8X4 TYPE12 SCREW COVER
    HOFFMAN A845JFGR J BOX TYPE 4X, SOLID COVER/SCR
    HOFFMAN A-84PM40 PANEL 72X33.75 FOR 84X1-BAY MULTI-D ENCL
    HOFFMAN A-84XM3EW18FTC ENCLOSURE
    HOFFMAN A-865JFGR ENCLOSURE 7.5X6X5.19 J-BOX NEMA-4X FIBERGLASS
    HOFFMAN A866DL J BOX,TYPE 12 HINGED COVER QR
    HOFFMAN A8JBNS TERMINAL STRIP ASSEMBLY 8 BLOCKS
    HOFFMAN A-8JS TERMINAL STRAP KIT
    HOFFMAN A-8P6 BACK PANEL 6.75X4.88 FOR 8X6 J-BOX
    HOFFMAN A8P6AL PANEL, J BOX / 6.75X4.88
    HOFFMAN A8P6SS PANEL, J BOX / 6.75X4.88
    HOFFMAN A8P8 PANEL, J BOX / 6.75X4.88
    HOFFMAN A8R86HCR ENCLOSURE 8X8X6 GALV/PAINT NEMA 3R HINGED COVER
    HOFFMAN A903624FSDA ONE-DR. DUAL ACC. FS ENCLOSURE
    HOFFMAN AAA1544 ANGLE ADAPTER, 15 DEG
    HOFFMAN AASHLF1818 SHELF 18X18 STEEL WHITE
    HOFFMAN A-BRKT4 FAN BRACKET 4INCH FOR FAN ALUMINUM
    HOFFMAN A-CSHELF18 FOLDING SHELF 18X18X1 STEEL WHITE
    HOFFMAN ADP2 DATA POCKET LARGE 12X12INCH PLASTIC
    HOFFMAN A-EK115 INTERLOCK FOR DOOR 120/110VAC
    HOFFMAN A-EK115NDH ELECTRICAL INTERLOCK 115V/60HZ
    HOFFMAN AEK230 ELECTRICAL INTERLOCK STEEL/ZINC 230V
    HOFFMAN AEK230NDH INTERLOCK STEEL ZINC 230V
    HOFFMAN AEK460 ELECTRICAL INTERLOCK STEEL ZINC 460VOLT
    HOFFMAN AEXGR10 EXHAUST GRILL KIT W/GRILL FILTER FINGER GUARD
    HOFFMAN A-EXGR275 FILTER EXHAUST GRILL FOR BLOWER
    HOFFMAN A-EXGR4 EXHAUST GRILLE & FILTER
    HOFFMAN AFK1212 FLOOR STAND KIT 12X12.06 GRAY STEEL QUANITY 2
    HOFFMAN AFK1218 FLOOR STAND KIT (QTY 2)
    HOFFMAN AFK2410 FLOOR STAND KIT (QTY 2)
    HOFFMAN AFLT34 FILTER ALUMINUM 3.25X4.09
    HOFFMAN A-FLT66 LOUVER/FILTER KIT FILTER ALUMINUM F/AVK66
    HOFFMAN AFLT88 FILTER & KIT
    HOFFMAN A-FLTR6 FILTER FOAM PACK SET OF 5 FOR 6 INCH FAN
    HOFFMAN AFLTR6AL FILTER PACKAGE FOR 6 IN (5)
    HOFFMAN AGARD4 FINGER GUARD FOR 4 IN
    HOFFMAN AGS816 GROUNDING STRAP, BRAIDED
    HOFFMAN AHCI10E CORROSION INHIBITOR, EMITTER
    HOFFMAN AHCI5E EMITTER CORROSION INHIBITOR
    HOFFMAN A-JCDFK SWING-OUT PANEL KIT FOR J-BOX STEEL/ZINC
    HOFFMAN AL23SS CLAMP ASSY,FAST OPERATING (1)
    HOFFMAN AL2A LATCH KIT KEY LOCK CW
    HOFFMAN A-L31 LATCH SLOTTED INSERT
    HOFFMAN AL48 QUICK-RELEASE LATCH KIT (2)
    HOFFMAN ALF16D18 LIGHT FIXTURE FLOURESCENT 18.88 INCH 115V
    HOFFMAN A-LF16D24 LIGHT FIXTURE FLOURESCENT 24.88INCH 115V
    HOFFMAN ALT2 PUNCH
    HOFFMAN A-LTDB1 LIGHT FIXTURE INCANDESCENT W/DOOR SWITCH 120V
    HOFFMAN A-LTMB1 LIGHTING PACKAGE INCANDESCENT 120V 50-60HZ
    HOFFMAN A-MOD8418FGK GASKET KIT RUBBER FOR MOD. ENCLOSURE
    HOFFMAN AP12P10 PANEL
    HOFFMAN AP36L44 PEDESTAL WITH LEGS
    HOFFMAN A-PA10AXFN FAN COOLING PACKAGE 115VAC
    HOFFMAN A-PA4AXFN FAN FILTER ASSEMBLY 100CFM 4IN 115VAC
    HOFFMAN A-PA6AXFN FAN COOLING PACKAGE 115VAC 6INCH
    HOFFMAN APCCHVA ADAPTOR PLATE STEEL/ZINC
    HOFFMAN APLKJIC PADLOCK KIT FOR J BOX STEEL/ZINC
    HOFFMAN APLKJIC6SS PADLOCK KIT
    HOFFMAN A-PS51618CN CLAMPING NUT PACKAGE 5/16-18 PKG OF 20
    HOFFMAN APWK133NF WINDOW KIT 13.00X3.00
    HOFFMAN APWK1711NF WINDOW KIT 17.00X11.00
    HOFFMAN A-PWK95NF KIT WINDOW 9.00X5.50
    HOFFMAN A-S050 HOLE PLUG SEAL FOR 1/2INCH KO WP
    HOFFMAN AS050SS HOLE PLUG SEAL 1.38 DIA. SS FOR 1/2 CONDUIT
    HOFFMAN AS075 HOLE PLUG SEAL 1.56DIAMETER FOR 3/4INCH CONDUIT
    HOFFMAN AS075SS HOLE PLUG SEAL 1.56 DIA. SS FOR 3/4INCH CONDUIT
    HOFFMAN A-S100 HOLE PLUG SEAL 1.88DIAMETER FOR 1INCH CONDUIT
    HOFFMAN AS100SS HOLE PLUG SEAL 1.88 DIA. SS FOR 1-INCH CONDUIT
    HOFFMAN AS1032 SCREW PKG , RACK P. (QTY 20)
    HOFFMAN A-S125 HOLE PLUG SEAL FOR 1-1/4INCH KO WP
    HOFFMAN AS125SS HOLE PLUG SEAL 2.19 DIA. SS FOR 1.25 INCH CONDUIT
    HOFFMAN A-S150 HOLE PLUG SEAL FOR 1-1/2INCH CONDUIT
    HOFFMAN A-S250 HOLE PLUG SEAL FOR 2-1/2INCH CONDUIT
    HOFFMAN ASE12124NK ENCLOSURE
    HOFFMAN ASE36X36X12XNK BOX
    HOFFMAN ASE6X6X6 PULL BOX, SCREW COVER / KO'S
    HOFFMAN ASE8X8X8 PULL BOX, SCREW COVER / KO'S
    HOFFMAN ASF12124NK ENCLOSURE
    HOFFMAN ASG12X12X4NK PULL BOX, SCREW COVER
    HOFFMAN ASG12X12X8NK PULL BOX, SCREW COVER
    HOFFMAN ASG24X24X8NK ENCLOSURE 24X24X8 GALV. PULL BOX W/SCREW COVER
    HOFFMAN ASG8X8X4NX ENCLOSURE
    HOFFMAN A-SPB HOLE SEAL 1.75DIA. FOR 30.5MM PUSHBUTTON
    HOFFMAN A-SPBG HOLE SEAL 1.22 DIA. FOR 22.5MM PUSHBUTTON
    HOFFMAN ASPBSS HOLE SEAL 1.75DIA. SS FOR 30.5MM PUSHBUTTON
    HOFFMAN AST3123R SPLITTER TROUGH,3 WIRE,125 AMP
    HOFFMAN ASWV44 ENCLOSURE
    HOFFMAN A-TEMNO THERMOSTAT FOR FAN N/O CONTACTS
    HOFFMAN AVK34 LOUVER KIT 4L X 3INCH STEEL GRAY
    HOFFMAN AVK43 LOUVER KIT 4.5 X 5.5 INCH STEEL GREY
    HOFFMAN A-VK64 LOUVER KIT 4LX6.0 INCH STEEL GRAY
    HOFFMAN A-VK88 LOUVER KIT 8LX8.00INCH STEEL GRAY
    HOFFMAN C-12C12 ENCLOSURE CONSOLE SLOPED COVER 12X12X9IN 16HOLE
    HOFFMAN C12C16 ENCLOSURE CONSOLE TYPE W/SLOPED COVER 12X16X9.09IN
    HOFFMAN C1624 ACCESSORY
    HOFFMAN C16C20SS CONSOLET, SLOPED COVER
    HOFFMAN C16C20STD CONSOLE
    HOFFMAN C-16C24 ENCLOSURE CONSOLE TYPE W/SLOPED COVER 16 X 24 X 11
    HOFFMAN C16C24SS CONSOLET, SLOPED COVER
    HOFFMAN C8C8 CONSOLET, SLOPED COVER
    HOFFMAN C92020 PLATE
    HOFFMAN CBH4045 OI BEZEL, HINGED
    HOFFMAN CBH5557 OI BEZEL, HINGED
    HOFFMAN C-CA1286 J BOX 125X80X57MM CAST ALUMINUM TYPE-4X
    HOFFMAN CCA332318 CAST J BOX,TYPE 4X
    HOFFMAN CCA886 ENCLOSURE 75X80X57MM J-BOX NEMA-4X ALUMINUM
    HOFFMAN CCAHK HINGE KIT (QTY 2)
    HOFFMAN CCB404515 OI BODY, SOLID BACK
    HOFFMAN CCB55517 ENCLOSURE
    HOFFMAN CCBDH404523 OI BODY, DOUBLE- HINGED
    HOFFMAN CCBR404515 OI BODY, REAR ACCESS
    HOFFMAN CCC603115 CAST OI ENCLOSURE,TYPE 4X
    HOFFMAN CCC603122 ENCLOSURE CAST OI TYPE4X 620X330X221MM
    HOFFMAN C-CCH220 HANDLE KIT 220MM ALUMINUM STRAIGHT QUANTITY 2
    HOFFMAN CCCH300 HANDLE KIT STRAIGHT ALUMINUM QUANTITY 2
    HOFFMAN CCP555715 OI ASSEMBLED PACKAGE
    HOFFMAN CCS1H5V PENDANT ARM, HORIZ/VERT.
    HOFFMAN CCS2EHD PENDANT
    HOFFMAN C-CS2EHDLG ELBOW H.DUTY PENDANT ARM FITS 45X60MM
    HOFFMAN CCS2FEC COUPLING
    HOFFMAN CCS2FECLG FLANGE ELBOW COUPLING, P. ARM
    HOFFMAN CCS2IJ JOINT
    HOFFMAN CCS2IJLG INTERMEDIATE JOINT, PEND. ARM
    HOFFMAN CCS2RRBLG BOX
    HOFFMAN CCS2SJLG CAST ALUMINUM RAL 7035 LIGHT GRAY HORIZONTAL MOUNT
    HOFFMAN C-CS2STLG SWIVEL TILT STRAIGHT PENDANT ARM
    HOFFMAN CCS2T10 TUBE,PENDANT ARM
    HOFFMAN C-CS2T20 TUBE PENDANT ARM 2000X45X60MM ALUMINUM
    HOFFMAN CCS2WFB BRACKET
    HOFFMAN CCS2WFBLG WALL FLANGE/ BASE BRKT. P. ARM
    HOFFMAN CCS2WJHLG WALL JOINT, HORIZONTAL, P. ARM
    HOFFMAN C-CS5EL ELBOW PENDANT ARM FITS 50X50MM ALUMINUM GREY
    HOFFMAN CCS5ELLG ELBOW FOR PENDANT ARM ALUMINUM GREY
    HOFFMAN CCS5FCLG COUPLING FOR PENDANT ARM ALUMINUM GREY
    HOFFMAN CCS5FECLG FLANGE ELBOW COUPLING, P. ARM
    HOFFMAN C-CS5T10 TUBE PENDANT ARM
    HOFFMAN CCS6BBLG BASE BRACKET, PENDANT ARM
    HOFFMAN CCS6STBLG SWIVEL TILT, PENDANT ARM
    HOFFMAN CCS6T20 TUBE,PENDANT ARM
    HOFFMAN CCS6T5 TUBE,PENDANT ARM
    HOFFMAN CCSK4045F16 PLATE
    HOFFMAN CCSK4045F7 BOX
    HOFFMAN CCSK5557F12 ENCLOSURE
    HOFFMAN CDSC423212 TYPE 12 DISCONNECT ENCLOSURE
    HOFFMAN CDSC423812 TYPE 12 DISCONNECT ENCLOSURE
    HOFFMAN C-DSC483812 ENCLOSURE FOR C/B DISCONNECT 48X38X12 N-12 W/HANDL
    HOFFMAN CFC382416 ENCLOSURE
    HOFFMAN C-HDL40 OI HANDLE KIT 400MM HIGH
    HOFFMAN CHDL55 HANDLE KIT 550MM CONCEPT OIQTY2
    HOFFMAN CKBC24 KEYBOARD BOX
    HOFFMAN CMFK ENCLOSURE FOOT MOUNTING KIT STEEL/ZINC
    HOFFMAN CMTGFT MOUNTING FOOT KIT (QTY 4)
    HOFFMAN C-P1212 OPTION PANEL FORENCLOSURES CONCEPT WALL MOUNT A3..
    HOFFMAN C-P1612 BACK PANEL 14.20X10.20 FITS 16X12 ENCLOSURE
    HOFFMAN C-P1616 BACK PANEL STEEL 14.2X14.2 FITS 16X16 ENCLOSURE
    HOFFMAN CP2016 BACK PANEL STEEL 18.2X14.2 FITS 20X16 ENCLOSURE
    HOFFMAN CP2020 BACK PANEL STEEL 18.2X18.2 FITS 20X20 ENCLOSURE
    HOFFMAN CP2416 BACK PANEL STEEL 22.2X14.2 FITS 24X16 ENCLOSURE
    HOFFMAN CP2420 PANEL STEEL WHITE 22.20X18.20
    HOFFMAN CP2424 PANEL STEEL WHITE 22.20X22.20
    HOFFMAN C-P3020 BACK PANEL STEEL WHITE 28.2X18.2 FITS 30X20 ENCL.
    HOFFMAN C-P3024 PANEL 28.2HX22.2W
    HOFFMAN CP3030 PANEL 28.2HX28.2W
    HOFFMAN C-P3624 BACK PANEL STEEL WHITE 34.20X22.20
    HOFFMAN CP3630 PANEL, 34.20X28.20
    HOFFMAN CP4230 PANEL, 40.20X28.20
    HOFFMAN CP4236 PANEL, 40.20X34.20
    HOFFMAN CP4824 PANEL, 46.20X22.20
    HOFFMAN C-P4836 BACK PANEL STEEL WHITE 46.2X34.2 FITS 48X36 ENCL
    HOFFMAN C-P6036 ENCLOSURE CONCEPT PANEL STEEL WHITE 58.2X34.2
    HOFFMAN CR290426G002 AIR CONDITIONER 3500-4000BTU 230VAC SIDE MTG
    HOFFMAN C-SD12126 ENCLOSURE STEEL 12X12X6 WALL MOUNT NEMA-4/12
    HOFFMAN CSD16128W WALL-MOUNT ENCL./WINDOW
    HOFFMAN CSD16168 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD16208 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD16208SS6 WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN C-SD20166 ENCLOSURE 20X16X6 WALL MOUNT NEMA-4/12
    HOFFMAN CSD20168 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD20168S ENCLOSURE
    HOFFMAN C-SD202012 ENCLOSURE 20X20X12 WALL MOUNT NEMA-4/12
    HOFFMAN CSD202012SS WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN CSD20206 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN C-SD20208 ENCLOSURE 20X20X8 WALL MOUNT NEMA-4/12
    HOFFMAN CSD20208SS ENCLOSURE WALL-MOUNT NEMA4X 20.00X20.00X8.00
    HOFFMAN CSD20208SS6 ENCLOSURE 20X20X8 WALL-MOUNT NEMA-4X SS TYPE 316L
    HOFFMAN CSD20248 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD24166 ENCLOSURE STEEL 24X16X6 WALL MOUNT NEMA 4/12
    HOFFMAN C-SD242012 ENCLOSURE WALL MOUNT TYPE4-12
    HOFFMAN C-SD24206 ENCLOSURE 24X20X6 WALL MOUNT NEMA-4/12
    HOFFMAN CSD24208 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD24208SS WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN CSD24208WSS WALL-MOUNT TYPE 4X ENCL/WINDOW
    HOFFMAN CSD242412 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD242412SS WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN CSD242448 ENCLOSURE
    HOFFMAN CSD24248 ENCLOSURE STEEL 24X24X8 WALL MOUNT NEMA-4/12
    HOFFMAN CSD24248SS WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN CSD24248WSS WALL-MOUNT TYPE 4X ENCL/WINDOW
    HOFFMAN CSD242O8LG ENCLOSURE
    HOFFMAN CSD24308 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD302412WSS WALL-MOUNT TYPE 4X ENCL/WINDOW
    HOFFMAN CSD302420WLG WALL-MOUNT ENCL./WINDOW
    HOFFMAN CSD30248SS ENCLOSURE WALL MOUNT 30X24X8 SS TYPE 304
    HOFFMAN C-SD303012 ENCLOSURE WALL-MOUNT NEMA4/12
    HOFFMAN CSD30308 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD362410 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD36248 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD363012 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD363612SS WALL-MOUNT TYPE 4X ENCLOSURE
    HOFFMAN CSD482410 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN CSD483612 WALL-MOUNT TYPE 4/12 ENCLOSURE
    HOFFMAN C-SD603612LG ENCLOSURE CONCEPT PANEL 60X36X12 WALL MOUNT
    HOFFMAN CTS5715 ENCLOSURE
    HOFFMAN CVMPMB33 PENDANT MOUNTING BRACKET 3INCH X 3INCH POST
    HOFFMAN CWHNL HANDLE, NON-LOCKING
    HOFFMAN CWHPTO HANDLE PADLOCKING
    HOFFMAN D-AH1001A ELECTRIC HEATER 100WATT 115V 50/60HZ 0.9A 0-100F
    HOFFMAN D-AH2001A ELECTRIC HEATER FOR ENCLOSURE 200WATTS
    HOFFMAN DAH4001B ELECTRIC HEATER, 400 WATT
    HOFFMAN DAH501 SEMICONDUCTOR HEATER, 50 WATT
    HOFFMAN DAH8001B ELECTRIC HEATER 800W 115V 50/60HZ 6.5A
    HOFFMAN DLCASTERS CASTER KIT (4), NETWORK CAB.
    HOFFMAN DROPFEE PART
    HOFFMAN E10PBA PUSHBUTTON ENCLOSURE 10PB X 30.5MM SLOPED FRONT
    HOFFMAN E12PB PB ENCLOSURE
    HOFFMAN E-12PBA PUSHBUTTON ENCLOSURE 12PB X 30.5MM SLOPED FRONT
    HOFFMAN E12SPBA PB ENCLOSURE, SLOPED FRONT
    HOFFMAN E16PBY25 PB ENCLOSURE, EXTRA LG/PANEL
    HOFFMAN E-1PB PUSHBUTTON STEEL ENCLOSURE 1PB X 30.5MM
    HOFFMAN E-1PBA PUSHBUTTON ENCLOSURE 1PB X 30.5MM SLOPED FRONT
    HOFFMAN E1PBG PB ENCLOSURE 1PBX22.5MM
    HOFFMAN E1PBGXM ENCLOSURE PUSHBUTTON 1PB X 22.5MM
    HOFFMAN E-1PBSS ENCLOSURE PUSHBUTTON 1PB X 30.5MM SS TYPE 304
    HOFFMAN E-1PBX ENCLOSURE STEEL ONE HOLE 30.5MM PUSHBUTTON
    HOFFMAN E1PBXM ENCLOSURE PUSHBUTTON STEEL 1PB X 22.5MM EXTRA DEEP
    HOFFMAN E-2PB PUSHBUTTON STEEL ENCLOSURE 2PB X 30.5MM
    HOFFMAN E-2PBG ENCLOSURE FOR PUSHBUTTONS
    HOFFMAN E-2PBSS PUSHBUTTON ENCLOSURE 2PB X 30.5MM S/S TYPE 304
    HOFFMAN E-2PBX PUSHBUTTON ENCLOSURE 2PB X 30.5MM
    HOFFMAN E-2PBXSS PUSHBUTTON ENCLOSURE 2PB STAINLESS STEEL
    HOFFMAN E3BPSS CONTROL
    HOFFMAN E-3PB PUSHBUTTON ENCLOSURE 3PB X 30.5MM
    HOFFMAN E3PBSS PB ENCLOSURE
    HOFFMAN E-4PB PUSHBUTTON STEEL ENCLOSURE 4PB X 30.5MM
    HOFFMAN E4PBA PUSHBUTTON ENCLOSURE 4PB X 30.5MM, SLOPED FRONT
    HOFFMAN E4PBAM PUSHBUTTON ENCLOSURE 4PB X 22.5MM SLOPED FRONT
    HOFFMAN E-4PBSS PUSHBUTTON ENCLOSURE 4PB X 30.5MM S/S TYPE 304
    HOFFMAN E-4PBX PUSHBUTTON ENCLOSURE STEEL 4PB X 30.5MM EXTRA DEEP
    HOFFMAN E4SPBA PB ENCL, SLOPED SQUARE FRONT
    HOFFMAN E4SPBX PB ENCLOSURE, EXTRA DEEP
    HOFFMAN E-5PB PUSHBUTTON ENCLOSURE STEEL 5PBX30.5MM
    HOFFMAN E6PB ENCLOSURE FOR 6PUSHBUTTONS
    HOFFMAN E-6PBA ENCLOSUE SLOPED FRONT STEEL 6PB X 30.5MM
    HOFFMAN E-6PBGX PUSHBUTTON ENCLOSURE 6HOLE 30MM
    HOFFMAN E-6PBSS PUSHBUTTON ENCLOSURE 6PB X 30.5MM NEMA4 SS TYPE304
    HOFFMAN E-6PBVL ENCLOSURE PUSHBUTTON STEEL 6PB X 30.5MM
    HOFFMAN E6PBX PUSHBUTTON ENCLOSURE STEEL 6PB X 30.5MM
    HOFFMAN E6PBXM PUSHBUTTON ENCLOSURE STEEL 6PB X 22.5MM EXTRA DEEP
    HOFFMAN E8PB PUSH BUTTON ST
    HOFFMAN E-8PBA PUSHBUTTON ENCLOSURE STEEL 8PBX30.5MM SLOPED FRONT
    HOFFMAN E9PB PB ENCLOSURE
    HOFFMAN E9PBA PB ENCLOSURE, SLOPED FRONT
    HOFFMAN E9PBY25 PB ENCLOSURE, EXTRA LG/PANEL
    HOFFMAN ED1PB2 PB ENCLOSURE, EXTRA LG
    HOFFMAN E-D1PBM1 PUSHBUTTON ENCLOSURE STEEL 1PB X 22.5MM
    HOFFMAN ED1PBM2 PB ENCLOSURE, EXTRA LG
    HOFFMAN E-D1PBX PUSHBUTTON ENCLOSURE STEEL 1PB X 30.5MM EXTRA DEEP
    HOFFMAN E-D2PBM PUSHBUTTON ENCLOSURE STEEL 2PB X 22.5MM
    HOFFMAN E-D3PBX PUSHBUTTON ENCLOSURE 3PB X 30.5MM EXTRA DEEP
    HOFFMAN ENC1776PC NETWORKING PC CABINET
    HOFFMAN F-126L06 WIREWAY 12X6X6 INCH NEMA12 STRAIGHT SECTION
    HOFFMAN F-126L120 WIREWAY 12X6X120 INCH NEMA12 STRAIGHT SECTION
    HOFFMAN F-126L24 WIREWAY 12X6X24 INCH NEMA12 STRAIGHT SECTION
    HOFFMAN F-126L36 WIREWAY STEEL 12X6X36 INCH NEMA12 STRAIGHT SECTION
    HOFFMAN F-126L60 WIREWAY STEEL 12X6X60 INCH NEMA12 STRAIGHT SECTION
    HOFFMAN F-126LA WIREWAY 12X6 10.25L ADJ TELESCOPIC FITTING
    HOFFMAN F126LE45A WIREWAY, 45 ELBOW/TOP OPEN
    HOFFMAN F-126LE9A WIREWAY HINGED COVER 90DEGREE TOP OPENING
    HOFFMAN F-126LP WIREWAY CLOSURE PLATE 12X6 STEEL GRAY
    HOFFMAN F-126LSAG WIREWAY SEAL PLATE 90DEG ANGLE 12X6
    HOFFMAN F-126LTA WIREWAY TEE FITTING STEEL 12X6 INCH TOP OPENING
    HOFFMAN F2212SC WIRE TROUGH, SCREW COVER
    HOFFMAN F22G12WK WIREWAY 2.5X2.5X12 INCH NEMA1 STRAIGHT SECTION
    HOFFMAN F22L60 WIREWAY,STRAIGHT SECTION
    HOFFMAN F-22LE9B WIREWAY STEEL 2.5X2.5 90DEG ELBOW INSIDE OPENING
    HOFFMAN F-22LE9C WIREWAY 90ELBOW/OUTSIDE OPEN
    HOFFMAN F-22LP CLOSURE PLATE STEEL 2.50X2.50
    HOFFMAN F-22LSAG SEAL PLATE STEEL 90DEG WIREWAY
    HOFFMAN F-22LX WIREWAY STEEL 2.5X2.5 CUTOFF FITTING NON LAY-IN
    HOFFMAN F22W12 WIREWAY,STRAIGHT SECTION
    HOFFMAN F-22W24 WIREWAY 2.5X2.5X24 INCH NEMA12 STRAIGHT SECTION
    HOFFMAN F22WA WIREWAY 2.5X2.5 TELESCOPIC FITTING
    HOFFMAN F22WB WIREWAY 2.5X2.5 BOX CONNECTOR
    HOFFMAN F22WE45 WIREWAY STEEL 2.50 X 2.50 45DEG ELBOW
    HOFFMAN F22WE90 WIREWAY, ELBOW 90 DEG
    HOFFMAN F22WP WIREWAY CLOSURE PLATE STEEL 2.50 X 2.50
    HOFFMAN F-22WT WIREWAY STEEL 2.5X2.5 TEE FITTING
    HOFFMAN F4430SC WIRE TROUGH SCREW COVER STEEL 4.00 X 4.00 X 30.00
    HOFFMAN F-44BB2C WIREWAY BRACKET LAY IN TYPE 12 BARRIER
    HOFFMAN F-44BK60 BARRIER BOLT STEEL FITS ON 4X4
    HOFFMAN F-44G12 WIREWAY NEMA1 W/O KNOCKOUTS 12HX4D STEEL
    HOFFMAN F44G120WK WW, TYPE 1, STR.SECTION/KO
    HOFFMAN F-44G12WK WIREWAY NEMA1 STRAIGHT SECTION 12HX4D MATERIAL
    HOFFMAN F44G90SE WW, TYPE1, SWEEP ELBOW/90 DEG
    HOFFMAN F-44GCPNK CLOSURE PLATE STEEL 4.00 X 4.00
    HOFFMAN F44GPA WW, TYPE 1, PANEL ADAPTER
    HOFFMAN F-44HB BRAKET HANGER STEEL FITS 4.00 X 4.00
    HOFFMAN F-44L12 WIREWAY STRAIGHT SECTION
    HOFFMAN F-44L120 WIREWAY HINGED STRAIGHT STEEL 4 X 4 X 120INCH
    HOFFMAN F-44L24 WIREWAY STRAIGHT SECTION STEEL 4.00X4.00X24.00
    HOFFMAN F-44L36 WIRE WAY STRAIGHT SECTION 4X4X36INCH
    HOFFMAN F-44L48 WIRE WAY STRAIGHT SECTION STEEL 4X4X48INCH
    HOFFMAN F-44L60 WIREWAY STRAIGHT SECTION STEEL 4X4X60INCH
    HOFFMAN F-44LA WIREWAY FITTING TELESCOPE LAY-IN 4.00 X 4.00
    HOFFMAN F-44LB BOX CONNECTOR WIREWAY STEEL 4.00 X 4.00
    HOFFMAN F-44LC WIREWAY CROSS FITTING STEEL 4X4
    HOFFMAN F-44LE9A WIREWAY 90ELBOW TOP OPEN STEEL 4.00X4.00
    HOFFMAN F-44LE9B WIREWAY 90 ELBOW/INSIDE STEEL 4.00X4.00
    HOFFMAN F-44LE9C WIREWAY 90 ELBOW/OUTSIDE STEEL 4.00X4.00
    HOFFMAN F-44LE9KOKT WIREWAY 90 ELBOW/TRANSPO FTG STEEL 4.00X4.00
    HOFFMAN F44LE9KT WW,90 ELBOW/TRANSPO FTG, CW
    HOFFMAN F44LJ WIREWAY , J BOX
    HOFFMAN F44LKOKT WW,TRANSPO SECTION, CCW
    HOFFMAN F-44LKT WIREWAY TRANSPORT SECTION CW STEEL 4.00X4.00
    HOFFMAN F44LN1 WIREWAY, NIPPLE
    HOFFMAN F-44LN2 WIREWAY NIPPLE STEEL 4X4X2
    HOFFMAN F-44LN3 WIREWAY NIPPLE
    HOFFMAN F-44LP WIREWAY STEEL PLATE LAY IN NEMA12 CLOSURE 4X4
    HOFFMAN F-44LRE22 WIREWAY REDUCER
    HOFFMAN F44LSAG WIREWAY, SEAL PLATE, 90 DEG
    HOFFMAN F44LSGQR WIREWAY PLATE FLAT SEALING
    HOFFMAN F44T124GVWK WIRE DUCT 4X4X24INCH GALVANIZED
    HOFFMAN F44T148GVWK WIRE DUCT 4X4X48INCH GALVANIZED
    HOFFMAN F44T160GVWK WIRE DUCT 4X4X60INCH GALVANIZED
    HOFFMAN F-44T36HC WIRING STEEL TROUGH HINGED COVER NEMA 12
    HOFFMAN F44T3R120 WW, 3R, STR. SECTION, MALE
    HOFFMAN F44T3R120F WW, 3R, STR. SECTION, FEMALE
    HOFFMAN F44T3R60 WIRE TROUGH 4X4X60 INCHES NEMA-3R W/HINGED COVER
    HOFFMAN F44T3RCP WW. 3R, CLOSURE PLATE
    HOFFMAN F44T3RPA WW. 3R, PANEL ADAPTER
    HOFFMAN F44T3RT WW. 3R, 90 FLUSH TEE
    HOFFMAN F44W24 WIREWAY STRAIGHT 4.00X4.00X24.00 STEEL/GRAY
    HOFFMAN F-44W36 WIRE WAY AUXILIARY GUTTER FITTING 4X4X36
    HOFFMAN F-44W60 WIREWAY STEEL N12 STRAIGHT 4X4X60INCH
    HOFFMAN F-44WA WIREWAY N12 STRAIGHT ADJUSTMENT
    HOFFMAN F-44WB WIREWAY BOX CONNECTOR 4X4INCH STEEL/GRAY W/GASKET
    HOFFMAN F44WBFG WIREWAY BOX CONNECTOR
    HOFFMAN F44WE90 WIREWAY, ELBOW 90 DEG
    HOFFMAN F-44WE90FG WIREWAY ELBOW 90 DEGREE 4X4
    HOFFMAN F-44WFF WIREWAY FLEXIBLE FITTING 4.00X4.00 RUBBER/STEEL
    HOFFMAN F44WFFFG WIREWAY FLEXIBLE FITTING 4X4
    HOFFMAN F44WG WIREWAY GASKET SET FOR FLANGED 4X4
    HOFFMAN F-44WPFG WIREWAY CLOSURE PLATE
    HOFFMAN F-44WT WIREWAY TEE FTG 4X4
    HOFFMAN F66G36WK WW, TYPE 1, STR.SECTION/KO
    HOFFMAN F66GCPNK WW, TYPE 1, CLOSURE PLATE
    HOFFMAN F66HBSS BRACKET STAINLESS STEEL HANGER
    HOFFMAN F66L02 BOX
    HOFFMAN F66L04 BOX
    HOFFMAN F-66L06 WIREWAY STRAIGHT SECTION
    HOFFMAN F-66L120 WIREWAY STRAIGHT SECTION 6 X 6 X 120
    HOFFMAN F-66L24 WIREWAY STRAIGHT SECTION 6X6X24
    HOFFMAN F-66L36 WIREWAY STRAIGHT SECTION
    HOFFMAN F66LA WIREWAY,TELESCOPE FTG
    HOFFMAN F66LB WIREWAY, BOX CONNECTOR
    HOFFMAN F-66LE45A WIREWAY ELBOW 45 DEGREE TOP OPEN 6X6
    HOFFMAN F-66LE9AC WIREWAY 90 ELBOW OUT/TOP OPEN 6.00X6.00
    HOFFMAN F-66LE9B WIREWAY ELBOW 90 DEGREE INSIDE OPEN 6X6
    HOFFMAN F-66LE9KOKT ELBOW
    HOFFMAN F-66LKT WIREWAY CLOCKWISE SECTION 6X6
    HOFFMAN F-66LP WIREWAY CLOSURE PLATE
    HOFFMAN F-66LRE44 WIREWAY REDUCER 6X6 TO 4X4
    HOFFMAN F-66LSAG WIREWAY SEAL PLATE 90 DEGREE ANGLE 6X6
    HOFFMAN F-66LTC WIREWAY TEEL/OUT+TOP OPEN
    HOFFMAN F66T1120GVP WW, TYPE 1, STRAIGHT SECTION
    HOFFMAN F66T18HC ENCLOSURE WIRE TROUGH HINGED
    HOFFMAN F66T30HC WIRE TROUGH, HINGED COVER
    HOFFMAN F-66T48HC WIRE TROUGH AND HINGED COVER 6X6X60INCH
    HOFFMAN F66W36SS WIREWAY 6X6X36 SS
    HOFFMAN F-66WG WIREWAY GASKET/SCREWS
    HOFFMAN F88GCPNK WW, TYPE 1, CLOSURE PLATE
    HOFFMAN F88T1120GVP WW, TYPE 1, STRAIGHT SECTION
    HOFFMAN FLT66 FILTER
    HOFFMAN G090000 FAN SEALING GASKET
    HOFFMAN K10113 VAPOR JAR
    HOFFMAN L-P2520 SUBPANEL 231 X 181MM STEEL/WHITE
    HOFFMAN LP3530 PANEL, 331X281MM
    HOFFMAN LSC151512SS INST. BOX,TYPE 4X SCREW COVER
    HOFFMAN M130116G1014 AIR CONDITIONER 800-1000BTU/HOUR 125F 115V/60HZ
    HOFFMAN MHB110416G307 AIR CONDITIONER 115VOLT 4000BTU TOP MOUNT
    HOFFMAN MISC HANDLING CHRG
    HOFFMAN P-19RP5UA PANEL RACK MOUNT 5UX19 ALUMINUM
    HOFFMAN PC1M12 CASTER KIT (4) M12
    HOFFMAN P-GH3S6 GRID STRAPS (2) THREE HOLE WIDE 442X75MM
    HOFFMAN PGLD1074DC DESK CONSOLE, 1 DR, SINGLE ACCESS
    HOFFMAN PGS2K GROUNDING BAR SYSTEM
    HOFFMAN P-J2FB JOINING KIT BASE TO BASE
    HOFFMAN PKODB KEY INSERT, DAIMLER BENZ
    HOFFMAN PP96G FULL PANEL
    HOFFMAN PSHKBL SMALL HANDLE, FLUSH/ KEYLOCK
    HOFFMAN PST566 SURFACE COVER
    HOFFMAN Q1388PCE J BOX TYPE 4X / SCREW COVER
    HOFFMAN Q138PE PANEL, QLINE E / 98X48MM
    HOFFMAN Q-181813PCECC ENCLOSURE TYPE 4X CLEAR WITH SCREW COVER
    HOFFMAN Q1PBPCDM ENCLOSURE PUSHBUTTON 22.5MM POLYCARB.
    HOFFMAN Q2PBPCDM PB ENCLOSURE
    HOFFMAN Q302013ABI J BOX TYPE 4X / SCREW COVER
    HOFFMAN S44ST1E COUPLING
    HOFFMAN SERVICECHARGE SERVICE
    HOFFMAN SG-0500-002 EXHAUST GRILLE/FILTER FITS SF-05
    HOFFMAN SG-1000-002 EXHAUST GRILL FILTER SF10
    HOFFMAN SG-1300-002 EXHAUST GRILLE FILTER SF13
    HOFFMAN TEG4 GRILLE/FILTER
    HOFFMAN TEP10 FAN
    HOFFMAN TEP6 EXHAUST GRILLE FITS 6INCH PKG ABS/LTGRAY
    HOFFMAN TFP101 COOLING FAN PACKAGE 10INCH
    HOFFMAN TFP41 COOLING FAN PACKAGE 4INCH 115VAC 50/60HZ
    HOFFMAN TFP42 COOLING FAN PACKAGE, 4 IN
    HOFFMAN T-FP42UL12 FAN 230V 4 INCH TYPE-12
    HOFFMAN TFP61 COOLING FAN PACKAGE 6INCH 115VAC
    HOFFMAN UU504020 TYPE 4X ENCLOSURE /SOLID DOOR
    HOFFMAN UU606030 TYPE 4X ENCLOSURE /SOLID DOOR
    HOFFMAN XCS136 ENCLOSURE
    HOFFMAN XCS56F COVER
    HOFFMAN XDW56F ENCLOSURE
    HOFFMAN XDW76 ENCLOSURE
    HOFFMAN XFC1466 ENCLOSURE
    HOFFMAN X-GH6P8 GRID PLATE 66MM STEEL ZINC
    HOFFMAN XPV32 VENT/FILTER KIT
    HOFFMAN X-ST566 ENCLOSURE W/SLOPED TOP FOR OPERATOR INTERFACE
    HOFFMAN ZBC1PB REPLACMNT KIT
明想科技是一家专门从事PLC备件进出口销售、技术咨询、技术服务、自动化设备维修服务为一体的贸易公司。并与世界著名的多家PLC产品维护服务提供商建立了紧密的合作关系,北美、欧洲、亚洲您多能看到我们的身影。我们售出的PLC最长提供两年的…  更多>>
上海明想电子
联系人:曾小姐
地址:上海市松江区文诚路2159弄240号
邮编:201620
电话:021-31261686
传真:021-31059032
公司网址:http://www.shmxdz.com
  • 蔡宗翰 在2017/1/25 12:26:00留言
  • 详细留言:PHOENIX CONTACT 1757268 HEADER 4POSITION 12A 250V SOLDER MOUNT 過爐曲線 SMT or wavesolder?
  • 王力 在2015/3/17 11:00:00留言
  • 王力 在2014/12/10 18:33:00留言
  • 冯秀思 在2014/10/20 11:39:00留言
  • 详细留言:
  • 白万洋 在2014/3/6 16:30:00留言
  • 详细留言:寻址光电侦烟感知器2951J 寻址式差动型探测器5951RJ 寻址式定温型探测器5951J 寻址式定温型探测器(高温型)5951HJ 控制模块M300CJ 迷你监视模块M301MJ 感知器欧式底座B501JCH
