深圳市申克工业设备有限公司
  • 法国ADAS STB532
  • 发布时间:2019/10/28 10:20:59   修改时间:2008/12/1 9:21:47 浏览次数:1553
  • Stb Adas Electronique
    Description
    • 32 isolated digital inputs
    • AC or DC signals
    • Adjustable trigger threshold of the 5V level to
      220Vac
    • 2ms input filtering
    • Indicator DELs
    • Galvanic isolation ≥ 1.500V from one channel to the other and from the computer
    • Connects directly to ADAS I/O boards
    • Easily mounted on DIN RAIL
    • Small footprint
    Description
    The STB 532 terminal block is a modular and friendly approach to connecting digital inputs galvanically isolated from each other and from the computer.
    Its design makes it directly compatible ADAS I/O boards.
    It provides a very attractive price/number of channels ratio.
    It has a very small footprint and is easy to mount on DIN RAIL.
    Direct outputs to FRONT panel ID 16 indicator.
    Iqnet
    9 rue Georges Besse – BP 47 – 78330 FONTENAY LE FLEURY – FRANCE
    Tél.:(33) 1 30 58 90 09 fax:(33) 1 30 58 21 33 http://www.adas.fr
    Afaq
    STB 532
    32 ISOLATED DIGITAL INPUTS
    TERMINAL BLOCK
    STB 532
    SPECIFICATIONS (t = 25°C)
    TYPE
    INPUTS
    - Number of channels
    32
    PHOTOCOUPLERS
    - Signals AC or DC
    - Models H11AA1 (A version)
      HCPL 3700 (B, C, D, E, F versions)
    - Levels
    Adjustable through injection resistors on 5V contact blocks to 220Vac (trigger threshold to be specified on order)
    GALVANIC ISOLATION
    - Inter-channel 1.500V
    - From the computer
    1.500V
    CONNECTION
    - Type
    3 removable screw terminals ? ≤ 1.5 mm2
    INDICATORS
    - DELs
    Inputs are indicated by DELs
    FILTERING
    - Time constant
    2ms
    CONNECTIVITY
    - Connection to logic input boards By a HE 10 / 50-pt connector
    - Connection to remote indicators
    By two HE 10 / 20-pt connectors
    POWER SUPPLY
    - Voltage
    + 5V / 300mA typical
    PHYSICAL CHARACTERISTICS
    - Dimension in mm (L x W x H) 285 x 125 x 52
    - Mounting
    On DIN RAIL
    ENVIRONMENT
    - Operating temperature 0°C to + 60°C
    - Storage temperature - 10°C to + 70°C
    - Relative humidity
    90 % (without condensation)
    EUROPEAN NORMS
      EMC - EN 61326
      CE Compliance
      ROHS - 2002/95/EC
深圳市申克工业设备有限公司仪器和过程控制部负责销售ADAS电子模板,并且有法国ADAS电子公司所有系列产品在亚州的独家销售权.ADAS提供品种众多的独立的I/O模块,适用于各种不同的物理总线(PC/PCI,CompactPCI,PMC …),在数据分析仪器和过…  更多>>
深圳市申克工业设备有限公司
联系人:赵工
地址:深圳市 福田区 福强路32号
邮编:518048
电话:0755-83841930
传真:0755-83841895
公司网址:http://www.sz-victory.com.cn
  • 陈碧娟 在2024/3/28 17:47:00留言
  • 详细留言:ADAS ICV150 1个,有货吗?价格是?
