ADAS
covers all parts of a test system from data acquisition boards to final test
report.
Our
product range includes telemetry solutions, data processing software, rugged
displays, Panel PC and data processing software as well as graphic user
interface.
Our Group :
ADAS is a company of Group : leader in
high technology projects for defense and aerospace industries.
Three companies, Antycip Technologies, Midi Ingénierie and
ADAS built the "PRODUCTS" branch of NEXEYA. The "PRODUCT"
branch specializes in COTS solutions.
品牌?
型号?
ADAS
Electronique
ACM/OUTBD
ADAS
Electronique
STB 534 Rev.A
ADAS
Electronique
STB520/SB
SN:21070394
ADAS
Electronique
STB532/C
SN:22020712
ADAS
Electronique
ADAS
ICV307+Connecting cable, connector terminals
ADAS
Electronique
ADAS-ICV150/D-14/4/256I
S/N:21071194
供应商
品牌
品牌
型号
ADAS
Electronique
ACM/OUTBD
ADAS
Electronique
STB 534 Rev.A
ADAS
Electronique
STB520/SB
SN:21070394
ADAS
Electronique
STB532/C
SN:22020712
品牌
型号
ADAS
Electronique
ADAS
ADAS
Electronique
S/N:21071194
ADAS
Electronique
ACM/OUTBD
ADAS
Electronique
STB 534 Rev.A
ADAS
Electronique
STB520/SB
SN:21070394
ADAS
Electronique
STB532/C
SN:22020712
品牌
型号
ADAS
Electronique
ADAS
ADAS
Electronique
S/N:21071194
供应商
品牌
品牌
型号
ADAS
Electronique
ACM/OUTBD
ADAS
Electronique
STB 534 Rev.A
ADAS
Electronique
STB520/SB
SN:21070394
ADAS
Electronique
STB532/C
SN:22020712
ADAS
Electronique
ADAS
ADAS
Electronique
S/N:21071194
ADAS
Electronique
ACM/OUTBD
ADAS
Electronique
STB 534 Rev.A
ADAS
Electronique
STB520/SB
SN:21070394
ADAS
Electronique
STB532/C
SN:22020712
品牌
型号
ADAS
Electronique
ADAS
型号
ADAS
Electronique
S/N:21071194
供应商
品牌
品牌
型号
ADAS
Electronique
ACM/OUTBD
ADAS
Electronique
STB 534 Rev.A
ADAS
Electronique
STB520/SB
SN:21070394
ADAS
Electronique
STB532/C
SN:22020712
ADAS
Electronique
ADAS
ADAS
Electronique
S/N:21071194
ADAS
Electronique
ACM/OUTBD
ADAS
Electronique
STB 534 Rev.A
ADAS
Electronique
STB520/SB
SN:21070394
ADAS
Electronique
STB532/C
SN:22020712
ADAS
Electronique
ADAS
ADAS
Electronique
S/N:21071194
常用相关型号,如有不明,请来电详细咨询! Produits au standard VME
ICV107/20 CARTE VME MAITRE ACQUISITION RAPIDE 16MHz 2048K. mesures/s
ICV108 CARTE VME MAITRE ACQUISITION RAPIDE 64 BITS Buffers de 2M. mesures/s
ICV150/D-12/4/106-I CARTE VME 32 E. DIFFERENTIELLES ISO. 12 bits G1 à 8 100K.acq./s ±0.05% PE
ICV150/D-12/4/206-I CARTE VME 32 E. DIFFERENTIELLES ISO. 12 bits G1 à 8 50K.acq./s ±0.03% PE
ICV150/D-14/4/256-I CARTE VME 32 E.DIFFERENTIELLES ISO 14 bits G1 à 8 40K.acq./s ±0.016% PE
ICV150/D-16/4/336-I CARTE VME 32 E. DIFFERENTIELLES ISO. 16 bits G1 à 8 30K.acq./s ±0.008% PE
ICV178 CARTE VME ET COUPLEUR ICV108 8 E. ANA. ISOLEES 16 bits 1,2MSPS SIGMA DELTA ADCs
ICV196 CARTE VME ENTREES SORTIES DIGITALES Protégées 70V / 100mA ICV296 CARTE VME ET COUPLEUR ICV10x 96 ENTREES/SORTIES DIGITALES
ICV307 6 ISOLATED, HIGH SPEED 32-BIT COUNTER CHANNELS
ICV320/RB CARTE VME 32 SORTIES RELAIS 1RT 125V / 2A
ICV320/SB CARTE VME 32 SORTIES RELAIS STATIQUES 1T 60V / 0,5A
ICV706 CARTE VME SORTIE ANA. 4 VOIES ISOLEES BIPOLAIRE 16 BITS RAM DE 512 MOTS PAR VOIES
ICV714 CARTE VME SORTIE ANA. 16 VOIES ISOLEES 12 BITS 0/5V;0/10V;±5V;±10V
ICV714/BC CARTE VME SORTIE ANA. 16 VOIES ISOLEES 12 BITS 0/5V;0/10V;±5V;±10V;0/20 4/20mA
ICV716 CARTE VME SORTIE ANA. 8 VOIES 16 BITS 0/10V;±10V
ICV716/BC CARTE VME SORTIE ANA. 8 VOIES 16 BITS 0/10V;±10V BOUCLE DE COURANT
ICV726 CARTE VME SORTIE ANA. 24 VOIES 12 OU 14 BITS ±10V
ICV914 CARTE VME 4 VOIES DE COMMANDE D'AXES RCV20 RACK VME 20 SLOTS 9U 19" p=480mm ALIM 600W +5V/120A;+/-12V/10A DEFLECTEUR-19" DEFLECTEUR VENTILATION CHASSIS 19" 1U INT-1-MEDIA INTEGRATION DANS UN CHASSIS DE 1 MEDIA FOURNI PAR VOS SOINS. RCV-20/20 RACK 19" 7U P1=20 SLOTS / P2=20SLOTS ALIM 600W (5V/120A ; EUR 24 CHASSIS EUROMULT 24 SLOTS ALIM 600W Produits au standard PCI PCI102/05 CARTE PCI GESTION D'ACQUISITION RAPIDE 20 Méga échantillons/s ; 512K. mesures
PCI102/20 CARTE PCI GESTION D'ACQUISITION RAPIDE 20 Méga échantillons/s 2048K. mesures
PCI150 CARTE PCI 32 E.DIFF. 64 E. UNI. ISO 12 14 16 bits G1 à 8 100K.acq./s MAX
PCI160 CARTE PCI 16 E. ANA. 32 E/S TTL 8 S ANA. 16 bits G1 200K.acq. / voie
PCI220/D CARTE PCI 32E.DIFF.ISOLEES 12/14/16 bits G1 à 8 100K à 30K.acq./s
PCI220/S CARTE PCI 64E.UNI.ISOLEES 12/14/16 bits G1 à 8 100K à 30K.acq./s
PCI224 CARTE PCI 32 E.DIFF 12 14 16 bits G1 à 8 100K.acq./s MAX
PCI228 CARTE PCI 16 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie
PCI238/BE CARTE PCI 8 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie +FLT.BESSEL
PCI238/BU CARTE PCI 8 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie +FLT.BUTH.
PCI264 CARTE PCI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA μD68 PINS
PCI307 CARTE PCI 4 VOIES DE COMPTAGE ISOLEES 32 BITS μD68 PINS
PCI744 CARTE PCI 16 SORTIES ANALOGIQUES ± 10 VOLTS 14 bits μD68 PINS
PCI786 CARTE PCI 8 SORTIES ANALOGIQUES ISOLEES ± 10 VOLTS 16 bits μD68 PINS
PCIDX6 CARTE CPU POUR LE TEMPS REEL
BLA102/02 BUS LOCAL 2 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/03 BUS LOCAL 3 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/04 BUS LOCAL 4 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/05 BUS LOCAL 5 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/06 BUS LOCAL 6 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/07 BUS LOCAL 7 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/09 BUS LOCAL 9 SLOTS POUR PCI102 ET CARTES COUPLEURS
![](http://www.jdzj.com/oledit/UploadFile/20105/201052284842635.gif)
Produits au standard CPCI – PXI CPCI1150 CARTE PXI 32 E. DIFFERENTIELLES ISO. 12 14 16 bits G1 à 8 100K.acq./s MAX
CPCI1228 CARTE PXI 16 E. ANA. 32 E/S TTL 16 bits G1 200K.acq. / voie
CPCI1264 CARTE PXI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA AVEC POSTTTION DE REPLIS
CPCI1786 CARTE PXI 8 SORTIES ANALOGIQUES ± 10 VOLTS 16 bits
CPCI228 CARTE CPCI 16 E. ANA. 32 E/S DIGITALES ECHANTILLONNAGE SUMULTANE 250 kHz
CPCI264 CARTE CPCI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA
CPCI307 CARTE CPCI 4 VOIES DE COMPTAGE ISOLEES 32 BITS
CPCI412 CARTE CPCI 3U 4 entrées analogiques 12 bits /22MHz 4Mech/voies
CPCI744 CARTE CPCI 16 SORTIES ANALOGIQUES ± 10 VOLTS 14 bits
CPCISYN CARTE FORMAT CPCI POUR SYNCHRONISATION INTER CHASSIS
Produits au standard LMC LMC-429 MODULE COUPLEUR LIAISONS ARINC 429
LMC-ADC MODULE 8D / 16S ENTREES ANALOGIQUES 14 bits ±10.24Volts
LMC-CAN MODULE GESTIONNAIRE DE RESEAU CAN
LMC-DAC MODULE 8 SORTIES ANALOGIQUES 14 bits ; ± 10V
LMC-DDS MODULE 8 SORTIES ANALOGIQUES DDS / SYNTHE
LMC-DIO MODULE 16 ENTREES / SORTIES TOR ISOLEES
LMC-ESCC/16 MODULE INTEL 2 LIAISONS SERIES MULTI- PROTOCOLES GEREES PAR DSP à 16 MHz
LMC-ESCC/20 MODULE INTEL. 2 LIAISONS SERIES MULTI- PROTOCOLES GEREES PAR DSP à 20MHz
LMC-SSI MODULE GESTIONNAIRE DE 4 LIAISONS SYNCHRONES 24 à 32 BITS 104-LMC CARTE PC104 SUPPORT DE 1 MODULE LMC
CPCI-LMC CARTE COMPACT PCI 3U SUPPORT DE 2 MODULES LMCS VIA DMC
CPCI-LMC-D CARTE COMPACT PCI 3U SUPPORT DE 2 MODULES LMCS HD44pts
ICV-LMC CARTE VME SUPPORT DE 3 MODULES LMCS
PCI-LMC CARTE PCI SUPPORT DE 2 MODULES LMCS SUBD HD44PTS
UCV-DIO CARTE VME 3U 32 ENTREES / SORTIES DIGITALES ISOLEES + 2 SUPPORTS LMCS
UCV-LMC CARTE VME 3U SUPPORT DE 2 MODULES LMCS ![](http://www.jdzj.com/oledit/UploadFile/20105/201052284843882.gif)
Borniers conditionneurs industriels BCI BCI128- BNC BORNIER 8 PRISES BNC POUR ICV128 / ICV138 / ICV148
BCI138 BORNIER PASSIF 8 VOIES POUR ICV138 ET MODULE MAL
BCI140/C BORNIER 16 ENTREES DIGITALES ISOLEES Vin=24Volts
BCI140/D BORNIER 16 ENTREES DIGITALES ISOLEES Vin=48Volts
BCI146 BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 64 PTS
BCI148 BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 48 PTS
BCI160/RB BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A
BCI160/SB BORNIER 16 SORTIES RELAIS STATIQUES 1T 60V DC /0.5A
BCI160/SH BORNIER 16 SORTIES RELAIS STATIQUES 1T 400V DC/0.1A
BCI168 BORNIER 8 SORTIES ANALOGIQUES ISOLEES TENSION/COURANT
BCI184/XX/YY BORNIER COND. 8 E ANA. HAUT MODE COMMUN VERSION A DEFINIR
BCI100-PB PLAQUE DE BOUCHAGE 6U 5TE
BCI100-RACK-9U RACK 9U POUR RECEVOIR 16 BCI SERIE 100 ALIM 250W +5V/35A;+12V/8A ; -12V/8A
BCI300-PRL CARTE DE PROLONGATION POUR BCI SERIE 300
BCI300-VISU BORNIER DE RECOPIE 16 VOIES
BCI314/ALPF BORNIER 8 ENTREES ANALOGIQUES CONDITIONNEES POLYVALENT FILTRE PASSE BAS AJUSTABLE
BCI314/SF BORNIER 8 ENTREES ANALOGIQUES CONDITIONNEES POLYVALENT SANS FILTRE
BCI328-5/037/BU BORNIER 8 ENTREES ANALOGIQUES FILTREES FC A DEFINIR
BCI328-5/037/BU-TEDS BORNIER 8 ENTREES ANALOGIQUES FILTREES GESTION DES CAPTEURS TEDS
BCI360-5/RB/INV BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A LOGIQUE
INVERSEE BCI364-5/B72 BORNIER 4 SORTIES ANALOGIQUES ISOLEES Vout = ±72 Volts FAV 5TE
BCI368-5 BORNIER 8 SORTIES ANALOGIQUES ISOLEES Vout = ±10 Volts FAV 5TE
BCI382-5/XX BORNIER COD. 8 E ANALOGIQUES ISOLEES 5 TE (version à préciser)
BCISIN BORNIER COND. 4 E ANALOGIQUES ISOLEES DEPHASEUR
BCI300-PB-5TE PLAQUE DE BOUCHAGE 6U 5TE
BCI300-PB-6T E PLAQUE DE BOUCHAGE 6U 6TE
BCI300-RACK RACK 9U POUR RECEVOIR 12 BCI SERIE 300 EQUIPE D'UNE ALIMENTATION 24V/12A
BCI300-RACK-16 RACK 9U POUR RECEVOIR 16 BCI SERIE 300 5Te EQUIPE D'UNE ALIMENTATION 24V/12A
Borniers industriels STB STB-SSI BORNIER D'INTERFACE FILAIRE POUR 1 LMC VERS ICVLMC
STB306 TERMINAL BLOCK FOR INCREMENTAL ENCODERS STB306/ISO/C BORNIER INTERFACE ISOLE POUR CARTES ICV307 PCI307 (Vnom=24V ; I=5mA)
STB504 BORNIER CONDITIONNEUR DE NIVEAU 4 VOIES DE COMPTAGE
STB512 BORNIER INTERFACE PASSAGE DE 1x32 VOIES à 2x16 VOIES
STB514 BORNIER INTERFACE PASSAGE DE 1x64 VOIES à 4x16 VOIES
STB516 BORNIER 16 ENTREES SORTIES DIGITALES MODULAIRES
STB520/8SB/24RB BORNIER 32 SORTIES RELAIS 0à7-->SB 8à31-->RB
STB520/RB BORNIER 32 SORTIES RELAIS 1RT 220V DC/2A
STB520/SB BORNIER 32 SORTIES RELAIS STATIQUES 1T 60V DC/0,5A
STB520/SH BORNIER 32 SORTIES RELAIS STATIQUES 1T 400V DC/0,5A
STB524 32 SORTIES POWER SWITCH
STB525 BORNIER INTERFACE POUR PASSAGE DE 1 MICRO 68 PTS VERS 2 HE501 25 PTS
STB532/A BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 5 Volts
STB532/B BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 12Volts
STB532/C 32 ISOLATED DIGITAL INPUTS TERMINAL BLOCK STB532/E BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 115Volts
STB532/F BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 220Volts
STB534 BORNIER INTERFACE PASSAGE DE 2x32 VOIES à 1x64 VOIES
STB540/C BORNIER 16 ENTREES DIG. ISO. AC/DC Vin=24Volts
STB542 BORNIER INTERFACE CARTE SORTIES ANA. 8 CANAUX
STB544 BORNIER D'INTERFACE FILAIRE POUR 2 LMCS
STB546 BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 68 PTS
STB548/F1 BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX DIFFERENTIELS FILTRES FC =10Hz
STB550 BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 50 PTS
STB552 BORNIER INTERFACE ENTREES / SORTIES 32 CANAUX UNIFILAIRES
STB554 BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX DIFFERENTIELS
STB554/BC/0250 BORNIER INTERFACE CARTE ENTREES ANA. 16 VOIES BOUCLE DE COURANT R=250Ohms
STB556 BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX POUR ENTREES THERMOCOUPLES
STB560/RB BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A
STB560/SB BORNIER 16 SORTIES RELAIS STATIQUES 1T 60V DC/0,5A
STB560/SH BORNIER 16 SORTIES RELAIS STATIQUES 1T 400V DC/0,5A
STB562 BORNIER 16 SORTIES RELAIS 1RT 380V DC/5A
ACM/IN/xx/RMS MODULE D'ENTREE POUR STB658 STB6x2 STB4ACM VERSION RMS
ACM/INxx MODULE D'ENTREE POUR STB658 STB6x2 STB4ACM STB/LA55P/XX MODULE TRANSDUCER 10A
STB/SHUNT-XX SHUNT POUR STB R=0.010 OHM ±1%
STB4ACM BORNIER D'INTERFACE POUVANT RECEVOIR 4 MODULES ADAS
STB658 BORNIER D'INTERFACE POUVANT RECEVOIR 16 MODULES ADAS
STB6x2 ANALOG CONDITIONING MODULES 8 CHANNELS BACK PANEL
Cables WF245/300 CABLE ROND BLINDE 3 m SUBD-HD 44P VERS SUBD-HD 44S
WR205/300 NAPPE RONDE BLINDEE 3,00 m SUBD 50P VERS HE10 50S
WR212/050 NAPPE RONDE BLINDEE 0 m 50 HE10 50S VERS HE10 50S
WR212/300 NAPPE RONDE BLINDEE 3 m HE10 50S VERS HE10 50S
WR214/300 NAPPE RONDE BLINDEE 3 m HE10 50S VERS 2 HE10 26S
WR215/300 NAPPE RONDE BLINDEE 3 m SUBD 50P VERS 2 HE10 26S
WR228/300 NAPPE RONDE BLINDEE 3m00 SUBD 50P VERS SUBD 50P
WR233/300 NAPPE RONDE BLINDEE 3 m SUBD 25P VERS SUBD 25P
WR235/300 NAPPE RONDE BLINDEE 3 m SUBD 25S VERS SUBD 25S
WR2XX-METRE-SUP. METRE DE NAPPE SUPPLEMENTAIRE
WR368/100 MICRO NAPPE BLINDEE 68PTS μSUBD 1m00
WR368/180 MICRO NAPPE BLINDEE 68PTS μSUBD 1m80
WR368/300 MICRO NAPPE BLINDEE 68PTS μSUBD 3m00
