深圳市申克工业设备有限公司
  • 供应ADAS ICV150/D Produits au standard ADAS VME卡件
  • 发布时间:2017/6/27 15:02:32   修改时间:2017/3/9 16:26:49 浏览次数:1305
    • 常用相关型号,如有不明,请来电详细咨询!
      Produits au standard VME
      ICV107/20     CARTE VME MAITRE ACQUISITION RAPIDE 16MHz 2048K. mesures/s
      ICV108        CARTE VME MAITRE ACQUISITION RAPIDE 64 BITS Buffers de 2M. mesures/s
      ICV150/D-12/4/106-I    CARTE VME 32 E. DIFFERENTIELLES ISO. 12 bits G1 à 8 100K.acq./s ±0.05% PE
      ICV150/D-12/4/206-I     CARTE VME 32 E. DIFFERENTIELLES ISO. 12 bits G1 à 8 50K.acq./s ±0.03% PE
      ICV150/D-14/4/256-I     CARTE VME 32 E.DIFFERENTIELLES ISO 14 bits G1 à 8 40K.acq./s ±0.016% PE
      ICV150/D-16/4/336-I    CARTE VME 32 E. DIFFERENTIELLES ISO. 16 bits G1 à 8 30K.acq./s ±0.008% PE
      ICV178     CARTE VME ET COUPLEUR ICV108 8 E. ANA. ISOLEES 16 bits 1,2MSPS SIGMA DELTA ADCs
      ICV196     CARTE VME ENTREES SORTIES DIGITALES Protégées 70V / 100mA
      ICV296    CARTE VME ET COUPLEUR ICV10x 96 ENTREES/SORTIES DIGITALES
      ICV307      6 ISOLATED, HIGH SPEED 32-BIT COUNTER CHANNELS
      ICV320/RB     CARTE VME 32 SORTIES RELAIS 1RT 125V / 2A
      ICV320/SB      CARTE VME 32 SORTIES RELAIS STATIQUES 1T 60V / 0,5A
      ICV706    CARTE VME SORTIE ANA. 4 VOIES ISOLEES BIPOLAIRE 16 BITS RAM DE 512 MOTS PAR VOIES
      ICV714     CARTE VME SORTIE ANA. 16 VOIES ISOLEES 12 BITS 0/5V;0/10V;±5V;±10V
      ICV714/BC    CARTE VME SORTIE ANA. 16 VOIES ISOLEES 12 BITS
      0/5V;0/10V;±5V;±10V;0/20 4/20mA
      ICV716      CARTE VME SORTIE ANA. 8 VOIES 16 BITS 0/10V;±10V
      ICV716/BC     CARTE VME SORTIE ANA. 8 VOIES 16 BITS 0/10V;±10V BOUCLE DE COURANT
      ICV726      CARTE VME SORTIE ANA. 24 VOIES 12 OU 14 BITS ±10V
      ICV914       CARTE VME 4 VOIES DE COMMANDE D'AXES
      RCV20   RACK VME 20 SLOTS 9U 19" p=480mm ALIM 600W +5V/120A;+/-12V/10A
      DEFLECTEUR-19" DEFLECTEUR VENTILATION CHASSIS 19" 1U
      INT-1-MEDIA INTEGRATION DANS UN CHASSIS DE 1 MEDIA FOURNI PAR VOS SOINS.
      RCV-20/20   RACK 19" 7U P1=20 SLOTS / P2=20SLOTS ALIM 600W (5V/120A ;
      EUR 24  CHASSIS EUROMULT 24 SLOTS ALIM 600W
      Produits au standard PCI
      PCI102/05   CARTE PCI GESTION D'ACQUISITION RAPIDE 20 Méga échantillons/s ; 512K. mesures
      PCI102/20   CARTE PCI GESTION D'ACQUISITION RAPIDE 20 Méga échantillons/s 2048K. mesures
      PCI150   CARTE PCI 32 E.DIFF. 64 E. UNI. ISO 12 14 16 bits G1 à 8 100K.acq./s MAX
      PCI160   CARTE PCI 16 E. ANA. 32 E/S TTL 8 S ANA. 16 bits G1 200K.acq. / voie
      PCI220/D   CARTE PCI 32E.DIFF.ISOLEES 12/14/16 bits G1 à 8 100K à 30K.acq./s
      PCI220/S   CARTE PCI 64E.UNI.ISOLEES 12/14/16 bits G1 à 8 100K à 30K.acq./s
      PCI224   CARTE PCI 32 E.DIFF 12 14 16 bits G1 à 8 100K.acq./s MAX
      PCI228   CARTE PCI 16 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie
      PCI238/BE   CARTE PCI 8 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie +FLT.BESSEL
      PCI238/BU   CARTE PCI 8 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie +FLT.BUTH.
      PCI264   CARTE PCI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA μD68 PINS
      PCI307   CARTE PCI 4 VOIES DE COMPTAGE ISOLEES 32 BITS μD68 PINS
      PCI744   CARTE PCI 16 SORTIES ANALOGIQUES ± 10 VOLTS 14 bits μD68 PINS
      PCI786   CARTE PCI 8 SORTIES ANALOGIQUES ISOLEES ± 10 VOLTS 16 bits μD68 PINS
      PCIDX6   CARTE CPU POUR LE TEMPS REEL
      BLA102/02   BUS LOCAL 2 SLOTS POUR PCI102 ET CARTES COUPLEURS
      BLA102/03   BUS LOCAL 3 SLOTS POUR PCI102 ET CARTES COUPLEURS
      BLA102/04   BUS LOCAL 4 SLOTS POUR PCI102 ET CARTES COUPLEURS
      BLA102/05   BUS LOCAL 5 SLOTS POUR PCI102 ET CARTES COUPLEURS
      BLA102/06   BUS LOCAL 6 SLOTS POUR PCI102 ET CARTES COUPLEURS
      BLA102/07   BUS LOCAL 7 SLOTS POUR PCI102 ET CARTES COUPLEURS
      BLA102/09   BUS LOCAL 9 SLOTS POUR PCI102 ET CARTES COUPLEURS
      Produits au standard CPCI – PXI
      CPCI1150   CARTE PXI 32 E. DIFFERENTIELLES ISO. 12 14 16 bits G1 à 8 100K.acq./s MAX
      CPCI1228   CARTE PXI 16 E. ANA. 32 E/S TTL 16 bits G1 200K.acq. / voie
      CPCI1264   CARTE PXI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA AVEC POSTTTION DE REPLIS
      CPCI1786   CARTE PXI 8 SORTIES ANALOGIQUES ± 10 VOLTS 16 bits
      CPCI228    CARTE CPCI 16 E. ANA. 32 E/S DIGITALES ECHANTILLONNAGE SUMULTANE 250 kHz
      CPCI264   CARTE CPCI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA
      CPCI307   CARTE CPCI 4 VOIES DE COMPTAGE ISOLEES 32 BITS
      CPCI412   CARTE CPCI 3U 4 entrées analogiques 12 bits /22MHz 4Mech/voies
      CPCI744   CARTE CPCI 16 SORTIES ANALOGIQUES ± 10 VOLTS 14 bits
      CPCISYN   CARTE FORMAT CPCI POUR SYNCHRONISATION INTER CHASSIS
      Produits au standard LMC
      LMC-429   MODULE COUPLEUR LIAISONS ARINC 429
      LMC-ADC   MODULE 8D / 16S ENTREES ANALOGIQUES 14 bits ±10.24Volts
      LMC-CAN   MODULE GESTIONNAIRE DE RESEAU CAN
      LMC-DAC   MODULE 8 SORTIES ANALOGIQUES 14 bits ; ± 10V
      LMC-DDS   MODULE 8 SORTIES ANALOGIQUES DDS / SYNTHE
      LMC-DIO   MODULE 16 ENTREES / SORTIES TOR ISOLEES
      LMC-ESCC/16   MODULE INTEL 2 LIAISONS SERIES MULTI- PROTOCOLES GEREES PAR DSP à 16 MHz
      LMC-ESCC/20   MODULE INTEL. 2 LIAISONS SERIES MULTI- PROTOCOLES GEREES PAR DSP à 20MHz
      LMC-SSI   MODULE GESTIONNAIRE DE 4 LIAISONS SYNCHRONES 24 à 32 BITS
      104-LMC CARTE PC104 SUPPORT DE 1 MODULE LMC
      CPCI-LMC   CARTE COMPACT PCI 3U SUPPORT DE 2 MODULES LMCS VIA DMC
      CPCI-LMC-D    CARTE COMPACT PCI 3U SUPPORT DE 2 MODULES LMCS HD44pts
      ICV-LMC    CARTE VME SUPPORT DE 3 MODULES LMCS
      PCI-LMC    CARTE PCI SUPPORT DE 2 MODULES LMCS SUBD HD44PTS
      UCV-DIO    CARTE VME 3U 32 ENTREES / SORTIES DIGITALES ISOLEES + 2 SUPPORTS LMCS
      UCV-LMC    CARTE VME 3U SUPPORT DE 2 MODULES LMCS
      Borniers conditionneurs industriels BCI
      BCI128- BNC   BORNIER 8 PRISES BNC POUR ICV128 / ICV138 / ICV148
      BCI138       BORNIER PASSIF 8 VOIES POUR ICV138 ET MODULE MAL
      BCI140/C     BORNIER 16 ENTREES DIGITALES ISOLEES Vin=24Volts
      BCI140/D     BORNIER 16 ENTREES DIGITALES ISOLEES Vin=48Volts
      BCI146      BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 64 PTS
      BCI148      BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 48 PTS
      BCI160/RB    BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A
      BCI160/SB    BORNIER 16 SORTIES RELAIS STATIQUES 1T 60V DC /0.5A
      BCI160/SH    BORNIER 16 SORTIES RELAIS STATIQUES 1T 400V DC/0.1A
      BCI168      BORNIER 8 SORTIES ANALOGIQUES ISOLEES TENSION/COURANT
      BCI184/XX/YY   BORNIER COND. 8 E ANA. HAUT MODE COMMUN VERSION A DEFINIR
      BCI100-PB   PLAQUE DE BOUCHAGE 6U 5TE
      BCI100-RACK-9U   RACK 9U POUR RECEVOIR 16 BCI SERIE 100 ALIM 250W +5V/35A;+12V/8A ; -12V/8A
      BCI300-PRL   CARTE DE PROLONGATION POUR BCI SERIE 300
      BCI300-VISU   BORNIER DE RECOPIE 16 VOIES
      BCI314/ALPF   BORNIER 8 ENTREES ANALOGIQUES CONDITIONNEES POLYVALENT FILTRE PASSE BAS AJUSTABLE
      BCI314/SF    BORNIER 8 ENTREES ANALOGIQUES CONDITIONNEES POLYVALENT SANS FILTRE
      BCI328-5/037/BU    BORNIER 8 ENTREES ANALOGIQUES FILTREES FC A DEFINIR
      BCI328-5/037/BU-TEDS    BORNIER 8 ENTREES ANALOGIQUES FILTREES GESTION DES CAPTEURS TEDS
      BCI360-5/RB/INV    BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A LOGIQUE
      INVERSEE BCI364-5/B72    BORNIER 4 SORTIES ANALOGIQUES ISOLEES Vout = ±72 Volts FAV 5TE
      BCI368-5    BORNIER 8 SORTIES ANALOGIQUES ISOLEES Vout = ±10 Volts FAV 5TE
      BCI382-5/XX    BORNIER COD. 8 E ANALOGIQUES ISOLEES 5 TE (version à préciser)
      BCISIN    BORNIER COND. 4 E ANALOGIQUES ISOLEES DEPHASEUR
      BCI300-PB-5TE    PLAQUE DE BOUCHAGE 6U 5TE
      BCI300-PB-6T   E PLAQUE DE BOUCHAGE 6U 6TE
      BCI300-RACK     RACK 9U POUR RECEVOIR 12 BCI SERIE 300 EQUIPE D'UNE ALIMENTATION 24V/12A
      BCI300-RACK-16    RACK 9U POUR RECEVOIR 16 BCI SERIE 300 5Te EQUIPE D'UNE ALIMENTATION 24V/12A
      Borniers industriels STB
      STB-SSI    BORNIER D'INTERFACE FILAIRE POUR 1 LMC VERS ICVLMC
      STB306   TERMINAL BLOCK FOR INCREMENTAL ENCODERS
      STB306/ISO/C    BORNIER INTERFACE ISOLE POUR CARTES ICV307 PCI307 (Vnom=24V ; I=5mA)
      STB504    BORNIER CONDITIONNEUR DE NIVEAU 4 VOIES DE COMPTAGE
      STB512    BORNIER INTERFACE PASSAGE DE 1x32 VOIES à 2x16 VOIES
      STB514    BORNIER INTERFACE PASSAGE DE 1x64 VOIES à 4x16 VOIES
      STB516    BORNIER 16 ENTREES SORTIES DIGITALES MODULAIRES
      STB520/8SB/24RB    BORNIER 32 SORTIES RELAIS 0à7-->SB 8à31-->RB
      STB520/RB    BORNIER 32 SORTIES RELAIS 1RT 220V DC/2A
      STB520/SB    BORNIER 32 SORTIES RELAIS STATIQUES 1T 60V DC/0,5A
      STB520/SH    BORNIER 32 SORTIES RELAIS STATIQUES 1T 400V DC/0,5A
      STB524 32    SORTIES POWER SWITCH
      STB525    BORNIER INTERFACE POUR PASSAGE DE 1 MICRO 68 PTS VERS 2 HE501 25 PTS
      STB532/A    BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 5 Volts
      STB532/B    BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 12Volts
      STB532/C    32 ISOLATED DIGITAL INPUTS TERMINAL BLOCK
      STB532/E    BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 115Volts
      STB532/F    BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 220Volts
      STB534    BORNIER INTERFACE PASSAGE DE 2x32 VOIES à 1x64 VOIES
      STB540/C    BORNIER 16 ENTREES DIG. ISO. AC/DC Vin=24Volts
      STB542    BORNIER INTERFACE CARTE SORTIES ANA. 8 CANAUX
      STB544    BORNIER D'INTERFACE FILAIRE POUR 2 LMCS
      STB546    BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 68 PTS
      STB548/F1    BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX DIFFERENTIELS FILTRES FC =10Hz
      STB550   BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 50 PTS
      STB552   BORNIER INTERFACE ENTREES / SORTIES 32 CANAUX UNIFILAIRES
      STB554    BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX DIFFERENTIELS
      STB554/BC/0250    BORNIER INTERFACE CARTE ENTREES ANA. 16 VOIES BOUCLE DE COURANT R=250Ohms
      STB556    BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX POUR ENTREES THERMOCOUPLES
      STB560/RB    BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A
      STB560/SB    BORNIER 16 SORTIES RELAIS STATIQUES 1T 60V DC/0,5A
      STB560/SH    BORNIER 16 SORTIES RELAIS STATIQUES 1T 400V DC/0,5A
      STB562    BORNIER 16 SORTIES RELAIS 1RT 380V DC/5A
      ACM/IN/xx/RMS    MODULE D'ENTREE POUR STB658 STB6x2 STB4ACM VERSION RMS
      ACM/INxx    MODULE D'ENTREE POUR STB658 STB6x2 STB4ACM
      STB/LA55P/XX     MODULE TRANSDUCER 10A
      STB/SHUNT-XX    SHUNT POUR STB R=0.010 OHM ±1%
      STB4ACM     BORNIER D'INTERFACE POUVANT RECEVOIR 4 MODULES ADAS
      STB658     BORNIER D'INTERFACE POUVANT RECEVOIR 16 MODULES ADAS
      STB6x2 ANALOG    CONDITIONING MODULES 8 CHANNELS BACK PANEL
      Cables
      WF245/300     CABLE ROND BLINDE 3 m SUBD-HD 44P VERS SUBD-HD 44S
      WR205/300     NAPPE RONDE BLINDEE 3,00 m SUBD 50P VERS HE10 50S
      WR212/050     NAPPE RONDE BLINDEE 0 m 50 HE10 50S VERS HE10 50S
      WR212/300     NAPPE RONDE BLINDEE 3 m HE10 50S VERS HE10 50S
      WR214/300     NAPPE RONDE BLINDEE 3 m HE10 50S VERS 2 HE10 26S
      WR215/300     NAPPE RONDE BLINDEE 3 m SUBD 50P VERS 2 HE10 26S
      WR228/300     NAPPE RONDE BLINDEE 3m00 SUBD 50P VERS SUBD 50P
      WR233/300     NAPPE RONDE BLINDEE 3 m SUBD 25P VERS SUBD 25P
      WR235/300     NAPPE RONDE BLINDEE 3 m SUBD 25S VERS SUBD 25S
      WR2XX-METRE-SUP.     METRE DE NAPPE SUPPLEMENTAIRE
      WR368/100     MICRO NAPPE BLINDEE 68PTS μSUBD 1m00
      WR368/180     MICRO NAPPE BLINDEE 68PTS μSUBD 1m80
      WR368/300     MICRO NAPPE BLINDEE 68PTS μSUBD 3m00
深圳市申克工业设备有限公司仪器和过程控制部负责销售ADAS电子模板,并且有法国ADAS电子公司所有系列产品在亚州的独家销售权.ADAS提供品种众多的独立的I/O模块,适用于各种不同的物理总线(PC/PCI,CompactPCI,PMC …),在数据分析仪器和过…  更多>>
深圳市申克工业设备有限公司
联系人:赵工
地址:深圳市 福田区 福强路32号
邮编:518048
电话:0755-83841930
传真:0755-83841895
公司网址:http://www.sz-victory.com.cn
  • 彭聖才 在2024/11/29 14:10:00留言
  • 详细留言:您好,本公司位在台灣 網路查詢貴公司有ADAS PCI 264 数字输入输出卡 不知道能否跟您交易買賣此卡片。 http://www.cechina.cn/Company/84091_146953/messagedetail.aspx
  • 陈碧娟 在2024/3/28 17:47:00留言
  • 详细留言:ADAS ICV150 1个,有货吗?价格是?
