技术规格
详情
Cherry D4 Series 0.1A, 16A & 21A
- Contact configuration: SPDT & SPST versions
Available with quick connect QC terminals (6.3 x 0.8mm), screw terminals or solder terminals
Contact material: Au Ag Pt (0.1A), AgNi (16 & 21A)
Actuator material: Aluminium, Stainless Steel, Cold-Rolled Steel combination, except button versions which are Acetal/Polyester
Contact voltage: 250Vac
Case material: Polyester, approved to UL94V-0
Operating temperature: -40 to 85°C (16A High Temperature range: -40 to 150°C)
Dimensions: H15.88mm x W10.31mm x D27.81mm
Conforms to IEC Clause 60335 Flame Retardancy
Mechanical life ≥ 2x107 (3 x 106 for high temperature versions)
认可
16A: UL, CSA, VDE, SEV, SEMKO, KEMA, DEMKO, NEMKO, ?VE, BEAB, SETI
16A Screw Terminal: UL, CSA, VDE
16A High Temperature: UL, CSA, VDE, SEV, SEMKO, KEMA, DEMKO, NEMKO, ?VE, BEAB, SETI
21A: UL, CSA, VDE, SEV, SEMKO, KEMA, DEMKO, NEMKO, ?VE, BEAB, SETI
