![](https://img.alicdn.com/imgextra/i3/903837056/TB2vCzyqpXXXXaYXpXXXXXXXXXX_!!903837056.jpg)
![](https://img.alicdn.com/imgextra/i3/903837056/TB2geD2qpXXXXcpXXXXXXXXXXXX_!!903837056.jpg)
![](https://img.alicdn.com/imgextra/i1/903837056/TB2Io2qlFXXXXaOXXXXXXXXXXXX_!!903837056.jpg)
产品概述
The 641H/2 is a double-pole single-throw (DPST) high amperage Toggle switch with metal lever and solder lug terminals. The 600H series switch has polyester case and silver/nickel alloy contacts. Terminal and contact support are manufactured from a single piece of metal. The contacts are resistance-welded to the terminal for increased mechanical strength.
- 10mR Maximum initial contact resistance
- 2000Vrms Dielectric strength
- -20 to 55°C Operating temperature range
- UL94V-0 Flammability rating
应用
工业
